I have a problem starting Winetricks after updating Manjaro. I installed Wine correctly from the command line where everything worked fine before the update. I get notifications like this after starting winetricks:
“You are using winetricks-20210206-the next newest version of winetricks-20211!”
“It is recommended that you upgrade with your distribution’s package manager, --self-update, or update manually.”
“You are using a 64-bit WINEPREFIX. Note that many verbs only install 32-bit versions of packages. If you encounter problems, please retest in a clean 32-bit WINEPREFIX before reporting a bug.”
wine cmd.exe /c echo ‘%AppData%’ returned empty string, error message “”
I am asking for a hint or help because I do not know how to fix.
System Information:
Operating system: Manjaro Linux
KDE Plasma Version: 5.24.4
KDE Frameworks version: 5.92.0
Qt version: 5.15.3
Kernel version: 5.17.1-1-rt16-MANJARO (64-bit)
Graphics platform: X11
Processor: 4 × Intel® Core ™ i3-6100U @ 2.30 GHz processor
Memory: 15.5 GiB RAM
Graphics Processor: Mesa Intel® HD Graphics 520
Dedicated graphics card NVIDIA GeForce 940MX 2GB
