hi i recently bought a wifi dongle https://www.mediatek.com/products/broadbandWifi/mt7601u
it works well on windows 10
but in linux i have a problem
lsusb
Bus 001 Device 005: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 40:61:86:97:bd:a0 brd ff:ff:ff:ff:ff:ff
3: enp0s29f7u6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 1000
link/ether ce:57:18:08:fd:9b brd ff:ff:ff:ff:ff:ff
third one is my phone (
uname -a
Linux amir-ms7392 5.4.72-1-MANJARO #1 SMP PREEMPT Sat Oct 17 11:06:19 UTC 2020 x86_64 GNU/Linux
i have CD with dongle but i think it’s for kernel 2.6
440Hz
2 November 2020 08:45
2
Could you post ther output of inxi -Fxz --no-host as well, please?
440Hz
2 November 2020 09:16
4
Looks like there is no driver loaded for the wifi controller.
There is an (outdated) AUR firmware package available that might help, but that’s just me guessing.
Better wait for someone more knowledgeable for competent help.
440Hz
2 November 2020 09:29
6
These look like totally different chips though?
They both can use the MT7601U driver. The OP is tying to run the binary one they downloaded
Some people use this firmware AUR (en) - mt7601u-firmware but is out of date
Others use this AUR (en) - mt7601u-ap-dkms
On the other hand can be done like this [Solved] MT7601U USB Wireless Adapter doesn't work / Newbie Corner / Arch Linux Forums
Are both Ralink and from the information from OP i can’t be sure they do not connected it to a USB3 port, hence not recognized properly …
440Hz
2 November 2020 13:42
8
Gawd, that’s complicated.
Thanks!
I used this the third link you sent but not working
Sorry for sending picture
I get these when dongle is plugged
What can i do ?
Edit
I had another compiled driver but it was same
Any one can help me ?
I tried use driver in live ubuntu but it is still like that
sudo dmesg
[ 8039.128751] usb 1-5: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[ 8039.128756] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8039.128758] usb 1-5: Product: 802.11 n WLAN
[ 8039.128761] usb 1-5: Manufacturer: MediaTek
[ 8039.128763] usb 1-5: SerialNumber: 1.0
[ 8039.257609] usb 1-5: reset high-speed USB device number 19 using ehci-pci
[ 8039.407120] mt7601u 1-5:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 8039.409190] mt7601u 1-5:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[ 8039.785247] mt7601u 1-5:1.0: EEPROM ver:0d fae:00
[ 8039.955498] mt7601u 1-5:1.0: rx urb failed: -71
[ 8039.956308] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8039.956313] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8039.959742] mt7601u 1-5:1.0: rx urb failed: -71
[ 8039.960248] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8039.960253] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8039.963989] mt7601u 1-5:1.0: rx urb failed: -71
[ 8039.964499] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8039.964504] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8039.968239] mt7601u 1-5:1.0: rx urb failed: -71
[ 8039.968745] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8039.968749] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8039.972488] mt7601u 1-5:1.0: rx urb failed: -71
[ 8039.972994] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8039.972998] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8039.973001] mt7601u 1-5:1.0: Error: mt7601u_mcu_wait_resp timed out
[ 8040.154315] audit: type=1101 audit(1604397305.370:210): pid=28398 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting g
rantors=pam_permit,pam_time acct="amir" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 8040.155729] audit: type=1110 audit(1604397305.373:211): pid=28398 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantor
s=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 8040.155735] audit: type=1105 audit(1604397305.373:212): pid=28398 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open gr
antors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 8040.167614] mt7601u 1-5:1.0: Vendor request req:07 off:0080 failed:-71
[ 8040.184024] audit: type=1106 audit(1604397305.400:213): pid=28398 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close g
rantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 8040.184243] audit: type=1104 audit(1604397305.400:214): pid=28398 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantor
[ 8040.334281] mt7601u 1-5:1.0: Vendor request req:02 off:0080 failed:-71
[ 8040.500964] mt7601u 1-5:1.0: Vendor request req:02 off:0080 failed:-71
[ 8040.501030] mt7601u: probe of 1-5:1.0 failed with error -110
[ 8040.501337] usb 1-5: USB disconnect, device number 19
[ 8040.757618] usb 1-5: new high-speed USB device number 20 using ehci-pci
[ 8040.919000] usb 1-5: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[ 8040.919004] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8040.919006] usb 1-5: Product: 802.11 n WLAN
[ 8040.919008] usb 1-5: Manufacturer: MediaTek
[ 8040.919010] usb 1-5: SerialNumber: 1.0
[ 8041.047623] usb 1-5: reset high-speed USB device number 20 using ehci-pci
[ 8041.197252] mt7601u 1-5:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 8041.199714] mt7601u 1-5:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[ 8041.579998] mt7601u 1-5:1.0: EEPROM ver:0d fae:00
