Is he?
yes, he is…
hes got this symbol: # and also runs pacman command without sudo
Could you tell me please how to use proper formatting?
you have already proper formatted outputs…
use this:
your output here
Is there any chance of repair?
yes… just follow the instructions… did you rerun the update?
It’s just that the update on the live CD is very slow.
Which instruction do you have in mind?
what is it doing now? only downloading?
to rerun the update first, since it was interrupted…
only downloading…
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst failed to download
Total ( 1/562) 1919.6 MiB 17.7 MiB/s 01:48 [####################################] 100%
error: failed retrieving file 'onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst' from mirror.yandex.ru : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst' from manjaro.astra.in.ua : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst' from manjarolinux-mirror.cloud.mu : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst' from mirrors.vishnetwork.in : Could not resolve host: mirrors.vishnetwork.in
warning: too many errors from mirrors.vishnetwork.in, skipping for the remainder of this transaction
error: failed retrieving file 'onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst' from mirrors.jlu.edu.cn : Could not resolve host: mirrors.jlu.edu.cn
warning: too many errors from mirrors.jlu.edu.cn, skipping for the remainder of this transaction
warning: failed to retrieve some files
error: failed to commit transaction (invalid url for server)
yes, could be the mirrors, or your actuall internet…
exit chroot:
exit
reboot, boot into live usb again, connect to internet and make sure you are connected, chroot:
manjaro-chroot -a
rerun update again:
pacman-mirrors -f 5 && pacman -Syyu
Addition:
pacman-mirrors --geoip && pacman-mirrors --fasttrack && pacman -Syyu
Then it chooses mirrors by your geolocation. Instead of --geoip you could use --country Global, then it will use Manjaros global CDN. Maybe that works better then.
[manjaro manjaro]# pacman-mirrors --country Global && pacman-mirrors --fasttrack && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
2.935 Global : https://mirrors.manjaro.org/repo/
::INFO Writing mirror list
::Global : https://mirrors.manjaro.org/repo/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
::INFO To reset custom mirrorlist 'sudo pacman-mirrors -id'
::INFO To remove custom config run 'sudo pacman-mirrors -c all'
2.969 Global : https://mirrors.manjaro.org/repo/
error: failed to synchronize all databases (unable to lock database)
remove the lock:
rm /var/lib/pacman/db.lck
rerun the update command again
Total ( 1/562) 1905.9 MiB 8.11 MiB/s 03:55 [####################################] 100%
error: failed retrieving file 'onlyoffice-desktopeditors-7.3.3-1-x86_64.pkg.tar.zst' from manjaro.ucom.am : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed to commit transaction (download library error)
Phew… that is ridiculous. The only thing I could imagine now is that space is left on the harddrive. Which connection are you using? Cable or Wifi?
If WiFi, then you need to install the broadcom driver, since the baked in drivers are rather reversed-engneered.
Not in chroot:
sudo mhwd --install pci network-broadcom-wl
Otherwise use a cable.
sudo mhwd --install network-broadcom-wl ✔
Error: invalid use of option: -i/--install
Usage: mhwd [OPTIONS] <config(s)>
--pci list only pci devices and driver configs
--usb list only usb devices and driver configs
-h/--help show help
-v/--version show version of mhwd
-f/--force force reinstallation
-d/--detail show detailed info for -l/-li/-lh
-l/--list list available configs for devices
-la/--listall list all driver configs
-li/--listinstalled list installed driver configs
-lh/--listhardware list hardware information
-i/--install <usb/pci> <config(s)> install driver config(s)
-ic/--installcustom <usb/pci> <path> install custom config(s)
-r/--remove <usb/pci> <config(s)> remove driver config(s)
-a/--auto <usb/pci> <free/nonfree> <classid> auto install configs for classid
--pmcachedir <path> set package manager cache path
--pmconfig <path> set package manager config
--pmroot <path> set package manager root
:: Some packages should be upgraded first...
resolving dependencies...
Packages (3) archlinux-keyring-20230320-1 manjaro-keyring-20230318-1 manjaro-system-20230401-1
Total Download Size: 1.69 MiB
Total Installed Size: 2.31 MiB
Net Upgrade Size: 0.01 MiB
archlinux-keyring-20230320-1-any 1156.8 KiB 53.5 KiB/s 00:22 [####################################] 100%
manjaro-keyring-20230318-1-any 547.7 KiB 52.0 KiB/s 00:11 [####################################] 100%
manjaro-system-20230401-1-any 29.0 KiB 55.0 KiB/s 00:01 [####################################] 100%
Total (3/3) 1733.5 KiB 52.5 KiB/s 00:33 [####################################] 100%
(3/3) checking keys in keyring [####################################] 100%
(3/3) checking package integrity [####################################] 100%
(3/3) loading package files [####################################] 100%
(3/3) checking for file conflicts [####################################] 100%
(3/3) checking available disk space [####################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap because system is booted in Live CD mode...
(1/3) upgrading archlinux-keyring [####################################] 100%
==> Appending keys from archlinux.gpg...
==> Updating trust database...
gpg: next trustdb check due at 2023-07-07
(2/3) upgrading manjaro-keyring [####################################] 100%
==> Appending keys from manjaro.gpg...
gpg: error reading key: No public key
==> Locally signing trusted keys in keyring...
-> Locally signed 2 keys.
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
-> Disabled 8 keys.
(3/3) upgrading manjaro-system [####################################] 100%
==> Checking for 'os-prober' setup ...
We will reenable 'os-prober' for you ...
/usr/bin/grub-probe: error: failed to get canonical path of `overlay'.
==> Checking if graphic drivers need an update ...
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
warning: mhwd-nvidia will be installed before its mhwd dependency
warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Packages (563) accountsservice-23.13.9-1 adobe-source-code-pro-fonts-2.042u+1.062i+1.026vf-1
adobe-source-sans-fonts-3.052-1 alsa-firmware-1.2.4-3 alsa-oss-1.1.8-5
alsa-plugins-1:1.2.7.1-2 alsa-topology-conf-1.2.5.1-3 amd-ucode-20230404.2e92a49f-1
appstream-0.16.1-2 appstream-glib-0.8.2-2 appstream-qt-0.16.1-2
archlinux-appstream-data-20230421-1 ark-23.04.0-1 at-spi2-core-2.48.0-2 attica-5.105.0-1
attr-2.5.1-3 audiocd-kio-23.04.0-1 audit-3.1-1 baloo-5.105.0-1 baloo-widgets-23.04.0-1
bluedevil-1:5.27.4-1 bluez-qt-5.105.0-1 breeze-5.27.4-1 breeze-gtk-5.27.4-2.1
breeze-icons-5.105.0-1 brotli-1.0.9-10 btrfs-progs-6.2.2-1 bubblewrap-0.8.0-1
ca-certificates-mozilla-3.89-1 calamares-3.2.62-1 chromaprint-1.5.1-7 cifs-utils-7.0-3
ckbcomp-1.215-1 clang-15.0.7-2 clinfo-3.0.21.02.21-1 cmus-2.10.0-4 coreutils-9.3-1
cpupower-6.2-1 cracklib-2.9.11-1 cryptsetup-2.6.1-3.2 cups-1:2.4.2-6
cups-filters-1.28.17-2 curl-8.0.1-1 cython-0.29.34-1 dav1d-1.1.0-1 dbus-1.14.6-2
dbus-python-1.2.18-4 device-mapper-2.03.21-1 dmidecode-3.5-1 dolphin-23.04.0-2
dolphin-plugins-23.04.0-1 efibootmgr-18-2 efivar-38-3 elisa-23.04.0-1 enchant-2.3.4-1
f2fs-tools-1.16.0-1 faac-1.30-4 ffmpeg-2:6.0-5 ffmpeg4.4-4.4.3-2 ffmpegthumbs-23.04.0-1
fftw-3.3.10-4 file-5.44-3 filelight-23.04.0-1 filesystem-2023.03.21-1 findutils-4.9.0-3
firefox-113.0-0.1 flatpak-1:1.15.4-1 fluidsynth-2.3.2-1 foomatic-db-3:20230402-1
foomatic-db-nonfree-3:20230402-1 foomatic-db-nonfree-ppds-3:20230402-1
foomatic-db-ppds-3:20230402-1 frameworkintegration-5.105.0-1 fuse-common-3.14.1-1
fuse3-3.14.1-1 fwupd-1.8.14-1 fzf-0.39.0-1 gawk-5.2.1-2 gdbm-1.23-2 gettext-0.21.1-5
