we’re still stuck on this
_
edit:
i have another computer with same manjaro installed, only I don’t use it or update it very often. should I use it for comparing something? any command i could do for comparing?
_
edit:
so chroot again, and run this command:
cat /var/log/pacman.log | grep upgrade
and copy all lines from this date: 2022-08-14
we need to downgrade some more stuff - video drivers and aslo light dm if it was upgraded
edit: no there would be nothing of help in the another computer, it looks like you are affected with the issue mentioned above…
Edit: or you can use this command:
cat /var/log/pacman.log | grep upgrade | grep 2022-08-14
[2022-08-14T16:37:32-0300] [ALPM] upgraded util-linux-libs (2.38-1 -> 2.38.1-1)
[2022-08-14T16:37:32-0300] [ALPM] upgraded libevent (2.1.12-1 -> 2.1.12-2)
[2022-08-14T16:37:32-0300] [ALPM] upgraded apparmor (3.0.6-1 -> 3.0.7-1)
[2022-08-14T16:37:32-0300] [ALPM] upgraded gcab (1.4-2 -> 1.5-1)
[2022-08-14T16:37:32-0300] [ALPM] upgraded systemd-libs (251.3-1 -> 251.4-1)
[2022-08-14T16:37:32-0300] [ALPM] upgraded gdk-pixbuf2 (2.42.8-1 -> 2.42.9-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded libglvnd (1.4.0-2 -> 1.4.0-3)
[2022-08-14T16:37:33-0300] [ALPM] upgraded mesa (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded util-linux (2.38-1 -> 2.38.1-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded sqlite (3.39.1-1 -> 3.39.2-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded nettle (3.8-1 -> 3.8.1-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded gnutls (3.7.6-1 -> 3.7.7-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded glib-networking (1:2.72.1-1 -> 1:2.72.2-1)
[2022-08-14T16:37:33-0300] [ALPM] upgraded tracker3 (3.3.2-1 -> 3.3.3-1)
[2022-08-14T16:37:34-0300] [ALPM] upgraded systemd (251.3-1 -> 251.4-1)
[2022-08-14T16:37:34-0300] [ALPM] upgraded appstream-glib (0.8.0-1 -> 0.8.1-1)
[2022-08-14T16:37:34-0300] [ALPM] upgraded binutils (2.38-7 -> 2.39-2)
[2022-08-14T16:37:34-0300] [ALPM] upgraded bluez (5.64-2 -> 5.65-1)
[2022-08-14T16:37:34-0300] [ALPM] upgraded bluez-libs (5.64-2 -> 5.65-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded cpupower (5.18-1 -> 5.19-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded nspr (4.34-1 -> 4.34.1-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded cups-filters (1.28.15-1 -> 1.28.15-2)
[2022-08-14T16:37:35-0300] [ALPM] upgraded dkms (3.0.5-2 -> 3.0.6-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded double-conversion (3.2.0-1 -> 3.2.1-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded geocode-glib (3.26.3-1 -> 3.26.4-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded gnome-desktop-common (1:42.3-1 -> 1:42.4-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded gnome-desktop (1:42.3-1 -> 1:42.4-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded gnome-desktop-4 (1:42.3-1 -> 1:42.4-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded libwebp (1.2.3-1 -> 1.2.4-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded graphviz (5.0.0-1 -> 5.0.0-2)
[2022-08-14T16:37:35-0300] [ALPM] upgraded gsm (1.0.21-1 -> 1.0.22-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded hwinfo (21.82-1 -> 22.0-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded intel-ucode (20220510-1 -> 20220809-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib2geom (1.2-1 -> 1.2-2)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-mesa (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-libglvnd (1.4.0-2 -> 1.4.0-3)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-libva-mesa-driver (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-mesa-vdpau (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-nspr (4.34-1 -> 4.34.1-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-systemd (251.3-1 -> 251.4-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-util-linux (2.38-1 -> 2.38.1-1)
