Prime driver not working for my dual gpu laptop
i tried to install the nvidia’s no-free driver on my asus tuf gaming f15 laptop with dual gpu(core i7-12700h and rtx3070).
here are my hardware information:
12System:
  12Kernel 6.1.1-1-MANJARO 12arch x86_64 12bits 64 12Desktop GNOME 12v 43.2 12Distro Manjaro Linux
12Machine:
  12Type Laptop 12System ASUSTeK 12product ASUS TUF Gaming F15 FX507ZR_FX507ZR 12v 1.0 12serial <filter>
  12Mobo ASUSTeK 12model FX507ZR 12v 1.0 12serial <filter> 12UEFI American Megatrends LLC. 12v FX507ZR.315
    12date 06/17/2022
12Battery:
  12ID-1 BAT1 12charge 92.5 Wh (100.0%) 12condition 92.5/90.2 Wh (102.5%)
12CPU:
  12Info 14-core (6-mt/8-st) 12model 12th Gen Intel Core i7-12700H 12bits 64 12type MST AMCP 12cache
    12L2 11.5 MiB
  12Speed (MHz) 12avg 2404 12min/max 400/4600:4700:3500 12cores 121 691 122 2700 123 2700 124 2700 125 786 126 2700
    127 2700 128 2700 129 2700 1210 2700 1211 2700 1212 2700 1213 2700 1214 2700 1215 2700 1216 2700 1217 2700 1218 2700
    1219 715 1220 2700
12Graphics:
  12Device-1 Intel Alder Lake-P Integrated Graphics 12driver i915 12v kernel
  12Device-2 NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] 12driver nouveau 12v kernel
  12Device-3 Sonix USB2.0 HD UVC WebCam 12type USB 12driver uvcvideo
  12Display 12server X.org 12v 1.21.1.6 12with Xwayland 12v 22.1.7 12driver 12X 12loaded modesetting 12gpu i915
    12resolution 2560x1440
  12API OpenGL 12Message GL data unavailable for root.
firstly, i tried to follow the sector Configure Graphics Cards on manjaro wiki
i used the command
sudo mhwd -a pci nonfree 0300
and successfully installed the prime driver:
[manjaro-gnome /]# mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-intel-nvidia-prime            2021.11.04               false            PCI
so i tried to reboot and i stuck in the booting process with dmesg:
[    0.000000] microcode: microcode updated early to revision 0x424, date = 2022-09-19
[    0.000000] Linux version 6.1.1-1-MANJARO (builduser@fv-az191-932) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT_DYNAMIC Wed Dec 21 23:21:50 UTC 2022
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_GNOME_220 quiet systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[    0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    0.000000] x86/fpu: Enabled xstate features 0x207, context size is 840 bytes, using 'compacted' format.
[    0.000000] signal: max sigframe size: 3632
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000037d57fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000037d58000-0x0000000040b74fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040b75000-0x0000000040c5bfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000040c5c000-0x0000000040dc9fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000040dca000-0x0000000041765fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000041766000-0x00000000417fefff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000417ff000-0x00000000417fffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000041800000-0x0000000047ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000048c00000-0x000000004f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000004b07fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.80 by American Megatrends
[    0.000000] efi: ACPI=0x40c5b000 ACPI 2.0=0x40c5b014 TPMFinalLog=0x40cf5000 SMBIOS=0x41587000 SMBIOS 3.0=0x41586000 MEMATTR=0x20695018 ESRT=0x2069b598
[    0.000000] SMBIOS 3.4.0 present.
[    0.000000] DMI: ASUSTeK COMPUTER INC. ASUS TUF Gaming F15 FX507ZR_FX507ZR/FX507ZR, BIOS FX507ZR.315 06/17/2022
[    0.000000] tsc: Detected 2700.000 MHz processor
[    0.000000] tsc: Detected 2688.000 MHz TSC
[    0.000420] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000422] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000427] last_pfn = 0x4b0800 max_arch_pfn = 0x400000000
[    0.000575] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001230] last_pfn = 0x41800 max_arch_pfn = 0x400000000
[    0.013187] esrt: Reserving ESRT space from 0x000000002069b598 to 0x000000002069b698.