ghostscript-10.01.1-1 git-2.40.1-1 glib-networking-1:2.76.0-1 glib2-2.76.1-1
glibmm-2.66.6-1 glslang-12.1.0-1 gnupg-2.2.41-1 gnutls-3.8.0-1
gobject-introspection-runtime-1.76.1-1 gparted-1.5.0-1 gperftools-2.10-1 gpgme-1.20.0-1
grep-3.10-1 groff-1.22.4-10 grub-2.06.r499.ge67a551a4-2 grub-theme-live-common-20.2-15
grub-theme-live-manjaro-20.2-15 grub-theme-manjaro-20.2-15 gsettings-desktop-schemas-44.0-1
gsfonts-20200910-3 gst-libav-1.22.1-2 gst-plugins-bad-1.22.1-2
gst-plugins-bad-libs-1.22.1-2 gst-plugins-base-1.22.1-2 gst-plugins-base-libs-1.22.1-2
gst-plugins-good-1.22.1-2 gst-plugins-ugly-1.22.1-2 gstreamer-1.22.1-2
gtk-update-icon-cache-1:4.10.3-1 gtk3-1:3.24.37-1 gupnp-igd-1.6.0-1 gwenview-23.04.0-1
harfbuzz-7.1.0-1 harfbuzz-icu-7.1.0-1 hicolor-icon-theme-0.17-3 hidapi-0.13.1-2
highway-1.0.4-1 hwdata-0.369-1 hwloc-2.9.1-1 iana-etc-20230405-1 imagemagick-7.1.1.8-1
imath-3.1.7-1 imlib2-1.11.0-1 inetutils-2.4-1 intel-ucode-20230214-1 inxi-3.3.27.1-1
iproute2-6.2.0-2 iso-codes-4.13.0-1 kaccounts-integration-23.04.0-1
kaccounts-providers-23.04.0-1 kactivities-5.105.0-1 kactivities-stats-5.105.0-1
kactivitymanagerd-5.27.4-1 kamera-23.04.0-1 karchive-5.105.0-1 kate-23.04.0-1
kauth-5.105.0-1 kbookmarks-5.105.0-1 kcalc-23.04.0-1 kcmutils-5.105.0-1 kcodecs-5.105.0-1
kcompletion-5.105.0-1 kconfig-5.105.0-1 kconfigwidgets-5.105.0-1 kcontacts-1:5.105.0-1
kcoreaddons-5.105.0-1 kcrash-5.105.0-1 kdbusaddons-5.105.0-1 kde-cli-tools-5.27.4-1
kde-gtk-config-5.27.4-1 kdeclarative-5.105.0-1 kdeconnect-23.04.0-1 kdecoration-5.27.4-1
kded-5.105.0-1 kdegraphics-mobipocket-23.04.0-1 kdegraphics-thumbnailers-23.04.0-1
kdelibs4support-5.105.0-1 kdenetwork-filesharing-23.04.0-1 kdeplasma-addons-5.27.4-1
kdesu-5.105.0-1 kdnssd-5.105.0-1 kdoctools-5.105.0-1 keditbookmarks-23.04.0-1
kemoticons-5.105.0-1 kfilemetadata-5.105.0-1 kfind-23.04.0-1 kgamma5-5.27.4-1
kglobalaccel-5.105.0-1 kguiaddons-5.105.0-1 khelpcenter-23.04.0-1 kholidays-1:5.105.0-1
khotkeys-5.27.4-1 khtml-5.105.0-1 ki18n-5.105.0-1 kiconthemes-5.105.0-1
kidletime-5.105.0-1 kimageannotator-0.6.1-1 kimageformats-5.105.0-1 kinfocenter-5.27.4-1
kinit-5.105.0-1 kio-5.105.0-1 kio-extras-23.04.0-1 kirigami-addons-0.8.0-1
kirigami2-5.105.0-1 kitemmodels-5.105.0-1 kitemviews-5.105.0-1 kjobwidgets-5.105.0-1
kjs-5.105.0-1 kmenuedit-5.27.4-1 knewstuff-5.105.0-1 knotifications-5.105.0-1
knotifyconfig-5.105.0-1 konsole-23.04.0-1 kpackage-5.105.0-1 kparts-5.105.0-1
kpeople-5.105.0-1 kpipewire-5.27.4-1 kpmcore-23.04.0-1 kpty-5.105.0-1
kquickcharts-5.105.0-1 krunner-5.105.0-1 ksanecore-23.04.0-1 kscreen-5.27.4-1
kscreenlocker-5.27.4-1 kservice-5.105.0-1 ksshaskpass-5.27.4-1 ksystemlog-23.04.0-1
ksystemstats-5.27.4-1 ktexteditor-5.105.0-1 ktextwidgets-5.105.0-1
kunitconversion-5.105.0-1 kwallet-5.105.0-1 kwallet-pam-5.27.4-1 kwalletmanager-23.04.0-1
kwayland-5.105.0-1 kwayland-integration-5.27.4-1 kwidgetsaddons-5.105.0-1 kwin-5.27.4.1-1
kwindowsystem-5.105.0-1 kwrited-5.27.4-1 kxmlgui-5.105.0-1 l-smash-2.14.5-3
layer-shell-qt-5.27.4-1 lcms2-2.15-1 ldb-2:2.7.2-1 lib32-curl-8.0.1-1 lib32-dbus-1.14.6-2
lib32-libcap-2.68-1 lib32-libdrm-2.4.115-1 lib32-libelf-0.189-1 lib32-libgcrypt-1.10.2-1
lib32-libldap-2.6.4-1 lib32-libltdl-2.4.7-3 lib32-libpsl-0.21.2-1 lib32-libpulse-16.1-6
lib32-libva-mesa-driver-23.0.3-1 lib32-libx11-1.8.4-1 lib32-libxml2-2.10.4-2
lib32-mesa-23.0.3-1 lib32-mesa-vdpau-23.0.3-1 lib32-openssl-1:3.0.8-1 lib32-opus-1.4-1
lib32-systemd-252.10-2 lib32-tdb-1.4.8-1 lib32-vulkan-icd-loader-1.3.245-1
lib32-vulkan-intel-23.0.3-1 lib32-vulkan-radeon-23.0.3-1 lib32-wayland-1.22.0-1
lib32-xz-5.4.2-1 lib32-zstd-1.5.5-1 libaio-0.3.113-2 libass-0.17.1-1 libassuan-2.5.5-2
libavc1394-0.5.4-5 libavtp-0.2.0-2 libbpf-1.1.0-1 libcamera-0.0.4-4 libcamera-ipa-0.0.4-4
libcap-2.68-1 libcbor-0.10.2-1 libcups-1:2.4.2-6 libde265-1.0.11-2 libdecor-0.1.1-2
libdiscid-0.6.4-2 libdrm-2.4.115-1 libdv-1.0.0-10 libedit-20221030_3.1-1 libelf-0.189-1
libgcrypt-1.10.2-1 libgirepository-1.76.1-1 libgit2-1:1.6.4-1 libgme-0.6.3-2
libgpg-error-1.47-1 libhandy-1.8.2-1 libheif-1.15.2-1 libibus-1.5.28-3 libice-1.1.1-2
libid3tag-0.15.1b-12 libimagequant-4.1.1-1 libinput-1.23.0-1 libinstpatch-1.1.6-2
libisl-0.26-1 libjcat-0.1.13-2 libjpeg-turbo-2.1.5.1-1 libjxl-0.8.1-1 libkate-0.4.1-9
libkcddb-23.04.0-1 libkcompactdisc-23.04.0-1 libkdcraw-23.04.0-1 libkexiv2-23.04.0-1
libksane-23.04.0-1 libkscreen-5.27.4-1 libksysguard-5.27.4-1 libldap-2.6.4-2
libmad-0.15.1b-10 libmalcontent-0.11.1-1 libmanette-0.2.6-4 libmbim-1.28.4-1
libmfx-23.1.6-1 libmm-glib-1.20.6-1 libmtp-1.1.21-1 libnftnl-1.2.5-1 libnghttp2-1.52.0-2
libnice-0.1.21-2 libnm-1.42.6-1 libnotify-0.8.2-1 libnsl-2.0.0-3 libopenmpt-0.6.10-1
libpamac-11.5.3-1 libpamac-flatpak-plugin-11.5.3-1 libpaper-2.1.0-1 libpcap-1.10.4-1
libpipewire-1:0.3.70-1 libplacebo-5.229.2-2 libpulse-16.1-6 libqalculate-4.6.1-1
libqmi-1.32.4-1 libraqm-0.10.1-1 librsvg-2:2.56.0-1 libsamplerate-0.2.2-2 libsoup3-3.4.1-1
libsysprof-capture-3.48.0-1 libtiff-4.5.0-3 libtraceevent-1:1.7.2-1 libtracefs-1.6.4-2
libupnp-1.14.16-1 liburcu-0.14.0-1 libusb-1.0.26-2 libva-2.18.0-1
libva-mesa-driver-23.0.3-1 libvpx-1.13.0-1 libwacom-2.6.0-2 libwbclient-4.18.2-1
libwireplumber-0.4.14-1 libwpe-1.14.1-2 libx86emu-3.5-3 libxau-1.0.11-2 libxaw-1.0.15-1
libxdmcp-1.1.4-2 libxfixes-6.0.1-1 libxfont2-2.0.6-2 libxft-2.3.8-1 libxi-1.8-3
libxklavier-5.4-4 libxml2-2.10.4-2 libxmlb-0.3.11-1 libxpm-3.5.16-1 libxt-1.3.0-1
libxvmc-1.0.13-2 licenses-20220125-2 linux-firmware-20230404.2e92a49f-1
linux-firmware-whence-20230404.2e92a49f-1 linux61-6.1.26-1 llvm-15.0.7-2 llvm-libs-15.0.7-2
lmdb-0.9.30-3 lua-5.4.4-4 lvm2-2.03.21-1 man-pages-6.04-1 manjaro-hello-0.7.0-5
manjaro-kde-settings-20230505-2 manjaro-log-helper-0.3.4+3+ga471e55-1
manjaro-release-22.1.1-1 manjaro-zsh-config-0.25-2 mesa-23.0.3-1 mesa-demos-9.0.0-2
mesa-utils-9.0.0-2 mesa-vdpau-23.0.3-1 mhwd-0.6.5-25 mhwd-db-0.6.5-25
mhwd-nvidia-530.41.03-4 mhwd-nvidia-390xx-390.157-6 mhwd-nvidia-470xx-470.182.03-2
milou-5.27.4-1 mkinitcpio-35.2-2 mobile-broadband-provider-info-20230416-1
modemmanager-1.20.6-1 modemmanager-qt-5.105.0-1 mpg123-1.31.3-1 nbd-3.24-2 ndctl-76.1-1
networkmanager-1.42.6-1 networkmanager-pptp-1.2.12-1 networkmanager-qt-5.105.0-1
networkmanager-vpnc-1.2.8-3 nfs-utils-2.6.3-1 nfsidmap-2.6.3-1 nftables-1:1.0.7-1
noto-fonts-20230401-1 npth-1.6-4 nss-3.89-1 okular-23.04.0-1
onlyoffice-desktopeditors-7.3.3-1 openal-1.23.1-1 openexr-3.1.7-1 openmpi-4.1.5-1
openpmix-4.2.3-2 openresolv-3.13.0-1 openssh-9.3p1-1 openvpn-2.6.3-1 opus-1.4-1
ostree-2023.2-1 oxygen-5.27.4-1 oxygen-icons-1:5.105.0-1 oxygen-sounds-5.27.4-1
p7zip-1:17.05-1 packagekit-qt5-1.1.1-1 pacman-6.0.2-10 pacui-1.14+56+g4976123-3
pam-1.5.2-2 pamac-cli-10.5.1-1 pamac-gtk-10.5.1-1 pango-1:1.50.14-1 parted-3.6-1
partitionmanager-23.04.0-1 pcsclite-1.9.9-3 perl-http-daemon-6.16-1 pipewire-1:0.3.70-1
plasma-browser-integration-5.27.4-1 plasma-desktop-5.27.4-1 plasma-framework-5.105.0-1
plasma-integration-5.27.4-1 plasma-nm-5.27.4-1 plasma-pa-5.27.4-1
plasma-systemmonitor-5.27.4-1 plasma-workspace-5.27.4.1-1
plasma-workspace-wallpapers-5.27.4.1-1 plymouth-22.02.122-12 polkit-kde-agent-5.27.4.1-1
poppler-23.03.0-1 poppler-glib-23.03.0-1 poppler-qt5-23.03.0-1 portaudio-1:19.7.0-2
powerdevil-5.27.4.1-1 print-manager-23.04.0-1 prison-5.105.0-1 pulseaudio-16.1-6
pulseaudio-alsa-1:1.2.7.1-2 pulseaudio-bluetooth-16.1-6 pulseaudio-zeroconf-16.1-6
purpose-5.105.0-1 pyside6-6.5.0-1 python-3.10.10-1 python-cryptography-40.0.1-1
python-fastjsonschema-2.16.3-1 python-gobject-3.44.1-1 python-inflect-6.0.4-1
python-jaraco.functools-3.6.0-1 python-more-itertools-9.1.1-1 python-pip-23.0.1-1
python-platformdirs-3.2.0-1 python-pydantic-1.10.7-2 python-pyqt5-sip-12.12.1-1
python-requests-2.28.2-1 python-setuptools-1:67.6.1-1 python-trove-classifiers-2023.4.18-1
