PulseAudio depending packages prevent upgrade
Update:
Sorry, I’ve missed the release notes in 2024-08-08, as I only looked in 2024-08-20. My bad!
Original question:
What’s the general guidance about pulse-audio conflicts?
Yerror: failed to prepare transaction (could not satisfy dependencies)
:: installing pipewire-pulse (1:1.2.2-2) breaks dependency 'pulseaudio' required by pulseaudio-arctis-pro-wireless
:: installing pipewire-pulse (1:1.2.2-2) breaks dependency 'pulseaudio' required by pulseaudio-ctl
:: installing pipewire-pulse (1:1.2.2-2) breaks dependency 'pulseaudio' required by pulseeffects-legacy
:: installing pipewire-pulse (1:1.2.2-2) breaks dependency 'pulseaudio' required by scream-pulse
 !  ~  pacman-mirrors -G        2.7m  2024-08-23T09:38:15 UTC
stable
I’ve spotted this:
Where there’s a link to this post, but I’m wondering why it’s not mentioned in the “release notes”. I remember some time ago, where Pulse Audio was a problem, too.
sudo pacman -R pulseaudio-ctl pulseeffects-legacy scream-pulse
And specific to my system (i guess?), .
sudo pacman -R  pulseaudio-arctis-pro-wireless
I’m not sure if the Arctic Pro package are the reason why it didn’t rent smoothly. By taking a look at this post, I guess not.
those are all either AUR or even non existing packages.
Remove non existing ones and for the AUR packages: try updating if they were adjusted to current package provides.
I’ve moved your post to AUR as it didn’t belong in the previous thread.
Thanks :slight_smile:
I’ll quote the solution:
Personally I removed all the packages, as mentioned in the original post.
AUR - pulseaudio-ctl
kode54 commented on 2021-12-31 03:02 (UTC)
@Pound_Hash: This tool doesn’t work with PipeWire, only PulseAudio.
AUR - pulseeffects-legacy
Description: Audio Effects for Pulseaudio Applications, without pipewire
#208: PipeWire support · scream · GitHub
Ironfist69 commented Sep 30, 2023
Need pipewire support
steelseries-arctis-pro-wireless/PKGBUILD · GitHub
pkgname=pulseaudio-arctis-pro-wireless
depends=(“pulseaudio”)
