Hi, I read there are some issues with plasma 6, and I too have some, not major, but still annoying:
- when I click ‘Audio Volume’ icon in the panel the pop up window just flashes for a moment and closes, along with it flash ‘keyboard layout’ letters and ‘show hidden icons’ arrow as if they were clicked on - to keep it open I first have to click on the hidden icons arrow and after that click audio icon. Changing keyboard language allows then the audio volume window to stay open - I have 3 languages and when cycling through them it works on 2 out of 3 seemingly randomly and together with volume window being opened and closed the language icon switches to another language and back.
- icons in Dolphin toolbar blurry when using Oxygen application style, changing size doesn’t fix, on other styles toolbar icons look sharp, but not sidebar icons; weird broken font in system settings > background services (letters thin or wide, blue and red color showing in some places) - fonts were fixed after playing around with global themes.
And these two probably not caused by this update, but it’d be nice if there was a fix:
- LibreOffice freezes after saving a new document - I found a post saying it’s being fixed though?
- Dolphin search looks broken and I believe I could use it normally before, e.g. in a folder with various text files it fetches some files with the keyword in the title but not others (two pdf with titles beginning with 6, search shows only one, at least 4 files with ‘about’ in title but shows 2 pdfs and one docx but not the docx that begins with ‘about’) and it seems it’s the newer files that are invisible - it finds those that were created first.
System info says I’m now on X11 (hadn’t checked what it was after update, was it ever on wayland?), not wayland and I read that wayland with nvidia might not be good, so is it any good trying to switch? When I tried to switch from the log out window (I believe I selected xorg then) the screen just went black and I had to hard shut down.
On a new user the issues (except LibreOffice one) do not appear, and the search works. However the second time I tried to switch to the new user the screen stuck to ‘made by KDE’ screen and I had to hard shut off again.
Would resetting desktop appearance and dolphin settings be more practical than trying to fix issues separately?
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=d748179e-6e28-49ed-a0d6-8851bd570a5c rw quiet apparmor=1
security=apparmor resume=UUID=d46bc2ea-cb32-48ca-b221-7f3f5fd2ac79
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: Micro-Star model: A520M PRO (MS-7D14) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.80 date: 06/23/2021
System RAM: total: 16 GiB available: 13.54 GiB used: 1.72 GiB (12.7%)
Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
part-no: LD4AU008G-H3200GST serial: <filter>
Info: model: AMD Ryzen 5 PRO 4650G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1862 high: 3440 min/max: 400/4308 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3347 2: 400 3: 400
4: 3440 5: 3332 6: 400 7: 3174 8: 3289 9: 3362 10: 400 11: 400 12: 400
bogomips: 88663
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA GA107 [GeForce RTX 3050 8GB] driver: nvidia v: 550.90.07
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 10:00.0 chip-ID: 10de:2582 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: none empty: DP-1,DP-2,HDMI-A-1 bus-ID: 30:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 32.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 1920x1080 dpi: 102
size: 477x268mm (18.78x10.55") modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 driver: nvidia v: 550.90.07
device-ID: 10de:2582 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RENOIR) driver: mesa radv
v: 24.0.9-manjaro1.1 device-ID: 1002:1636 surfaces: xcb,xlib
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 30:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 462.05 GiB used: 231.02 GiB (50.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 238.47 GiB block-size: physical: 512 B
fw-rev: ECFM12.6 temp: 27.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Apacer model: AS340 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3PE0 scheme: GPT
ID-1: / raw-size: 235.98 GiB size: 231.22 GiB (97.98%)
used: 73.24 GiB (31.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: d748179e-6e28-49ed-a0d6-8851bd570a5c
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: D303-8E10
ID-3: /home raw-size: 223.57 GiB size: 219 GiB (97.96%)
used: 157.79 GiB (72.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ea631f77-f1d8-4ab5-a27a-bf198e88ee5d
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: d46bc2ea-cb32-48ca-b221-7f3f5fd2ac79
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-6:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d14 class-ID: 0300
serial: <filter>
Device-2: 1-7:4 info: Razer USA RZ01-0036 Optical Gaming Mouse [Abyssus]
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 1532:001c class-ID: 0301
Hub-3: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 36.4 C mobo: N/A
Fan Speeds (rpm): fan-1: 1143 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
fan-7: 0 fan-8: 0 fan-9: 0 fan-10: 0
GPU: device: nvidia screen: :0.0 temp: 48 C fan: 0% device: amdgpu
temp: 31.0 C
Packages: 1805 pm: pacman pkgs: 1799 libs: 485 tools: pamac pm: flatpak
pkgs: 6
1: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
2: https://mirror.23m.com/manjaro/stable/$repo/$arch
3: https://mirrors.netix.net/manjaro/stable/$repo/$arch
4: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
5: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
6: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
7: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
8: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 286
1: cpu: 11.8% command: konsole pid: 2481 mem: 149.6 MiB (1.0%)
2: cpu: 1.7% command: Xorg pid: 1074 mem: 86.9 MiB (0.6%)
3: cpu: 1.6% command: kate pid: 2377 mem: 173.1 MiB (1.2%)
4: cpu: 1.1% command: kwin_x11 pid: 1338 mem: 174.2 MiB (1.2%)
5: cpu: 0.9% command: plasmashell pid: 1354 mem: 491.2 MiB (3.5%)
Memory top: 5 of 286
1: mem: 491.2 MiB (3.5%) command: plasmashell pid: 1354 cpu: 0.9%
2: mem: 194.8 MiB (1.4%) command: dolphin pid: 2337 cpu: 0.7%
3: mem: 174.2 MiB (1.2%) command: kwin_x11 pid: 1338 cpu: 1.1%
4: mem: 173.1 MiB (1.2%) command: kate pid: 2377 cpu: 1.6%
5: mem: 149.6 MiB (1.0%) command: konsole pid: 2481 cpu: 11.8%
Processes: 286 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.4 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
