Hello everyone.
Im new to linux ecosystem.
Nvidia GPU is N / A, but the driver is installed I guess.
Any advices?
inxi -G
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GK107M [GeForce GT 750M] driver: N / A
mhwd -li
Installed PCI configs:
video-hybrid-intel-nvidia-390xx-bumblebee 2020.11.30 false PCI
Kernel: Linux 5.10.53-1-MANJARO
Hello,
Can you post full inxi -Gazy ??
I think N/A means that its not installed.
Unfortunately I also have Nvidia.
I do (did) like that to have my Nvidia running correctly:
I changed kernel 5.10 to 5.13 using the system settings and rebooted the machine.
Then I installed the linux513-headers and linux513-nvidia.
If the package nvidia-utils is not installed automatically, you can install it.
And reboot the machine again.
Observation: It is NOT mandatory change kernels, so if you prefer kernel 5.10, install linux510-headers and linux510-nvidia. Ok?
I’ve done like that and nothing happened.
Can you show the out of these commands?:
uname -r
mhwd -li
pamac search -i "^linux"
uname or mhwd commands are displayed in topic(first message)
pamac search -i “^linux”
linux-firmware 20210719.r1990.168452e-1 core
Firmware files for Linux (Manjaro
Overlay Package)
linux-api-headers 5.12.3-1 core
Kernel headers sanitized for use in
userspace
linux510-nvidia-390xx 390.144-2 extra
NVIDIA drivers for linux.
linux510-headers 5.10.53-1 core
Header files and scripts for building
modules for Linux510 kernel
linux510-bbswitch 0.8-69 extra
kernel module allowing to switch
dedicated graphics card on Optimus
laptops
linux510 5.10.53-1 core
The Linux510 kernel and modules
cpupower 5.13-1 community
Linux kernel tool to examine and tune
power saving related features of your
processor
My maaann
@rescue88, you are clearly hiding some of the output from the inxi -Gazy. I don’t know why, but you are, hence is harder to help you.
So here is mine and you compare with yours, so you can have a clear picture of what is going on.
$ inxi -Gazy
Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: NVIDIA GT216M [GeForce GT 325M] vendor: ASUSTeK driver: nvidia
v: 340.108 alternate: nouveau bus-ID: 01:00.0 chip-ID: 10de:0a35
class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS-1-1 res: 1600x900 hz: 60 dpi: 106
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: GeForce GT 325M/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
direct render: Yes
I use different setup than yours, but you can compare nevertheless.
Pay attention to Device-2 driver and v:. Mine is 340.108, yours should be 390.xx
My suggestion is to reinstall the driver, rather the package. The easiest way should be through mhwd. You can find a lot of posts on how to do that. Good luck
Cheers…
Yes, im hiding unnecessary info, because my monitor drivers and other things does not matter at all i guess.
Ive tried to install via
mhwd -a pci nonfree 0300
Or manually via
mhwd -i pci nvidia-hybrid bla bla bla
But something goes wrong and driver still N / A. I do reinstall more and more, but no results.
On my main PC all was OK, drivers set automatically, but laptop is unlucky one.
Maybe i should try another versions, but, for example, for me smth like 418xx or others not exists (nvidia official website finds 418.* version the best for my gpu).
Daft question but did you reboot after installing the drivers? What does it say when you use mhwd to install the drivers,it should give you an error message if it fails
ofc i do reboot after all the manipulations)
If i try to install other drivers(like guys in other topics as well), getting this error:
Error: config ‘video-hybrid-intel-nvidia-390xx-prime’ does not exist!
Is there any way to list all available driver versions for me to install ?
The 390 prime driver doesn’t exist, if you are installing 390 from the repos it’s video-hybrid-intel-nvidia-390xx-bumblebee
I’m definitely no expert on this, hopefully someone more knowledgeable can confirm
Yeah, this one installs by default or with:
Still N / A with output of
inxi -G
I can’t find package with 418.xx for linux, so your best bet would 390.xx.
Have you tried to use nvidia-390xx-dkms ?? from AUR ?? and only use nvidia as primary driver no bumblebee and the other stuff (just to see if it works).
Oh… and
Can sometimes matter.
I hope someone more knowledgeable can help you solve this.
EDIT See this page in case you haven’t. Configure_Graphics_Cards-Manjaro
I’ve never used bumblebee only prime but if you launch
primusrun glxgears -info
Do you get anything or if you use primusrun to launch anything does anything happen
Few minutes ago i’ve installed video-nvidia and it worked, replaced N / A with v470.*, but… It seems incompatible with my devices, so the system wasnt able to start. Instead i got into terminal via Ctrl+Alt+F2 and deleted it
I know it’s a silly question, but does inxi show a driver for both graphic cards, or only for the active one?
Yeah, i see the picture with 3 bolts with infinite spinning.
The output is
GL_RENDERER = GeForce GT 750M/PCIe/SSE2
GL_VERSION = 4.6.0 NVIDIA 390.144
GL_VENDOR = NVIDIA Corporation
And GL_EXTENSIONS which are not readable.
Here is the text at the end:
301 frames in 5.0 seconds = 60.092 FPS
301 frames in 5.0 seconds = 60.102 FPS
301 frames in 5.0 seconds = 60.093 FPS
301 frames in 5.0 seconds = 60.096 FPS
301 frames in 5.0 seconds = 60.100 FPS
301 frames in 5.0 seconds = 60.095 FPS
301 frames in 5.0 seconds = 60.097 FPS
301 frames in 5.0 seconds = 60.099 FPS
301 frames in 5.0 seconds = 60.094 FPS
301 frames in 5.0 seconds = 60.098 FPS
The only version that should run is 390 or nouveau. Other won’t work.
EDIT Wow… This is strange.
According to this nvidia is working…
It should show for both. Device 1 and Device 2. The active one is shown in display and renderer, I guess.
Take a look at mine above
in eralier post.