[    0.013192] e820: update [mem 0x2069b000-0x2069bfff] usable ==> reserved
[    0.013224] Using GB pages for direct mapping
[    0.013324] Secure boot disabled
[    0.013324] RAMDISK: [mem 0x1ade9000-0x1e008fff]
[    0.013328] ACPI: Early table checksum verification disabled
[    0.013331] ACPI: RSDP 0x0000000040C5B014 000024 (v02 _ASUS_)
[    0.013333] ACPI: XSDT 0x0000000040C5A728 000134 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013337] ACPI: FACP 0x0000000040C56000 000114 (v06 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013341] ACPI: DSDT 0x0000000040BE8000 06DFB7 (v02 _ASUS_ Notebook 01072009 INTL 20200717)
[    0.013343] ACPI: FACS 0x0000000040DC8000 000040
[    0.013344] ACPI: SSDT 0x0000000040C57000 002877 (v02 DptfTb DptfTabl 00001000 INTL 20200717)
[    0.013346] ACPI: FIDT 0x0000000040BE7000 00009C (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.013348] ACPI: MSDM 0x0000000040BE6000 000055 (v03 _ASUS_ Notebook 01072009 ASUS 00000001)
[    0.013350] ACPI: SSDT 0x0000000040BE5000 00038C (v02 PmaxDv Pmax_Dev 00000001 INTL 20200717)
[    0.013352] ACPI: SSDT 0x0000000040BDF000 005D0B (v02 CpuRef CpuSsdt  00003000 INTL 20200717)
[    0.013354] ACPI: SSDT 0x0000000040BDC000 002AA1 (v02 SaSsdt SaSsdt   00003000 INTL 20200717)
[    0.013356] ACPI: SSDT 0x0000000040BD8000 0033D3 (v02 INTEL  IgfxSsdt 00003000 INTL 20200717)
[    0.013357] ACPI: SSDT 0x0000000040BCA000 00D39F (v02 INTEL  TcssSsdt 00001000 INTL 20200717)
[    0.013359] ACPI: HPET 0x0000000040BC9000 000038 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013361] ACPI: APIC 0x0000000040BC8000 0001DC (v05 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013363] ACPI: MCFG 0x0000000040BC7000 00003C (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013365] ACPI: SSDT 0x0000000040BC2000 004BA7 (v02 _ASUS_ AdlP_Rvp 00001000 INTL 20200717)
[    0.013366] ACPI: NHLT 0x0000000040BC1000 0002F1 (v00 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013368] ACPI: LPIT 0x0000000040BC0000 0000CC (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013370] ACPI: WSMT 0x0000000040BBF000 000028 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013372] ACPI: SSDT 0x0000000040BBC000 002A83 (v02 _ASUS_ PtidDevc 00001000 INTL 20200717)
[    0.013373] ACPI: SSDT 0x0000000040BB9000 002357 (v02 _ASUS_ TbtTypeC 00000000 INTL 20200717)
[    0.013375] ACPI: DBGP 0x0000000040BB8000 000034 (v01 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013377] ACPI: DBG2 0x0000000040BB7000 000054 (v00 _ASUS_ Notebook 01072009 AMI  01000013)
[    0.013379] ACPI: SSDT 0x0000000040BB6000 000ECF (v02 _ASUS_ UsbCTabl 00001000 INTL 20200717)
[    0.013380] ACPI: DMAR 0x0000000040BB5000 000088 (v02 INTEL  EDK2     00000002      01000013)
[    0.013382] ACPI: SSDT 0x0000000040BB4000 0008E7 (v02 INTEL  xh_adlLP 00000000 INTL 20200717)
[    0.013384] ACPI: SSDT 0x0000000040BB0000 003AEA (v02 SocGpe SocGpe   00003000 INTL 20200717)
[    0.013386] ACPI: SSDT 0x0000000040BAC000 0035A2 (v02 SocCmn SocCmn   00003000 INTL 20200717)
[    0.013388] ACPI: SSDT 0x0000000040BAB000 000457 (v02 HgRef  HgRpSsdt 00001000 INTL 20200717)
[    0.013390] ACPI: SSDT 0x0000000040BAA000 000144 (v02 Intel  ADebTabl 00001000 INTL 20200717)
[    0.013391] ACPI: UEFI 0x0000000040CD7000 00063A (v01 INTEL  RstVmdE  00000000 INTL 00000000)
[    0.013393] ACPI: UEFI 0x0000000040CD6000 00005C (v01 INTEL  RstVmdV  00000000 INTL 00000000)
[    0.013395] ACPI: TPM2 0x0000000040BA8000 00004C (v04 _ASUS_ Notebook 00000001 AMI  00000000)
[    0.013397] ACPI: BGRT 0x0000000040BA9000 000038 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
[    0.013399] ACPI: SSDT 0x0000000040BA5000 002DCA (v01 OptRf2 Opt2Tabl 00001000 INTL 20200717)
[    0.013400] ACPI: PHAT 0x0000000040BA4000 00062D (v01 _ASUS_ Notebook 00000005 MSFT 0100000D)
[    0.013402] ACPI: FPDT 0x0000000040BA3000 000044 (v01 _ASUS_ A M I    01072009 AMI  01000013)
[    0.013404] ACPI: Reserving FACP table memory at [mem 0x40c56000-0x40c56113]
[    0.013405] ACPI: Reserving DSDT table memory at [mem 0x40be8000-0x40c55fb6]
[    0.013405] ACPI: Reserving FACS table memory at [mem 0x40dc8000-0x40dc803f]
[    0.013406] ACPI: Reserving SSDT table memory at [mem 0x40c57000-0x40c59876]
[    0.013407] ACPI: Reserving FIDT table memory at [mem 0x40be7000-0x40be709b]
[    0.013407] ACPI: Reserving MSDM table memory at [mem 0x40be6000-0x40be6054]
