Problem with boot partition Acer Aspire 5742G
Hi all,
During the update the power went out and my boot partition was corrupted. I can’t boot normally only the live CD helps here.
I ask you all for help because I can’t cope with this anymore.
Best regards
Hi,
I hope this wiki article might help in case the bootloader is broken:
https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader#For_UEFI_Systems
A corrupt package state might be repaired using this guide:
Good luck!
Andreas
I also tried this and without success
[manjaro manjaro]# inxi -fazv7
  Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2205 quiet
    systemd.show_status=1 splash driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Acer product: Aspire 5742G v: V1.30 serial: <filter>
  Mobo: Acer model: Aspire 5742G v: V1.30 serial: N/A BIOS: Acer v: 1.30
    date: 08/13/2012
  ID-1: BAT0 charge: 47.2 Wh (100.0%) condition: 47.2/95.0 Wh (49.7%)
    volts: 12.3 min: 10.8 model: PANASONIC Li_Ion_4000mA type: Li-ion
    serial: <filter> status: full
  RAM: total: 7.44 GiB used: 2.79 GiB (37.5%)
  Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB
  Device-1: DIMM0 info: single-bank type: DDR3 detail: synchronous
    size: 4 GiB speed: 1067 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471B5273DH0-CH9 serial: <filter>
  Device-2: DIMM1 info: single-bank type: DDR3 detail: synchronous
    manufacturer: ELPIDA part-no: EBJ41UF8BAS0-DJ-F serial: <filter>
  Info: model: Intel Core i5 M 460 bits: 64 type: MT MCP arch: Westmere
    gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
    model-id: 0x25 (37) stepping: 5 microcode: 0x7
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1532 high: 2534 min/max: 1199/2534 boost: enabled
    base/boost: 2522/2533 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 0.0 V ext-clock: 1066 MHz cores: 1: 1199 2: 2534 3: 1199 4: 1199
    bogomips: 20226
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
    monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pdcm pebs pge pni
    popcnt pse pse36 pti rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology
    xtpr
    vulnerable
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Core Processor Integrated Graphics
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-5.75
    process: Intel 45nm built: 2010 ports: active: LVDS-1
    empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0046
    class-ID: 0300
  Device-2: NVIDIA GF108M [GeForce GT 540M] vendor: Acer Incorporated ALI
    driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: series: 390.xx+
    status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
    process: 40/28nm built: 2010-16 pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:0df4 class-ID: 0300
  Device-3: Suyin 1.3M HD WebCam type: USB driver: uvcvideo bus-ID: 1-1.1:3
    chip-ID: 064e:c218 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: LVDS-1 mapped: LVDS1 model: AU Optronics 0x22ec built: 2009
    res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
    diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
  API: OpenGL v: 2.1 Mesa 22.3.5 renderer: Mesa Intel HD Graphics (ILK)
    direct-render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:3b56 class-ID: 0403
  Device-2: NVIDIA GF108 High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
  Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
    vendor: Acer Incorporated ALI driver: N/A modules: tg3 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 14e4:1692
    class-ID: 0200
  Device-2: Broadcom BCM43225 802.11b/g/n vendor: Foxconn T77H103.00
    Wireless Half-size Mini PCIe Card driver: bcma-pci-bridge v: N/A
    modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 14e4:4357 class-ID: 0280
  IF-ID-1: wlp3s0b1 state: up mac: <filter>
  Local Storage: total: 961.32 GiB used: 228.35 GiB (23.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    family: based SSDs size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 3.0 Gb/s type: SSD serial: <filter>
    rev: 4B6Q temp: 32 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 162d 6h cycles: 2125
    written: 4.21 TiB
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Lexar
    model: USB Flash Drive size: 29.81 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT32N rev: 1.00
    dev-links: cdrom
  ID-1: /run/media/manjaro/220a1af9-6149-4610-b459-8a45115148b3
    raw-size: 56 MiB size: 49.2 MiB (87.91%) used: 14 KiB (0.0%) fs: ext4
    block-size: 1024 B dev: /dev/sda6 maj-min: 8:6 label: N/A
    uuid: 220a1af9-6149-4610-b459-8a45115148b3
  ID-2: /run/media/manjaro/515D-BD42 raw-size: 300 GiB
    size: 299.93 GiB (99.98%) used: 32 KiB (0.0%) fs: vfat block-size: 512 B
    dev: /dev/sda4 maj-min: 8:4 label: N/A uuid: 515D-BD42
  ID-3: /run/media/manjaro/6763df11-af8e-4a4d-8992-c71075fd63f2
    raw-size: 321.97 GiB size: 315.85 GiB (98.10%) used: 221.68 GiB (70.2%)
    fs: ext4 block-size: 4096 B dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 6763df11-af8e-4a4d-8992-c71075fd63f2
  ID-4: /run/media/manjaro/bfd472f8-ae4f-4c53-8be6-38e57d530867
    raw-size: 292.98 GiB size: 287.33 GiB (98.07%) used: 6.67 GiB (2.3%)
    fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: bfd472f8-ae4f-4c53-8be6-38e57d530867
  ID-1: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
    uuid: 5288-D5A4
  ID-2: /dev/sda3 maj-min: 8:3 size: 16 GiB fs: vfat label: N/A
    uuid: 50EC-367D
  ID-3: /dev/sdb1 maj-min: 8:17 size: 3.8 GiB fs: iso9660
  ID-4: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 623B-25B9
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
  Device-1: 1-1.1:3 info: Suyin 1.3M HD WebCam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 064e:c218
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.1:6 info: Logitech Unifying Receiver type: Keyboard,Mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 98mA chip-ID: 046d:c534 class-ID: 0301
  Device-2: 2-1.2:3 info: Lexar Media JumpDrive Tough type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
    chip-ID: 05dc:a838 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 194 Uptime: 1h 31m wakeups: 1 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1202 libs: 324 tools: pamac pm: flatpak pkgs: 0
  Shell: Bash (su) v: 5.1.16 running-in: konsole inxi: 3.3.25
[manjaro manjaro]# systemctl status sddm
● sddm.service - Simple Desktop Display Manager
     Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: disabled)
     Active: active (running) since Tue 2023-05-16 15:51:29 UTC; 1h 39min ago
       Docs: man:sddm(1)
             man:sddm.conf(5)
   Main PID: 1103 (sddm)
      Tasks: 5 (limit: 9074)
     Memory: 166.7M
        CPU: 1min 45.599s
     CGroup: /system.slice/sddm.service
             ├─1103 /usr/bin/sddm
             └─1109 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{d735e4d>
May 16 15:51:32 manjaro sddm-helper[1116]: [PAM] Preparing to converse...
May 16 15:51:32 manjaro sddm-helper[1116]: [PAM] Conversation with 1 messages
May 16 15:51:32 manjaro sddm-helper[1116]: [PAM] returning.
May 16 15:51:32 manjaro sddm-helper[1116]: pam_systemd_home(sddm-autologin:account): systemd-homed is not ava>
May 16 15:51:32 manjaro sddm[1103]: Authenticated successfully
May 16 15:51:32 manjaro sddm-helper[1116]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
May 16 15:51:32 manjaro sddm-helper[1116]: pam_unix(sddm-autologin:session): session opened for user manjaro(>
May 16 15:51:32 manjaro sddm-helper[1116]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_se>
May 16 15:51:32 manjaro sddm-helper[1116]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma>
May 16 15:51:32 manjaro sddm[1103]: Session started
...skipping...
       Docs: man:sddm(1)
             man:sddm.conf(5)
     Memory: 166.7M
        CPU: 1min 45.599s
[manjaro manjaro]# sudo update-grub
/usr/bin/grub-probe: error: failed to get canonical path of `overlay'.
boot into manjaro live usb, make sure you are connected to internet, open terminal and chroot:
manjaro-chroot -a
rerun update:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here, if there are no errors and you are up to date, post output from:
mhwd-kernel -li && mhwd -l -li
pacman -Qs nvidia
ldconfig - (this should return nothing)
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
[manjaro manjaro]# manjaro-chroot -a grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map. grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map. ==> ERROR: No Linux partitions detected!
[manjaro manjaro]# mhwd-kernel -li && mhwd -l -li
Currently running: 6.1.19-1-MANJARO (linux61)
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
   * linux61
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> Installed PCI configs:
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.26               false            PCI
> 0000:03:00.0 (0200:14e4:4357) Network controller Broadcom:
   network-broadcom-wl            2018.10.07               false            PCI
> 0000:01:00.0 (0300:10de:0df4) Display controller nVidia Corporation:
    video-nvidia-390xx            2021.11.26               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0046) Display controller Intel Corporation:
[manjaro manjaro]# pacman -Qs nvidia
local/bumblebee 3.2.1-23
    NVIDIA Optimus support for Linux through Primus/VirtualGL
local/egl-wayland 2:1.1.11-3
    EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
    Nvidia VDPAU library
local/lib32-nvidia-390xx-utils 390.157-3
    NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl-390xx 390.157-1
    NVIDIA NV-CONTROL X extension
local/linux61-nvidia-390xx 390.157-24 (linux61-extramodules)
    NVIDIA drivers for linux
local/mhwd-nvidia 525.89.02-1
    MHWD module-ids for nvidia 525.89.02
local/mhwd-nvidia-390xx 390.157-1
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.161.03-2
    MHWD module-ids for nvidia 470.161.03
local/nvidia-390xx-utils 390.157-2
[manjaro manjaro]# ls /etc/modprobe.d
mhwd-bbswitch.conf mhwd-nvidia.conf
[manjaro manjaro]# find /etc/X11/ -name "*.conf"
/etc/X11/mhwd.d/intel.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
if you cant chroot, those outputs are useless… and they are not even properly formatted, like the inxi and sddm status outputs…
are you using btrfs or encryption?
[manjaro manjaro]# pacman-mirrors -f 5 && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  3.680 India          : https://mirrors.vishnetwork.in/manjaro/
  3.056 Russia         : https://mirror.yandex.ru/mirrors/manjaro/
  ..... China          : https://mirrors.jlu.edu.cn/manjaro/
  3.079 Ukraine        : https://manjaro.astra.in.ua/
  3.586 Mauritius      : https://manjarolinux-mirror.cloud.mu/
::INFO Writing mirror list
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/stable
::Ukraine         : https://manjaro.astra.in.ua/stable
::Mauritius       : https://manjarolinux-mirror.cloud.mu/stable
::India           : https://mirrors.vishnetwork.in/manjaro/stable
::China           : https://mirrors.jlu.edu.cn/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                                  141.1 KiB  45.6 KiB/s 00:03 [####################################] 100%
 extra                                1640.5 KiB  50.5 KiB/s 00:32 [####################################] 100%
 community                               6.8 MiB  47.0 KiB/s 02:28 [####################################] 100%
 multilib                              145.2 KiB  17.7 KiB/s 00:08 [####################################] 100%
error: failed retrieving file 'community.db' from mirror.yandex.ru : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'community.db' from manjaro.astra.in.ua : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'community.db' from manjarolinux-mirror.cloud.mu : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'community.db' from mirrors.vishnetwork.in : Resolving timed out after 10000 milliseconds
:: Some packages should be upgraded first...
resolving dependencies...
Packages (3) archlinux-keyring-20230320-1  manjaro-keyring-20230318-1  manjaro-system-20230401-1
Total Download Size:   1.69 MiB
Total Installed Size:  2.31 MiB
Net Upgrade Size:      0.01 MiB
None of the above
From the liveUSB, show the output of:
fdisk -l
and
blkid
:: Retrieving packages...
 archlinux-keyring-20230320-1-any     1156.8 KiB  51.6 KiB/s 00:22 [####################################] 100%
 manjaro-keyring-20230318-1-any        547.7 KiB  50.9 KiB/s 00:11 [####################################] 100%
 manjaro-system-20230401-1-any          29.0 KiB  46.7 KiB/s 00:01 [####################################] 100%
 Total (3/3)                          1733.5 KiB  50.6 KiB/s 00:34 [####################################] 100%
(3/3) checking keys in keyring                                     [####################################] 100%
(3/3) checking package integrity                                   [####################################] 100%
(3/3) loading package files                                        [####################################] 100%
(3/3) checking for file conflicts                                  [####################################] 100%
(3/3) checking available disk space                                [####################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap because system is booted in Live CD mode...
(1/3) upgrading archlinux-keyring                                  [####################################] 100%
==> Appending keys from archlinux.gpg...
==> Updating trust database...
gpg: next trustdb check due at 2023-07-07
(2/3) upgrading manjaro-keyring                                    [####################################] 100%
==> Appending keys from manjaro.gpg...
gpg: error reading key: No public key
==> Locally signing trusted keys in keyring...
  -> Locally signed 2 keys.
==> Importing owner trust values...
==> Disabling revoked keys in keyring...
  -> Disabled 8 keys.
(3/3) upgrading manjaro-system                                     [####################################] 100%
==> Checking for 'os-prober' setup ...
    We will reenable 'os-prober' for you ...
==> Checking if graphic drivers need an update ...
(1/3) Reloading system manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Refreshing PackageKit...
