So I way trying to install new kde manjaro from live usb but my laptop with following specs :
amd ryzen 5 5500u cpu with integrated graphics
nvidia 1650 gpu
kernel 5.9
on booting it gets stuck on this screen
imgur[dot]com/a/l4GBGkc (sorry can’t add link )
however I’m able to access tty
from mhwd it was quite clear that its not installing nvidia non free graphic drivers ,
NAME VERSION FREEDRIVER TYPE
however on installing nvidia graphic drivers manually it automatically installs latest ones(version:460) and then after install it again shows previous screen (init logs),
and in xorg logs it shows that it can’t find compatible device for graphic card installed. also I can’t specify version of graphic driver I want to install for example video-nvidia-450xx , on trying to install mhwd return " config video-nvidia-450xx does’nt exist how can I fix this?
here is output of inxi btw →
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2021 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Console: tty 2 Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Aspire A715-42G v: V1.01 serial: <filter>
Mobo: LN model: Azalea_CAS v: V1.01 serial: <filter> UEFI: Insyde v: 1.01 date: 12/14/2020
Battery: ID-1: BAT1 charge: 41.5 Wh condition: 47.3/47.9 Wh (99%) volts: 12.0/11.4 model: Murata AP18C4K type: Li-ion
serial: <filter> status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen note: check
family: 17 (23) model-id: 68 (104) stepping: 1 microcode: 8608102 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 50327
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397
6: 1396 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1396
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA vendor: Acer Incorporated ALI driver: N/A alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1f9d
Device-2: Advanced Micro Devices [AMD/ATI] vendor: Acer Incorporated ALI driver: N/A bus ID: 05:00.0
chip ID: 1002:164c
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus ID: 3-3:2 chip ID: 0408:a061
Display: server: X.org 1.20.10 driver: N/A note: n/a (using device driver) tty: 128x48
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 05:00.5
chip ID: 1022:15e2
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: kernel port: 2000 bus ID: 03:00.0 chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 04:00.0 chip ID: 8086:2723
IF: wlp4s0 state: down mac: <filter>
IF-ID-1: enp5s0f4u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 505.59 GiB used: 115.3 MiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 41020C20 temp: 38.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade size: 28.65 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: 1.00
Partition: ID-1: / raw size: N/A size: 5.4 GiB used: 115.3 MiB (2.1%) fs: overlay source: ERR-102
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 52.2 C mobo: N/A
Info: Processes: 227 Uptime: 1h 28m wakeups: 2 Memory: 7.2 GiB used: 791.8 MiB (10.7%) Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1265 lib: 375 flatpak: 0 Shell: Bash v: 5.1.0 running in: tty 2 inxi: 3.2.01
