Problem with reading AUR data after fresh install
Hey, new here. so, basically I have a really weird error after installing manjaro in my laltop a few days ago.The problem is as follows:Every time i want to install a package using yay, or pacman, I get an error saying (for example): → Error al buscar en AUR: 1 error occurred:* request failed: Get “https://aur.archlinux.org/rpc?arg=davinci-reolve&by=name-desc&type=search&v=5”: read tcp 192.168.1.47:37126->157.180.70.58:443: read: connection reset by peer
Wich is really throwing me off, because i updated the signatures, im using mirrors in my country (closest), and i have updated my system just yesterday.
Thanks for the support.
According to status.archlinux.org, the AUR is currently down. This is most likely due to the ongoing denial of service attack that Arch has been experiencing for the past couple of months:
DAMN
No wonder it has not been working since yesterday.
So, its a game of waiting now, i guess.
Thanks.
AUR has no connection to the system as you describe in the above quote.
Access to AUR is a courtesy of Arch Linux - and the service may or may not be available depending on maintenance or ongoing DoS or DDoS attacks on the Arch Linux infrastructure.
pamac can build custom scripts - such as those available via AUR - even given that - custom scripts are unsupported whether you build using pamac or any other AUR-helper.
AUR is Arch User Repository and may cause issues with your Manjaro installation - especially if you are using stable branch; regarding issues, testing and unstable branch are more forgiving.
Its fine, i checked.
The problem, as scotty65 described, its that it is currently under a DDOS attack. So, nothing wrong on my end. Thanks a lot :slight_smile:
