Problem with prime-run
Hello! I installed video-hybrid-intel-nvidia-prime and I cannot use prime-run to run applications with my nvidia graphic card. xrandr --listproviders also list only one provider.
prime-run glxinfo | grep "OpenGL"
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  152 (GLX)
  Minor opcode of failed request:  24 (X_GLXCreateNewContext)
  Value in failed request:  0x0
  Serial number of failed request:  39
  Current serial number in output stream:  40
Providers: number : 1
Provider 0: id: 0x49 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 7 associated providers: 0 name:modesetting
mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2020.11.30               false            PCI
nvidia-smi
Sun Mar 21 19:44:12 2021
| NVIDIA-SMI 460.56       Driver Version: 460.56       CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Quadro T2000        Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   37C    P0     7W /  N/A |      0MiB /  3914MiB |      0%      Default |
|                               |                      |                  N/A |
inxi -G
  Device-1: Intel UHD Graphics 630 driver: i915 v: kernel
  Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] driver: nvidia
lsmod |grep nvidia
nvidia_modeset       1232896  0
nvidia_uvm           1175552  0
nvidia              34181120  2 nvidia_uvm,nvidia_modeset
For me it shows:
lsmod |grep nvidia
nvidia_drm             65536  2
nvidia_modeset       1232896  3 nvidia_drm
nvidia              34185216  98 nvidia_modeset
drm_kms_helper        282624  2 nvidia_drm,i915
drm                   581632  22 drm_kms_helper,nvidia_drm,i915
Seems like you are either missing some nvidia packages or maybe some configs. Try to uninstall and install it again using mhwd via tty, then reboot.
Did you use mhwd to install the drivers for the first time?
Please post the full output of inxi -G, and furthermore the latest Xorg log file (which is either in /var/log/ or ~/.local/share/xorg/).
inxi -G
  v: 460.56
  Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  Device-4: Sunplus Innovation Aukey-PC-LM1E Camera type: USB
  driver: snd-usb-audio,uvcvideo
  Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting
  resolution: 1: 1080x1920 2: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
  v: 4.6 Mesa 20.3.4
It seems that I cannot post .txt file, do you need the output of cat Xorg.0.log? (it is very long)
edit : ok I didn’t know about pastebin services. But I am a new account and thus cannot paste link. h t t p : / / ix . io / 2TIE
and thank you for your help :slight_smile:
I did the installation via gui “Hardware Configuration” of KDE, I clicked on Auto Install Proprietary Driver and I think it auto installed video-hybrid.
But yes ok let me try.
Edit : So I uninstalled the driver (sudo mhwd -r pci video-hybrid-intel-nvidia-prime) and successfully reinstalled it (sudo mhwd -i pci video-hybrid-intel-nvidia-prime) then reboot, but it still outputs the same error :
And additionally the output of lsmod | grep nvidia is now empty :sweat_smile:
There’s nothing saying “NVIDIA” in the logs, so there might be some misconfiguration. Please post the output of head -n 999 /etc/X11/xorg.conf.d/* /etc/X11/xorg.conf.
==> /etc/X11/xorg.conf.d/00-keyboard.conf <==
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "ch"
        Option "XkbModel" "pc105"
        Option "XkbVariant" "fr"
EndSection
==> /etc/X11/xorg.conf.d/10-optimus-manager.conf <==
Section "Device"
        Identifier "integrated"
        Driver "modesetting"
        BusID "PCI:0:2:0"
        Option "DRI" "3"
EndSection
==> /etc/X11/xorg.conf.d/30-touchpad.conf <==
    Identifier "touchpad"
    Driver "libinput"
    MatchIsTouchpad "on"
    Option "Tapping" "on"
EndSection
==> /etc/X11/xorg.conf.d/90-mhwd.conf.bak <==
Section "ServerLayout"
  Identifier "layout"
  Screen 0 "intel"
  Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
  Identifier "intel"
  BusID "PCI:0:2:0"
EndSection
Section "Screen"
  Identifier "intel"
  Device "intel"
EndSection
Section "Device"
  Identifier "nvidia"
  Driver "nvidia"
  BusID "PCI:1:0:0"
  Option "AllowEmptyInitialConfiguration"
EndSection
head: cannot open '/etc/X11/xorg.conf' for reading: No such file or directory
I don’t have a xorg.conf file in my X11 directory :confused:
cd /etc/X11 && ls -a
.  ..  mhwd.d  xinit  xorg.conf.d
You have optimus-manager? If so, then you need to switch to “hybrid” mode for prime-run to work.
@whitecastle
Looks like optimus-manager has renamed:
you use this one:
10 has a higher priority than 90 and therefore it uses the 10-optimus-manager.conf, but there is no nvidia gpu written, but in 90-mhwd.conf.bak… do you see it?
Ok I see! Yes I didn’t remember I have optimus-manager. And Indeed I cannot switch to hybrid mode directly
optimus-manager --switch hybrid
ERROR: a GPU setup was initiated but Xorg post-start hook did not run.
Log at /var/log/optimus-manager/switch/switch-20210322T094629.log
If your login manager is GDM, make sure to follow those instructions:
https://github.com/Askannz/optimus-manager#important--gnome-and-gdm-users
If your display manager is neither GDM, SDDM nor LightDM, or if you don't use one, read the wiki:
https://github.com/Askannz/optimus-manager/wiki/FAQ,-common-issues,-troubleshooting
Cannot execute command because of previous errors.
Should I remove optimus-manager then? Or modify 10-optimus-manager.conf?
Run prime-offload and try again.
It didn’t work
What’s in /etc/optimus-manager/optimus-manager.conf?
there is no optimus-manager.conf in /etc/optimus-manager/
ls -a /etc/optimus-manager/
.   nvidia-disable.sh  xorg              xsetup-integrated.sh
..  nvidia-enable.sh   xsetup-hybrid.sh  xsetup-nvidia.sh
Do you get any output when you run prime-offload?
prime-offload
[5] INFO: # Xorg post-start hook
[1180] INFO: Running /etc/optimus-manager/xsetup-integrated.sh
[1196] INFO: Writing state {'type': 'done', 'switch_id': '20210322T094629', 'current_mode': 'integrated'}
[1197] INFO: Xorg post-start hook completed successfully.
And when you run optimus-manager --switch hybrid you get the exact same error?
Oh yes I am able to switch now
WARNING : no power management option is currently enabled (this is the default since v1.2). Switching between GPUs will work but you will likely experience poor battery life.
Follow instructions at https://github.com/Askannz/optimus-manager/wiki/A-guide--to-power-management-options to enable power management.
You are about to switch GPUs. This will forcibly close all graphical sessions and all your applications WILL CLOSE.
(you can pass the --no-confirm option to disable this warning)
Continue ? (y/N)
So I switched but now the display is like super slow on my external monitor
