Pulseaudio does not work
I want to change the sound from Alsa to Pulse Audio, but I can’t. Sometimes it’s because I break the Pipewire connection, other times it asks me for a server.
Apparently, I have to uninstall Pipewire to be able to install Pulse Audio?
sudo pacman -R manjaro-pipewire && sudo pacman -S manjaro-pulse
But that said, the above is only an answer to your direct question — which is about a perceived problem — and not a solution to the actual problem.
So what is the current solution for this case?
Well, I don’t know your audio setup — i.e. which audio hardware is involved, and what usage scenario requires you to switch manually — and I am not exactly an expert on these matters. However, @nikgnomic is our resident audio expert, so perhaps he can provide further advice.
Thanks
This approach is not possible. PulseAudio packages must be installed to replace some PipeWire packages
Manjaro has metapackages to switch audio servers:
To replace Pipewire with PulseAudio:
pamac install manjaro-pulse
To replace PulseAudio with PipeWire:
pamac install manjaro-pipewire
To check installed audio servers:
inxi  -Aa
Is it not necessary to remove manjaro-pulse first?
To replace Pipewire with PulseAudio - pamac install manjaro-pulse
It has been quite a long time since anyone has installed either of these metapackages so I do not know if manjaro-pipewire needs to be removed before installing manjaro-pulse, but pamac will advise if this is needed
Well, I myself am still on manjaro-pulse, and I’ve never had any problems with it, so I also never thought of changing that. However, given that pipewire has already been the default in Manjaro for quite a while now, I’ve recently been contemplating switching over as well.
I reckon that pacman would certainly throw up a warning if one chooses to replace one with the other, but I didn’t know whether pamac would do the same or just silently remove the incompatible package(s) — I normally always use pacman for things from the official repositories, and pamac for the AUR.
<pre><font color="#00AA00">pamac</font> install manjaro-pulse                                     <font color="#000000"></font><span style="background-color:#000000"><font color="#00AA00"> ✔ </font></span>
A preparar...
<font color="#FF5555"><b>==== AUTHENTICATING FOR org.manjaro.pamac.commit ====</b></font>
É necessária autenticação para instalar, atualizar ou remover pacotes
Authenticating as: fernando
Password:
<font color="#FF5555"><b>==== AUTHENTICATION COMPLETE ====</b></font>
A sincronizar bases de dados de pacotes...
Escolher dependências opcionais para manjaro-pulse:
1:  paprefs: Configuration dialog
2:  pasystray: system tray application
3:  pavucontrol-qt: A Qt volume control tool
4:  pulseaudio-equalizer: Graphical equalizer
5:  pulseaudio-equalizer-ladspa: A 15-band equalizer
6:  pulseaudio-jack: Jack support
7:  pulseaudio-lirc: IR (lirc) support
8:  pulseaudio-rtp: RTP and RAOP support
9:  pulseaudio-zeroconf: Zeroconf support
Introduza uma seleção (padrão=nenhum)</pre>
This is the problem....which server?
pamac is asking if you want to choose additional optional packages
If you do not need additional packages press Enter to continue install
Enter a selection (default=none):
Resolving dependencies...
Checking for internal conflicts...
Error: An error occurred while preparing the transaction:
unable to fulfil dependencies:
- removing pipewire-pulse breaks dependency “pipewire-pulse” required by pulse-native-provider
At least the command did not fail because metapackage (manjaro-pipewire) was installed
Try this to install the 3 required packages discretely
pamac install pluseaudio pulseaudio-alsa pulseaudio bluetooth
pamac install pulseaudio pulseaudio-alsa pulseaudio-bluetooth
pamac install pulseaudio pulseaudio-alsa pulseaudio bluetooth
Error: object not found: pluseaudio
compare the two lines
you said you issued:
but the error message said:
This was no copy/paste of what was done.
You made a typo and didn’t copy the actual sequence.
it’s: pulseaudio
not
pluseaudio
ps:
no - you didn’t make a typo - you just copy/pasted the provided command - which included a typo :wink:
My typo error - command was missing a dash
Happy New Year
Fiddler’s Green - Auld Lang Syne
Synchronising package databases...
Updating AUR...
Preparing...
Authentication is required to install, update, or remove packages.
