Problems with dbus and xdg-desktop-portal
Hello !
Journalctl tells me xdg-desktop-portal has problem to launch itself.
systemctl status xdg-destop-portal says that xdg-desktop-portal.service doesn’t exist, but this file is in /usr/lib/systemd/user/.
When I try to launch xdg-desktop-portal manualy I have an error :
error: No session bus: Erreur lors de la génération de la ligne de commande « dbus-launch --autolaunch=8806d4a418894779becc56479dc0b204 --binary-syntax --close-stderr » : Le processus fils s’est terminé avec le code 1
So I asked systemctl for the status of dbus and everything seems to be ok. When I launch d-feet there’s no session bus.
So I tried to restart dbus and it seems that it was not a good idea: the system crashed…
I have searched the web for hints with no success. Do you have an idea of what append ?
really? searched and found nothing?
It’s seems not to be a backend problem since xdg-desktop-portal doesn’t succeed to launch itself at boot time. And as far as I understand, xdg-desktop-portal-gtk needs xdg-desktop-portal.
I do think there is a problem with dbus session…
systemctl --user status xdg-desktop-portal.service
It may not provide much more information than you have already received from journalctl.
There is two kinds of systemd services
  • system service
  • user services
The first requires administrative privileges to handle - the second is handled by user - and located in the user subtree of systemd.
Depending on your environment - you should ensure the correct package is installed as per @Lila-Kuh comment.
Here’s the result:
# systemctl --user status xdg-desktop-portal.service
Failed to connect to bus: Aucun médium trouvé
I’ve found a tip on wiki.archlinux.org at the Pipewire page:
Note: xdg-desktop-portal 1.10.0 fixed a mismatch between specification and implementation of its D-Bus interface. [2] Hence, some clients may not work with xdg-desktop-portal 1.10.0 or newer.
So I downgraded xdg-desktop-portal to the 1.8 version. But there’s still the same problem at boot:
Can’t find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
I also notice that when I run d-feet as a a simple user I have no session bus, only a system bus.
What does journalctl --user-unit dbus.service -e say?
It says nothing: No entries
Ok, I think I’ve understood what happened.
I used to work on my Manjaro via SSH since the laptop is behind the TV…
I have found a tip on another forum : set the UsePAM in sshd_config variable to yes… and now I have a dbus session. I also can restart xdg-desktop-portal while in user mode.
After a reboot, I don’t have a xdg-desktop-portal error in the journalctl and the system seems to be a little more reactive.
Tanks for helping!
