I just updated my computer yesterday and got a black screen after rebooting, I try to add the parameters for the nvidia but when I run the command sudo grub-mkconfig -o /boot/grub/grub.cfg I got this error
Generando un fichero de configuración de grub…
Encontrado tema: /usr/share/grub/themes/man jaro/theme.txt
Encontrada imagen de linux: /boot/umlinuz-6.5-x86_64
Encontrada imagen de memoria inicial: /boot/intel-code.ing boot/initranfs-6.5-x86_64.ing
Found initrd fallback image: /boot/initramfs-6.5-x86_64-fallback.ing
Aviso: os-prober will be executed to detect other bootable partitions.
Adding boot menu entry for LEFI Firmware Settings …
Root filesystem isn’t btrfs
If you think an error has occurred, please file a bug report at “GitHub - Antynea/grub-btrfs: Include btrfs snapshots at boot options. (Grub menu) ”
Found memtestß6+ image: /boot/nemtestB6+/memtest.bin
usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido.
Found memtest86+ EFI image: /boot/mentestB6+/mentest.efi usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido.
That is not an error - but you will need to sync a new kernel
sudo mhwd-kernel -i linux66
I tried to hide Plymouth and after rebooting the screen only shows the next info
/dev/nvme0n1p2: clean, 293178/61030100 files, 7163478/244112696 Blocks
cscs
11 March 2024 06:36
4
Then that output (from fsck checking the disk) is the last thing you see, and if plymouth is disabled, then something else is stopping boot. Considering your other post it would appear you are using an EOL kernel, which has resulted in numerous problems.
I just sync the linux66 version but I got the same message with the grub-mkconfig
:: grub-mkconfig output:
Encontrado tema: /usr/share/grub/themes/manjaro/theme.txt
Encontrada imagen de linux: /boot/vmlinuz-6.6-x86_64
Encontrada imagen de memoria inicial: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initr fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Adding boot menu entry for UEFI Firmware Settings …
If you think an error has occurred, please file a bug report at "GitHub - Antynea/grub-btrfs: Include btrfs snapshots at boot options. (Grub menu) *
Found memtest86+ image: /boot/memtest86+/mentest.bin
/usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
/usr/bin/grub-probe: aviso: tipo de dispositivo nvme0n1 desconocido.
cscs
11 March 2024 19:26
6
This is pretty self-explanatory.
Your root (/) filesystem is not btrfs.
This is probably mentioned because you are using grub-btrfs instead of regular grub.
The message can be ignored … or you can replace grub-btrfs with grub.
After reading this post Pantalla negra despues de actualizar - #13 by cfinnberg I tried adding the nvidia drivers for the new version of the kernel and now it works
