Problems updating bottles
I’ve updated bottles, and it seems to do it right, but for some reason it appears again and again, i’ve even tried using: sudo pacman -Syu and yes, i’ve updated the databases and mirrors (which i use USA only), and don’t want to uninstall and reinstall because of the bottles configurations i already have, so, any ideas? :confused:
Preparando...
Sincronizando bases de datos de paquetes...
Clonando archivos de construcción de bottles...
Generando información de bottles...
Verificando dependencias de bottles...
Aviso: bottles-2022.5.28-5 está actualizado -- reinstalándolo
Resolviendo dependencias...
Verificando interconflictos...
Construyendo bottles...
==> Creando el paquete: bottles 2022.5.28-5 (mié 03 ago 2022 09:36:09)
==> Comprobando dependencias mientras se ejecuta...
==> Comprobando dependencias mientras se compila...
==> Recibiendo las fuentes...
  -> bottles-2022.5.28-trento-3.tar.gz ha sido encontrado
==> Validando los archivos source con sha256sums...
    bottles-2022.5.28-trento-3.tar.gz ... Aprobado
==> Eliminando el directorio $srcdir/...
==> Extrayendo las fuentes...
  -> Extrayendo bottles-2022.5.28-trento-3.tar.gz con bsdtar
==> Iniciando build()...
The Meson build system
Version: 0.63.0
Source dir: /var/tmp/pamac-build-solidcapo/bottles/src/Bottles
Build dir: /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/build
Build type: native build
Project name: bottles
Project version: 2022.5.28-trento-3
Host machine cpu family: x86_64
Host machine cpu: x86_64
Program msgfmt found: YES (/usr/bin/msgfmt)
Program msginit found: YES (/usr/bin/msginit)
Program msgmerge found: YES (/usr/bin/msgmerge)
Program xgettext found: YES (/usr/bin/xgettext)
Found pkg-config: /usr/bin/pkg-config (1.8.0)
Run-time dependency libhandy-1 found: YES 1.6.3
Program python3 found: YES (/usr/bin/python3)
Configuring bottles using configuration
Configuring bottles-cli using configuration
Program glib-compile-resources found: YES (/usr/bin/glib-compile-resources)
Program desktop-file-validate found: YES (/usr/bin/desktop-file-validate)
Program appstream-util found: YES (/usr/bin/appstream-util)
Program glib-compile-schemas found: YES (/usr/bin/glib-compile-schemas)
Build targets in project: 43
NOTICE: Future-deprecated features used:
 * 0.55.0: {'ExternalProgram.path'}
bottles 2022.5.28-trento-3
  User defined options
    prefix: /usr
Found ninja-1.11.0 at /usr/bin/ninja
ninja: Entering directory `build'
[1/40] Generating po/hi/LC_MESSAGES/bottles-hi.mo with a custom command
[2/40] Generating po/de/LC_MESSAGES/bottles-de.mo with a custom command
[3/40] Generating po/pt/LC_MESSAGES/bottles-pt.mo with a custom command
[4/40] Generating po/it/LC_MESSAGES/bottles-it.mo with a custom command
[5/40] Generating po/nb_NO/LC_MESSAGES/bottles-nb_NO.mo with a custom command
[6/40] Generating po/fr/LC_MESSAGES/bottles-fr.mo with a custom command
[7/40] Generating po/es/LC_MESSAGES/bottles-es.mo with a custom command
[8/40] Generating po/pt_BR/LC_MESSAGES/bottles-pt_BR.mo with a custom command
[9/40] Generating po/da/LC_MESSAGES/bottles-da.mo with a custom command
[10/40] Generating po/id/LC_MESSAGES/bottles-id.mo with a custom command
[11/40] Generating po/nl/LC_MESSAGES/bottles-nl.mo with a custom command
[12/40] Generating po/sv/LC_MESSAGES/bottles-sv.mo with a custom command
[13/40] Generating po/eo/LC_MESSAGES/bottles-eo.mo with a custom command
[14/40] Generating po/tr/LC_MESSAGES/bottles-tr.mo with a custom command
[15/40] Generating po/ru/LC_MESSAGES/bottles-ru.mo with a custom command
[16/40] Generating po/zh_Hans/LC_MESSAGES/bottles-zh_Hans.mo with a custom command
[17/40] Generating po/fi/LC_MESSAGES/bottles-fi.mo with a custom command
[18/40] Generating po/hr/LC_MESSAGES/bottles-hr.mo with a custom command
[19/40] Generating po/uk/LC_MESSAGES/bottles-uk.mo with a custom command
[20/40] Generating po/ja/LC_MESSAGES/bottles-ja.mo with a custom command
[21/40] Generating po/cs/LC_MESSAGES/bottles-cs.mo with a custom command
[22/40] Generating po/zh_Hant/LC_MESSAGES/bottles-zh_Hant.mo with a custom command
[23/40] Generating po/hu/LC_MESSAGES/bottles-hu.mo with a custom command
[24/40] Generating po/pl/LC_MESSAGES/bottles-pl.mo with a custom command
[25/40] Generating po/ko/LC_MESSAGES/bottles-ko.mo with a custom command
[26/40] Generating po/vi/LC_MESSAGES/bottles-vi.mo with a custom command
[27/40] Generating po/eu/LC_MESSAGES/bottles-eu.mo with a custom command
[28/40] Generating po/bg/LC_MESSAGES/bottles-bg.mo with a custom command
[29/40] Generating po/el/LC_MESSAGES/bottles-el.mo with a custom command
[30/40] Generating po/ro/LC_MESSAGES/bottles-ro.mo with a custom command
[31/40] Generating po/gl/LC_MESSAGES/bottles-gl.mo with a custom command
[32/40] Generating po/sk/LC_MESSAGES/bottles-sk.mo with a custom command
[33/40] Generating po/ms/LC_MESSAGES/bottles-ms.mo with a custom command
[34/40] Generating src/ui/bottles_gresource with a custom command
[35/40] Generating po/fa/LC_MESSAGES/bottles-fa.mo with a custom command
[36/40] Generating po/ckb/LC_MESSAGES/bottles-ckb.mo with a custom command
[37/40] Generating po/th/LC_MESSAGES/bottles-th.mo with a custom command
[38/40] Generating po/ar/LC_MESSAGES/bottles-ar.mo with a custom command
[39/40] Generating data/com.usebottles.bottles.desktop with a custom command
[40/40] Generating data/com.usebottles.bottles.appdata.xml with a custom command
==> Entrando en entorno fakeroot...
==> Iniciando package()...
[0/1] Installing files.
Installing po/it/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/it/LC_MESSAGES
Installing po/fr/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/fr/LC_MESSAGES
Installing po/de/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/de/LC_MESSAGES
Installing po/hi/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/hi/LC_MESSAGES
Installing po/pt/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/pt/LC_MESSAGES
Installing po/es/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/es/LC_MESSAGES
Installing po/nb_NO/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/nb_NO/LC_MESSAGES
Installing po/pt_BR/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/pt_BR/LC_MESSAGES
Installing po/id/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/id/LC_MESSAGES
Installing po/da/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/da/LC_MESSAGES
Installing po/nl/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/nl/LC_MESSAGES
Installing po/tr/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/tr/LC_MESSAGES
Installing po/sv/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/sv/LC_MESSAGES
Installing po/ru/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ru/LC_MESSAGES
Installing po/eo/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/eo/LC_MESSAGES
Installing po/zh_Hans/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/zh_Hans/LC_MESSAGES
Installing po/fi/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/fi/LC_MESSAGES
Installing po/ja/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ja/LC_MESSAGES
Installing po/hr/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/hr/LC_MESSAGES
Installing po/cs/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/cs/LC_MESSAGES
Installing po/uk/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/uk/LC_MESSAGES
Installing po/hu/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/hu/LC_MESSAGES
Installing po/pl/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/pl/LC_MESSAGES
Installing po/zh_Hant/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/zh_Hant/LC_MESSAGES
Installing po/ko/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ko/LC_MESSAGES
Installing po/vi/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/vi/LC_MESSAGES
Installing po/eu/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/eu/LC_MESSAGES
Installing po/bg/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/bg/LC_MESSAGES
Installing po/el/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/el/LC_MESSAGES
Installing po/gl/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/gl/LC_MESSAGES
Installing po/sk/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/sk/LC_MESSAGES
Installing po/ro/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ro/LC_MESSAGES
Installing po/ms/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ms/LC_MESSAGES
Installing po/ckb/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ckb/LC_MESSAGES
Installing po/fa/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/fa/LC_MESSAGES
Installing po/th/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/th/LC_MESSAGES
Installing po/ar/LC_MESSAGES/bottles.mo to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/locale/ar/LC_MESSAGES
Installing src/ui/bottles.gresource to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles
Installing data/com.usebottles.bottles.desktop to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/applications
Installing data/com.usebottles.bottles.appdata.xml to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/metainfo
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/build/src/bottles to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/bin
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/build/src/bottles-cli to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/bin
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/catalogs.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winecommand.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/wineprogram.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/uninstaller.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winecfg.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winedbg.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/wineserver.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/wineboot.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winepath.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/cmd.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/taskmgr.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/control.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/regedit.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/reg.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/regkeys.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/net.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/msiexec.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/executor.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/start.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/register.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/regsvr32.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winebridge.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/explorer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/drives.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/eject.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/expand.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/hh.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/icinfo.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/notepad.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/oleview.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/progman.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/rundll32.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winefile.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/winhelp.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/wine/xcopy.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/wine
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/models/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/models
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/models/result.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/models
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/models/samples.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/models
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/models/vdict.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/models
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/display.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/gpu.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/manager.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/vulkan.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/terminal.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/file.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/generic.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/wine.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/steam.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/snake.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/utils/vdf.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/dlls/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/dlls
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/dlls/dll.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/dlls
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/dlls/dxvk.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/dlls
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/dlls/vkd3d.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/dlls
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/dlls/nvapi.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/dlls
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/dlls/latencyflex.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/dlls
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/repos/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/repos
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/repos/repo.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/repos
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/repos/dependency.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/repos
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/repos/component.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/repos
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/repos/installer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/repos
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/backup.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/component.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/dependency.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/installer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/library.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/manager.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/versioning.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/data.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/notifications.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/runtime.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/importer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/conf.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/journal.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/repository.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/template.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/managers/steam.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend/managers
