Which are de equivalent packages/libraries for compiling mysqlclient when installing via pip in Manjaro? In the pypi mysqlclient page says that these can be downloaded for Debian/Ubuntu:
The only assumption I can take from that tutorial is that by installing MariaDB I’ll be ready to compile the python module, however I intend to use databases via docker, but I’ll do it anyways, if it works, great then, the learning path is not a straight line. I’m downloading the .iso now, because I’m lookig for a good KDE experience but also I need I can install everything I need, I’ll try that soon.