[    0.013408] ACPI: Reserving SSDT table memory at [mem 0x40be5000-0x40be538b]
[    0.013409] ACPI: Reserving SSDT table memory at [mem 0x40bdf000-0x40be4d0a]
[    0.013409] ACPI: Reserving SSDT table memory at [mem 0x40bdc000-0x40bdeaa0]
[    0.013410] ACPI: Reserving SSDT table memory at [mem 0x40bd8000-0x40bdb3d2]
[    0.013410] ACPI: Reserving SSDT table memory at [mem 0x40bca000-0x40bd739e]
[    0.013411] ACPI: Reserving HPET table memory at [mem 0x40bc9000-0x40bc9037]
[    0.013412] ACPI: Reserving APIC table memory at [mem 0x40bc8000-0x40bc81db]
[    0.013412] ACPI: Reserving MCFG table memory at [mem 0x40bc7000-0x40bc703b]
[    0.013413] ACPI: Reserving SSDT table memory at [mem 0x40bc2000-0x40bc6ba6]
[    0.013414] ACPI: Reserving NHLT table memory at [mem 0x40bc1000-0x40bc12f0]
[    0.013414] ACPI: Reserving LPIT table memory at [mem 0x40bc0000-0x40bc00cb]
[    0.013415] ACPI: Reserving WSMT table memory at [mem 0x40bbf000-0x40bbf027]
[    0.013416] ACPI: Reserving SSDT table memory at [mem 0x40bbc000-0x40bbea82]
[    0.013416] ACPI: Reserving SSDT table memory at [mem 0x40bb9000-0x40bbb356]
[    0.013417] ACPI: Reserving DBGP table memory at [mem 0x40bb8000-0x40bb8033]
[    0.013417] ACPI: Reserving DBG2 table memory at [mem 0x40bb7000-0x40bb7053]
[    0.013418] ACPI: Reserving SSDT table memory at [mem 0x40bb6000-0x40bb6ece]
[    0.013419] ACPI: Reserving DMAR table memory at [mem 0x40bb5000-0x40bb5087]
[    0.013419] ACPI: Reserving SSDT table memory at [mem 0x40bb4000-0x40bb48e6]
[    0.013420] ACPI: Reserving SSDT table memory at [mem 0x40bb0000-0x40bb3ae9]
[    0.013421] ACPI: Reserving SSDT table memory at [mem 0x40bac000-0x40baf5a1]
[    0.013421] ACPI: Reserving SSDT table memory at [mem 0x40bab000-0x40bab456]
[    0.013422] ACPI: Reserving SSDT table memory at [mem 0x40baa000-0x40baa143]
[    0.013423] ACPI: Reserving UEFI table memory at [mem 0x40cd7000-0x40cd7639]
[    0.013423] ACPI: Reserving UEFI table memory at [mem 0x40cd6000-0x40cd605b]
[    0.013424] ACPI: Reserving TPM2 table memory at [mem 0x40ba8000-0x40ba804b]
[    0.013425] ACPI: Reserving BGRT table memory at [mem 0x40ba9000-0x40ba9037]
[    0.013426] ACPI: Reserving SSDT table memory at [mem 0x40ba5000-0x40ba7dc9]
[    0.013426] ACPI: Reserving PHAT table memory at [mem 0x40ba4000-0x40ba462c]
[    0.013427] ACPI: Reserving FPDT table memory at [mem 0x40ba3000-0x40ba3043]
[    0.013742] No NUMA configuration found
[    0.013742] Faking a node at [mem 0x0000000000000000-0x00000004b07fffff]
[    0.013745] NODE_DATA(0) allocated [mem 0x4b07fb000-0x4b07fffff]
[    0.013764] Zone ranges:
[    0.013765]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.013766]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.013767]   Normal   [mem 0x0000000100000000-0x00000004b07fffff]
[    0.013767]   Device   empty
[    0.013768] Movable zone start for each node
[    0.013768] Early memory node ranges
[    0.013768]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.013769]   node   0: [mem 0x000000000009f000-0x000000000009ffff]
[    0.013770]   node   0: [mem 0x0000000000100000-0x0000000037d57fff]
[    0.013770]   node   0: [mem 0x00000000417ff000-0x00000000417fffff]
[    0.013771]   node   0: [mem 0x0000000100000000-0x00000004b07fffff]
[    0.013772] Initmem setup node 0 [mem 0x0000000000001000-0x00000004b07fffff]
[    0.013774] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.013775] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.013787] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.014510] On node 0, zone DMA32: 6823 pages in unavailable ranges
[    0.030203] On node 0, zone Normal: 26624 pages in unavailable ranges
[    0.030364] On node 0, zone Normal: 30720 pages in unavailable ranges
[    0.030420] Reserving Intel graphics memory at [mem 0x4b800000-0x4f7fffff]
[    0.031016] ACPI: PM-Timer IO Port: 0x1808
