Still have unknown renderer via inxi -Gazy
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.1.5 compat-v: 3.0 direct render: Yes
I guess its because you are using hybrid, so the renderer is the Mesa DRI Intel HDā¦
Not sure though
I use only nvidia, no other stuff. Thatās why mine shows nvidia.
But, again to why your Device 2 doesnāt show the driver .
I think it should show at least the v: and the driver could show something like hybrid or bumblebee
or whatever along those lines.
Yeah, thats weird, so i decided to search an answer here. Similar topics wonāt help me
Maybe i should read smth about how to switch between gpu devicesā¦
Finally, nvidia-390xx-dkms is the solution, thanks. Now i got 390.** driver for GPU device #2 displaying via
inxi -G
All works fine as well. To change OpenGL renderer is enough to install optimus-manager from AUR and set nvidia using
optimus-manager --switch nvidia
One more time thanks !
No problem . Iām glad you solved it.
Cheersā¦
Ok, here is the best solution for me.
Ive installed 470.* drivers via AUR and inxi -G displayed the same: device #2 driver: N/A.
BUT!
If you switch into nvidia via
All drivers will be displayed correctly. So maybe the default driver, which installs by:
mhwd -a pci nonfree 0300
would work too, who knows(in my case its nvidia-intel-hybridā¦390xx-bumblebee, smth like that).
