~ sudo pacman -Suy ✔
core is up to date
extra is up to date
community is up to date
multilib is up to date
:: Replace kirigami-addons with extra/kirigami-addons5? [Y/n]
warning: kpeoplevcard: local (0.1+r38.32d50a9-1) is newer than extra (0.1-2)
resolving dependencies...
:: installing kdbusaddons5 (5.111.0-1) breaks dependency 'kdbusaddons' required by fancontrol-gui
:: installing knotifications5 (5.111.0-1) breaks dependency 'knotifications' required by fancontrol-gui
:: installing kdeclarative5 (5.111.0-1) breaks dependency 'kdeclarative' required by fancontrol-gui
:: installing kauth5 (5.111.0-1) breaks dependency 'kauth' required by fancontrol-gui
:: installing kpackage5 (5.111.0-1) breaks dependency 'kpackage' required by fancontrol-gui
:: installing ki18n5 (5.111.0-1) breaks dependency 'ki18n' required by fancontrol-gui
:: installing kconfig5 (5.111.0-1) breaks dependency 'kconfig' required by fancontrol-gui
:: installing kpeople5 (5.111.0-1) breaks dependency 'kpeople' required by kpeoplevcard
:: installing kcontacts5 (5.111.0-1) breaks dependency 'kcontacts' required by kpeoplevcard
:: installing kxmlgui5 (5.111.0-1) breaks dependency 'kxmlgui' required by libkipi
:: installing kservice5 (5.111.0-1) breaks dependency 'kservice' required by libkipi
Remove this package.
pamac remove fancontrol-gui
sudo pacman -R libkipi fancontrol-gui && sudo pacman -Syuu && yay -S libkipi fancontrol-gui
You also haven’t tended to your .pacnew files, because the Community repo was dropped months ago already.
Thank you, it helps. What i need to do with my .pacnew files?
6 posts were split to a new topic: How to merge .pacnew files?
Why are people using/keeping *kipi* ? Is it not deprecated ?
It is, was moved to AUR but is now flagged out-of-date there and should be removed at some point. Nothing uses it any more so having it won’t break anything… at least not until you do something like this ![]()
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