warning: dependency cycle detected:
warning: libcamera-ipa will be installed before its libcamera dependency
warning: mhwd-nvidia will be installed before its mhwd dependency
warning: mhwd-nvidia-390xx will be installed before its mhwd dependency
warning: mhwd-nvidia-470xx will be installed before its mhwd dependency
Packages (562) accountsservice-23.13.9-1  adobe-source-code-pro-fonts-2.042u+1.062i+1.026vf-1
               adobe-source-sans-fonts-3.052-1  alsa-firmware-1.2.4-3  alsa-oss-1.1.8-5
               alsa-plugins-1:1.2.7.1-2  alsa-topology-conf-1.2.5.1-3  amd-ucode-20230404.2e92a49f-1
               appstream-0.16.1-2  appstream-glib-0.8.2-2  appstream-qt-0.16.1-2
               archlinux-appstream-data-20230421-1  ark-23.04.0-1  at-spi2-core-2.48.0-2  attica-5.105.0-1
               attr-2.5.1-3  audiocd-kio-23.04.0-1  audit-3.1-1  baloo-5.105.0-1  baloo-widgets-23.04.0-1
               bluedevil-1:5.27.4-1  bluez-qt-5.105.0-1  breeze-5.27.4-1  breeze-gtk-5.27.4-2.1
               breeze-icons-5.105.0-1  brotli-1.0.9-10  btrfs-progs-6.2.2-1  bubblewrap-0.8.0-1
               ca-certificates-mozilla-3.89-1  calamares-3.2.62-1  chromaprint-1.5.1-7  cifs-utils-7.0-3
               ckbcomp-1.215-1  clang-15.0.7-2  clinfo-3.0.21.02.21-1  cmus-2.10.0-4  coreutils-9.3-1
               cpupower-6.2-1  cracklib-2.9.11-1  cryptsetup-2.6.1-3.2  cups-1:2.4.2-6
               cups-filters-1.28.17-2  curl-8.0.1-1  cython-0.29.34-1  dav1d-1.1.0-1  dbus-1.14.6-2
               dbus-python-1.2.18-4  device-mapper-2.03.21-1  dmidecode-3.5-1  dolphin-23.04.0-2
               dolphin-plugins-23.04.0-1  efibootmgr-18-2  efivar-38-3  egl-wayland-2:1.1.11-4
               elisa-23.04.0-1  enchant-2.3.4-1  f2fs-tools-1.16.0-1  faac-1.30-4  ffmpeg-2:6.0-5
               ffmpeg4.4-4.4.3-2  ffmpegthumbs-23.04.0-1  fftw-3.3.10-4  file-5.44-3  filelight-23.04.0-1
               filesystem-2023.03.21-1  findutils-4.9.0-3  firefox-113.0-0.1  flatpak-1:1.15.4-1
               fluidsynth-2.3.2-1  foomatic-db-3:20230402-1  foomatic-db-nonfree-3:20230402-1
               foomatic-db-nonfree-ppds-3:20230402-1  foomatic-db-ppds-3:20230402-1
               frameworkintegration-5.105.0-1  fuse-common-3.14.1-1  fuse3-3.14.1-1  fwupd-1.8.14-1
               fzf-0.39.0-1  gawk-5.2.1-2  gdbm-1.23-2  gettext-0.21.1-5  ghostscript-10.01.1-1  git-2.40.1-1
               glib-networking-1:2.76.0-1  glib2-2.76.1-1  glibmm-2.66.6-1  glslang-12.1.0-1  gnupg-2.2.41-1
               gnutls-3.8.0-1  gobject-introspection-runtime-1.76.1-1  gparted-1.5.0-1  gperftools-2.10-1
               gpgme-1.20.0-1  grep-3.10-1  groff-1.22.4-10  grub-2.06.r499.ge67a551a4-2
               grub-theme-live-common-20.2-15  grub-theme-live-manjaro-20.2-15  grub-theme-manjaro-20.2-15
               gsettings-desktop-schemas-44.0-1  gsfonts-20200910-3  gst-libav-1.22.1-2
               gst-plugins-bad-1.22.1-2  gst-plugins-bad-libs-1.22.1-2  gst-plugins-base-1.22.1-2
               gst-plugins-base-libs-1.22.1-2  gst-plugins-good-1.22.1-2  gst-plugins-ugly-1.22.1-2
               gstreamer-1.22.1-2  gtk-update-icon-cache-1:4.10.3-1  gtk3-1:3.24.37-1  gupnp-igd-1.6.0-1
               gwenview-23.04.0-1  harfbuzz-7.1.0-1  harfbuzz-icu-7.1.0-1  hicolor-icon-theme-0.17-3
               hidapi-0.13.1-2  highway-1.0.4-1  hwdata-0.369-1  hwloc-2.9.1-1  iana-etc-20230405-1
               imagemagick-7.1.1.8-1  imath-3.1.7-1  imlib2-1.11.0-1  inetutils-2.4-1  intel-ucode-20230214-1
               inxi-3.3.27.1-1  iproute2-6.2.0-2  iso-codes-4.13.0-1  kaccounts-integration-23.04.0-1
               kaccounts-providers-23.04.0-1  kactivities-5.105.0-1  kactivities-stats-5.105.0-1
               kactivitymanagerd-5.27.4-1  kamera-23.04.0-1  karchive-5.105.0-1  kate-23.04.0-1
               kauth-5.105.0-1  kbookmarks-5.105.0-1  kcalc-23.04.0-1  kcmutils-5.105.0-1  kcodecs-5.105.0-1
               kcompletion-5.105.0-1  kconfig-5.105.0-1  kconfigwidgets-5.105.0-1  kcontacts-1:5.105.0-1
               kcoreaddons-5.105.0-1  kcrash-5.105.0-1  kdbusaddons-5.105.0-1  kde-cli-tools-5.27.4-1
               kde-gtk-config-5.27.4-1  kdeclarative-5.105.0-1  kdeconnect-23.04.0-1  kdecoration-5.27.4-1
               kded-5.105.0-1  kdegraphics-mobipocket-23.04.0-1  kdegraphics-thumbnailers-23.04.0-1
               kdelibs4support-5.105.0-1  kdenetwork-filesharing-23.04.0-1  kdeplasma-addons-5.27.4-1
               kdesu-5.105.0-1  kdnssd-5.105.0-1  kdoctools-5.105.0-1  keditbookmarks-23.04.0-1
               kemoticons-5.105.0-1  kfilemetadata-5.105.0-1  kfind-23.04.0-1  kgamma5-5.27.4-1
               kglobalaccel-5.105.0-1  kguiaddons-5.105.0-1  khelpcenter-23.04.0-1  kholidays-1:5.105.0-1
               khotkeys-5.27.4-1  khtml-5.105.0-1  ki18n-5.105.0-1  kiconthemes-5.105.0-1
               kidletime-5.105.0-1  kimageannotator-0.6.1-1  kimageformats-5.105.0-1  kinfocenter-5.27.4-1
               kinit-5.105.0-1  kio-5.105.0-1  kio-extras-23.04.0-1  kirigami-addons-0.8.0-1
               kirigami2-5.105.0-1  kitemmodels-5.105.0-1  kitemviews-5.105.0-1  kjobwidgets-5.105.0-1
               kjs-5.105.0-1  kmenuedit-5.27.4-1  knewstuff-5.105.0-1  knotifications-5.105.0-1
               knotifyconfig-5.105.0-1  konsole-23.04.0-1  kpackage-5.105.0-1  kparts-5.105.0-1
               kpeople-5.105.0-1  kpipewire-5.27.4-1  kpmcore-23.04.0-1  kpty-5.105.0-1
               kquickcharts-5.105.0-1  krunner-5.105.0-1  ksanecore-23.04.0-1  kscreen-5.27.4-1
               kscreenlocker-5.27.4-1  kservice-5.105.0-1  ksshaskpass-5.27.4-1  ksystemlog-23.04.0-1
               ksystemstats-5.27.4-1  ktexteditor-5.105.0-1  ktextwidgets-5.105.0-1
               kunitconversion-5.105.0-1  kwallet-5.105.0-1  kwallet-pam-5.27.4-1  kwalletmanager-23.04.0-1
               kwayland-5.105.0-1  kwayland-integration-5.27.4-1  kwidgetsaddons-5.105.0-1  kwin-5.27.4.1-1
               kwindowsystem-5.105.0-1  kwrited-5.27.4-1  kxmlgui-5.105.0-1  l-smash-2.14.5-3
               layer-shell-qt-5.27.4-1  lcms2-2.15-1  ldb-2:2.7.2-1  lib32-curl-8.0.1-1  lib32-dbus-1.14.6-2
               lib32-libcap-2.68-1  lib32-libdrm-2.4.115-1  lib32-libelf-0.189-1  lib32-libgcrypt-1.10.2-1
               lib32-libldap-2.6.4-1  lib32-libltdl-2.4.7-3  lib32-libpsl-0.21.2-1  lib32-libpulse-16.1-6
               lib32-libva-mesa-driver-23.0.3-1  lib32-libx11-1.8.4-1  lib32-libxml2-2.10.4-2
               lib32-mesa-23.0.3-1  lib32-nvidia-390xx-utils-390.157-4  lib32-openssl-1:3.0.8-1
               lib32-opus-1.4-1  lib32-systemd-252.10-2  lib32-tdb-1.4.8-1  lib32-vulkan-icd-loader-1.3.245-1
               lib32-wayland-1.22.0-1  lib32-xz-5.4.2-1  lib32-zstd-1.5.5-1  libaio-0.3.113-2
               libass-0.17.1-1  libassuan-2.5.5-2  libavc1394-0.5.4-5  libavtp-0.2.0-2  libbpf-1.1.0-1
               libcamera-0.0.4-4  libcamera-ipa-0.0.4-4  libcap-2.68-1  libcbor-0.10.2-1  libcups-1:2.4.2-6
               libde265-1.0.11-2  libdecor-0.1.1-2  libdiscid-0.6.4-2  libdrm-2.4.115-1  libdv-1.0.0-10
