do you even have working audio:?
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: no
also in the debug logs there was some xauthority issue, so post output from:
find $HOME/ -name ".Xauthority"
/home/edicao/.Xauthority
xauthority can also cause black screens, so remove it:
rm /home/edicao/.Xauthority
reboot
I am sorry, I forgot to mention that you need to install this before running lightdm as normal user:
pamac install xorg-server-xephyr
Then
lightdm --test-mode --debug
It works also in graphical mode (so in xfce). It is a so called nested xserver which runs a xserver as a xapplication.
no switching the Desktop Environment doesnāt change anything, but switching the display-manager would give you an alternativeā¦ The are many of them: Display manager - ArchWiki
It should also noted that if at the BIOS Fastboot is enabled it could have a negative impact like late initialization of the gpu.
Tomorrow Iāll try to be around and do all this. Just to be sure, @megavolt
After installing xorg-server-xephyr,
I reboot and run bash file in tty?
Edit: Luckily I still can enter system with startx.
Yesterday Iāve got the same failed pkgfile database update, but Iāve been entering system with startx.
Today Iāve got
[FAILED] to start Light Display Manager
Sorry, I am tiredā¦ just switch the display-managerā¦
sudo systemctl disable lightdm
pamac install gdm
sudo systemctl enable gdm
reboot
Maybe that works.
Or sddm:
pamac install sddm
sudo systemctl enable sddm
reboot
Obviously only one display-manager (login manager) can be enabled.
It havenāt work.
Will just reinstall manjaro and hope for it not to happen anymore.
Sorry, thank you for help.
