I would like to configure my hybrid system to use the NVidia Reverse Prime method to only use the discrete GPU. I am failing to even get the NVidia driver to run though.
I installed the drivers with the automatic proprietary installation method. This give me the prime drivers.
My cards is recognized
❯ lspci -k | grep -A 2 -E "(VGA|3D)"
0000:00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P Integrated Graphics Controller (rev 0c)
Subsystem: Dell Device 0b1a
Kernel driver in use: i915
0000:01:00.0 3D controller: NVIDIA Corporation GA107GLM [RTX A1000 Laptop GPU] (rev a1)
Kernel modules: nouveau
There is no nvidia kernel module available though and the system seems to still be using the Intel driver. Also when I use DRI_PRIME=0
❯ lspci -vnnn | perl -lne 'print if /^\d+\:.+(\[\S+\:\S+\])/' | grep VGA
0000:00:02.0 VGA compatible controller [0300]: Intel Corporation Alder Lake-P Integrated Graphics Controller [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
If I try to activate the Reverse Prime method using the mentioned xorg configuration, Xorg fails to start.
On the Arch forum it says that systems using DKMS fail to boot on processors later than 11th gen. No idea if this is related.
brahma
March 6, 2023, 5:17pm
2
yes you need ibt if you are running on newer kernels than 5.15, so post output from:
mhwd -l -li
brahma:
mhwd -l -li
❯ mhwd -l -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-modesetting 2020.01.13 true PCI
> 0000:01:00.0 (0302:10de:25b9) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
> 0000:00:02.0 (0300:8086:46a6) Display controller Intel Corporation:
video-vesa 2017.03.12 true PCI
Guess it is missing?
brahma
March 7, 2023, 8:23am
4
proper drivers are installed, so add the parameter:
sudo nano /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT
inside the quotes add this parameter:
ibt=off
dont remove anything, just add it to existing parameters, save the file with ctrl+x
, press Y, then enter;
update grub:
sudo update-grub
reboot
Still nothing
$ prime glxinfo | grep "OpenGL"
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 50
Current serial number in output stream: 51
brahma
March 7, 2023, 8:24am
6
did you added the parameter and rebooted?
brahma
March 7, 2023, 8:26am
8
so provide full system info:
inxi -zav7
what drivers you have installed:
pacman -Qs 'nvidia|prim'
and configs:
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
Kernel: 6.2.1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=a0c4466d-04d3-40f1-8235-d70129aa9c02 rw quiet splash
udev.log_priority=3 ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Precision 5570 v: N/A
Mobo: Dell model: 0DPVMT v: A00 serial: <superuser required> UEFI: Dell
v: 1.10.0 date: 12/14/2022
ID-1: BAT0 charge: 84.3 Wh (100.0%) condition: 84.3/84.3 Wh (100.0%)
volts: 13.2 min: 11.4 model: SMP DELL 70N2F95 type: Li-poly serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.03 GiB used: 5.45 GiB (17.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x429
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2624 high: 4690 min/max: 400/4700:4800:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 4690 2: 2800 3: 583
4: 2800 5: 2800 6: 2800 7: 2800 8: 873 9: 1247 10: 2800 11: 2242 12: 2800
13: 2800 14: 3600 15: 3489 16: 2161 17: 2800 18: 2800 19: 2800 20: 2800
bogomips: 112160
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: DP-5,DP-6,DP-7 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A1000 Laptop GPU] vendor: Dell driver: N/A
alternate: nouveau non-free: 525.xx+ status: current (as of 2023-02)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
bus-ID: 0000:01:00.0 chip-ID: 10de:25b9 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:6732 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting failed: nvidia dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1521x285mm (59.88x11.22")
s-diag: 1547mm (60.92")
Monitor-1: not-matched mapped: DP-2-1 pos: primary,center res: 1920x1080
hz: 60 dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01")
modes: N/A
Monitor-2: not-matched mapped: DP-2-2 pos: left res: 1920x1080 hz: 60
dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-3: not-matched mapped: DP-2-3 pos: right res: 1920x1080 hz: 60
Monitor-4: eDP-1 note: disabled model: Sharp 0x1516 built: 2021
res: 1920x1080 dpi: 290 gamma: 1.2 size: 336x210mm (13.23x8.27")
diag: 396mm (15.6") ratio: 16:10 modes: 3840x2400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel bus-ID: 3-3.1:4 v: kernel
alternate: snd_sof_pci_intel_tgl chip-ID: 0b0e:24c9 class-ID: 0300
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 serial: <filter> class-ID: 0403
Device-2: GN Netcom Jabra Link 380 type: USB
driver: jabra,snd-usb-audio,usbhid