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/globals.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/runner.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/layers.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/diff.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/health.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/downloader.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/logger.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/backend/cabextract.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/backend
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/utils/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/utils/connection.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/utils/threading.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/utils/common.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/utils
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/crash.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/dlloverrides.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/duplicate.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/envvars.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/generic.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/launchoptions.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/onboard.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/runargs.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/rename.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/drives.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/gamescope.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/generic_cli.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/dialogs/journal.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/dialogs
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/new.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/list.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/library.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/details.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/preferences.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/importer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/loading.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_details.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_installers.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_dependencies.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_preferences.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_programs.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_versioning.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/views/bottle_taskmanager.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/views
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/dependency.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/executable.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/importer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/installer.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/page.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/program.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/state.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/message.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/component.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/widgets/library.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles/widgets
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/__init__.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/main.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/window.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/params.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/operation.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/src/operation_cli.py to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/bottles/bottles
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/data/com.usebottles.bottles.gschema.xml to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/glib-2.0/schemas
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/data/icons/hicolor/scalable/apps/com.usebottles.bottles.svg to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/icons/hicolor/scalable/apps
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/data/icons/symbolic/scalable/apps/com.usebottles.bottles-symbolic.svg to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/icons/hicolor/symbolic/apps
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/data/icons/hicolor/scalable/apps/com.usebottles.bottles-program.svg to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/icons/hicolor/scalable/apps
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/data/icons/symbolic/scalable/apps/bottle-symbolic.svg to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/icons/hicolor/symbolic/apps
Installing /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/data/icons/symbolic/scalable/apps/bottles-steam-symbolic.svg to /var/tmp/pamac-build-solidcapo/bottles/pkg/bottles/usr/share/icons/hicolor/symbolic/apps
Running custom install script '/usr/bin/python /var/tmp/pamac-build-solidcapo/bottles/src/Bottles/build-aux/meson/postinstall.py'
==> Depurando la instalación...
  -> Quitando los archivos libtool...
  -> Purgando los archivos innecesarios...
  -> Quitando los archivos de las bibliotecas estáticas...
  -> Despojando los símbolos innecesarios de los binarios y de las bibliotecas...
  -> Comprimiendo las páginas del manual y de información...
==> Buscando problemas de empaquetado...
==> Creando el paquete «bottles»...
  -> Generando el archivo .PKGINFO...
  -> Generando el archivo .BUILDINFO...
  -> Generando el archivo .MTREE...
  -> Comprimiendo el paquete...
==> Abandonando el entorno fakeroot.
==> Compilación terminada: bottles 2022.5.28-5 (mié 03 ago 2022 09:36:13)
==> Limpiando...
Verificando depósito de llaves (keyring)...
Verificando integridad...
Cargando paquetes de archivos...
Verificando conflictos de los archivos...
Verificando espacio disponible en el disco...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Reinstalando bottles (2022.5.28-5)...
Ejecutando postransacción hooks...
Arming ConditionNeedsUpdate...
Compiling GSettings XML schema files...
Updating icon theme caches...
Updating the desktop file MIME type cache...
Transacción finalizada con éxito.
Uninstalling and/or reinstalling will not affect whatever configuration files you have. Your configuration files are stored in your home directory, which an uninstall, reinstall or update will never touch.
Also… :arrow_down:
bottles is an AUR package. pacman does not access the AUR. In order to update bottles, you need to use pamac instead.
pamac update
… or, for reinstalling, … :arrow_down:
pamac build bottles
Please don’t use screenshots but actual text of the output.
You can see that it’s from the AUR, which can’t be updated with pacman. You need pamac for this:
pamac update
Ok, first tried to do pamac update and this appeared:
pamac update                                                     ✔
Preparando...