[ 8041.749760] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8041.749767] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8041.754247] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8041.754252] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8041.758498] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8041.758503] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8041.762746] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8041.762751] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8041.766997] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8041.767002] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8041.767006] mt7601u 1-5:1.0: Error: mt7601u_mcu_wait_resp timed out
[ 8041.964321] mt7601u 1-5:1.0: Vendor request req:07 off:0080 failed:-71
[ 8042.130960] mt7601u 1-5:1.0: Vendor request req:02 off:0080 failed:-71
[ 8042.297625] mt7601u 1-5:1.0: Vendor request req:02 off:0080 failed:-71
[ 8042.297676] mt7601u: probe of 1-5:1.0 failed with error -110
[ 8042.300824] usb 1-5: USB disconnect, device number 20
[ 8042.557631] usb 1-5: new high-speed USB device number 21 using ehci-pci
[ 8042.715374] usb 1-5: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[ 8042.715379] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8042.715382] usb 1-5: Product: 802.11 n WLAN
[ 8042.715384] usb 1-5: Manufacturer: MediaTek
[ 8042.715386] usb 1-5: SerialNumber: 1.0
[ 8042.844316] usb 1-5: reset high-speed USB device number 21 using ehci-pci
[ 8042.993872] mt7601u 1-5:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 8042.995322] mt7601u 1-5:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[ 8043.384251] mt7601u 1-5:1.0: EEPROM ver:0d fae:00
[ 8043.556244] mt7601u_complete_rx: 5 callbacks suppressed
[ 8043.556260] mt7601u 1-5:1.0: rx urb failed: -71
[ 8043.556282] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8043.556286] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8043.560489] mt7601u 1-5:1.0: rx urb failed: -71
[ 8043.560745] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8043.560749] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8043.564739] mt7601u 1-5:1.0: rx urb failed: -71
[ 8043.564995] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8043.564999] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8043.568990] mt7601u 1-5:1.0: rx urb failed: -71
[ 8043.569242] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8043.569245] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8043.573245] mt7601u 1-5:1.0: rx urb failed: -71
[ 8043.573502] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8043.573505] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8043.573508] mt7601u 1-5:1.0: Error: mt7601u_mcu_wait_resp timed out
[ 8043.770990] mt7601u 1-5:1.0: Vendor request req:07 off:0080 failed:-71
[ 8043.937665] mt7601u 1-5:1.0: Vendor request req:02 off:0080 failed:-71
[ 8044.104312] mt7601u 1-5:1.0: Vendor request req:02 off:0080 failed:-71
[ 8044.104367] mt7601u: probe of 1-5:1.0 failed with error -110
[ 8044.104641] usb 1-5: USB disconnect, device number 21
[ 8044.360991] usb 1-5: new high-speed USB device number 22 using ehci-pci
[ 8044.518877] usb 1-5: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[ 8044.518881] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8044.518884] usb 1-5: Product: 802.11 n WLAN
[ 8044.518886] usb 1-5: Manufacturer: MediaTek
[ 8044.518888] usb 1-5: SerialNumber: 1.0
[ 8044.647673] usb 1-5: reset high-speed USB device number 22 using ehci-pci
[ 8044.797247] mt7601u 1-5:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 8044.799325] mt7601u 1-5:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
[ 8045.171998] mt7601u 1-5:1.0: EEPROM ver:0d fae:00
[ 8045.341618] mt7601u 1-5:1.0: rx urb failed: -71
[ 8045.342169] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8045.342175] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8045.345867] mt7601u 1-5:1.0: rx urb failed: -71
[ 8045.346302] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8045.346306] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8045.350117] mt7601u 1-5:1.0: rx urb failed: -71
[ 8045.350373] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8045.350378] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8045.354366] mt7601u 1-5:1.0: rx urb failed: -71
[ 8045.354621] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8045.354625] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8045.358615] mt7601u 1-5:1.0: rx urb failed: -71
[ 8045.358871] mt7601u 1-5:1.0: Error: MCU resp urb failed:-71
[ 8045.358874] mt7601u 1-5:1.0: Error: MCU resp evt:0 seq:5-4!
[ 8045.358878] mt7601u 1-5:1.0: Error: mt7601u_mcu_wait_resp timed out
[ 8045.545161] kauditd_printk_skb: 5 callbacks suppressed
[ 8045.545163] audit: type=1101 audit(1604397310.763:220): pid=28463 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting g
[ 8045.545538] audit: type=1110 audit(1604397310.763:221): pid=28463 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantor
[ 8045.545922] audit: type=1105 audit(1604397310.763:222): pid=28463 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open gr
[ 8045.554329] mt7601u 1-5:1.0: Vendor request req:07 off:0080 failed:-71
This might be due to a hardware problem of the USB to parallel port converter or the cable itself inside your case. That will happen indefinitely till you solve it. Also can be due to the way is set in BIOS. Maybe make it to be just USB1.1 instead of USB2 from BIOS settings … Have you tried other ports ?
Also, have you thought of updating the BIOS ?
https://www.msi.com/Motherboard/support/P31_Neo_V2
You have the 2.2 version and there is 2.3 version.
when i disable driver it’s not happening
so idont think it’s about BIOS
and it’s work well on windows 10 in this system
It also happens in other disto
i download driver from mediatek site
But it for old kernels
There is a problem with device, not configuration.
well device works great in windows