               libedit-20221030_3.1-1  libelf-0.189-1  libgcrypt-1.10.2-1  libgirepository-1.76.1-1
               libgit2-1:1.6.4-1  libgme-0.6.3-2  libgpg-error-1.47-1  libhandy-1.8.2-1  libheif-1.15.2-1
               libibus-1.5.28-3  libice-1.1.1-2  libid3tag-0.15.1b-12  libimagequant-4.1.1-1
               libinput-1.23.0-1  libinstpatch-1.1.6-2  libisl-0.26-1  libjcat-0.1.13-2
               libjpeg-turbo-2.1.5.1-1  libjxl-0.8.1-1  libkate-0.4.1-9  libkcddb-23.04.0-1
               libkcompactdisc-23.04.0-1  libkdcraw-23.04.0-1  libkexiv2-23.04.0-1  libksane-23.04.0-1
               libkscreen-5.27.4-1  libksysguard-5.27.4-1  libldap-2.6.4-2  libmad-0.15.1b-10
               libmalcontent-0.11.1-1  libmanette-0.2.6-4  libmbim-1.28.4-1  libmfx-23.1.6-1
               libmm-glib-1.20.6-1  libmtp-1.1.21-1  libnftnl-1.2.5-1  libnghttp2-1.52.0-2  libnice-0.1.21-2
               libnm-1.42.6-1  libnotify-0.8.2-1  libnsl-2.0.0-3  libopenmpt-0.6.10-1  libpamac-11.5.3-1
               libpamac-flatpak-plugin-11.5.3-1  libpaper-2.1.0-1  libpcap-1.10.4-1  libpipewire-1:0.3.70-1
               libplacebo-5.229.2-2  libpulse-16.1-6  libqalculate-4.6.1-1  libqmi-1.32.4-1  libraqm-0.10.1-1
               librsvg-2:2.56.0-1  libsamplerate-0.2.2-2  libsoup3-3.4.1-1  libsysprof-capture-3.48.0-1
               libtiff-4.5.0-3  libtraceevent-1:1.7.2-1  libtracefs-1.6.4-2  libupnp-1.14.16-1
               liburcu-0.14.0-1  libusb-1.0.26-2  libva-2.18.0-1  libva-mesa-driver-23.0.3-1  libvpx-1.13.0-1
               libwacom-2.6.0-2  libwbclient-4.18.2-1  libwireplumber-0.4.14-1  libwpe-1.14.1-2
               libx86emu-3.5-3  libxau-1.0.11-2  libxaw-1.0.15-1  libxdmcp-1.1.4-2  libxfixes-6.0.1-1
               libxfont2-2.0.6-2  libxft-2.3.8-1  libxi-1.8-3  libxklavier-5.4-4  libxml2-2.10.4-2
               libxmlb-0.3.11-1  libxnvctrl-390xx-390.157-4  libxpm-3.5.16-1  libxt-1.3.0-1  libxvmc-1.0.13-2
               licenses-20220125-2  linux-firmware-20230404.2e92a49f-1
               linux-firmware-whence-20230404.2e92a49f-1  linux61-6.1.26-1  linux61-bbswitch-0.8-31
               linux61-nvidia-390xx-390.157-31  llvm-15.0.7-2  llvm-libs-15.0.7-2  lmdb-0.9.30-3  lua-5.4.4-4
               lvm2-2.03.21-1  man-pages-6.04-1  manjaro-hello-0.7.0-5  manjaro-kde-settings-20230505-2
               manjaro-log-helper-0.3.4+3+ga471e55-1  manjaro-release-22.1.1-1  manjaro-zsh-config-0.25-2
               mesa-23.0.3-1  mesa-demos-9.0.0-2  mesa-utils-9.0.0-2  mhwd-0.6.5-25  mhwd-db-0.6.5-25
               mhwd-nvidia-530.41.03-4  mhwd-nvidia-390xx-390.157-6  mhwd-nvidia-470xx-470.182.03-2
               milou-5.27.4-1  mkinitcpio-35.2-2  mobile-broadband-provider-info-20230416-1
               modemmanager-1.20.6-1  modemmanager-qt-5.105.0-1  mpg123-1.31.3-1  nbd-3.24-2  ndctl-76.1-1
               networkmanager-1.42.6-1  networkmanager-pptp-1.2.12-1  networkmanager-qt-5.105.0-1
               networkmanager-vpnc-1.2.8-3  nfs-utils-2.6.3-1  nfsidmap-2.6.3-1  nftables-1:1.0.7-1
               noto-fonts-20230401-1  npth-1.6-4  nss-3.89-1  nvidia-390xx-utils-390.157-6  okular-23.04.0-1
               onlyoffice-desktopeditors-7.3.3-1  openal-1.23.1-1  openexr-3.1.7-1  openmpi-4.1.5-1
               openpmix-4.2.3-2  openresolv-3.13.0-1  openssh-9.3p1-1  openvpn-2.6.3-1  opus-1.4-1
               ostree-2023.2-1  oxygen-5.27.4-1  oxygen-icons-1:5.105.0-1  oxygen-sounds-5.27.4-1
               p7zip-1:17.05-1  packagekit-qt5-1.1.1-1  pacman-6.0.2-10  pacui-1.14+56+g4976123-3
               pam-1.5.2-2  pamac-cli-10.5.1-1  pamac-gtk-10.5.1-1  pango-1:1.50.14-1  parted-3.6-1
               partitionmanager-23.04.0-1  pcsclite-1.9.9-3  perl-http-daemon-6.16-1  pipewire-1:0.3.70-1
               plasma-browser-integration-5.27.4-1  plasma-desktop-5.27.4-1  plasma-framework-5.105.0-1
               plasma-integration-5.27.4-1  plasma-nm-5.27.4-1  plasma-pa-5.27.4-1
               plasma-systemmonitor-5.27.4-1  plasma-workspace-5.27.4.1-1
               plasma-workspace-wallpapers-5.27.4.1-1  plymouth-22.02.122-12  polkit-kde-agent-5.27.4.1-1
               poppler-23.03.0-1  poppler-glib-23.03.0-1  poppler-qt5-23.03.0-1  portaudio-1:19.7.0-2
               powerdevil-5.27.4.1-1  print-manager-23.04.0-1  prison-5.105.0-1  pulseaudio-16.1-6
               pulseaudio-alsa-1:1.2.7.1-2  pulseaudio-bluetooth-16.1-6  pulseaudio-zeroconf-16.1-6
               purpose-5.105.0-1  pyside6-6.5.0-1  python-3.10.10-1  python-cryptography-40.0.1-1
               python-fastjsonschema-2.16.3-1  python-gobject-3.44.1-1  python-inflect-6.0.4-1
               python-jaraco.functools-3.6.0-1  python-more-itertools-9.1.1-1  python-pip-23.0.1-1
               python-platformdirs-3.2.0-1  python-pydantic-1.10.7-2  python-pyqt5-sip-12.12.1-1
               python-requests-2.28.2-1  python-setuptools-1:67.6.1-1  python-trove-classifiers-2023.4.18-1
               python-typing_extensions-4.5.0-1  python-urllib3-1.26.13-1  python-validate-pyproject-0.12.2-1
               python-wheel-0.40.0-1  qpdf-11.3.0-1  qqc2-desktop-style-5.105.0-1  qt5-base-5.15.9+kde+r151-1
               qt5-declarative-5.15.9+kde+r24-1  qt5-graphicaleffects-5.15.9-1
               qt5-imageformats-5.15.9+kde+r9-1  qt5-location-5.15.9+kde+r4-1  qt5-multimedia-5.15.9+kde+r3-1
               qt5-quickcontrols-5.15.9-1  qt5-quickcontrols2-5.15.9+kde+r5-1  qt5-sensors-5.15.9-1
               qt5-speech-5.15.9+kde+r1-1  qt5-svg-5.15.9+kde+r7-1  qt5-tools-5.15.9+kde+r1-1
               qt5-translations-5.15.9-1  qt5-virtualkeyboard-5.15.9-1  qt5-wayland-5.15.9+kde+r55-1
               qt5-webchannel-5.15.9+kde+r3-1  qt5-webengine-5.15.13-2  qt5-webview-5.15.9-1
               qt5-x11extras-5.15.9-1  qt5-xmlpatterns-5.15.9-1  qt6-base-6.5.0-3  qt6-declarative-6.5.0-2
               qt6-translations-6.5.0-1  raptor-2.0.16-2  re2-1:20230301-1  rsync-3.2.7-4  samba-4.18.2-1
               sane-1.2.1-4  sddm-kcm-5.27.4.1-1  sdl2-2.26.5-1  sed-4.9-3  shaderc-2023.3-1
               shiboken6-6.5.0-1  signon-kwallet-extension-23.04.0-1  skanlite-23.04.0-1  smbclient-4.18.2-1
               snapper-gui-0.1.r8.g1915750-1  solid-5.105.0-1  sonnet-5.105.0-1  spectacle-23.04.0-1
               spectre-meltdown-checker-0.45+8+g6a61df2-1  sqlite-3.41.2-1  squashfs-tools-4.6.1-1
               sudo-1.9.13.p3-1  syndication-5.105.0-1  syntax-highlighting-5.105.0-1  systemd-252.10-2
               systemd-libs-252.10-2  systemd-sysvcompat-252.10-2  systemsettings-5.27.4.1-1  tar-1.34-2
               texinfo-7.0.3-1  thin-provisioning-tools-1.0.3-1  threadweaver-5.105.0-1  tracker3-3.5.0-1
               ttf-meslo-nerd-font-powerlevel10k-20230403-2  ttf-noto-nerd-2.3.3-2  twolame-0.4.0-3
               tzdata-2023c-1  util-linux-2.38.1-3  util-linux-libs-2.38.1-3  v4l-utils-1.24.1-1
               vid.stab-1.1.1-1  virtualbox-guest-utils-7.0.8-1  vlc-3.0.18-9  vpnc-1:0.5.3.r526.r213-1
