After an upgrade, calibre doesn’t crash but is invisible.
Was it complete?
sudo pacman -Syu
Is calibre the repo version?
pacman -Qs calibre
Maybe the terminal produces clues?
calibre
Yes it was.
Yes:
local/calibre 7.8.0-2
BTW, I’m using the testing channel.
Running calibre
produces no output in the terminal.
Maybe check gnome-extensions?
They can be a source of confusing behavior.
Well lets do the system info thing ;
inxi -Farz
I have just run pacman -Syyu
to make sure everything is up to date.
This is the output of inxi -Farz
Kernel: 6.6.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=[redacted] rw quiet
cryptdevice=UUID=[redacted]:luks-[redacted]
root=/dev/mapper/luks-[redacted] splash
Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 21AHCTO1WW v: ThinkPad T14 Gen 3
Mobo: LENOVO model: 21AHCTO1WW serial: <superuser required>
part-nu: LENOVO_MT_21AH_BU_Think_FM_ThinkPad T14 Gen 3
uuid: <superuser required> UEFI: LENOVO v: N3MET16W (1.15 )
date: 06/25/2023
ID-1: BAT0 charge: 53.0 Wh (100.0%) condition: 53.0/52.5 Wh (101.0%)
volts: 17.2 min: 15.5 model: Sunwoda 5B10W51867 type: Li-poly
serial: <filter> status: full cycles: 136
Info: model: 12th Gen Intel Core i7-1270P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x432
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 880 high: 3183 min/max: 400/4800:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1436 2: 400 3: 638 4: 400
5: 1935 6: 400 7: 3183 8: 400 9: 400 10: 400 11: 400 12: 2500 13: 400
14: 400 15: 400 16: 400 bogomips: 79888
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: HDMI-A-1 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: Bison Integrated RGB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 5986:2142
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) HDR 4K serial: <filter>
built: 2020 res: 3840x2160 dpi: 163 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
Monitor-2: eDP-1 model: AU Optronics 0xd291 built: 2020 res: 1920x1200
dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: 1920x1200
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 30.33 GiB unified: yes display-ID: :0.0
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.6.28-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: br-4655404f0d09 state: down mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: veth4b2ff40 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: vethef3a73f state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
class-ID: e001
Local Storage: total: 2.29 TiB used: 1.61 TiB (70.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA512TFH
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0002P7LN temp: 41.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0708 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 372.32 GiB (79.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3b0f96f9-124f-4a61-b2e4-756ee1ed8907
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1574 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 51 libs: 10 pm: pacman pkgs: 1523 libs: 403
tools: gnome-software,pamac pm: flatpak pkgs: 0
1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/testing/$repo/$arch
2: https://mirrors.xtom.de/manjaro/testing/$repo/$arch
3: https://mirror.23m.com/manjaro/testing/$repo/$arch
4: https://ftp.gwdg.de/pub/linux/manjaro/testing/$repo/$arch
5: https://ftp.halifax.rwth-aachen.de/manjaro/testing/$repo/$arch
6: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
7: https://mirror.netcologne.de/manjaro/testing/$repo/$arch
Active nix channels for user: manu
1: nixpkgs https://nixos.org/channels/nixpkgs-unstable
Memory: total: 32 GiB note: est. available: 31.06 GiB used: 7.88 GiB (25.4%)
Processes: 417 Power: uptime: 18m states: freeze,mem,disk suspend: s2idle
image: 12.41 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 running-in: guake
inxi: 3.3.34
I’m running Calibre 7.9.0 on Plasma 6.0.4/Wayland, and it works fine.
If you have CALIBRE_USE_SYSTEM_THEME
try to remove it from your environment. This will force Calibre to you its built-in Qt theme instead of searching for external one.
Why are you adding that foreign repo to Manjaro?
I want to be able to test nix
I haven’t set that AFAIK. Running
env | grep CALIBRE_USE_SYSTEM_THEME
returns nothing.
Today I ran sudo pacman -Syyu
and after restarting I have calibre back.
Please only use:
sudo pacman -Syu
…when performing an update (Notice, there should only be one y
). Using -Syyu
as you have been consistently demonstrating, is incorrect, and potentially damaging.
Cheers.