Sound API: ALSA v: k6.2.1-2-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.66 running: no
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 6-1.1:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0u1u1 state: down mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 6-2.4:6 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp4s0u2u4 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 953.87 GiB used: 217.52 GiB (22.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 36309229 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 32.4 GiB (33.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a0c4466d-04d3-40f1-8235-d70129aa9c02
used: 22.7 MiB (4.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: BBD4-680F
ID-3: /home raw-size: 855.71 GiB size: 841.21 GiB (98.30%)
used: 185.09 GiB (22.0%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: Home uuid: 399c4aee-3533-4280-85e0-e162139c2b69
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-3: 2-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 2-1.2:4 info: Future Devices FT4232H Quad HS USB-UART/FIFO IC
type: <vendor specific> driver: ftdi_sio interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0403:6011 class-ID: 0000
Hub-4: 2-2:3 info: Realtek Dell dock ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5487 class-ID: 0900
Device-1: 2-2.1:5 info: GN Netcom Jabra Evolve2 75 Deskstand type: HID
driver: jabra,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 0b0e:c0e0 class-ID: 0300 serial: <filter>
Hub-5: 2-2.3:6 info: Realtek Dell dock ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5413 class-ID: 0900
Device-1: 2-2.3.2:8 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 2-2.3.3:9 info: Logitech Logi Bolt Receiver
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-3: 2-2.3.5:10 info: Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 413c:b06f
class-ID: 0300
Device-4: 2-2.5:7 info: Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 413c:b06e
class-ID: 0300
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-7: 3-3:2 info: Cambridge Silicon Radio ports: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0a12:4010 class-ID: 0900
Device-1: 3-3.1:4 info: GN Netcom Jabra Link 380 type: Audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
chip-ID: 0b0e:24c9 class-ID: 0300 serial: <filter>
Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-9:5 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-4: 3-10:6 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-8: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-9: 5-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-11: 6-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 6-1.1:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-12: 6-2:3 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 0bda:0487 class-ID: 0900
Hub-13: 6-2.3:5 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0413 class-ID: 0900
Device-1: 6-2.4:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
System Temperatures: cpu: 80.0 C mobo: N/A
Processes: 406 Uptime: 0m wakeups: 8 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1423 libs: 354 tools: yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: kitty inxi: 3.3.25
❯ pacman -Qs 'nvidia|prim'
local/egl-wayland 2:1.1.11-3
EGLStream-based Wayland external platform
local/lib32-nvidia-utils 525.89.02-2
NVIDIA drivers utilities (32-bit)
local/libplacebo 5.229.2-1
Reusable library for GPU-accelerated video/image rendering primitives
local/libvdpau 1.5-1
Nvidia VDPAU library
local/libxnvctrl 525.89.02-1
NVIDIA NV-CONTROL X extension
local/linux61-nvidia 525.89.02-6 (linux61-extramodules)
NVIDIA drivers for linux
local/linux62-nvidia 525.89.02-2 (linux62-extramodules)
local/mhwd-nvidia 525.89.02-3
MHWD module-ids for nvidia 525.89.02
local/mhwd-nvidia-390xx 390.157-3
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.161.03-3
MHWD module-ids for nvidia 470.161.03
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 525.89.02-3
local/prime 1.0-14
Nvidia:PRIME Render Offload Launcher
local/python-cryptography 39.0.1-1
A package designed to expose cryptographic recipes and primitives to Python developers
local/xorg-xrandr 1.5.2-1 (xorg-apps xorg)
Primitive command line interface to RandR extension
❯ ls /etc/modprobe.d
mhwd-gpu.conf
❯ find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/mhwd.d/nvidia.conf
brahma
March 7, 2023, 8:33am
10
the nvidia driver is not even loaded:
you have 2 prime packages, one the default one from official repos:
and the second one from AUR:
and thats possible the reason for the mess, so remove the AUR one:
sudo pacman -Rs prime
reboot and check with:
inxi -G
if the nvidia driver is loaded
Yes, this is was I suspected as well.