               vte-common-0.72.1-1  vte3-0.72.1-1  vulkan-headers-1:1.3.246-1  vulkan-icd-loader-1.3.245-1
               vulkan-tools-1.3.245-1  wayland-1.22.0-1  wayland-protocols-1.31-1  webkit2gtk-2.40.1-1
               webkit2gtk-4.1-2.40.1-1  wireless-regdb-2023.02.13-1  wireplumber-0.4.14-1
               wpebackend-fdo-1.14.2-1  xapian-core-1:1.4.22-1  xapp-2.4.3-1
               xdg-desktop-portal-kde-5.27.4.1-1  xf86-input-libinput-1.3.0-1  xfsprogs-6.2.0-1
               xorg-fonts-encodings-1.0.7-1  xorg-server-21.1.8-1  xorg-server-common-21.1.8-1
               xorg-setxkbmap-1.3.3-2  xxhash-0.8.1-4  xz-5.4.2-1  yakuake-23.04.0-1  zenity-3.44.0-3
               zsh-autosuggestions-0.7.0-2  zsh-completions-0.34.0-4  zsh-history-substring-search-1.0.2-2
               zsh-theme-powerlevel10k-1.17.0+23+g1cff2249-1  zstd-1.5.5-1  zvbi-0.2.41-1  zxing-cpp-2.0.0-2
Total Download Size:   1919.57 MiB
Total Installed Size:  6349.32 MiB
Net Upgrade Size:      -124.95 MiB
[manjaro manjaro]# fdisk -l
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 860
Disklabel type: gpt
Disk identifier: 62F27049-23CB-4A40-AA15-B6D1F80E8211
Device          Start        End   Sectors  Size Type
/dev/sda1        2048    1050623   1048576  512M Microsoft basic data
/dev/sda2  1339090944 1953523711 614432768  293G Linux swap
/dev/sda3     1050624   34605055  33554432   16G Linux swap
/dev/sda4    34605056  663750655 629145600  300G Linux filesystem
/dev/sda5   663750656 1338976255 675225600  322G Linux filesystem
/dev/sda6  1338976256 1339090943    114688   56M Linux filesystem
Partition table entries are not in disk order.
Disk /dev/sdb: 29.81 GiB, 32008830976 bytes, 62517248 sectors
Disk model: USB Flash Drive
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot   Start     End Sectors  Size Id Type
/dev/sdb1  *         64 7976067 7976004  3.8G  0 Empty
/dev/sdb2       7976068 7984259    8192    4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 93.04 MiB, 97562624 bytes, 190552 sectors
Disk /dev/loop1: 867.48 MiB, 909623296 bytes, 1776608 sectors
Disk /dev/loop2: 1.89 GiB, 2031001600 bytes, 3966800 sectors
Disk /dev/loop3: 921.39 MiB, 966148096 bytes, 1887008 sectors
[manjaro manjaro]# blkid
/dev/loop1: TYPE="squashfs"
/dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="623B-25B9" BLOCK_SIZE="512" TYPE="
vfat"
/dev/sdb1: BLOCK_SIZE="2048" UUID="2023-03-16-12-31-50-00" LABEL="MANJARO_KDE_2205" TYPE="iso9660"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sda4: UUID="515D-BD42" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="4a47c64b-96fe-244e-9882-11f636a19f0d"
/dev/sda2: UUID="bfd472f8-ae4f-4c53-8be6-38e57d530867" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="2c9a6f81-be03-4
08c-b824-fcd5e9e3befc"
/dev/sda5: UUID="6763df11-af8e-4a4d-8992-c71075fd63f2" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="cb1a06fc-1346-d
e4a-b69f-202e65f76655"
/dev/sda3: UUID="50EC-367D" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="819ed769-458a-3d40-81af-1336c56db9fc"
/dev/sda1: UUID="5288-D5A4" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="eb891857-3836-ee4f-9022-436bc653b4fd"
/dev/sda6: UUID="220a1af9-6149-4610-b459-8a45115148b3" BLOCK_SIZE="1024" TYPE="ext4" PARTUUID="083c95eb-e18c-e
245-949f-23c9ef58b083"
/dev/loop3: TYPE="squashfs"
you are chrooted… and i told you to use proper formatting, you know how to do it…
so first rerun the update again, as instructed above, and if it updated and there were no errors, post output from the other commands…
