Problem with programs like qbittorrent and calibre after the last update
After the last update I have a strange problem with programs like qbittorrent and calibre. The applications launch, but the gui does not display. I don’t know too much what is the cause…
Hey, both are qt based programs. Have you tried launcing them from the terminal? If so, could you give us the logs and we might be able to help you with your problem.
Hi! Yes I tried to launch them from terminal but with no success. Which logs from where should I provide…? Sorry, I’m a newbe.
journalctl --since=today
:heavy_check_mark:
kwi 18 07:33:21 manjaro kernel: Freezing user space processes
kwi 18 07:33:21 manjaro kernel: Freezing user space processes completed (elapsed 0.002 seconds)
kwi 18 07:33:21 manjaro kernel: OOM killer disabled.
kwi 18 07:33:21 manjaro kernel: Freezing remaining freezable tasks
kwi 18 07:33:21 manjaro kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
kwi 18 07:33:21 manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
kwi 18 07:33:21 manjaro kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
kwi 18 07:33:21 manjaro kernel: ata1.00: Entering standby power mode
kwi 18 07:33:21 manjaro kernel: [drm] PCIE gen 2 link speeds already enabled
kwi 18 07:33:21 manjaro kernel: [drm] PCIE GART of 2048M enabled (table at 0x00000000001D6000).
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: WB enabled
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 6 use gpu addr 0x0000000080000c18
kwi 18 07:33:21 manjaro kernel: radeon 0000:03:00.0: fence driver on ring 7 use gpu addr 0x0000000080000c1c
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 0 succeeded in 1 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 1 succeeded in 1 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 2 succeeded in 1 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 3 succeeded in 11 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 4 succeeded in 4 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 5 succeeded in 2 usecs
kwi 18 07:33:21 manjaro kernel: [drm] UVD initialized successfully.
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 6 succeeded in 9 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ring test on 7 succeeded in 3 usecs
kwi 18 07:33:21 manjaro kernel: [drm] VCE initialized successfully.
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 0 succeeded in 0 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 1 succeeded in 0 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 2 succeeded in 0 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 3 succeeded in 0 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 4 succeeded in 0 usecs
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 5 succeeded
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 6 succeeded
kwi 18 07:33:21 manjaro kernel: [drm] ib test on ring 7 succeeded
kwi 18 07:33:21 manjaro kernel: ACPI: EC: interrupt blocked
kwi 18 07:33:21 manjaro kernel: ACPI: PM: Preparing to enter system sleep state S3
nxi --full --admin --filter --width  :heavy_check_mark:
  Kernel: 6.8.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.8-x86_64
    root=UUID=b0b94358-4179-4244-a5e2-5a977514c3cc rw rootflags=subvol=@ quiet
    cryptdevice=UUID=f27ada98-0e72-4262-908d-cd99ff896ba9:luks-f27ada98-0e72-4262-908d-cd99ff896ba9
    root=/dev/mapper/luks-f27ada98-0e72-4262-908d-cd99ff896ba9 splash
  Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
  Type: Portable System: Dell product: Inspiron 5537 v: A12
    serial: <superuser required> Chassis: type: 8 v: A12
  Mobo: Dell model: 03MV2R v: A00 serial: <superuser required>
    part-nu: Inspiron 5537 uuid: <superuser required> UEFI-[Legacy]: Dell v: A12
    date: 05/27/2019
  ID-1: BAT1 charge: 64.6 Wh (100.0%) condition: 64.6/75.5 Wh (85.5%)
    volts: 12.4 min: 11.1 model: LGC DELL 49VTP27J type: Li-ion serial: <filter>
    status: full
  Info: model: Intel Core i5-4200U bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1397 high: 1597 min/max: 800/2600 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 1596 3: 1596
    4: 1597 bogomips: 18360
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
  Device-2: AMD Venus PRO [Radeon HD 8850M / R9 M265X] vendor: Dell
    driver: radeon v: kernel alternate: amdgpu arch: GCN-1 code: Southern Islands
    process: TSMC 28nm built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.0 chip-ID: 1002:6823
    class-ID: 0300 temp: 50.0 C
  Device-3: Realtek Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.8:6 chip-ID: 0bda:58c2
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: X: loaded: modesetting,radeon unloaded: vesa
    alternate: fbdev dri: crocus,radeonsi gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: AU Optronics 0x45ec built: 2011 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus drv: amd radeonsi platforms:
    device: 0 drv: radeonsi device: 1 drv: crocus device: 2 drv: swrast
    surfaceless: drv: radeonsi wayland: drv: crocus x11: drv: crocus
    inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
    device-ID: 8086:0a16 memory: 1.46 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4400 (HSW GT2) driver: mesa intel v: 24.0.5-manjaro1.1
    device-ID: 8086:0a16 surfaces: xcb,xlib,wayland
  Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  API: ALSA v: k6.8.6-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.4 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
    bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
    vendor: Dell driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
  Device-1: Qualcomm Atheros AR9462 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.5:31
    chip-ID: 0cf3:0036 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 7 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 583.07 GiB (62.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 033 scheme: MBR
  ID-1: / raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 583.07 GiB (62.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-f27ada98-0e72-4262-908d-cd99ff896ba9
  ID-2: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
  ID-3: /var/log raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 501.3 MiB (97.9%) priority: -2
    file: /swap/swapfile
  System Temperatures: cpu: 52.0 C mobo: 42.0 C gpu: radeon temp: 50.0 C
  Fan Speeds (rpm): cpu: 2600
  Memory: total: 16 GiB available: 15.51 GiB used: 6.44 GiB (41.5%)
  Processes: 289 Power: uptime: 2d 23h 22m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 6 fails: 2 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.19 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 255
  Packages: 1766 pm: pacman pkgs: 1718 libs: 468
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 32 pm: snap pkgs: 16
    Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.34
Same as maybe?