python-typing_extensions-4.5.0-1 python-urllib3-1.26.13-1 python-validate-pyproject-0.12.2-1
python-wheel-0.40.0-1 qpdf-11.3.0-1 qqc2-desktop-style-5.105.0-1 qt5-base-5.15.9+kde+r151-1
qt5-declarative-5.15.9+kde+r24-1 qt5-graphicaleffects-5.15.9-1
qt5-imageformats-5.15.9+kde+r9-1 qt5-location-5.15.9+kde+r4-1 qt5-multimedia-5.15.9+kde+r3-1
qt5-quickcontrols-5.15.9-1 qt5-quickcontrols2-5.15.9+kde+r5-1 qt5-sensors-5.15.9-1
qt5-speech-5.15.9+kde+r1-1 qt5-svg-5.15.9+kde+r7-1 qt5-tools-5.15.9+kde+r1-1
qt5-translations-5.15.9-1 qt5-virtualkeyboard-5.15.9-1 qt5-wayland-5.15.9+kde+r55-1
qt5-webchannel-5.15.9+kde+r3-1 qt5-webengine-5.15.13-2 qt5-webview-5.15.9-1
qt5-x11extras-5.15.9-1 qt5-xmlpatterns-5.15.9-1 qt6-base-6.5.0-3 qt6-declarative-6.5.0-2
qt6-translations-6.5.0-1 raptor-2.0.16-2 re2-1:20230301-1 rsync-3.2.7-4 samba-4.18.2-1
sane-1.2.1-4 sddm-kcm-5.27.4.1-1 sdl2-2.26.5-1 sed-4.9-3 shaderc-2023.3-1
shiboken6-6.5.0-1 signon-kwallet-extension-23.04.0-1 skanlite-23.04.0-1 smbclient-4.18.2-1
snapper-gui-0.1.r8.g1915750-1 solid-5.105.0-1 sonnet-5.105.0-1 spectacle-23.04.0-1
spectre-meltdown-checker-0.45+8+g6a61df2-1 sqlite-3.41.2-1 squashfs-tools-4.6.1-1
sudo-1.9.13.p3-1 syndication-5.105.0-1 syntax-highlighting-5.105.0-1 systemd-252.10-2
systemd-libs-252.10-2 systemd-sysvcompat-252.10-2 systemsettings-5.27.4.1-1 tar-1.34-2
texinfo-7.0.3-1 thin-provisioning-tools-1.0.3-1 threadweaver-5.105.0-1 tracker3-3.5.0-1
ttf-meslo-nerd-font-powerlevel10k-20230403-2 ttf-noto-nerd-2.3.3-2 twolame-0.4.0-3
tzdata-2023c-1 util-linux-2.38.1-3 util-linux-libs-2.38.1-3 v4l-utils-1.24.1-1
vid.stab-1.1.1-1 virtualbox-guest-utils-7.0.8-1 vlc-3.0.18-9 vpnc-1:0.5.3.r526.r213-1
vte-common-0.72.1-1 vte3-0.72.1-1 vulkan-headers-1:1.3.246-1 vulkan-icd-loader-1.3.245-1
vulkan-intel-23.0.3-1 vulkan-radeon-23.0.3-1 vulkan-tools-1.3.245-1 wayland-1.22.0-1
wayland-protocols-1.31-1 webkit2gtk-2.40.1-1 webkit2gtk-4.1-2.40.1-1
wireless-regdb-2023.02.13-1 wireplumber-0.4.14-1 wpebackend-fdo-1.14.2-1
xapian-core-1:1.4.22-1 xapp-2.4.3-1 xdg-desktop-portal-kde-5.27.4.1-1
xf86-input-libinput-1.3.0-1 xf86-video-amdgpu-23.0.0-1 xfsprogs-6.2.0-1
xorg-fonts-encodings-1.0.7-1 xorg-server-21.1.8-1 xorg-server-common-21.1.8-1
xorg-setxkbmap-1.3.3-2 xxhash-0.8.1-4 xz-5.4.2-1 yakuake-23.04.0-1 zenity-3.44.0-3
zsh-autosuggestions-0.7.0-2 zsh-completions-0.34.0-4 zsh-history-substring-search-1.0.2-2
zsh-theme-powerlevel10k-1.17.0+23+g1cff2249-1 zstd-1.5.5-1 zvbi-0.2.41-1 zxing-cpp-2.0.0-2
Total Download Size: 1872.40 MiB
Total Installed Size: 6236.96 MiB
Net Upgrade Size: -103.60 MiB
