Continuing the discussion from Can’t install Manjaro:
I have the same problem. I tried the solution but it doesn’t work for me.
Host: qonos Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce
v: 4.18.1 Distro: Manjaro Linux
Type: Desktop System: LENOVO product: 10FLS2K100 v: ThinkCentre M900
serial: <superuser required>
Mobo: LENOVO model: SKYBAY v: SDK0J40705 WIN 3425058648778
serial: <superuser required> UEFI-[Legacy]: LENOVO v: FWKT54A
date: 06/24/2016
Info: quad core model: Intel Core i5-6600T bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 900 min/max: 800/3500 cores: 1: 900 2: 900 3: 900 4: 900
Device-1: Intel HD Graphics 530 driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting
dri: iris gpu: i915 resolution: 3840x2160~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
API: ALSA v: k5.15.81-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Intel Ethernet I219-LM driver: e1000e
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: 00:23:24:bd:2e:d1
Local Storage: total: 238.47 GiB used: 162.64 GiB (68.2%)
ID-1: /dev/sda vendor: Samsung model: MZ7TY256HDHP-000L7 size: 238.47 GiB
ID-1: / size: 199.83 GiB used: 162.64 GiB (81.4%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 218 Uptime: 20m Memory: 31.25 GiB used: 3.35 GiB (10.7%)
Shell: Zsh inxi: 3.3.26
