I’m trying to find the distro’s repo and/or issue tracker. This is to report issues and possibly to submit pull requests. Are they publicly available?
manjaro.org provides little info about the way manjaro development is organized. Apart from couple of gitlab repos for some apps developed by the team, and manjaro-dev mailing list I couldn’t find anything.
Just came across it from one of the forum’s About this Category posts. Wouldn’t it be better if it’s listed on the website itself. May be alongside (or instead of) the mailing lists.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
