i created a cluster in “/var/lib/postgres/data/” entered after that the command “sudo systemctl enable postgresql” and wanted to run with “sudo systemctl status postgresql” exits
(postgresql.service - PostgreSQL database server
Loaded: loaded (/usr/lib/systemd/system/postgresql.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Thu 2023-05-04 22:00:43 +05; 9 hours ago
CPU: 45ms
May 04 22:00:43 vladislav-macbookair systemd[1]: Starting PostgreSQL database server…
May 04 22:00:43 vladislav-macbookair postgres[447]: “/var/lib/postgres/data” is missing or empty. Use a command li>
May 04 22:00:43 vladislav-macbookair postgres[447]: su - postgres -c "initdb --locale en_US.UTF-8 -D '/var/lib/p>
May 04 22:00:43 vladislav-macbookair postgres[447]: with relevant options, to initialize the database cluster.
May 04 22:00:43 vladislav-macbookair systemd[1]: postgresql.service: Control process exited, code=exited, status=1>
May 04 22:00:43 vladislav-macbookair systemd[1]: postgresql.service: Failed with result ‘exit-code’.
May 04 22:00:43 vladislav-macbookair systemd[1]: Failed to start PostgreSQL database server.