[    0.031021] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.031022] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.031023] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.031023] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.031024] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.031024] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.031024] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.031024] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.031025] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.031025] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.031025] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.031026] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.031026] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.031026] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.031027] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.031027] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.031027] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[    0.031028] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[    0.031028] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[    0.031028] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[    0.031029] ACPI: LAPIC_NMI (acpi_id[0x15] high edge lint[0x1])
[    0.031029] ACPI: LAPIC_NMI (acpi_id[0x16] high edge lint[0x1])
[    0.031029] ACPI: LAPIC_NMI (acpi_id[0x17] high edge lint[0x1])
[    0.031030] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.031113] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.031115] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.031116] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.031118] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.031119] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.031125] e820: update [mem 0x33608000-0x33654fff] usable ==> reserved
[    0.031132] TSC deadline timer available
[    0.031133] smpboot: Allowing 20 CPUs, 0 hotplug CPUs
[    0.031150] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.031151] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[    0.031152] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.031153] PM: hibernation: Registered nosave memory: [mem 0x2069b000-0x2069bfff]
[    0.031154] PM: hibernation: Registered nosave memory: [mem 0x33608000-0x33654fff]
[    0.031155] PM: hibernation: Registered nosave memory: [mem 0x37d58000-0x40b74fff]
[    0.031155] PM: hibernation: Registered nosave memory: [mem 0x40b75000-0x40c5bfff]
[    0.031156] PM: hibernation: Registered nosave memory: [mem 0x40c5c000-0x40dc9fff]
[    0.031156] PM: hibernation: Registered nosave memory: [mem 0x40dca000-0x41765fff]
[    0.031156] PM: hibernation: Registered nosave memory: [mem 0x41766000-0x417fefff]
[    0.031157] PM: hibernation: Registered nosave memory: [mem 0x41800000-0x47ffffff]
[    0.031158] PM: hibernation: Registered nosave memory: [mem 0x48000000-0x48bfffff]
[    0.031158] PM: hibernation: Registered nosave memory: [mem 0x48c00000-0x4f7fffff]
[    0.031158] PM: hibernation: Registered nosave memory: [mem 0x4f800000-0xbfffffff]
[    0.031159] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
[    0.031159] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfdffffff]
[    0.031159] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.031159] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.031160] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.031160] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.031160] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.031161] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed1ffff]
[    0.031161] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
[    0.031161] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfedfffff]
[    0.031161] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.031162] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.031162] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.031163] [mem 0x4f800000-0xbfffffff] available for PCI devices
[    0.031164] Booting paravirtualized kernel on bare hardware
[    0.031165] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.034645] setup_percpu: NR_CPUS:320 nr_cpumask_bits:20 nr_cpu_ids:20 nr_node_ids:1
[    0.035201] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[    0.035206] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[    0.035207] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.035211] pcpu-alloc: [0] 16 17 18 19 -- -- -- --
[    0.035225] Fallback order for Node 0: 0
[    0.035227] Built 1 zonelists, mobility grouping on.  Total pages: 4033091
[    0.035228] Policy zone: Normal
[    0.035228] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_GNOME_220 quiet systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[    0.035319] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_GNOME_220 driver=free", will be passed to user space.
[    0.035333] random: crng init done
[    0.035334] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.035334] printk: log_buf_len total cpu_extra contributions: 77824 bytes
[    0.035335] printk: log_buf_len min size: 131072 bytes
[    0.035431] printk: log_buf_len: 262144 bytes
[    0.035431] printk: early log buf free: 114064(87%)
[    0.036393] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.036870] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.037108] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.037114] software IO TLB: area num 32.
[    0.064187] Memory: 15702296K/16389084K available (16391K kernel code, 2132K rwdata, 11072K rodata, 2148K init, 3360K bss, 686528K reserved, 0K cma-reserved)
[    0.064270] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=20, Nodes=1
[    0.064279] ftrace: allocating 46412 entries in 182 pages
[    0.068352] ftrace: allocated 182 pages with 5 groups
[    0.068406] Dynamic Preempt: full
[    0.068431] rcu: Preemptible hierarchical RCU implementation.
[    0.068432] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=20.
[    0.068433] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.068433] 	Trampoline variant of Tasks RCU enabled.
[    0.068434] 	Rude variant of Tasks RCU enabled.
[    0.068434] 	Tracing variant of Tasks RCU enabled.
[    0.068434] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.068435] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=20
[    0.070661] NR_IRQS: 20736, nr_irqs: 2216, preallocated irqs: 16
[    0.071002] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.071432] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.071452] Console: colour dummy device 80x25
[    0.071464] printk: console [tty0] enabled
[    0.071477] ACPI: Core revision 20220331
[    0.071695] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.071696] APIC: Switch to symmetric I/O mode setup
[    0.071697] DMAR: Host address width 39
[    0.071698] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.071701] DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
[    0.071702] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.071706] DMAR: dmar1: reg_base_addr fed91000 ver 5:0 cap d2008c40660462 ecap f050da
[    0.071707] DMAR: RMRR base: 0x0000004b000000 end: 0x0000004f7fffff
[    0.071709] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.071710] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.071711] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.075662] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.075664] x2apic enabled
[    0.075718] Switched APIC routing to cluster x2apic.
[    0.087128] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26bef67878b, max_idle_ns: 440795293631 ns
[    0.087132] Calibrating delay loop (skipped), value calculated using timer frequency.. 5378.00 BogoMIPS (lpj=8960000)
[    0.087133] pid_max: default: 32768 minimum: 301
[    0.090464] LSM: Security Framework initializing
[    0.090464] landlock: Up and running.
[    0.090464] Yama: becoming mindful.
[    0.090464] LSM support for eBPF active
[    0.090464] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.090464] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.090464] CPU0: Thermal monitoring enabled (TM1)
[    0.090464] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.090464] process: using mwait in idle threads
[    0.090464] CET detected: Indirect Branch Tracking enabled
[    0.090464] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[    0.090464] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[    0.090464] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.090464] Spectre V2 : Mitigation: Enhanced IBRS
[    0.090464] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.090464] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[    0.090464] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.090464] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.090464] Freeing SMP alternatives memory: 36K
[    0.090464] smpboot: CPU0: 12th Gen Intel(R) Core(TM) i7-12700H (family: 0x6, model: 0x9a, stepping: 0x3)
[    0.090464] cblist_init_generic: Setting adjustable number of callback queues.
