After the update I am experiencing problems with suspend and resume.
KDE Plasma Version: 5.24.5
KDE Frameworks Version: 5.93.0
Qt Version: 5.15.3
Kernel Version: 5.15.38-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-6820HQ CPU @ 2.70GHz
Memory: 31.3 GiB of RAM
Graphics Processor: Quadro M1000M/PCIe/SSE2
I also have the problem that the system often freezes when using Firefox.
I would say this is the most problematic update since I have been using this distro
Can confirm this bug, I switched to the stable Kernel 5.17.6 which does not have this issue.
Otherwise you can also try 5.15.39
But this kernel is not an option for me, because it does not have the vmmon kernel module.
yep, 5.15.39 does not have this bug.
@philm we shoukd push the newer Kernel versions to stable this versions not stable enough, at least 5.15.38 in my case.
there are some fixed amdgpu bugs in 5.15.39
My Sys Info:
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=2858d787-58d2-4b32-bfe2-dcd848223859 rw rootflags=subvol=@
cryptdevice=UUID=ec00de08-393b-4d8c-a1ed-853a4de311ee:cryptroot apparmor=1
security=apparmor bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4204
date: 02/24/2022
RAM: total: 31.32 GiB used: 5.92 GiB (18.9%)
RAM Report:
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3991 high: 3993 min/max: 2200/4918 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3992 2: 3992
3: 3992 4: 3992 5: 3992 6: 3991 7: 3992 8: 3991 9: 3992 10: 3989 11: 3992
12: 3992 13: 3991 14: 3992 15: 3991 16: 3992 17: 3992 18: 3991 19: 3992
20: 3992 21: 3992 22: 3993 23: 3992 24: 3991 bogomips: 191729
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0b:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 587mm (23.1") ratio: 16:9, 15:9
modes: max: 1920x1080 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:5 chip-ID: 046d:0a66
class-ID: 0300
Device-5: C-Media Auna Mic CM900 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 0d8c:0134
class-ID: 0300
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-2:3 chip-ID: 0a12:0001 class-ID: e001
Device-1: cryptroot maj-min: 254:0 type: LUKS dm: dm-0 size: 419.26 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:3 size: 419.26 GiB
Local Storage: total: 1.82 TiB used: 254.71 GiB (13.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 419.26 GiB size: 419.26 GiB (100.00%)
used: 28.98 GiB (6.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: cryptroot label: N/A uuid: N/A
used: 26.1 MiB (5.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
uuid: C380-DE14
ID-3: /home raw-size: 419.26 GiB size: 419.26 GiB (100.00%)
ID-4: /run/media/pheiduck/Daten raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 225.71 GiB (24.2%) fs: btrfs dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 3704c1e0-6710-4592-8b0b-28322fd45bbd
ID-5: /run/timeshift/backup raw-size: 419.26 GiB
size: 419.26 GiB (100.00%) used: 28.98 GiB (6.9%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: cryptroot label: N/A uuid: N/A
ID-1: swap-1 type: zram size: 15.66 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 16 MiB fs: <superuser required>
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 418.61 GiB fs: ntfs
label: Windoof uuid: 1E16606116603C41
ID-3: /dev/nvme1n1p3 maj-min: 259:6 size: 565 MiB fs: ntfs label: N/A
uuid: 30086A240869E974
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: Logitech C922 Pro Stream Webcam type: Video,Audio
power: 500mA chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Device-2: 1-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-1:5 info: Logitech [G533 Wireless Headset Dongle]
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 046d:0a66 class-ID: 0300
Device-2: 3-2:3 info: C-Media Auna Mic CM900 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
Device-3: 3-4:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 5-3.2:4 info: Metadot Das Keyboard 4 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 24f0:204a class-ID: 0300
Device-2: 5-4:3 info: Logitech Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 046d:c045 class-ID: 0301
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: 46.0 C gpu: amdgpu temp: 58.0 C
mem: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 530 Uptime: 2h 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1212 pacman: 1203 lib: 343
flatpak: 9 Shell: Zsh v: 5.8.1 running-in: xfce4-terminal inxi: 3.3.15
Thanks. I will try to upgrade to kernel 5.17.6
As for Firefox, it seems that the problem is solved by completely clearing the cache.
In any case, I have noticed an “RDD process” which, from time to time, takes up a considerable amount of the CPU
Unfortunately this was not conclusive.
I had to turn off the “lock screen automatically” feature again.
I also activated the option “Never turn off the screen or let it go to sleep”
