Problem installing HP Laserjet P1102
Hello there, just got the latest stable manjaro download and installed it to my new pc i bought a few days ago
I have problems installing the driver, then I follow advice in this forum from other posts having similar problems the the hplip-plugin is able to detect the correct model of my printer and it does download the driver (it complains that it cannot get the key to validate the install) it says success and then reports failure. Of course I am still not able to use the printer.
I also followed the directions in a post at support forum , print section , for the same printer, the forum does not allow me to link
but i have the usual problem for being unable to locate the pyqt4 package that other experience too
Any suggestions ?
What’s forum link??
And this what happen to the old one…
the link i wanted to provide is for the thread ā€œHPLIP install laserjet 1102pā€ same forum as this Support->Printers but the forum does not allow me to provide a link inside my posts probably because i am a newcomer and has not unlocked all my privileges
This one is locked, It has a time limit since the Soluion was marked.
yeap that was the one, I also googled around and tried several other solutions before asking here but to no avail
EDIT: apparently the printer has problems with Windows as well, so this is not a Manjaro problem
Hi, @kilon
I think the problem could be solved reading the recipe I wrote on this post.
https://forum.manjaro.org/t/basic-linux-compatible-printer/28597/7
Hope it help, regards.
thanks for the link but i discovered that the problem was that the printer was not even recognised even in windows, I got a new pc and assumed it worked because it used to work with my 7 year old imac. I had issues with the printer not being recognised the first time i turned it on on a boot , I thought it was my imac, by my new pc shows that there is something wrong with the printer itself on hardware level. In any case i hooked it back to my iMac which now i gave to my father. Thank you all for you assistance :slight_smile:
