I am on the unstable branch. Could that be a reason?
Nothing about nvidia was updated btw
well it could be, maybe manjaro didnt rebuild yet the nvidia/kernels …
so there was something updated? was linux61 and linux61-nvidia packages updated?
No nothing about nvidia was updated. Anyway, it works now
❯ inxi -G
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GA107GLM [RTX A1000 Laptop GPU] driver: nvidia
v: 525.89.02
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: modesetting,nvidia
dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
3: 1920x1080~60Hz 4: N/A
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Graphics (ADL GT2)
very good, now you can use your nvidia, either by running the prime-run
with specific programs, for example:
prime-run firefox
or just switching between gpus using optimus-manager - follow the instructions on the github page on how to modify the sddm.conf, then install optimus:
sudo pacman -S optimus-manager optimus-manager-plasma
reboot and switch via the optimus tray
Great, so can I fully use the NVidia GPU with the Optimus manager or do I have to use the Reverse Prime method from the Arch wiki?
yes you can use nvidia if you switch to it via optimus:
Getting a black screen as described after rebooting unfortunately
did you edited the sddm conf?
Yes
❯ cat /etc/sddm.conf
[General]
InputMethod=
Numlock=none
[Theme]
CursorTheme=breeze_cursors
DisableAvatarsThreshold=7
EnableAvatars=true
FacesDir=/usr/share/sddm/faces
ThemeDir=/usr/share/sddm/themes
[Users]
DefaultPath=/usr/local/sbin:/usr/local/bin:/usr/bin
HideShells=
HideUsers=
RememberLastSession=true
RememberLastUser=true
ReuseSession=false
[Wayland]
EnableHiDPI=false
SessionCommand=/usr/share/sddm/scripts/wayland-session
SessionDir=/usr/share/wayland-sessions
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
# DisplayCommand=/usr/share/sddm/scripts/Xsetup
# DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=false
MinimumVT=1
ServerArguments=-nolisten tcp
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
XephyrPath=/usr/bin/Xephyr
post again output from:
find /etc/X11/ -name "*.conf"
and use prime-run with firefox:
prime-run firefox
and check with:
nvidia-smi
if its running on nvidia
❯ find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/mhwd.d/nvidia.conf
Tried running Firefox, but seems to not be working
❯ nvidia-smi
Tue Mar 7 11:51:20 2023
| NVIDIA-SMI 525.89.02 Driver Version: 525.89.02 CUDA Version: 12.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA RTX A100... Off | 00000000:01:00.0 Off | N/A |
| N/A 49C P8 3W / 35W | 4MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
Works with glxgears though
❯ nvidia-smi
Tue Mar 7 11:52:24 2023
| | | MIG M. |
| N/A 48C P8 3W / 35W | 12MiB / 4096MiB | 5% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 8100 G glxgears 7MiB |
should be working also with firefox…
post output from:
cat /etc/X11/mhwd.d/nvidia.conf
Yeah, I already had another Firefox window open. After closing that it also works with Firefox
❯ nvidia-smi
Tue Mar 7 11:55:50 2023
| | | MIG M. |
| N/A 50C P8 6W / 35W | 6MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 8713 G ...-browser-integration-host 1MiB |
❯ cat /etc/X11/mhwd.d/nvidia.conf
## Generated by mhwd - Manjaro Hardware Detection
so have no idea why you had a black screen after installing optimus, that shouldnt happened; did you installed only optimus manager and optimus plasma as you should? and no other optional dependencies?
Yeah, there were no other dependencies. Reverse Prime also doesn’t work. I guess I will have to stick to offloading heavier applications the the NVidia GPU
you could try with envycontrol:
pamac build envycontrol
switch to nvidia:
sudo envycontrol -s nvidia
it will prompt you for reboot, so do it, and see if it worked… if not, enter into TTY, and remove it:
sudo pacman -Rs envycontrol
reboot
I tried envycontrol, but it also results in a black screen unfortunately.
then there is something wrong with your system/ nvidia drivers… could be because of you being on unstable… or there is still something messed up from the update … check with:
sudo ldconfig
it should return nothing
Yeah it returns nothing
sddm doesn’t seem to find the monitors
● sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: disabled)
Active: active (running) since Tue 2023-03-07 12:55:33 CET; 56s ago
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 1225 (sddm)
Tasks: 2 (limit: 37956)
Memory: 4.1M
CPU: 123ms
CGroup: /system.slice/sddm.service
└─1225 /usr/bin/sddm
Mär 07 12:55:35 precision5570 sddm[1225]: Failed to read display number from pipe
Mär 07 12:55:35 precision5570 sddm[1225]: Display server stopping...
Mär 07 12:55:35 precision5570 sddm[1225]: Attempt 2 starting the Display server on vt 1 failed
Mär 07 12:55:37 precision5570 sddm[1225]: Display server starting...
Mär 07 12:55:37 precision5570 sddm[1225]: Adding cookie to "/var/run/sddm/{d15b490f-97c4-4901-a8e2-3e74c4889514}"
Mär 07 12:55:37 precision5570 sddm[1225]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{d15b490f-97c4-4901-a8e2-3e74c4889514} -noreset -displayfd 17
Mär 07 12:55:37 precision5570 sddm[1225]: Failed to read display number from pipe
Mär 07 12:55:37 precision5570 sddm[1225]: Display server stopping...
Mär 07 12:55:37 precision5570 sddm[1225]: Attempt 3 starting the Display server on vt 1 failed
Mär 07 12:55:37 precision5570 sddm[1225]: Could not start Display server on vt 1
there is something messed up in your system… but have no idea what…
try reinstalling the video drivers, so remove them:
sudo mhwd -r pci video-hybrid-intel-nvidia-prime
now install them again:
sudo mhwd -a pci nonfree 0300
reboot;
install again optimus as instructed above and see if it helped