Refrescando AUR...
Aviso: bottles-2022.5.28-5 está actualizado -- omitiéndolo
Nada que hacer.
Where it says that it was already updated so there was nothing to do but it keeps appearing as an update in pamac :confused:
I’ll try the reinstall then as @Aragorn suggested, hope that works…but it asks if i should edit the build files (e/y/N) :confused: which one should i use?
Just answer N then. :man_shrugging:
It canceled the transaction :confused:
Well, that’s not supposed to happen. :man_shrugging:
jeje…that’s what i’ve been trying to explain…it’s strange cause it updates bottles, but still ask me to do the update again, by the way, i’ve just deleted the images at the beginning and changed it to text and pasted everything that shows when updating from pamac :confused: Could it be problem from bottles and not manjaro?
Thanks @mithrial cause it’s in fact easier to use the code instead of images :stuck_out_tongue:
Yes, I suppose the package itself could be corrupt in some way, but then you should normally get an indicative error message.
:cold_sweat:…then, what can or should i do? :confused: cause i can run my bottles without any problem
Well, if the system’s up-to-date, I’d just ignore it. :man_shrugging:
You can always check for a newer version again in a few days, or maybe in a few weeks.
Can you put LANG=C in front of your commands, so that we’re able to understand?
I think the pamac-gui has a different location of the database than pamac, so that it shows an update that actually isn’t there. In the GUI, there is the option to refresh the databases which then might update the view on the available updates.
Jajaja…that will be very annoying to ignore since i always look to this in my top bar :stuck_out_tongue:
Ok, tried the lang=c but i think i did it wrong:
    ~  pamac build bottles lang=c                                       ✔
Error: Objetivo no encontrado: lang=c
And the databases were updated but changed the USA mirror to ALL and installed bottles and also the adw-gtk3…but then, it appeared again the bottles update :confused: should i change the language from manjaro in general?
imagen
Yes, you did.
  1. UNIX is case-sensitive; and
  2. The variable assignment must precede the command. :arrow_down:
LANG=C the-command-you-want-to-run
Have you tried updating Pamac by right-clicking the icon, and choosing “refresh” or “check updates”, or whatever the option is?
(Note: I don’t use that tray icon, so I don’t know.)
Oh ok, now it worked…:stuck_out_tongue:
    ~  LANG=C pamac build bottles                                       ✔
Preparing...
Cloning bottles build files...
Generating bottles information...
Checking bottles dependencies...
Warning: bottles-2022.5.28-5 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  bottles  2022.5.28-5                 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] N
Transaction cancelled.
    ~  LANG=C pamac update                                    1 ✘  13s 
Preparing...
cp: cannot create regular file '/var/tmp/pamac/dbs/sync/pamac_aur.db': Permission denied
To build (1):
  bottles  1:2022.5.28-5  (2022.5.28-5)  AUR
    ~                                                         1 ✘  15s 
Tried the rebuild and the update but they both were cancelled :confused:
Yes, but it only shows what’s for updating and a button to open the GUI
imagen
WOAHH!! I have never tried this option, but checked the Software mode in the Pamac GUI and then updated and it seems to have worked!!! :smiley: can you explain that? O_o cause it still tells me that the bottles update is available… :confused:
Yes, that’s one of the recent pamac bugs… :roll_eyes:
Try this, pending a fix… :arrow_down:
sudo chown -R $USER:$USER /var/tmp/pamac
sudo chmod -R +w /var/tmp/pamac
pamac update --aur --devel
Noup, it seems that it didn’t work either :confused:
    ~  LANG=C sudo chown -R $USER:$USER /var/tmp/pamac                  ✔
LANG=C chmod -R +w /var/tmp/pamac
LANG=C pamac update --aur --devel
[sudo] password for solidcapo:
Preparing...
Warning: bottles-2022.5.28-5 is up to date -- skipping
Nothing to do.
    ~                                                           ✔  11s 
What is the output of the commands… :arrow_down:
ls -l /var/tmp/pamac/dbs/
ls -l /var/tmp/pamac/dbs/sync/
If all else fails, try this… :arrow_down:
sudo chmod 777 /var/tmp/pamac/dbs/sync
sudo touch /var/tmp/pamac/dbs/sync/pamac_aur.db
sudo chmod 666 /var/tmp/pamac/dbs/sync/pamac_aur.db
Your bottles installation is already up-to-date, but the fact that Pamac continues showing it as eligible for updating is probably caused by the fact that pamac couldn’t create the pamac_aur.db file.
The above commands should remedy this and cause Pamac to recognize your bottles installation as having been updated.
Cross your fingers… :wink:
:crossed_fingers:
