BG405
11 August 2024 20:00
21
bladee:
community is up to date
I must note that the community repo was deprecated over a year ago, so I suspect there’s rather a backlog of other system maintenance tasks.
I’d like to point you to a guide on dealing with a “stale” system but the search facility on this Forum isn’t too spectacular, as I guess you already know. I’ll continue to look into it as and when I can.
bladee
11 August 2024 20:05
22
here is the output of journalctl -xe when i tried to set the theme in system settings, maybe it will be useful
сер 11 23:02:26 manjarolinux systemd[833]: Started System Settings - System Settings.
░░ Subject: A start job for unit UNIT has finished successfully
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished successfully.
░░ The job identifier is 1864.
сер 11 23:02:26 manjarolinux systemd[833]: Starting Portal service (GTK/GNOME implementation)...
░░ Subject: A start job for unit UNIT has begun execution
░░ A start job for unit UNIT has begun execution.
░░ The job identifier is 1884.
сер 11 23:02:26 manjarolinux xdg-desktop-por[37273]: Settings schema 'org.gnome.system.location' is not installed
сер 11 23:02:26 manjarolinux kernel: traps: xdg-desktop-por[37273] trap int3 ip:7f05ecf42b08 sp:7ffc2af7d7d0 error:0 in libglib-2.0.so.0.8000.4[7f05eceff000+a4000]
сер 11 23:02:26 manjarolinux systemd-coredump[37280]: Process 37273 (xdg-desktop-por) of user 1000 terminated abnormally with signal 5/TRAP, processing...
сер 11 23:02:26 manjarolinux systemd[1]: Started Process Core Dump (PID 37280/UID 0).
░░ Subject: A start job for unit systemd-coredump@22-37280-0.service has finished successfully
░░ A start job for unit systemd-coredump@22-37280-0.service has finished successfully.
░░ The job identifier is 5327.
сер 11 23:02:26 manjarolinux systemd-coredump[37281]: [🡕] Process 37273 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 37273:
#0 0x00007f05ecf42b08 g_log_structured_array (libglib-2.0.so.0 + 0x61b08)
#1 0x00007f05ecf42e07 g_log_default_handler (libglib-2.0.so.0 + 0x61e07)
#2 0x00007f05ecf4308c g_logv (libglib-2.0.so.0 + 0x6208c)
#3 0x00007f05ecf43404 g_log (libglib-2.0.so.0 + 0x62404)
#4 0x00007f05ece00ece n/a (libgio-2.0.so.0 + 0xecece)
#5 0x00007f05eccd7bab n/a (libgobject-2.0.so.0 + 0x22bab)
#6 0x00007f05eccd85d8 n/a (libgobject-2.0.so.0 + 0x235d8)
#7 0x00007f05eccda6cb g_object_new_valist (libgobject-2.0.so.0 + 0x256cb)
#8 0x00007f05eccdaa80 g_object_new (libgobject-2.0.so.0 + 0x25a80)
#9 0x000055c329f50908 n/a (xdg-desktop-portal-gtk + 0x21908)
#10 0x00007f05ece25725 n/a (libgio-2.0.so.0 + 0x111725)
#11 0x00007f05ecdba1ac n/a (libgio-2.0.so.0 + 0xa61ac)
#12 0x00007f05ecdbe445 n/a (libgio-2.0.so.0 + 0xaa445)
#13 0x00007f05ece2075b n/a (libgio-2.0.so.0 + 0x10c75b)
#14 0x00007f05ecdba1ac n/a (libgio-2.0.so.0 + 0xa61ac)
#15 0x00007f05ecdba1f5 n/a (libgio-2.0.so.0 + 0xa61f5)
#16 0x00007f05ecf3dab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#17 0x00007f05ecf9f9e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
#18 0x00007f05ecf3e7b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
#19 0x000055c329f3a218 n/a (xdg-desktop-portal-gtk + 0xb218)
#20 0x00007f05ec172e08 n/a (libc.so.6 + 0x25e08)
#21 0x00007f05ec172ecc __libc_start_main (libc.so.6 + 0x25ecc)
#22 0x000055c329f3a395 n/a (xdg-desktop-portal-gtk + 0xb395)
Stack trace of thread 37277:
#0 0x00007f05ec1ee46e n/a (libc.so.6 + 0xa146e)
#1 0x00007f05ec1ef620 n/a (libc.so.6 + 0xa2620)
#2 0x00007f05ec1efcfa n/a (libc.so.6 + 0xa2cfa)
#3 0x00007f05ec1f25ce __libc_free (libc.so.6 + 0xa55ce)
#4 0x00007f05ece266c9 n/a (libgio-2.0.so.0 + 0x1126c9)
#5 0x00007f05ece2fec9 n/a (libgio-2.0.so.0 + 0x11bec9)
#6 0x00007f05ecdba1ac n/a (libgio-2.0.so.0 + 0xa61ac)
#7 0x00007f05ecdba1f5 n/a (libgio-2.0.so.0 + 0xa61f5)
#8 0x00007f05ecf3dab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#9 0x00007f05ecf9f9e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
#10 0x00007f05ecf3e7b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
#11 0x00007f05ece26574 n/a (libgio-2.0.so.0 + 0x112574)
#12 0x00007f05ecf6d266 n/a (libglib-2.0.so.0 + 0x8c266)
#13 0x00007f05ec1e139d n/a (libc.so.6 + 0x9439d)
#14 0x00007f05ec26649c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 37275:
#0 0x00007f05ec25863d __poll (libc.so.6 + 0x10b63d)
#1 0x00007f05ecf9f92d n/a (libglib-2.0.so.0 + 0xbe92d)
#2 0x00007f05ecf3cfc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
#3 0x00007f05ecf3d01a n/a (libglib-2.0.so.0 + 0x5c01a)
#4 0x00007f05ecf6d266 n/a (libglib-2.0.so.0 + 0x8c266)
#5 0x00007f05ec1e139d n/a (libc.so.6 + 0x9439d)
#6 0x00007f05ec26649c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 37274:
#0 0x00007f05ec2641fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007f05ecf98a10 g_cond_wait (libglib-2.0.so.0 + 0xb7a10)
#2 0x00007f05ecf0690c n/a (libglib-2.0.so.0 + 0x2590c)
#3 0x00007f05ecf726b7 n/a (libglib-2.0.so.0 + 0x916b7)
Stack trace of thread 37276:
#1 0x00007f05ecf99367 g_cond_wait_until (libglib-2.0.so.0 + 0xb8367)
#2 0x00007f05ecf068d5 n/a (libglib-2.0.so.0 + 0x258d5)
#3 0x00007f05ecf7327b n/a (libglib-2.0.so.0 + 0x9227b)
Stack trace of thread 37278:
#3 0x00007f05ed0642fe n/a (libdconfsettings.so + 0x62fe)
░░ Subject: Process 37273 (xdg-desktop-por) dumped core
░░ Documentation: man:core(5)
░░ Process 37273 (xdg-desktop-por) crashed and dumped core.
░░ This usually indicates a programming error in the crashing program and
░░ should be reported to its vendor as a bug.
сер 11 23:02:26 manjarolinux systemd[1]: systemd-coredump@22-37280-0.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit systemd-coredump@22-37280-0.service has successfully entered the 'dead' state.
сер 11 23:02:26 manjarolinux systemd[833]: xdg-desktop-portal-gtk.service: Main process exited, code=dumped, status=5/TRAP
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit UNIT has exited.
░░ The process' exit code is 'dumped' and its exit status is 5.
сер 11 23:02:26 manjarolinux systemd[833]: xdg-desktop-portal-gtk.service: Failed with result 'core-dump'.
░░ Subject: Unit failed
░░ The unit UNIT has entered the 'failed' state with result 'core-dump'.
сер 11 23:02:26 manjarolinux systemd[833]: Failed to start Portal service (GTK/GNOME implementation).
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 1884 and the job result is failed.
сер 11 23:02:26 manjarolinux xdg-desktop-por[893]: Failed to ReadAll() from Settings implementation: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.gtk': startup job failed
сер 11 23:02:26 manjarolinux systemsettings[37248]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
сер 11 23:02:29 manjarolinux systemsettings[37248]: qrc:/qt/qml/org/kde/systemsettings/CategoryItem.qml:33:13: Unable to assign IconPropertiesGroup_QMLTYPE_91 to IconPropertiesGroup_QMLTYPE_91
сер 11 23:02:29 manjarolinux systemsettings[37248]: qml: Page SubCategoryPage_QMLTYPE_60(0x56087f5c31f0) is already in the PageRow
сер 11 23:02:29 manjarolinux systemsettings[37248]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сер 11 23:02:29 manjarolinux systemsettings[37248]: qml: push (file:///usr/lib/qt6/qml/org/kde/kirigami/PageRow.qml:223)
onActiveSubCategoryRowChanged (qrc:/qt/qml/org/kde/systemsettings/SubCategoryPage.qml:165)
expression for onClicked (qrc:/qt/qml/org/kde/systemsettings/CategoriesPage.qml:192)
сер 11 23:02:33 manjarolinux systemsettings[37248]: qml: Page SubCategoryPage_QMLTYPE_60(0x56087f5c31f0) is already in the PageRow
сер 11 23:02:33 manjarolinux systemsettings[37248]: qml: Pushed pages do not conform to the rules. Please check the documentation.
сер 11 23:02:33 manjarolinux systemsettings[37248]: qml: push (file:///usr/lib/qt6/qml/org/kde/kirigami/PageRow.qml:223)
expression for onClicked (qrc:/qt/qml/org/kde/systemsettings/SubCategoryPage.qml:187)
сер 11 23:02:41 manjarolinux kded6[1154]: xsettingsd: Reloading configuration
сер 11 23:02:41 manjarolinux kded6[1154]: xsettingsd: Loaded 9 settings from /home/ayx/.config/xsettingsd/xsettingsd.conf
BG405
11 August 2024 20:28
23
Try this and see what comes up:
pamac search libglib | grep -i installed
… compared with my setup:
$ pamac search libglib | grep -i installed
lib32-glib2 2.80.4-1 [Installed] multilib
glibmm-2.68 2.80.0-1 [Installed] extra
glibmm 2.66.7-1 [Installed] extra
glib2 2.80.4-1 [Installed] core
libglibutil 1.0.69-1 [Installed]
bladee
11 August 2024 20:29
24
okay so should i install libglibutil ?
BG405
11 August 2024 20:32
25
Nothing to lose by doing so. I guess this was included in later updates. It can always be removed later, if needed.
bladee
11 August 2024 20:35
26
well. still the same.
❱ systemctl --user restart xdg-desktop-portal-gtk
Job for xdg-desktop-portal-gtk.service failed because a fatal signal was delivered causing the control process to dump core.
See "systemctl --user status xdg-desktop-portal-gtk.service" and "journalctl --user -xeu xdg-desktop-portal-gtk.service" for details.
i will try to reinstall the other packges. maybe it will help
UDP:
it did not. i am so tired of still bullshіt.
bladee
14 August 2024 16:34
27
the issue is still not resolved…
Kobold
14 August 2024 17:23
28
Im a blind dude around this gtk themes here and your problems with that, after that said watch my advise with a grain of salt.
Worth it to create a Timeshift snapshot befor messing around with your system.
1.Did you already Merged successfull all needed files with pacdiff as @BG405 mentioned? And this doesn’t mean just simple overwrite or delete…
2.Give us your Output from: /home/ayx/.config/gtk-4.0/settings.ini
You probably just need to adjust this lane and put your new installed GTK Theme inside:
gtk-theme-name=
3.When option 2 isn’t working, Maybe logout, go in TTY or boot in live environment and rename your .cache folder in your home user profile (you can delete it later when everything is working) and reboot.
4.When option 3 not working, you can try to create a new home profile and see if anything changed.
bladee
15 August 2024 12:48
29
while trying to merge pacnews together with meld, i’ve opened it with sudo and guess what, the themes was normal, the cursor was the same, so i tried to do so with sudo -E meld, and it failed to load the themes, so it means some env variable is wrong
❱ export
COLORTERM truecolor
DBUS_SESSION_BUS_ADDRESS unix:path=/run/user/1000/bus
DEBUGINFOD_URLS 'https://debuginfod.archlinux.org '
DESKTOP_SESSION plasmawayland
DISPLAY :1
DOTNET_CLI_TELEMETRY_OPTOUT 1
GTK2_RC_FILES /etc/gtk-2.0/gtkrc:/home/ayx/.gtkrc-2.0:/home/ayx/.config/gt…
GTK_RC_FILES /etc/gtk/gtkrc:/home/ayx/.gtkrc:/home/ayx/.config/gtkrc
HOME /home/ayx
ICEAUTHORITY /run/user/1000/iceauth_Dhmjwh
INVOCATION_ID ffe4866b4ca448f79cf5caa6a361477a
JOURNAL_STREAM 8:866678
KDE_APPLICATIONS_AS_SCOPE 1
KDE_FULL_SESSION true
KDE_SESSION_UID 1000
KDE_SESSION_VERSION 6
LANG en_US.UTF-8
LC_ADDRESS uk_UA.UTF-8
LC_IDENTIFICATION uk_UA.UTF-8
LC_MEASUREMENT uk_UA.UTF-8
LC_MONETARY uk_UA.UTF-8
LC_NAME uk_UA.UTF-8
LC_NUMERIC uk_UA.UTF-8
LC_PAPER uk_UA.UTF-8
LC_TELEPHONE uk_UA.UTF-8
LC_TIME uk_UA.UTF-8
LOGNAME ayx
MAIL /var/spool/mail/ayx
MANAGERPID 846
MEMORY_PRESSURE_WATCH /sys/fs/cgroup/user.slice/user-1000.slice/user@1000.service/…
MEMORY_PRESSURE_WRITE c29tZSAyMDAwMDAgMjAwMDAwMAA=
MOTD_SHOWN pam
PAM_KWALLET5_LOGIN /run/user/1000/kwallet5.socket
PATH '/home/ayx/.cargo/bin' '/home/ayx/.local/scripts' '/home/a…
PWD /home/ayx
QT_AUTO_SCREEN_SCALE_FACTOR 0
QT_LINUX_ACCESSIBILITY_ALWAYS_ON 1
QT_QPA_PLATFORMTHEME qt5ct
QT_WAYLAND_RECONNECT 1
SESSION_MANAGER local/manjarolinux:@/tmp/.ICE-unix/133872,unix/manjarolinux:…
SHELL /usr/bin/fish
SHLVL 1
SSH_AUTH_SOCK /run/user/1000/gcr/ssh
SYSTEMD_EXEC_PID 133957
TERM foot
USER ayx
WAYLAND_DISPLAY wayland-0
XAUTHORITY /run/user/1000/xauth_wVUuUS
XDG_CONFIG_DIRS /home/ayx/.config/kdedefaults:/etc/xdg:/usr/share/manjaro-kd…
XDG_CURRENT_DESKTOP KDE
XDG_MENU_PREFIX plasma-
XDG_RUNTIME_DIR /run/user/1000
XDG_SEAT seat0
XDG_SEAT_PATH /org/freedesktop/DisplayManager/Seat0
XDG_SESSION_CLASS user
XDG_SESSION_DESKTOP KDE
XDG_SESSION_ID 9
XDG_SESSION_PATH /org/freedesktop/DisplayManager/Session7
XDG_SESSION_TYPE wayland
XDG_VTNR 1
XKB_DEFAULT_LAYOUT us
and with sudo:
❱ sudo bash -c 'export'
declare -x COLORTERM="truecolor"
declare -x DISPLAY=":1"
declare -x DOTNET_CLI_TELEMETRY_OPTOUT="1"
declare -x HOME="/root"
declare -x LANG="en_US.UTF-8"
declare -x LC_ADDRESS="uk_UA.UTF-8"
declare -x LC_IDENTIFICATION="uk_UA.UTF-8"
declare -x LC_MEASUREMENT="uk_UA.UTF-8"
declare -x LC_MONETARY="uk_UA.UTF-8"
declare -x LC_NAME="uk_UA.UTF-8"
declare -x LC_NUMERIC="uk_UA.UTF-8"
declare -x LC_PAPER="uk_UA.UTF-8"
declare -x LC_TELEPHONE="uk_UA.UTF-8"
declare -x LC_TIME="uk_UA.UTF-8"
declare -x LOGNAME="root"
declare -x MAIL="/var/mail/root"
declare -x OLDPWD
declare -x PATH="/home/ayx/.cargo/bin:/home/ayx/.local/scripts:/home/ayx/.local/bin:/home/ayx/.spicetify:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/opt/rocm/bin"
declare -x PWD="/home/ayx"
declare -x QT_QPA_PLATFORMTHEME="qt5ct"
declare -x SHELL="/bin/bash"
declare -x SHLVL="1"
declare -x SUDO_COMMAND="/usr/bin/bash -c export"
declare -x SUDO_GID="1000"
declare -x SUDO_UID="1000"
declare -x SUDO_USER="ayx"
declare -x TERM="foot"
declare -x USER="root"
declare -x XAUTHORITY="/run/user/1000/xauth_wVUuUS"
declare -x XDG_CURRENT_DESKTOP="KDE"
here is GTK2_RC_FILES and GTK_RC_FILES
❱ cat /etc/gtk-2.0/gtkrc
❱ cat /home/ayx/.gtkrc-2.0
gtk-enable-animations=1
gtk-primary-button-warps-slider=1
gtk-sound-theme-name="ocean"
# DO NOT EDIT! This file will be overwritten by nwg-look.
# Any customization should be done in ~/.gtkrc-2.0.mine instead.
gtk-theme-name="adw-gtk3-dark"
gtk-icon-theme-name="breeze-dark"
gtk-font-name="Noto Sans, 10"
gtk-cursor-theme-name="WinSur-dark-cursors"
gtk-cursor-theme-size=24
gtk-toolbar-style=3
gtk-toolbar-icon-size=GTK_ICON_SIZE_LARGE_TOOLBAR
gtk-button-images=1
gtk-menu-images=1
gtk-enable-event-sounds=1
gtk-enable-input-feedback-sounds=0
gtk-xft-antialias=1
gtk-xft-hinting=1
gtk-xft-hintstyle="hintmedium"
gtk-xft-rgba="rgb"
❱ cat /home/ayx/.config/gtkrc-2.0
# created by KDE Plasma, Thu Aug 15 14:59:45 2024
gtk-alternative-button-order = 1
❱ cat /etc/gtk/gtkrc
cat: /etc/gtk/gtkrc: No such file or directory
~ | 1
cat: /home/ayx/.gtkrc: No such file or directory
~ | 1
Kobold
15 August 2024 15:09
30
bladee:
sudo -E meld
No idea for what the command is good for.
Try to merge this way:
DIFFPROG=meld pacdiff -s
Download another gtk theme and replace this adw theme.
Maybe there is a incompatibility
bladee
15 August 2024 15:11
31
i’ve merged already,
❱ pacdiff -o
the issue is still present. xdg-desktop-portal-gtk is failing to start
❱ systemctl --user status xdg-desktop-portal-gtk
× xdg-desktop-portal-gtk.service - Portal service (GTK/GNOME implementation)
Loaded: loaded (/usr/lib/systemd/user/xdg-desktop-portal-gtk.service; static)
Active: failed (Result: core-dump) since Thu 2024-08-15 18:09:40 EEST; 1min 16s ago
Invocation: 967e4c4bb5f44ef594236fab7061d074
Process: 1418 ExecStart=/usr/lib/xdg-desktop-portal-gtk (code=dumped, signal=TRAP)
Main PID: 1418 (code=dumped, signal=TRAP)
Mem peak: 10.8M
CPU: 121ms
сер 15 18:09:40 manjarolinux systemd[832]: Starting Portal service (GTK/GNOME implementation)...
сер 15 18:09:40 manjarolinux xdg-desktop-por[1418]: Settings schema 'org.gnome.system.location' is not installed
сер 15 18:09:40 manjarolinux systemd-coredump[1443]: [🡕] Process 1418 (xdg-desktop-por) of user 1000 dumped core.
Stack trace of thread 1418:
#0 0x00007f9767cc1b08 g_log_structured_array (libglib-2.0.so.0 + 0x61b08)
#1 0x00007f9767cc1e07 g_log_default_handler (libglib-2.0.so.0 + 0x61e07)
#2 0x00007f9767cc208c g_logv (libglib-2.0.so.0 + 0x6208c)
#3 0x00007f9767cc2404 g_log (libglib-2.0.so.0 + 0x62404)
#4 0x00007f9767b7fece n/a (libgio-2.0.so.0 + 0xecece)
#5 0x00007f9767a56bab n/a (libgobject-2.0.so.0 + 0x22bab)
#6 0x00007f9767a575d8 n/a (libgobject-2.0.so.0 + 0x235d8)
#7 0x00007f9767a596cb g_object_new_valist (libgobject-2.0.so.0 + 0x256cb)
#8 0x00007f9767a59a80 g_object_new (libgobject-2.0.so.0 + 0x25a80)
#9 0x000055cba221f908 n/a (xdg-desktop-portal-gtk + 0x21908)
#10 0x00007f9767ba4725 n/a (libgio-2.0.so.0 + 0x111725)
#11 0x00007f9767b391ac n/a (libgio-2.0.so.0 + 0xa61ac)
#12 0x00007f9767b3d445 n/a (libgio-2.0.so.0 + 0xaa445)
#13 0x00007f9767b9f75b n/a (libgio-2.0.so.0 + 0x10c75b)
#14 0x00007f9767b391ac n/a (libgio-2.0.so.0 + 0xa61ac)
#15 0x00007f9767b391f5 n/a (libgio-2.0.so.0 + 0xa61f5)
#16 0x00007f9767cbcab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#17 0x00007f9767d1e9e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
#18 0x00007f9767cbd7b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
#19 0x000055cba2209218 n/a (xdg-desktop-portal-gtk + 0xb218)
#20 0x00007f9766ef8e08 n/a (libc.so.6 + 0x25e08)
#21 0x00007f9766ef8ecc __libc_start_main (libc.so.6 + 0x25ecc)
#22 0x000055cba2209395 n/a (xdg-desktop-portal-gtk + 0xb395)
Stack trace of thread 1423:
#0 0x00007f9766fde63d __poll (libc.so.6 + 0x10b63d)
#1 0x00007f9767d1e92d n/a (libglib-2.0.so.0 + 0xbe92d)
#2 0x00007f9767cbbfc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
#3 0x00007f9767cbc01a n/a (libglib-2.0.so.0 + 0x5c01a)
#4 0x00007f9767cec266 n/a (libglib-2.0.so.0 + 0x8c266)
#5 0x00007f9766f6739d n/a (libc.so.6 + 0x9439d)
#6 0x00007f9766fec49c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 1425:
#0 0x00007f9766fee80b sendmsg (libc.so.6 + 0x11b80b)
#1 0x00007f9767b2cf65 g_socket_send_message_with_timeout (libgio-2.0.so.0 + 0x99f65)
#2 0x00007f9767b2d37c g_socket_send_message (libgio-2.0.so.0 + 0x9a37c)
#3 0x00007f9767bae346 n/a (libgio-2.0.so.0 + 0x11b346)
#4 0x00007f9767baea32 n/a (libgio-2.0.so.0 + 0x11ba32)
#5 0x00007f9767baebc1 n/a (libgio-2.0.so.0 + 0x11bbc1)
#6 0x00007f9767cbcab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#7 0x00007f9767d1e9e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
#8 0x00007f9767cbd7b7 g_main_loop_run (libglib-2.0.so.0 + 0x5d7b7)
#9 0x00007f9767ba5574 n/a (libgio-2.0.so.0 + 0x112574)
#10 0x00007f9767cec266 n/a (libglib-2.0.so.0 + 0x8c266)
#11 0x00007f9766f6739d n/a (libc.so.6 + 0x9439d)
#12 0x00007f9766fec49c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 1422:
#0 0x00007f9766fea1fd syscall (libc.so.6 + 0x1171fd)
#1 0x00007f9767d17a10 g_cond_wait (libglib-2.0.so.0 + 0xb7a10)
#2 0x00007f9767c8590c n/a (libglib-2.0.so.0 + 0x2590c)
#3 0x00007f9767cf16b7 n/a (libglib-2.0.so.0 + 0x916b7)
Stack trace of thread 1424:
#1 0x00007f9767d18367 g_cond_wait_until (libglib-2.0.so.0 + 0xb8367)
#2 0x00007f9767c858d5 n/a (libglib-2.0.so.0 + 0x258d5)
#3 0x00007f9767cf227b n/a (libglib-2.0.so.0 + 0x9227b)
Stack trace of thread 1426:
#1 0x00007f9767d1794d n/a (libglib-2.0.so.0 + 0xb794d)
#2 0x00007f9767b9ad93 n/a (libgio-2.0.so.0 + 0x107d93)
#3 0x00007f9767b9b9d7 g_dbus_connection_call (libgio-2.0.so.0 + 0x1089d7)
#4 0x00007f9767ddb1b7 n/a (libdconfsettings.so + 0x71b7)
#5 0x00007f9767cbcab9 n/a (libglib-2.0.so.0 + 0x5cab9)
#6 0x00007f9767d1e9e7 n/a (libglib-2.0.so.0 + 0xbe9e7)
#7 0x00007f9767cbbfc5 g_main_context_iteration (libglib-2.0.so.0 + 0x5bfc5)
#8 0x00007f9767dda2fe n/a (libdconfsettings.so + 0x62fe)
#9 0x00007f9767cec266 n/a (libglib-2.0.so.0 + 0x8c266)
#10 0x00007f9766f6739d n/a (libc.so.6 + 0x9439d)
#11 0x00007f9766fec49c n/a (libc.so.6 + 0x11949c)
сер 15 18:09:40 manjarolinux systemd[832]: xdg-desktop-portal-gtk.service: Main process exited, code=dumped, status=5/TRAP
сер 15 18:09:40 manjarolinux systemd[832]: xdg-desktop-portal-gtk.service: Failed with result 'core-dump'.
сер 15 18:09:40 manjarolinux systemd[832]: Failed to start Portal service (GTK/GNOME implementation).
Kobold
15 August 2024 15:18
32
Okay merging is done, but you know i wrote more than 1. point what you can try…
bladee
15 August 2024 15:21
33
okay. i removed the theme and set Adwaita-dark, guess what… xdg-desktop-portal-gtk is still crashing. it has nothing to do with it.
i will try to rename my .cache folder, will give you an update on that
UPD:
nothing changed
UPD 2:
added a new user, the same thing
Do you have gsettings-desktop-schemas installed?
Kobold
15 August 2024 17:48
35
bladee:
adw-gtk3-dark
Adwaita Adwaita Adwaita… do you really want to solve this problem? Why you don’t choose a complete other Theme?
He posted the output already:
okay, so i moved /usr/share/glib-2.0/schemas/ to ~/backup, removed the gsettings-desktop-schemas from pacman cache, updated my mirrors, installed it again and got this;
❱ sudo pacman -Sy gsettings-desktop-schemas
core is up to date
extra is up to date
multilib is up to date
warning: gsettings-desktop-schemas-46.1-2 is up to date -- reinstalling
resolving dependencies...
Package (1) …
bladee
15 August 2024 18:17
36
dude, no matter what theme i am setting, there is no difference. the problem is xdg-desktop-portal-gtk here
Kobold
15 August 2024 20:57
37
You need to ask yourself, why only you have this problem and why it happen after the update. I have 2 systems with Manjaro KDE in use and i don’t have any issues with GTK.
Do you have a Timeshift snapshot to restore your system? That you maybe could update again.
bladee
16 August 2024 11:22
38
i did not know it was was the xdpg at first, all i noticed that my cursor in gtk apps was different and the theme was default. i think i have given enough information for you not to advise me to set a different theme
no, i do not
ydar
17 August 2024 12:33
39
Since you’re using KDE/Plasma, you should probably be using xdg-desktop-portal-kde rather than xdg-desktop-portal-gtk.
On my system, I don’t even have xdg-desktop-portal-gtk installed.
Uninstall that. You are using Plasma, so the only two portal packages you need are xdg-desktop-portal and xdg-desktop-portal-kde.
Ditto.
