Hello guys, I recently had a popup telling me update packages are available. When the update is done, manjaro boot and stuck in black screen. i’ve launch majaro onto live usb and deleted the nvidia driver. Now my system boot to UI normally but when I want to install the proprietary driver again I get this error
Starting
> Using config 'video-nvidia' for device: 0000:24:00.0 (0300:10de:2507) Display controller nVidia Corporation
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
multilib downloading...
error: target not found: linux65-nvidia
Error: pacman failed!
Error: script failed!
Done ...
i have type inxi -Fxxxza in my terminal i had this output below. even noticed that nvidia graphic is missing
Kernel: 6.5.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=878bbf98-39b2-4ac3-a6bb-1274cf127f23 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: docker wm: kwin_x11
vt: 2 dm: SDDM Distro: Arch Linux
Type: Desktop System: Megaport product: Stallion v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: A520M-A PRO (MS-7C96) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.B0
date: 08/11/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2328 high: 3472 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2191 2: 2302
3: 2375 4: 2218 5: 2194 6: 2194 7: 3472 8: 2188 9: 2195 10: 2203 11: 2193
12: 2212 bogomips: 88830
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
cool someone help me?
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
brahma
22 November 2023 11:28
2
use formatting for the outputs, click this icon in editor </>
and copy the output there;
or use:
your output here
or:
your output here
post output from:
inxi -zav7
mhwd -l -li
Hello here are my outputs
inxi -zav7 ✔
udev.log_priority=3
date: 08/11/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 10.99 GiB (35.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Speed (MHz): avg: 2246 high: 2520 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2199 2: 2198
3: 2443 4: 2199 5: 2200 6: 2520 7: 2198 8: 2200 9: 2200 10: 2200 11: 2199
12: 2198 bogomips: 88830
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
mhwd -l -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
> 0000:24:00.0 (0300:10de:2507) Display controller nVidia Corporation:
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-vesa 2017.03.12 true PCI
> 0000:22:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
cscs
22 November 2023 11:53
5
It appears you are having trouble sharing the full output;
inxi -Fazy | curl -F 'file=@-' https://0x0.st
(share link)
I don’t understand what you are referring to, could you clarify please?
cscs
22 November 2023 12:01
7
Your inxi output is incomplete.
The command above will send it to a pastebin and give you a link.
The command you gave me doesn’t do anything in the terminal
alose whent typing the command inxi -Fazyn only, this is all i get. the graphics is missing
inxi -Fazy ✔
udev.log_priority=3
date: 08/11/2022
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2381 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2879 bogomips: 88830
cscs
22 November 2023 12:08
10
I think you are not scrolling or something.
There should be more output. (gpu, memory, swap, blah blah blah)
But instead of trying to fight about that … please just run the command above and share the link it creates.
cscs
22 November 2023 12:22
12
So you copy the command above, paste it into terminal, hit enter, and it responds with a link to the host domain (not something like https://0x0.st/zXt4.txt )?
I find that surprising.
Sorry for the confusion, but the command does nothing and does not respond with a link to the host domain
The command:
… should redirect the output to that website, which should automatically open in your default web browser; the resulting page contains your system information.
The link requested, was the link to the page that (in theory) opened, after performing the command. I hope this helps.
In the meantime, you might like to paste the output from:
… which should contain all info needed.
cscs
22 November 2023 12:30
15
Well, it works here.
And I know that all variants of inxi
shared here will reliably produce much more output than what you show ending with cpu vulnerability status.
So far your ‘nvidia graphic is missing from inxi’ because you simply arent seeing the whole inxi.
And we cant seem to get you to share it.
Though, according to your mhwd
output, it is true you do not have any nvidia driver installed. It should still be visible. But your inxi snippets dont show any gpu information at all. Because its cut off.
For now you have this problem:
Which should not be a problem, because that package does exist.
Okay, thank you for the info. I’m a newbie in linux
And how can I fix that, please?
cscs
22 November 2023 12:33
18
Start by mirrors and updates;
sudo pacman-mirrors -f && sudo pacman -Syu
okay, I’ve launched the command
here is the output
sudo pacman-mirrors -f && sudo pacman -Syu ✔
[sudo] password for mrrobot:
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.082 Belgium : https://mirror.futureweb.be/manjaro/
1.100 Iran : https://repo.iut.ac.ir/repo/manjaro/
0.178 Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
2.876 Brazil : https://mirror.ufam.edu.br/manjaro/
0.297 Bulgaria : https://mirrors.netix.net/manjaro/
0.124 Switzerland : https://mirror.init7.net/manjaro/
..... Taiwan : http://free.nchc.org.tw/manjaro/
0.334 India : https://mirror.albony.xyz/manjaro/
0.616 Georgia : https://repos.silknet.com/manjaro/
0.260 Czechia : https://mirror.dkm.cz/manjaro/
1.695 Taiwan : https://mirror.archlinux.tw/Manjaro/
2.784 China : https://mirrors.pku.edu.cn/manjaro/
0.203 Belgium : http://ftp.belnet.be/mirrors/manjaro/repos/
1.305 Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/
0.951 Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
0.842 United_States : http://mirror.fcix.net/manjaro/
1.699 Chile : https://mirror1.cl.netactuate.com/manjaro/
0.380 Russia : https://mirror.yandex.ru/mirrors/manjaro/
1.841 South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/
0.261 Finland : https://manjaro.kyberorg.fi/
..... Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
0.849 United_States : https://southfront.mm.fcix.net/manjaro/
0.936 United_States : https://codingflyboy.mm.fcix.net/manjaro/
2.399 Uruguay : https://manjaro.repo.cure.edu.uy/
0.480 Portugal : http://ftp.dei.uc.pt/pub/linux/manjaro/
0.327 Germany : http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/
1.289 Singapore : http://ossmirror.mycloud.services/os/linux/manjaro/
1.057 United_States : https://repo.ialab.dsu.edu/manjaro/
0.908 Canada : https://mirror.csclub.uwaterloo.ca/manjaro/
3.384 China : https://mirrors.ustc.edu.cn/manjaro/
0.733 United_States : https://volico.mm.fcix.net/manjaro/
1.412 China : https://mirror.nyist.edu.cn/manjaro/
0.553 United_States : https://nnenix.mm.fcix.net/manjaro/
0.124 United_Kingdom : http://manjaro.mirrors.uk2.net/
0.495 Italy : https://ct.mirror.garr.it/mirrors/manjaro/
0.236 Italy : https://manjaro.mirror.garr.it/manjaro/
0.084 Netherlands : http://ftp.snt.utwente.nl/pub/linux/manjaro/
0.271 Ukraine : https://fastmirror.pp.ua/manjaro/
0.568 United_States : https://coresite.mm.fcix.net/manjaro/
0.612 United_States : https://mirror.math.princeton.edu/pub/manjaro/
0.261 Poland : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/
1.743 Brazil : https://linorg.usp.br/manjaro/
0.688 United_States : https://mnvoip.mm.fcix.net/manjaro/
0.105 Germany : https://mirrors.xtom.de/manjaro/
0.307 Sweden : https://mirror.zetup.net/manjaro/
0.140 Germany : https://ftp.halifax.rwth-aachen.de/manjaro/
0.410 Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/
2.249 New_Zealand : https://mirror.2degrees.nz/manjaro/
0.127 Germany : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
1.083 Canada : https://mirror.xenyth.net/manjaro/
0.462 Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/
0.938 United_States : https://ziply.mm.fcix.net/manjaro/
0.154 Germany : https://ftp.gwdg.de/pub/linux/manjaro/
1.812 Japan : https://mirrors.xtom.jp/manjaro/
1.990 Indonesia : http://kartolo.sby.datautama.net.id/manjaro/
0.744 Georgia : http://manjaro.grena.ge/
0.802 Canada : https://muug.ca/mirror/manjaro/
0.025 France : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
0.253 Sweden : https://ftp.lysator.liu.se/pub/manjaro/
0.246 Estonia : https://mirrors.xtom.ee/manjaro/
0.511 Bulgaria : https://manjaro.ipacct.com/manjaro/
0.402 Global : https://mirrors.manjaro.org/repo/
0.943 United_States : https://irltoolkit.mm.fcix.net/manjaro/
2.111 China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
..... Kenya : https://manjaro.mirror.liquidtelecom.com/
0.104 United_Kingdom : https://mirror.vinehost.net/manjaro/
0.426 Poland : https://ftp.psnc.pl/linux/manjaro/
1.528 United_States : https://mirrors.sonic.net/manjaro/
..... China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
..... Norway : http://mirror.terrahost.no/linux/manjaro/
2.861 Brazil : https://manjaro.c3sl.ufpr.br/
0.382 Portugal : https://mirrors.up.pt/pub/manjaro/
0.353 Czechia : https://mirror.it4i.cz/manjaro/
0.237 Austria : https://mirror.alwyzon.net/manjaro/
0.110 Netherlands : https://manjaro.mirrors.lavatech.top/
0.590 United_States : https://ohioix.mm.fcix.net/manjaro/
0.354 Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/
..... Bangladesh : https://bd.mirror.vanehost.com/Manjaro/
0.112 Netherlands : https://manjaro.mirror.wearetriple.com/
0.400 Turkey : https://ftp.linux.org.tr/manjaro/
..... Australia : https://gsl-syd.mm.fcix.net/manjaro/
0.530 United_States : https://forksystems.mm.fcix.net/manjaro/
0.416 Italy : https://ba.mirror.garr.it/mirrors/manjaro/
0.974 United_States : https://ridgewireless.mm.fcix.net/manjaro/
2.615 China : https://mirrors.jlu.edu.cn/manjaro/
1.607 Russia : https://mirror.kamtv.ru/manjaro/
0.077 Germany : https://manjaro.kurdy.org/
0.552 United_States : https://uvermont.mm.fcix.net/manjaro/
0.317 Germany : https://mirror.seahost.de/manjaro/
0.864 Austria : https://mirror.easyname.at/manjaro/
2.628 Thailand : https://mirror.kku.ac.th/manjaro/
0.175 France : https://mirror.ibakerserver.pt/manjaro/
0.116 United_States : https://ask4.mm.fcix.net/manjaro/
1.065 Iran : https://mirror.bardia.tech/manjaro/
0.668 United_States : https://nocix.mm.fcix.net/manjaro/
0.533 Greece : https://fosszone.csd.auth.gr/manjaro/
0.284 Germany : https://mirror.23m.com/manjaro/
0.148 Germany : https://mirror.alpix.eu/manjaro/
0.118 France : https://manjaro.ynh.ovh/
1.567 South_Korea : https://mirror.funami.tech/manjaro/
1.167 Singapore : https://mirror.freedif.org/Manjaro/
0.748 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
0.170 Netherlands : https://mirror.koddos.net/manjaro/
0.190 Czechia : https://mirrors.nic.cz/manjaro/
1.354 Mauritius : https://manjarolinux-mirror.cloud.mu/
0.360 Bulgaria : https://mirror.telepoint.bg/manjaro/
0.931 United_States : https://opencolo.mm.fcix.net/manjaro/
1.731 New_Zealand : http://manjaro.mirrors.theom.nz/manjaro/
0.306 Sweden : https://ftpmirror1.infania.net/mirror/manjaro/
1.040 United_States : https://mirrors.gigenet.com/manjaro/
..... Bangladesh : http://mirror.xeonbd.com/manjaro/
::ERROR Connection: HTTPConnectionPool(host='mirror.xeonbd.com', port=80): Read timed out.
0.126 Germany : https://mirror.netcologne.de/manjaro/
..... Australia : https://mirror.aarnet.edu.au/pub/manjaro/
1.739 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
1.634 Russia : https://mirror.truenetwork.ru/manjaro/
0.312 Armenia : http://manjaro.ucom.am/
1.853 Japan : http://ftp.riken.jp/Linux/manjaro/
0.238 Denmark : https://mirrors.dotsrc.org/manjaro/
1.054 Colombia : https://edgeuno-bog2.mm.fcix.net/manjaro/
::INFO Writing mirror list
::France : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Germany : https://manjaro.kurdy.org/stable
::Belgium : https://mirror.futureweb.be/manjaro/stable
::Netherlands : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::United_Kingdom : https://mirror.vinehost.net/manjaro/stable
::Germany : https://mirrors.xtom.de/manjaro/stable
::Netherlands : https://manjaro.mirrors.lavatech.top/stable
::Netherlands : https://manjaro.mirror.wearetriple.com/stable
::United_States : https://ask4.mm.fcix.net/manjaro/stable
::France : https://manjaro.ynh.ovh/stable
::Switzerland : https://mirror.init7.net/manjaro/stable
::United_Kingdom : http://manjaro.mirrors.uk2.net/stable
::Germany : https://mirror.netcologne.de/manjaro/stable
::Germany : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Germany : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Germany : https://mirror.alpix.eu/manjaro/stable
::Germany : https://ftp.gwdg.de/pub/linux/manjaro/stable
::Netherlands : https://mirror.koddos.net/manjaro/stable
::France : https://mirror.ibakerserver.pt/manjaro/stable
::Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::Czechia : https://mirrors.nic.cz/manjaro/stable
::Belgium : http://ftp.belnet.be/mirrors/manjaro/repos/stable
::Italy : https://manjaro.mirror.garr.it/manjaro/stable
::Austria : https://mirror.alwyzon.net/manjaro/stable
::Denmark : https://mirrors.dotsrc.org/manjaro/stable
::Estonia : https://mirrors.xtom.ee/manjaro/stable
::Sweden : https://ftp.lysator.liu.se/pub/manjaro/stable
::Czechia : https://mirror.dkm.cz/manjaro/stable
::Finland : https://manjaro.kyberorg.fi/stable
::Poland : https://ftp.icm.edu.pl/pub/Linux/dist/manjaro/stable
::Ukraine : https://fastmirror.pp.ua/manjaro/stable
::Germany : https://mirror.23m.com/manjaro/stable
::Bulgaria : https://mirrors.netix.net/manjaro/stable
::Sweden : https://ftpmirror1.infania.net/mirror/manjaro/stable
::Sweden : https://mirror.zetup.net/manjaro/stable
::Armenia : http://manjaro.ucom.am/stable
::Germany : https://mirror.seahost.de/manjaro/stable
::Germany : http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable
::India : https://mirror.albony.xyz/manjaro/stable
::Czechia : https://mirror.it4i.cz/manjaro/stable
::Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::Bulgaria : https://mirror.telepoint.bg/manjaro/stable
::Russia : https://mirror.yandex.ru/mirrors/manjaro/stable
::Portugal : https://mirrors.up.pt/pub/manjaro/stable
::Turkey : https://ftp.linux.org.tr/manjaro/stable
::Global : https://mirrors.manjaro.org/repo/stable
::Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::Italy : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Poland : https://ftp.psnc.pl/linux/manjaro/stable
::Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::Portugal : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::Italy : https://ct.mirror.garr.it/mirrors/manjaro/stable
::Bulgaria : https://manjaro.ipacct.com/manjaro/stable
::United_States : https://forksystems.mm.fcix.net/manjaro/stable
::Greece : https://fosszone.csd.auth.gr/manjaro/stable
::United_States : https://uvermont.mm.fcix.net/manjaro/stable
::United_States : https://nnenix.mm.fcix.net/manjaro/stable
::United_States : https://coresite.mm.fcix.net/manjaro/stable
::United_States : https://ohioix.mm.fcix.net/manjaro/stable
::United_States : https://mirror.math.princeton.edu/pub/manjaro/stable
::Georgia : https://repos.silknet.com/manjaro/stable
::United_States : https://nocix.mm.fcix.net/manjaro/stable
::United_States : https://mnvoip.mm.fcix.net/manjaro/stable
::United_States : https://volico.mm.fcix.net/manjaro/stable
::Georgia : http://manjaro.grena.ge/stable
::United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable
::Canada : https://muug.ca/mirror/manjaro/stable
::United_States : http://mirror.fcix.net/manjaro/stable
::United_States : https://southfront.mm.fcix.net/manjaro/stable
::Austria : https://mirror.easyname.at/manjaro/stable
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::United_States : https://opencolo.mm.fcix.net/manjaro/stable
::United_States : https://codingflyboy.mm.fcix.net/manjaro/stable
::United_States : https://ziply.mm.fcix.net/manjaro/stable
::United_States : https://irltoolkit.mm.fcix.net/manjaro/stable
::Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::United_States : https://ridgewireless.mm.fcix.net/manjaro/stable
::United_States : https://mirrors.gigenet.com/manjaro/stable
::Colombia : https://edgeuno-bog2.mm.fcix.net/manjaro/stable
::United_States : https://repo.ialab.dsu.edu/manjaro/stable
::Iran : https://mirror.bardia.tech/manjaro/stable
::Canada : https://mirror.xenyth.net/manjaro/stable
::Iran : https://repo.iut.ac.ir/repo/manjaro/stable
::Singapore : https://mirror.freedif.org/Manjaro/stable
::Singapore : http://ossmirror.mycloud.services/os/linux/manjaro/stable
::Costa_Rica : https://mirrors.ucr.ac.cr/manjaro/stable
::Mauritius : https://manjarolinux-mirror.cloud.mu/stable
::China : https://mirror.nyist.edu.cn/manjaro/stable
::United_States : https://mirrors.sonic.net/manjaro/stable
::South_Korea : https://mirror.funami.tech/manjaro/stable
::Russia : https://mirror.kamtv.ru/manjaro/stable
::Russia : https://mirror.truenetwork.ru/manjaro/stable
::Taiwan : https://mirror.archlinux.tw/Manjaro/stable
::Chile : https://mirror1.cl.netactuate.com/manjaro/stable
::New_Zealand : http://manjaro.mirrors.theom.nz/manjaro/stable
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stable
::Brazil : https://linorg.usp.br/manjaro/stable
::Japan : https://mirrors.xtom.jp/manjaro/stable
::South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/stable
::Japan : http://ftp.riken.jp/Linux/manjaro/stable
::Indonesia : http://kartolo.sby.datautama.net.id/manjaro/stable
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::New_Zealand : https://mirror.2degrees.nz/manjaro/stable
::Norway : http://mirror.terrahost.no/linux/manjaro/stable
::Taiwan : http://free.nchc.org.tw/manjaro/stable
::Uruguay : https://manjaro.repo.cure.edu.uy/stable
::China : https://mirrors.jlu.edu.cn/manjaro/stable
::Thailand : https://mirror.kku.ac.th/manjaro/stable
::China : https://mirrors.pku.edu.cn/manjaro/stable
::Brazil : https://manjaro.c3sl.ufpr.br/stable
::Brazil : https://mirror.ufam.edu.br/manjaro/stable
::China : https://mirrors.ustc.edu.cn/manjaro/stable
::Australia : https://mirror.aarnet.edu.au/pub/manjaro/stable
::China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::Australia : https://gsl-syd.mm.fcix.net/manjaro/stable
::Kenya : https://manjaro.mirror.liquidtelecom.com/stable
::Bangladesh : https://bd.mirror.vanehost.com/Manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core is up to date
extra is up to date
multilib is up to date
there is nothing to do
cscs
22 November 2023 12:41
21
And now?
sudo mhwd -i pci video-nvidia