Authenticating as: Fernando (fernando)
Password:
Select optional dependencies for pulseaudio:
1:  pulseaudio-equalizer: Graphical equaliser
2:  pulseaudio-jack: Jack support
3:  pulseaudio-lirc: IR (lirc) support
4:  pulseaudio-rtp: RTP and RAOP support
5:  pulseaudio-zeroconf: Zeroconf support
Enter a selection (default=none): 1
To install (6):
  pulseaudio-alsa       1:1.2.12-5                                                            extra  3.5 kB
  pulseaudio            17.0+r93+gbe2efb69b-1                                                 extra  1.2 MB
  python-pyqt5-sip      12.17.2-1              (Required by: pulseaudio-equalizer)          extra  64.6 kB
  python-pyqt5          5.15.11-3              (Required by: pulseaudio-equalizer)          extra  3.9 MB
  pulseaudio-equalizer  17.0+r93+gbe2efb69b-1                                                 extra  33.5 kB
  pulseaudio-bluetooth  17.0+r93+gbe2efb69b-1                                                 extra  96.6 kB
To be removed (2):
  manjaro-pipewire      20231009-1             (Conflicts with: pulseaudio-equalizer)  extra
  pipewire-pulse        1:1.4.9-2              (Conflicts with: pulseaudio)            extra
Executing post-transaction hooks...
Reloading user manager configuration...                                    [1/5]
Warning: The unit file, source configuration file or drop-ins of user@1000.service changed on disk. Run “systemctl daemon-reload” to reload units.
Reloading device manager configuration...                                  [2/5]
Arming ConditionNeedsUpdate...                                             [3/5]
Reloading system bus configuration...                                      [4/5]
Warning: The unit file, source configuration file or drop-ins of dbus.service changed on disk. Run “systemctl daemon-reload” to reload units.
Compiling GSettings XML schema files...                                    [5/5]
Transaction completed successfully.
I didn’t notice the error until later, and then I corrected it. But it didn’t work.
Mod edit: Please, only post code or command output as pre-formatted text – all normal/plain text should be typed normally. Pre-formatted enclosure removed. No charge.
But the command did work. :man_shrugging:
What do you mean with: … it didn’t work?
Reboot system to unload systemctl units for pipewire-pulse and load systemctl units for pulseaudio
If PulseAudio is not working as expected please post more information:
systemctl --user -l --no-pager status pulseaudio.socket pulseaudio.service
inxi -Aa
● pulseaudio.socket - Sound System
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; preset: enabled)
     Active: active (running) since Fri 2026-01-02 09:32:47 WET; 1min 50s ago
 Invocation: c56e9d0010294e0ca6c79b3898583a27
   Triggers: ● pulseaudio.service
     Listen: /run/user/1000/pulse/native (Stream)
Jan 02 09:32:47 fernando-ms7b18 systemd[1235]: Listening on Sound System.
● pulseaudio.service - Sound Service
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
     Active: active (running) since Fri 2026-01-02 09:32:49 WET; 1min 48s ago
 Invocation: e6afcf71261741e383d295fca8c9cbb1
TriggeredBy: ● pulseaudio.socket
   Main PID: 1359 (pulseaudio)
      Tasks: 9 (limit: 18793)
     Memory: 51M (peak: 53.7M)
        CPU: 329ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
             ├─1359 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─1727 /usr/lib/pulse/gsettings-helper
Jan 02 09:32:48 fernando-ms7b18 systemd[1235]: Starting Sound Service...
Jan 02 09:32:49 fernando-ms7b18 systemd[1235]: Started Sound Service.
Jan 02 09:32:49 fernando-ms7b18 pulseaudio[1359]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer “org.bluez”: unit failed
inxi -Aa         ✔
  Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: Sunplus Innovation USB 2.0 Camera driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
    chip-ID: 1bcf:0c45 class-ID: 0102
  API: ALSA v: k6.17.13-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: wireplumber
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-93-gbe2efb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Actually, I don’t have PulseAudio sound, despite installing it. Despite the PulseAudio equaliser, I don’t hear any difference in the sound.
Well, I managed to get PulseAudio working.
Thanks to Nikgnomic for his help, and to Aragorn.
If there are no intervening replies, please edit your previous post instead to add further information.
:wink:
