~ LANG=C ls -l /var/tmp/pamac/dbs/ ✔
total 4
lrwxrwxrwx 1 solidcapo solidcapo 21 ago 3 14:39 local -> /var/lib/pacman/local
drwxrwxrwx 2 solidcapo solidcapo 4096 ago 3 14:39 sync
~ LANG=C ls -l /var/tmp/pamac/dbs/sync/ ✔
total 53984
-rw-r--r-- 1 solidcapo solidcapo 7414301 ago 3 09:39 community.db
-rw-r--r-- 1 solidcapo solidcapo 33744377 ago 3 11:56 community.files
-rw-r--r-- 1 solidcapo solidcapo 170259 jul 29 05:48 core.db
-rw-r--r-- 1 solidcapo solidcapo 1613319 jul 29 05:48 core.files
-rw-r--r-- 1 solidcapo solidcapo 1905963 jul 29 13:01 extra.db
-rw-r--r-- 1 solidcapo solidcapo 9928913 jul 29 13:01 extra.files
-rw-rw-rw- 1 solidcapo solidcapo 18058 dic 11 2021 mhwd.db
-rw-r--r-- 1 solidcapo solidcapo 178519 jul 29 05:48 multilib.db
-rw-r--r-- 1 solidcapo solidcapo 262648 jul 29 05:48 multilib.files
-rw-r--r-- 1 solidcapo solidcapo 2560 ago 3 10:11 pamac_aur.db
-rw-rw-rw- 1 solidcapo solidcapo 0 ago 3 10:22 refresh_timestamp
~ LANG=C sudo chmod 777 /var/tmp/pamac/dbs/sync ✔
LANG=C sudo touch /var/tmp/pamac/dbs/sync/pamac_aur.db
LANG=C sudo chmod 666 /var/tmp/pamac/dbs/sync/pamac_aur.db
LANG=C pamac update --aur --devel
[sudo] password for solidcapo:
Preparing...
Sincronizando bases de datos de paquetes...
Refrescando community.db...
Refreshing AUR...
Cloning bottles build files...
Generating bottles information...
Checking bottles dependencies...
Warning: bottles-2022.5.28-5 is up to date -- skipping
Nothing to do.
~ ✔ 14s
Well, unfortunately it didn’t work either, it still appears in the Pamac GUI and topbar icon
so, for now we should wait? or where else should i report it? or what do you recommend? ![]()