[2022-08-14T16:37:35-0300] [ALPM] upgraded lib32-vulkan-intel (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded lib32-vulkan-radeon (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libadwaita (1:1.1.3-1 -> 1:1.1.4-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libbluray (1.3.1-1 -> 1.3.2-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libevdev (1.12.1-1 -> 1.13.0-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libimagequant (4.0.0-1 -> 4.0.1-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libnfs (5.0.1-2 -> 5.0.2-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libnm (1.38.2-2 -> 1.38.4-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libva-mesa-driver (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libwacom (2.3.0-1 -> 2.4.0-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded libxcvt (0.1.1-1 -> 0.1.2-1)
[2022-08-14T16:37:36-0300] [ALPM] upgraded lightdm (1:1.30.0-4 -> 1:1.32.0-1)
[2022-08-14T16:37:42-0300] [ALPM] upgraded linux419-headers (4.19.254-2 -> 4.19.255-1)
[2022-08-14T16:37:43-0300] [ALPM] upgraded linux515 (5.15.59-1 -> 5.15.60-1)
[2022-08-14T16:37:58-0300] [ALPM] upgraded linux515-headers (5.15.59-1 -> 5.15.60-1)
[2022-08-14T16:37:58-0300] [ALPM] upgraded luajit (2.1.0.beta3.r431.g5677985d-1 -> 2.1.0.beta3.r439.g633f265f-1)
[2022-08-14T16:37:58-0300] [ALPM] upgraded manjaro-settings-manager (0.5.7-5 -> 0.5.7-6)
[2022-08-14T16:37:58-0300] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.7-5 -> 0.5.7-6)
[2022-08-14T16:37:58-0300] [ALPM] upgraded mesa-vdpau (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:37:58-0300] [ALPM] upgraded mhwd-db (0.6.5-21 -> 0.6.5-22)
[2022-08-14T16:37:59-0300] [ALPM] upgraded mhwd (0.6.5-2 -> 0.6.5-22)
[2022-08-14T16:37:59-0300] [ALPM] upgraded nano (6.3-1 -> 6.4-1)
[2022-08-14T16:38:01-0300] [ALPM] upgraded wpa_supplicant (2:2.10-4 -> 2:2.10-5)
[2022-08-14T16:38:02-0300] [ALPM] upgraded networkmanager (1.38.2-2 -> 1.38.4-1)
[2022-08-14T16:38:41-0300] [ALPM] upgraded papirus-icon-theme (20220710-1 -> 20220808-1)
[2022-08-14T16:38:42-0300] [ALPM] upgraded python-trove-classifiers (2022.7.22-1 -> 2022.8.7-1)
[2022-08-14T16:38:42-0300] [ALPM] upgraded rsync (3.2.4-1 -> 3.2.5pre2-1)
[2022-08-14T16:38:42-0300] [ALPM] upgraded smbclient (4.16.4-2 -> 4.16.4-3)
[2022-08-14T16:38:43-0300] [ALPM] upgraded samba (4.16.4-2 -> 4.16.4-3)
[2022-08-14T16:38:46-0300] [ALPM] upgraded snapd (2.57-2 -> 2.57.1-1)
[2022-08-14T16:38:46-0300] [ALPM] upgraded systemd-sysvcompat (251.3-1 -> 251.4-1)
[2022-08-14T16:38:46-0300] [ALPM] upgraded tlp (1.5.0-4 -> 1.5.0-5)
[2022-08-14T16:38:46-0300] [ALPM] upgraded unzip (6.0-18 -> 6.0-19)
[2022-08-14T16:38:46-0300] [ALPM] upgraded vulkan-intel (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:38:46-0300] [ALPM] upgraded vulkan-radeon (22.1.4-1 -> 22.1.6-1)
[2022-08-14T16:38:46-0300] [ALPM] upgraded wpebackend-fdo (1.12.0-2 -> 1.12.1-1)
[2022-08-14T16:38:48-0300] [ALPM] upgraded webkit2gtk (2.36.5-2 -> 2.36.6-1)
[2022-08-14T16:39:00-0300] [ALPM] upgraded webkit2gtk-4.1 (2.36.5-2 -> 2.36.6-1)
[2022-08-14T16:39:01-0300] [ALPM] upgraded xdg-user-dirs (0.17-3 -> 0.18-1)
[2022-08-14T16:39:01-0300] [ALPM] upgraded xfce4-screenshooter (1.9.10-2 -> 1.9.11-1)
[2022-08-14T16:39:01-0300] [ALPM] upgraded zsh-completions (0.34.0-1 -> 0.34.0-2)
edit:
i only remember changing dkms stuff, the same day i installed kernel-headers for installing v4l2loopback-utils.
edit2:
you see it stills showing:
didn’t we change that a few minutes before?
no we only downgraded the kernel not the headers because of the error, try downgrading it:
pacman -U /var/cache/pacman/pkg/linux515-headers-5.15.59-1-x86_64.pkg.tar.zst
and output from:
pacman -Qs linux419
ls -hl /var/cache/pacman/pkg | grep 2022-08-14
downgrade=done.
1:
local/linux419-headers 4.19.255-1
Header files and scripts for building modules for Linux419 kernel
2:
no output.
ok, so you have installed headers for a non existing kernel, so remove it first:
pacman -R linux419-headers
then post output from:
ls -hl /var/cache/pacman/pkg | grep lightdm
ls -hl /var/cache/pacman/pkg | grep mesa
kernel=removed.
