I’ve recently used discord, on brave (because discord only works on the browser where I live), and when I use my mic, the game audio can be heard, or anything on the desktop. I’m using my earphones for the mic and speakers so it can’t be loud speakers. I thought it might be the pulseaudio monitors and tried muting all monitor inputs, but that didn’t work either. The same issue happens in firefox and obs. I’ve tried rebooting and the issue still remains.
Source #0
State: SUSPENDED
Description: Monitor of Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4)
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 1
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: alsa_output.pci-0000_08_00.1.hdmi-stereo-extra3
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4)"
device.class = "monitor"
alsa.card = "1"
alsa.card_name = "HDA ATI HDMI"
alsa.long_card_name = "HDA ATI HDMI at 0xfcf60000 irq 80"
device.bus_path = "pci-0000:08:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:08:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "aaf0"
device.product.name = "Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]"
device.string = "1"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Formats:
pcm
Source #1
State: SUSPENDED
Description: Monitor of Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
Owner Module: 2
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_0a_00.3.analog-stereo
Properties:
device.description = "Monitor of Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo"
alsa.card = "2"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfce00000 irq 82"
device.bus_path = "pci-0000:0a:00.3"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/sound/card2"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1457"
device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
device.string = "2"
Formats:
pcm
Source #2
State: SUSPENDED
Description: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
Owner Module: 2
Mute: no
Volume: front-left: 19557 / 30% / -31.51 dB, front-right: 19557 / 30% / -31.51 dB
balance 0.00
Base Volume: 6554 / 10% / -60.00 dB
Monitor of Sink: n/a
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC887-VD Analog"
alsa.id = "ALC887-VD Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "2"
device.bus = "pci"
device.string = "front:2"
device.buffering.buffer_size = "17664"
device.buffering.fragment_size = "2944"
device.access_mode = "mmap"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo"
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, not available)
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, available)
analog-input-linein: Line In (type: Line, priority: 8100, not available)
Active Port: analog-input-rear-mic
Formats:
pcm
Source #3
State: SUSPENDED
Description: Monitor of Built-in Audio Analog Stereo
Owner Module: 3
Mute: no
Volume: front-left: 65532 / 100% / -0.00 dB, front-right: 65532 / 100% / -0.00 dB
balance 0.00
Monitor of Sink: alsa_output.platform-snd_aloop.0.analog-stereo
Properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
alsa.card = "0"
alsa.card_name = "Loopback"
alsa.long_card_name = "Loopback 1"
alsa.driver_name = "snd_aloop"
device.bus_path = "platform-snd_aloop.0"
sysfs.path = "/devices/platform/snd_aloop.0/sound/card0"
device.string = "0"
device.icon_name = "audio-card"
Formats:
pcm
Source #4
State: SUSPENDED
Description: Built-in Audio Analog Stereo
Owner Module: 3
Mute: no
balance 0.00
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
device.api = "alsa"
alsa.name = "Loopback PCM"
alsa.id = "Loopback PCM"
alsa.device = "0"
alsa.card = "0"
device.string = "front:0"
device.buffering.buffer_size = "17632"
device.buffering.fragment_size = "4408"
device.description = "Built-in Audio Analog Stereo"
Ports:
analog-input: Analog Input (type: Analog, priority: 10000, availability unknown)
Formats:
pcm
Source #5
State: SUSPENDED
Driver: module-alsa-sink.c
Owner Module: 27
Mute: yes
balance 0.00
Monitor of Sink: alsa_output.hw_0_0
Properties:
device.description = "Monitor of Built-in Audio"
Formats:
pcm
Source #6
State: SUSPENDED
Description: Monitor Source of Simultaneous output to Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4), Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo, Built-in Audio Analog Stereo, Built-in Audio
Driver: module-combine-sink.c
Owner Module: 28
Mute: yes
Volume: front-left: 65626 / 100% / 0.04 dB, front-right: 65626 / 100% / 0.04 dB
balance 0.00
Monitor of Sink: combined
Properties:
device.description = "Monitor Source of Simultaneous output to Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] Digital Stereo (HDMI 4), Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo, Built-in Audio Analog Stereo, Built-in Audio"
Formats:
pcm
This is the source list from pactl. The input I use is alsa_input.pci-0000_0a_00.3.analog-stereo
. I don’t really know whats causing this and think it might either be a configuration issue or a bug.