Still nothing unfortunately
❯ prime-run glxinfo
name of display: :0
❯ inxi -G
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GA107GLM [RTX A1000 Laptop GPU] driver: N/A
Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
3: 1920x1080~60Hz 4: N/A
Something odd here maybe?
❯ cat /etc/modprobe.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
brahma
March 7, 2023, 8:40am
12
the driver is still not loaded…
post output from:
pacman -Qm
❯ pacman -Qm
aic94xx-firmware 30-9
applet-window-appmenu-git v0.8.0-1
bottles 2:50.2-1
dell-command-configure 4.7.0.433-3
etcher-bin 1.14.3-1
fvs 0.3.4-1
gitter-bin 5.0.1-2
icoextract 0.1.4-1
insomnia-designer-bin 2020.5.2-2
jellyfin-media-player 1.8.1-1
kwin-scripts-window-colors 0.2-3
masterpdfeditor-free 4.3.89-1
mfgtools-git 1.5.21.r3.gcbff795-1
nodejs-nativefier 50.0.1-1
ocs-url 3.1.0-7
onedrive 1.1.4-1
openvpn-update-systemd-resolved 1.3.0-4
patool 1.12-5
pcalc 4-1
plasma5-applets-latte-spacer 0.3.0-1
prospect-mail-bin 0.4.0-3
python-kconfiglib 14.1.0-2
python-steamgriddb 1.0.5-1
python2 2.7.18-8
slack-desktop 4.29.149-1
spotify 1:1.1.84.716-12
spotify-adblock-git 1:1.0.2.r0.g9ba383b-2
swagger-editor-git 20230118-1
swagger-ui 4.12.0-1
teams 1.5.00.23861-1
teams-for-linux 1.0.49-1
vkbasalt-cli 3.1.1-1
wd719x-firmware 1-7
wireguard-dkms 1.0.20220627-1
youtube-music-bin 1.19.0-1
I am currently checking if it is turned off in the BIOS, but there doesn’t even seem to be a setting for that
Dell Command Configure Version 4.7.0 433 (Linux - Mar 30 2022, 17:54:19)
Copyright 2009 - 2022 Dell Inc. All rights reserved.
Usage: cctk --option[=argument]
For more information about a particular command,
use the option '-H' followed by the command name.
Example: cctk -H --Asset
Note: Commands with * Symbol are Read-Only BIOS Features.
--Absolute --FnLockMode --SdCard
--AdminSetupLockout FotaProfile --SdCardBoot
--AdvBatteryChargeCfg --FullScreenLogo --SdCardReadOnly
--AdvancedMode -H or --help --SecureBoot
Advsm --HddInfo* --SecureBootMode
--AllowBiosDowngrade --HddPwd --SetupPwd
--AmtCap HttpBootProfile --SignOfLifeByDisplay
--Asset --HttpsBoot --SignOfLifeByKbdBacklight
--AutoOSRecoveryThreshold --HttpsBootMode --SmartErrors
--AutoOn -I or --infile --SmmSecurityMitigation
--AutoOnHr --IntegratedAudio --SpeedShift
--AutoOnMn --IntelSagv --Speedstep
--AutoRtcRecovery --IntelTME --StrongPassword
--BIOSConnect --InternalSpeaker --SupportAssistOSRecovery
--BiosAutoRcvr --Itbm --SvcTag*
--BiosCharacteristics* --KbdBacklightTimeoutAc --SysId*
--BiosCurLang* --KbdBacklightTimeoutBatt --SysName*
--BiosListInstallLang* --KernelDma --SysPwd
--BiosLogClear --KeyboardIllumination --SysRev*
--BiosRcvrFrmHdd -L or --logfile --TelemetryAccessLvl
--BiosRomSize* --LastBiosUpdate* --ThermalLogClear
--BiosVer* --LidSwitch --ThermalManagement
--BlockBootUntilChasIntrusionClr--LogicProc --ThunderboltBoot
--BlockSleep --MSUefiCA --ThunderboltPorts
--BluetoothDevice --MacAddrPassThru --ThunderboltPreboot
BootOrder --MasterPasswordLockout --Touchscreen
--BrightnessAc --MediaCard --TpmPpiClearOverride
--BrightnessBattery --Mem* --TpmSecurity
--CStatesCtrl --MfgDate* --TrustExecution
--Camera --Microphone --TurboMode
--CapsuleFirmwareUpdate --MinSizeOfContigMem* --TypeCDockAudio
--ChasIntrusion --MultipleAtomCores --TypeCDockLan
--ChassisIntruStatus --NonAdminPsidRevert --TypeCDockOverride
CloudAppProfile --NumLock --UefiBootPathSecurity
--CompletionCode* -O or --outfile --UefiNwStack
ConnectionProfile --OvrWrt* --UsbEmu
--CpuCore --PasswordBypass --UsbEmuNoUsbBoot
--CpuCount* PasswordConfiguration --UsbPortsExternal
--CpuSpeed* --PasswordLock --Uuid*
CsosProfile --PeakShiftBatteryThreshold --ValSetupPwd
--DeviceHotkeyAccess --PeakShiftCfg --ValSysPwd
--DisUsb4Pcie --PowerLogClear --Version*
--DockWarningsEnMsg --PowerOnLidOpen --VerticalIntegration
--DynamicWirelessTransmitPower --PowerWarn --VideoPowerOnlyPorts
