I recently moved to manjaro . i installed manjaro on my ssd and i have 3 ntfs partition in my hdd. At first i couldn’t write to my drives but only in my ssd. Then i followed some links to fix this using kde partition manager. I think i made some mistakes while using partition manager. Now i can mount one of my partition only if i click the other two the following error shows
“An error occurred while accessing ‘Home’, the system responded: The requested operation has failed: Error mounting system-managed device /dev/sdb4: Unknown error when mounting /run/media/”
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=b77508cd-8214-4bf8-a420-6b33a303e82f rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_wayland vt: 2
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X509DJ_D509DJ
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X509DJ v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X509DJ.307 date: 10/08/2021
ID-1: BAT0 charge: 23.9 Wh (95.2%) condition: 25.1/32.1 Wh (78.1%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging cycles: 205
RAM: total: 5.8 GiB used: 1.73 GiB (29.8%)
RAM Report:
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1462 high: 1942 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1942 2: 1293
3: 1226 4: 1225 5: 1427 6: 1408 7: 1426 8: 1756 bogomips: 33550
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: NVIDIA GP108M [GeForce MX230] vendor: ASUSTeK driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d11 class-ID: 0302
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.2:5 chip-ID: 13d3:5a11 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
alternate: fbdev,vesa gpu: nouveau,amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.42.0
5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.48 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: N/A modules: rtw88_8821ce,8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
chip-ID: 10ec:c821 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2.1:4 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
Local Storage: total: 1.03 TiB used: 43.87 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS2040 128GB SSD
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: BB.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 17.81 GiB (15.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b77508cd-8214-4bf8-a420-6b33a303e82f
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: C32C-1BF8
ID-3: /run/media raw-size: 310.46 GiB size: 310.46 GiB (100.00%)
used: 26.05 GiB (8.4%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: New_Volume1 uuid: 7C281C6D281C28A2
ID-1: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb3 maj-min: 8:19 size: 310.52 GiB fs: ntfs label: new_volume3
uuid: 6DCDC3472A0485CE
ID-3: /dev/sdb4 maj-min: 8:20 size: 310.4 GiB fs: ntfs label: New_Volume2
uuid: 72B42BE8B42BAD93
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: A4Tech USB Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 09da:c10a class-ID: 0301
Device-2: 1-4:3 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-4: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-2.1:4 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-2: 3-2.2:5 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1700
GPU: device: nouveau temp: 45.0 C device: amdgpu temp: 58.0 C
Processes: 258 Uptime: 28m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1303 lib: 363
flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.14
As i am new . it will be pretty helpful if someone helps me solve this
