Pulseaudio does not work
Kernel 6.17.13-1-MANJARO is marked as End Of Life and will be dropped soon, so I suggest install Kernel 6.18 via Manjaro Settings Manager - Kernel GUI or:
sudo mhwd-kernel -i linux618
The installation stopped here (5/5) Signing EFI binaries...
Generating EFI bundles.... Installed
There's a problem. The video plays without sound, but when I turn on the sound, the video stops!!!!!!
You only need to format what you are writing in that way
when you are posting terminal output.
don't write like this
write like this - just normal
unless there is terminal output or quotes or whatever …
ArchWiki - WirePlumber - Configuration
Disable audio stack integration
If you do not want PipeWire/Wireplumber to take over control of your audio devices because you are opting for a different audio solution (e.g. PulseAudio/JACK/ALSA) but still want it to be available for screen sharing/video purposes you can make use of the wireplumber@.service template unit to enable a different set of default profiles. Wireplumber ships with a profile configuration that enables only the video parts and disables audio integration (including Bluetooth audio) by enabling the video-only template user unit.
Disable wireplumber.service user unit and enable wireplumber@video-only.service user unit.
systemctl --user disable --now wireplumber.service; systemctl --user enable --now wireplumber@video-only.service
Thanks