-rw-r--r-- 1 root root 240K Aug 11 11:01 lightdm-1:1.32.0-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 566 Aug 11 11:01 lightdm-1:1.32.0-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 90K Mar 6 15:28 lightdm-gtk-greeter-1:2.0.8-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Mar 6 15:28 lightdm-gtk-greeter-1:2.0.8-2-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 161K Dec 12 2021 lightdm-gtk-greeter-settings-1.2.2-7-any.pkg.tar.zst
-rw-r--r-- 1 root root 566 Dec 12 2021 lightdm-gtk-greeter-settings-1.2.2-7-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.3M Jul 27 14:40 lib32-libva-mesa-driver-22.1.4-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 141 Jul 27 14:40 lib32-libva-mesa-driver-22.1.4-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.3M Aug 11 11:01 lib32-libva-mesa-driver-22.1.6-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Aug 11 11:01 lib32-libva-mesa-driver-22.1.6-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 12M Jul 27 14:40 lib32-mesa-22.1.4-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 141 Jul 27 14:40 lib32-mesa-22.1.4-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 12M Aug 11 11:01 lib32-mesa-22.1.6-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Aug 11 11:01 lib32-mesa-22.1.6-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.5M Jul 21 05:53 lib32-mesa-vdpau-22.1.3-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 3.5M Jul 27 14:40 lib32-mesa-vdpau-22.1.4-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 141 Jul 27 14:40 lib32-mesa-vdpau-22.1.4-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.5M Aug 11 11:01 lib32-mesa-vdpau-22.1.6-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Aug 11 11:01 lib32-mesa-vdpau-22.1.6-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.2M Jul 27 14:40 libva-mesa-driver-22.1.4-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 141 Jul 27 14:40 libva-mesa-driver-22.1.4-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.2M Aug 11 11:01 libva-mesa-driver-22.1.6-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Aug 11 11:01 libva-mesa-driver-22.1.6-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 13M Jul 27 14:40 mesa-22.1.4-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 141 Jul 27 14:40 mesa-22.1.4-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 13M Aug 11 11:01 mesa-22.1.6-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Aug 11 11:01 mesa-22.1.6-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.4M Jul 21 05:53 mesa-vdpau-22.1.3-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 3.4M Jul 27 14:40 mesa-vdpau-22.1.4-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 141 Jul 27 14:40 mesa-vdpau-22.1.4-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root 3.3M Aug 11 11:01 mesa-vdpau-22.1.6-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root 310 Aug 11 11:01 mesa-vdpau-22.1.6-1-x86_64.pkg.tar.zst.sig
there is no longer a package to downgrade the lightdm, so downgrade this:
pacman -U /var/cache/pacman/pkg/lib32-libva-mesa-driver-22.1.4-1-x86_64.pkg.tar.zst
pacman -U /var/cache/pacman/pkg/lib32-mesa-22.1.4-1-x86_64.pkg.tar.zst
pacman -U /var/cache/pacman/pkg/lib32-mesa-vdpau-22.1.4-1-x86_64.pkg.tar.zst
pacman -U /var/cache/pacman/pkg/libva-mesa-driver-22.1.4-1-x86_64.pkg.tar.zst
pacman -U /var/cache/pacman/pkg/mesa-22.1.4-1-x86_64.pkg.tar.zst
pacman -U /var/cache/pacman/pkg/mesa-vdpau-22.1.4-1-x86_64.pkg.tar.zst
any error post here
if there are none, reboot and hopefully it will work
hopefully i’m answering you from my system.
so what happened? how could i previne myself from seeing it happening again?
i presume i couldn’t install that kernel-headers again, am i right?
edit:
i just opened obs and it seems i still have obs virtual camera enabled, so that’s good.
in a couple minutes ill be back if theres anything else we should be doing.
thank you for all help.
first check if it even worked …
theres really nothing you can do, since its linux/manjaro thing
and you have installed the 5.15 kernel headers, we just downgraded them, and removed the 4.19 headers since you dont have the 4.19 kernel …
if this worked, then you can normally use your system, and hopefully with the next update, the issue will be resolved
So when I could turn on computer we had a lot of work to do, so I didn’t came here anymore. Everything was running ok, before yesterday when I turned on OBS virtual camera and then turned off computer, the same thing happened. Will try now to do that same commands again.
update: it didn’t work this time.
should I be doing everything again?
edit: I did all downgrade commands and it didn’t help.
you need to downrgade also the kernel + headers:
pacman -U /var/cache/pacman/pkg/linux515-5.15.59-1-x86_64.pkg.tar.zst
and dont run update, thats the reason why it happened again, it updated these packages that we downgraded … wait for the next system update, until then dont update them …
how have i update them? i don’t remember doing such thing
well if downgrading them works, then there was a update …
post output from:
cat /var/log/pacman.log |grep upgraded|grep linux515|tail -5
[2022-08-08T07:23:08-0300] [ALPM] upgraded linux515 (5.15.55-1 -> 5.15.59-1)
[2022-08-22T09:39:56-0300] [ALPM] upgraded linux515 (5.15.59-1 -> 5.15.60-1)
[2022-08-22T09:40:00-0300] [ALPM] upgraded linux515-headers (5.15.59-1 -> 5.15.60-1)
the kernel and headers were updated on: 2022-08-22T09:39:56
so downgrading them again with the video drivers should fix it
did you run all of these commands from chroot:
were there any errors?
(1/1) reinstalling linux515-headers [######################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Install DKMS modules
==> dkms install --no-depmod v4l2loopback/0.12.5 -k 5.15.59-1-MANJARO
Deprecated feature: REMAKE_INITRD
==> depmod 5.15.59-1-MANJARO
