Problem with gtk themes after the update
i have a problem with gtk themes after the update.
this is what happens when i try to open nautilus.
> nautilus .
** Message: 13:35:11.067: Connecting to org.freedesktop.Tracker3.Miner.Files
(org.gnome.Nautilus:5680): Gtk-WARNING **: 13:35:11.664: Unknown key gtk-modules in /home/ayx/.config/gtk-4.0/settings.ini
(org.gnome.Nautilus:5680): Adwaita-WARNING **: 13:35:14.057: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
(org.gnome.Nautilus:5680): GLib-GIO-ERROR **: 13:35:14.082: Settings schema 'org.gnome.desktop.interface' is not installed
fish: Job 1, 'nautilus .' terminated by signal SIGTRAP (Trace or breakpoint trap)
also every other gtk application that is not crashing has default theme
here is the output of nwg-look when i try to set theme:
INFO[0000] >>> Loading preferences
INFO[0000] lang: en_US
INFO[0000] >>> Loading basic lang from '/usr/share/nwg-look/langs/en_US.json'
WARN[0000] exit status 1
INFO[0000] >>> Parsing original /home/ayx/.config/gtk-3.0/settings.ini
WARN[0000] Unsupported config key: gtk-decoration-layout
WARN[0000] Unsupported config key: gtk-enable-animations
WARN[0000] Unsupported config key: gtk-modules
WARN[0000] Unsupported config key: gtk-primary-button-warps-slider
WARN[0000] Unsupported config key: gtk-sound-theme-name
WARN[0000] Unsupported config key: gtk-xft-dpi
INFO[0000] >>> Reading gsettings
WARN[0000] Couldn't read gtk-theme, leaving default Adwaita
WARN[0000] Couldn't read icon-theme, leaving default Adwaita
WARN[0000] Couldn't read font-name, leaving default Sans 10
WARN[0000] Couldn't read cursor-theme, leaving default
WARN[0000] Couldn't read cursorSize, leaving default %!s(int=24)
WARN[0000] Couldn't read toolbar-style, leaving default both-horiz
WARN[0000] Couldn't read toolbar-icons-size, leaving default large
WARN[0000] Couldn't read font-hinting, leaving default medium
WARN[0000] Couldn't read font-antialiasing, leaving default grayscale
WARN[0000] Couldn't read font-rgba-order, leaving default rgb
WARN[0000] Couldn't read textScalingFactor, leaving default %!s(float64=1)
WARN[0000] Couldn't read color-scheme, leaving default default
INFO[0000] event-sounds: true
INFO[0000] input-feedback-sounds: false
INFO[0014] >>> Applying gsettings
INFO[0014] >> org.gnome.desktop.interface
WARN[0014] gtk-theme: exit status 1
WARN[0014] icon-theme: exit status 1
WARN[0014] cursor-theme: exit status 1
WARN[0014] cursor-size: exit status 1
WARN[0014] font-name: Sans 10 exit status 1
WARN[0014] font-hinting: medium exit status 1
WARN[0014] font-antialiasing: grayscale exit status 1
WARN[0014] font-rgba-order: rgb exit status 1
WARN[0014] text-scaling-factor: %!s(float64=1) exit status 1
WARN[0014] toolbar-style: both-horiz exit status 1
WARN[0014] toolbar-icons-size: large exit status 1
WARN[0014] color-scheme: default exit status 1
INFO[0014] >> org.gnome.desktop.sound
INFO[0014] event-sounds: true OK
INFO[0014] input-feedback-sounds: false OK
INFO[0014] >>> Backing up gsettings to /home/ayx/.local/share/nwg-look
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=gtk-theme)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=icon-theme)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=font-name)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=cursor-theme)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=cursor-size)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=toolbar-style)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=toolbar-icons-size)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=font-hinting)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=font-antialiasing)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=font-rgba-order)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=text-scaling-factor)
WARN[0014] Couldn't get gsettings key: $s%!(EXTRA string=color-scheme)
INFO[0014] >>> Exporting /home/ayx/.config/gtk-3.0/settings.ini
INFO[0014] >>> Exporting /etc/gtk-2.0/gtkrc:/home/ayx/.gtkrc-2.0:/home/ayx/.config/gtkrc-2.0
WARN[0014] Failed creating file: open /etc/gtk-2.0/gtkrc:/home/ayx/.gtkrc-2.0:/home/ayx/.config/gtkrc-2.0: no such file or directory
INFO[0014] >>> Exporting /home/ayx/.icons/default/index.theme
INFO[0014] >>> Exporting /home/ayx/.config/xsettingsd/xsettingsd.conf
can anyone help me with this problem?
Maybe try the upstream Adwaita theme …
maybe try being more specific? try where? what the hell should i do
Adwaita theme - in your settings manager
in the settings manager
use a supported theme - Gnome tries to ensure the desktop doesn’t break
i am on kde, i cannot change gtk theme in my settings manager. when i try so in nwg-look, this is what happens:
setting it to Adwaita Dark.
INFO[0007] >>> Applying gsettings
INFO[0007] >> org.gnome.desktop.interface
WARN[0007] gtk-theme: exit status 1
WARN[0007] icon-theme: exit status 1
WARN[0007] cursor-theme: exit status 1
WARN[0007] cursor-size: exit status 1
WARN[0007] font-name: Sans 10 exit status 1
WARN[0007] font-hinting: medium exit status 1
WARN[0007] font-antialiasing: grayscale exit status 1
WARN[0007] font-rgba-order: rgb exit status 1
WARN[0007] text-scaling-factor: %!s(float64=1) exit status 1
WARN[0007] toolbar-style: both-horiz exit status 1
WARN[0007] toolbar-icons-size: large exit status 1
WARN[0007] color-scheme: default exit status 1
INFO[0007] >> org.gnome.desktop.sound
INFO[0007] event-sounds: true OK
INFO[0007] input-feedback-sounds: false OK
INFO[0007] >>> Backing up gsettings to /home/ayx/.local/share/nwg-look
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=gtk-theme)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=icon-theme)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=font-name)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=cursor-theme)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=cursor-size)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=toolbar-style)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=toolbar-icons-size)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=font-hinting)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=font-antialiasing)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=font-rgba-order)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=text-scaling-factor)
WARN[0007] Couldn't get gsettings key: $s%!(EXTRA string=color-scheme)
INFO[0007] >>> Exporting /home/ayx/.config/gtk-3.0/settings.ini
INFO[0007] >>> Exporting /etc/gtk-2.0/gtkrc:/home/ayx/.gtkrc-2.0:/home/ayx/.config/gtkrc-2.0
WARN[0007] Failed creating file: open /etc/gtk-2.0/gtkrc:/home/ayx/.gtkrc-2.0:/home/ayx/.config/gtkrc-2.0: no such file or directory
INFO[0007] >>> Exporting /home/ayx/.icons/default/index.theme
INFO[0007] >>> Exporting /home/ayx/.config/xsettingsd/xsettingsd.conf
quiting nwg-look. starting it again. same default theme.
what am i doing wrong here?
The nwg-applications is targeting systems using window manager only - I don’t know how it is supposed to work
On plasma you configure GTK by navigating to
→ Settings Manager
→ Colors & Themes
→ Application Style
→ upper right corner Configure GNOME/GTK Application style…
nothing happened. i am still on default theme
I think this is an XY problem type - you are trying to apply some gnome specific settings on a system which do not provide the correct interface
I advise against mixing Gnome and Plasma desktop components - as it usually creates a lot of frustration when one expects the Qt and Gnome toolkit to work seamless together - and that is never going to happen.
I was thrown of Linux decades ago due to these inconsistencies - and is only after I retired my worklife I was actually able to commit to using Linux - and during those decades Linux evolved greatly.
Do you have gsettings-desktop-schema installed? If not, try installing it and test if the error persists.
i have it installed
❱ pacman -Qs gsettings-desktop-schema
local/gsettings-desktop-schemas 46.1-2
    GSettings schemas for GNOME desktop components
UPD
tried to reinstall it, i’ve got these errors:
/usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.magnifier.gschema.xml:25:1  Error on line 25 char 1: <enum id='org.gnome.desktop.GDesktopMagnifierFocusTrackingMode'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.interface.gschema.xml:278:1  Error on line 278 char 1: <enum id='org.gnome.desktop.GDesktopFontAntialiasingMode'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.peripherals.gschema.xml:34:1  Error on line 34 char 1: <enum id='org.gnome.desktop.GDesktopTouchpadTapButtonMap'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.privacy.gschema.xml:86:1  Error on line 86 char 1: <enum id='org.gnome.desktop.GDesktopUsbProtection'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.system.location.gschema.xml:13:1  Error on line 13 char 1: <enum id='org.gnome.desktop.GDesktopLocationAccuracyLevel'> not (yet) defined..  This entire file has been ignored.
anybody, help please
Just fishing for additional clues: please provide the outputs of inxi -zv8 and pacman -Qm.
❱ inxi -zv8
  Kernel: 6.6.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=fd4ee7b4-f6a6-4b7f-9544-0dfc3836dd60 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
    wm: kwin_wayland tools: avail: hyprlock, lockscreen, swayidle, swaylock
    vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A
  Mobo: HP model: 887A v: 59.11 serial: <superuser required>
    part-nu: 422G6EA#A2Q uuid: <superuser required> UEFI: AMI v: F.15
    date: 08/17/2021
  ID-1: BAT0 charge: 36.6 Wh (99.7%) condition: 36.7/36.7 Wh (100.0%)
    volts: 12.7 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
    status: not charging
  System RAM: total: 16 GiB available: 14.97 GiB used: 2.61 GiB (17.4%)
  Device-1: Bottom - Slot 1 (left) type: DDR4 detail: synchronous
    unbuffered (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E2 serial: <filter>
  Device-2: Bottom - Slot 2 (right) type: DDR4 detail: synchronous
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608103
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1452 high: 2521 min/max: 400/4056 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1377 2: 1617 3: 2521
    4: 400 5: 400 6: 400 7: 1585 8: 1595 9: 1492 10: 2111 11: 1984 12: 1947
    bogomips: 50327
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
    ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
    class-ID: 0300 temp: 41.0 C
  Device-2: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:5365
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-manjaro1.1
    renoir LLVM 18.1.8 DRM 3.54 6.6.44-1-MANJARO) device-ID: 1002:164c
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.5-manjaro1.1
    device-ID: 1002:164c surfaces: xcb,xlib,wayland
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-4: C-Media USB Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0d8c:0012 class-ID: 0300
  API: ALSA v: k6.6.44-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
    chip-ID: 10ec:c822 class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 0bda:b00c
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: yes address: N/A
  Local Storage: total: 476.94 GiB used: 228.31 GiB (47.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBPNTY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: HPS2 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 476.34 GiB size: 468.54 GiB (98.36%)
    used: 228.31 GiB (48.7%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:2
    label: N/A uuid: fd4ee7b4-f6a6-4b7f-9544-0dfc3836dd60
  ID-2: /boot/efi raw-size: 511 MiB size: 510 MiB (99.80%)
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:1 label: N/A
    uuid: E5EA-D890
  Device-1: 1-2:2 info: C-Media USB Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-2: 1-3:3 info: Quanta HP TrueVision HD Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
  Device-3: 1-4:4 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Device-1: 3-2:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 0000:3825 class-ID: 0301
  System Temperatures: cpu: 52.1 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: pm: pacman pkgs: 2075 libs: 471 tools: pamac,yay
    1: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    2: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    3: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    4: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 312
  1: cpu: 40.2% command: firefox pid: 1988 mem: 577.0 MiB (3.7%)
  2: cpu: 17.4% command: baloo_file_extractor pid: 1589
    mem: 432.0 MiB (2.8%)
  3: cpu: 14.0% command: firefox pid: 2268 mem: 263.9 MiB (1.7%)
  4: cpu: 5.9% command: kwin_wayland pid: 887 mem: 253.0 MiB (1.6%)
  5: cpu: 5.9% command: firefox pid: 2146 mem: 165.7 MiB (1.0%)
  Memory top: 5 of 312
  1: mem: 577.0 MiB (3.7%) command: firefox pid: 1988 cpu: 40.2%
  2: mem: 432.0 MiB (2.8%) command: baloo_file_extractor pid: 1589
    cpu: 17.4%
  3: mem: 353.9 MiB (2.3%) command: plasmashell pid: 1127 cpu: 3.6%
  4: mem: 263.9 MiB (1.7%) command: firefox pid: 2268 cpu: 14.0%
  5: mem: 253.0 MiB (1.6%) command: kwin_wayland pid: 887 cpu: 5.9%
  Processes: 312 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
    image: 5.97 GiB services: org_kde_powerdevil, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: fish v: 3.7.1 running-in: foot
    inxi: 3.3.35
❱ pacman -Qm
1password 8.10.13-5
amberol 0.10.3-1
android-apktool 2.7.0-1
aquamarine-git 0.2.0_r162.g7c3565f-1
bbe 0.2.2-3
burpsuite 2024.7-1
catppuccin-gtk-theme-latte 0.7.3-1
catppuccin-gtk-theme-mocha 0.7.3-1
cava 0.9.0-2
cewl-git 151.1c3b076-1
crunch 3.6-1
dex2jar 2.1-1
extra-cmake-modules-git 6.1.0.r3688.eeac86c9-1
fastfetch-bin 2.0.5-1
ffuf-bin 2.1.0-2
gobuster-bin 3.6.0-1
google-chrome 127.0.6533.88-1
gotop-bin 4.2.0-1
hexcat-bin 2.3.4-1
hexo-cli 4.3.2-1
httpx 1.6.3-1
hyprcursor-git 0.1.9.r5.g66d5b46f-1
hyprland-git 0.41.2.r142.8ec3dc4c-1
hyprlang-git 0.5.1.r0.78fcaa2-1
hyprutils-git 0.2.1.r0.g5dcbbc1e-1
hyprwayland-scanner-git 0.4.0.r4.ga048a6cb-1
ironbar-git v0.15.1.r8.g4695279-1
kerbrute-bin 1.0.3-1
khotkeys 5.27.11-1
manjaro-hotfixes 2024.1-2
manjaro-settings-manager-kcm 0.5.7-22
minecraft-launcher 1:1.0.1221-1
mlterm 3.9.3-2
mousam 1.3.2-1
netdiscover 0.10-0
nitch 0.1.6-2
nwg-look-bin 0.2.7-1
perl-xml-rpc 1.1-1
perl-xml-treepp 0.43-3
plasma-simplemenu 1.0.12-1
prismlauncher-qt5-bin 7.2-1
proton-vpn-gtk-app 4.3.3-1
python-proton-core 0.1.16-4
python-proton-keyring-linux 0.0.2-3
python-proton-keyring-linux-secretservice 0.0.2-4
python-proton-vpn-api-core 0.27.2-1
python-proton-vpn-connection 0.14.4-3
python-proton-vpn-killswitch 0.4.0-3
python-proton-vpn-killswitch-network-manager 0.4.5-1
python-proton-vpn-logger 0.2.1-7
python-proton-vpn-network-manager 0.4.2-3
python-proton-vpn-network-manager-openvpn 0.0.7-3
python-pyshark 0.6-2
python-pytelegrambotapi 4.17.0-1
python-selenium 4.21.0-1
python-spotipy 2.23.0-1
python-ssh-mitm 1.0.0-1
python-updog 1.4-1
python2-bin 2.7.18_1-1
so-git r200.7b73c39-1
spectre-meltdown-checker 0.46+26+gbd0c7c9-1
spotify 1:1.2.42.290-1
stegseek 0.6-1
stegsnow-git 2022.11.23.gf80a16e-1
subfinder-bin 2.6.6-2
swaylock-effects-git r416.a7691b8-1
systemd-kcm 1.2.1-8
textlint 12.2.2-1
tofi 0.9.1-2
ttf-twemoji 14.0.2-2
tty-clock 2.3-2
typespeed 0.6.5-10
vimv-git r50.83f179f-1
vinegar 1.5.9-1
visual-studio-code-bin 1.90.2-1
vkd3d-proton-bin 2.11.1-1
warp-plus-bin 1.1.3-1
waybackurls-bin 0.1.0-2
waybar-git r3428.cb2d54a2-1
webcamoid-git 9.1.1.r6.gcd578a054-1
webcord 4.9.2-1
xwaylandvideobridge-cursor-mode-2-git r210.9519d24-1
Well, the very first search I performed from your list of packages reveals this:
$ pamac search -a aquamarine
hyprland-hidpi-xprop-git  0.41.2.r77.3c758db9-1                                                            AUR
    A dynamic tiling Wayland compositor based on aquamarine that doesn't sacrifice on its looks.
hyprland-aquamarine-git  0.41.2.r132.5b1400f6-1                                                            AUR
    A dynamic tiling Wayland compositor that doesn't sacrifice on its looks. (Aquamarine backend)
aquamarine-git  0.1.0_r147.g7a84686-1        AUR
    Aquamarine is a very light linux rendering backend library
and this:
$ pamac search -a android-apktool
android-apktool-git  2.2.4.r5.g2f387288-2        AUR
    a tool for reengineering Android apk files
android-apktool-bin  2.9.3-2        AUR
    A tool for reverse engineering Android .apk files
android-apktool  2.9.3-1        AUR
Looks like you are a bit behind on updating your AUR packages. And you seem to have a lot of them. Might also be worth checking for pacnews e.g. using pacdiff -o while you’re at it.
i dont see how version of andoid-apktool can be relevant here. but i’ve updated
most of the packages.
❱ pacdiff -o
/etc/cups/cupsd.conf.pacnew
/etc/passwd.pacnew
/etc/shells.pacnew
/etc/locale.gen.pacnew
/etc/pam.d/kde.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/ssh/ssh_config.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.pacnew
/etc/pacman-mirrors.conf.pacnew
/etc/pam.d/sddm.pacnew
/etc/sudoers.pacnew
That was just an example.
However, these commands may prove useful to sort out those pacnews:
sudo pacman -S meld
DIFFPROG=meld pacdiff -s
… probably better to start a separate thread about this though; don’t just blindly merge the files particularly /etc/passwd.pacnew and the ones with pam.d for example.
You might be missing out on current mirrors also, which could possibly interfere with updates.
how about that, i move everything from /usr/share/glib-2.0/schemas/ to backup folder, reinstall the gsettings-desktop-schemas and test it out? can that help here?
Yes, it is worth a try. I do think it’s a corruption somewhere in your theme configs.
okay, so i moved /usr/share/glib-2.0/schemas/ to ~/backup, removed the gsettings-desktop-schemas from pacman cache, updated my mirrors, installed it again and got this;
❱ sudo pacman -Sy gsettings-desktop-schemas
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: gsettings-desktop-schemas-46.1-2 is up to date -- reinstalling
resolving dependencies...
Package (1)                      Old Version  New Version  Net Change  Download Size
extra/gsettings-desktop-schemas  46.1-2       46.1-2         0,00 MiB       0,70 MiB
Total Download Size:   0,70 MiB
Total Installed Size:  5,13 MiB
Net Upgrade Size:      0,00 MiB
:: Retrieving packages...
 gsettings-desktop-schemas-46.1-2-any                                                   714,6 KiB   905 KiB/s 00:01 [---------------------------------------------------------------------] 100%
(1/1) checking keys in keyring        [---------------------------------------------------------------------] 100%
(1/1) checking package integrity        [---------------------------------------------------------------------] 100%
(1/1) loading package files        [---------------------------------------------------------------------] 100%
(1/1) checking for file conflicts        [---------------------------------------------------------------------] 100%
(1/1) checking available disk space        [---------------------------------------------------------------------] 100%
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.applications.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.interface.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.keyboard.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.magnifier.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.mouse.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.app-folders.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.background.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.calendar.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.datetime.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.default-applications.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.input-sources.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.interface.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.lockdown.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.media-handling.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.notifications.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.peripherals.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.privacy.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.screensaver.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.search-providers.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.session.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.sound.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.thumbnail-cache.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.thumbnailers.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.wm.keybindings.gschema.xml
warning: could not get file information for usr/share/glib-2.0/schemas/org.gnome.desktop.wm.preferences.gschema.xml
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling gsettings-desktop-schemas        [---------------------------------------------------------------------] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
(3/3) Compiling GSettings XML schema files...
/usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.magnifier.gschema.xml:7:1  Error on line 7 char 1: <enum id='org.gnome.desktop.GDesktopMagnifierMouseTrackingMode'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.a11y.mouse.gschema.xml:15:1  Error on line 15 char 1: <enum id='org.gnome.desktop.GDesktopMouseDwellDirection'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.background.gschema.xml:5:1  Error on line 5 char 1: <enum id='org.gnome.desktop.GDesktopBackgroundStyle'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.interface.gschema.xml:35:1  Error on line 35 char 1: <enum id='org.gnome.desktop.GDesktopToolbarStyle'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.screensaver.gschema.xml:89:1  Error on line 89 char 1: <enum id='org.gnome.desktop.GDesktopBackgroundStyle'> not (yet) defined..  This entire file has been ignored.
/usr/share/glib-2.0/schemas/org.gnome.desktop.wm.preferences.gschema.xml:42:1  Error on line 42 char 1: <enum id='org.gnome.desktop.GDesktopFocusMode'> not (yet) defined..  This entire file has been ignored.