--EmbSataRaid --PreBootDma --Virtualization
--ExtPostTime --PrimaryBattChargeCfg --VtForDirectIo
--FOTA --PropOwnTag --WakeOnAc
--Fastboot --ReportLogoType* --WakeOnDock
--FingerprintReader --RestoreBIOSSettings --WakeOnLan
--FirmwareTamperDet -S or search --WarningsAndErr
--FirstPowerOnDate* --SHA256 --WirelessLan
--FnLock --SaveConfig --WlanAutoSense
brahma
March 7, 2023, 8:46am
14
if it was disabled in bios, the nvidia gpu would not be even detected…
enable early loading:
kate /etc/mkinitcpio.conf
and edit the modules section to look like this:
MODULES=(i915 nvidia nvidia_drm nvidia_uvm nvidia_modeset)
save it and update it:
sudo mkinitcpio -P
reboot and check again
I already tried that yesterday. The modules are not there for some reason
❯ sudo mkinitcpio -p linux62
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: 'default'
-> -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64.img
==> Starting build: 6.2.1-2-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> ERROR: module not found: `nvidia'
==> ERROR: module not found: `nvidia_drm'
==> ERROR: module not found: `nvidia_uvm'
==> ERROR: module not found: `nvidia_modeset'
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.2-x86_64.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: 'fallback'
-> -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.2-x86_64-fallback.img
Standard Manjaro 6.2 Kernel. No idea…
brahma
March 7, 2023, 8:53am
16
switch to the 6.1 kernel and see if it works there
Seems like for 6.1 it doesn’t even attempt to compile the nvidia modules
❯ sudo mkinitcpio -p linux61
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: 6.1.14-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64-fallback.img
or maybe it is successful?
Anyway, when booted, nothing is being loaded either.
❯ inxi -G
brahma
March 7, 2023, 9:20am
18
looks like they are being blacklisted… post output from:
journalctl -b0 -p5 --no-pager | grep nvidia
sudo dmesg | grep -E 'nvidia|nvm'
❯ journalctl -b0 -p5 --no-pager | grep nvidia
Mär 07 10:18:38 precision5570 kernel: nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
Mär 07 10:18:38 precision5570 systemd-modules-load[386]: Failed to insert module 'nvidia': Exec format error
Mär 07 10:18:39 precision5570 kernel: nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
Mär 07 10:18:39 precision5570 systemd-modules-load[386]: Failed to insert module 'nvidia_drm': Exec format error
Mär 07 10:18:40 precision5570 kernel: nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
Mär 07 10:18:40 precision5570 systemd-modules-load[386]: Failed to insert module 'nvidia_uvm': Exec format error
Mär 07 10:18:43 precision5570 kernel: nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
❯ sudo dmesg | grep -E 'nvidia|nvm'’
[sudo] Passwort für jan:
[ 3.510071] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 3.527471] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 3.542964] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 3.558192] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 3.625962] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 3.642281] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 7.804545] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 8.620673] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 8.967078] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 9.779367] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 10.018501] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
[ 13.156406] nvidia: version magic '6.1.15-1-MANJARO SMP preempt mod_unload ' should be '6.1.14-1-MANJARO SMP preempt mod_unload '
brahma
March 7, 2023, 9:25am
20
looks like a messed up update… you have mismatch in versions… refresh mirrors:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
if it was updating kernel and nvidia, reboot and test again