[    0.090464] cblist_init_generic: Setting shift to 5 and lim to 1.
[    0.090464] Performance Events: XSAVE Architectural LBR, PEBS fmt4+-baseline,  AnyThread deprecated, Alderlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.090464] core: cpu_core PMU driver:
[    0.090464] ... version:                5
[    0.090464] ... bit width:              48
[    0.090464] ... generic registers:      8
[    0.090464] ... value mask:             0000ffffffffffff
[    0.090464] ... max period:             00007fffffffffff
[    0.090464] ... fixed-purpose events:   4
[    0.090464] ... event mask:             0001000f000000ff
[    0.090464] Estimated ratio of average max frequency by base frequency (times 1024): 1668
[    0.090464] rcu: Hierarchical SRCU implementation.
[    0.090464] rcu: 	Max phase no-delay instances is 1000.
[    0.090464] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.090464] smp: Bringing up secondary CPUs ...
[    0.090464] x86: Booting SMP configuration:
[    0.090464] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12
[    0.019088] core: cpu_atom PMU driver: PEBS-via-PT
[    0.019088] ... version:                5
[    0.019088] ... bit width:              48
[    0.019088] ... generic registers:      6
[    0.019088] ... value mask:             0000ffffffffffff
[    0.019088] ... max period:             00007fffffffffff
[    0.019088] ... fixed-purpose events:   3
[    0.019088] ... event mask:             000000070000003f
[    0.133033]  #13 #14 #15 #16 #17 #18 #19
[    0.150758] smp: Brought up 1 node, 20 CPUs
[    0.150758] smpboot: Max logical packages: 1
[    0.150758] smpboot: Total of 20 processors activated (107563.00 BogoMIPS)
[    0.154229] devtmpfs: initialized
[    0.154229] x86/mm: Memory block size: 128MB
[    0.154283] ACPI: PM: Registering ACPI NVS region [mem 0x40c5c000-0x40dc9fff] (1499136 bytes)
[    0.154283] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.154283] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.154283] pinctrl core: initialized pinctrl subsystem
[    0.154350] PM: RTC time: 02:39:37, date: 2023-01-14
[    0.154685] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.154868] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.154992] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.155119] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.155124] audit: initializing netlink subsys (disabled)
[    0.155127] audit: type=2000 audit(1673663977.066:1): state=initialized audit_enabled=0 res=1
[    0.155127] thermal_sys: Registered thermal governor 'fair_share'
[    0.155127] thermal_sys: Registered thermal governor 'bang_bang'
[    0.155127] thermal_sys: Registered thermal governor 'step_wise'
[    0.155127] thermal_sys: Registered thermal governor 'user_space'
[    0.155127] thermal_sys: Registered thermal governor 'power_allocator'
[    0.155127] cpuidle: using governor ladder
[    0.155127] cpuidle: using governor menu
[    0.155127] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.155127] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.155127] PCI: MMCONFIG for domain 0000 [bus 00-e0] at [mem 0xc0000000-0xce0fffff] (base 0xc0000000)
[    0.155127] PCI: MMCONFIG at [mem 0xc0000000-0xce0fffff] reserved in E820
[    0.155127] PCI: Using configuration type 1 for base access
[    0.155127] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.157836] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.157836] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.157836] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.157836] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.157836] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.157836] ACPI: Added _OSI(Module Device)
[    0.157836] ACPI: Added _OSI(Processor Device)
[    0.157836] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.157836] ACPI: Added _OSI(Processor Aggregator Device)
[    0.229454] ACPI: 17 ACPI AML tables successfully acquired and loaded
[    0.244975] ACPI: Dynamic OEM Table Load:
[    0.244982] ACPI: SSDT 0xFFFF93F4C2DEF400 0001AB (v02 PmRef  Cpu0Psd  00003000 INTL 20200717)
[    0.245727] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.247473] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[    0.247474] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[    0.248642] ACPI: Dynamic OEM Table Load:
[    0.248647] ACPI: SSDT 0xFFFF93F4C133FC00 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20200717)
[    0.249539] ACPI: Dynamic OEM Table Load:
[    0.249543] ACPI: SSDT 0xFFFF93F4C1345000 000626 (v02 PmRef  Cpu0Ist  00003000 INTL 20200717)
[    0.250515] ACPI: Dynamic OEM Table Load:
[    0.250519] ACPI: SSDT 0xFFFF93F4C1344800 0004BA (v02 PmRef  Cpu0Hwp  00003000 INTL 20200717)
[    0.251701] ACPI: Dynamic OEM Table Load:
[    0.251707] ACPI: SSDT 0xFFFF93F4C1330000 001BAF (v02 PmRef  ApIst    00003000 INTL 20200717)
[    0.253150] ACPI: Dynamic OEM Table Load:
[    0.253155] ACPI: SSDT 0xFFFF93F4C1334000 001038 (v02 PmRef  ApHwp    00003000 INTL 20200717)
[    0.254417] ACPI: Dynamic OEM Table Load:
[    0.254422] ACPI: SSDT 0xFFFF93F4C1332000 001349 (v02 PmRef  ApPsd    00003000 INTL 20200717)
[    0.255702] ACPI: Dynamic OEM Table Load:
[    0.255706] ACPI: SSDT 0xFFFF93F4C134B000 000FBB (v02 PmRef  ApCst    00003000 INTL 20200717)
[    0.262754] ACPI: EC: EC started
[    0.262755] ACPI: EC: interrupt blocked
[    0.262820] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.262821] ACPI: \_SB_.PC00.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.262821] ACPI: Interpreter enabled
[    0.262863] ACPI: PM: (supports S0 S3 S4 S5)
[    0.262864] ACPI: Using IOAPIC for interrupt routing
[    0.262898] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.262898] PCI: Using E820 reservations for host bridge windows
[    0.264024] ACPI: Enabled 10 GPEs in block 00 to 7F
[    0.265015] ACPI: PM: Power Resource [PXP]
[    0.273366] ACPI: PM: Power Resource [PXP]
[    0.278255] ACPI: PM: Power Resource [DBTP]
[    0.278477] ACPI: PM: Power Resource [BTRT]
[    0.279004] ACPI: PM: Power Resource [PAUD]
[    0.279704] ACPI: PM: Power Resource [PXTC]
[    0.283990] ACPI: PM: Power Resource [WRST]
[    0.286392] ACPI: PM: Power Resource [V0PR]
[    0.286426] ACPI: PM: Power Resource [V1PR]
[    0.286459] ACPI: PM: Power Resource [V2PR]
[    0.286491] ACPI: PM: Power Resource [V3PR]
[    0.286764] ACPI: PM: Power Resource [TBT0]
[    0.287012] ACPI: PM: Power Resource [TBT1]
[    0.287256] ACPI: PM: Power Resource [D3C]
[    0.443725] ACPI: PM: Power Resource [PIN]
[    0.443974] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
[    0.443978] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.445679] acpi PNP0A08:00: _OSC: platform does not support [AER]
[    0.448966] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[    0.448967] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.450873] PCI host bridge to bus 0000:00
[    0.450874] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.450875] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.450876] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.450876] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[    0.450877] pci_bus 0000:00: root bus resource [mem 0x4f800000-0xbfffffff window]
[    0.450878] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[    0.450878] pci_bus 0000:00: root bus resource [bus 00-e0]
[    0.451005] pci 0000:00:00.0: [8086:4641] type 00 class 0x060000
[    0.451162] pci 0000:00:01.0: [8086:460d] type 01 class 0x060400
[    0.451217] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.451238] pci 0000:00:01.0: PTM enabled (root), 4ns granularity
[    0.451772] pci 0000:00:02.0: [8086:46a6] type 00 class 0x030000
[    0.451779] pci 0000:00:02.0: reg 0x10: [mem 0x622e000000-0x622effffff 64bit]
[    0.451783] pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
[    0.451787] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
[    0.451798] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.451799] pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
[    0.451801] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.451822] pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
[    0.451823] pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
[    0.451827] pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
[    0.451827] pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
[    0.451924] pci 0000:00:04.0: [8086:461d] type 00 class 0x118000
[    0.451936] pci 0000:00:04.0: reg 0x10: [mem 0x622f240000-0x622f25ffff 64bit]
[    0.452147] pci 0000:00:06.0: [8086:09ab] type 00 class 0x088000
[    0.452664] pci 0000:00:07.0: [8086:466e] type 01 class 0x060400
[    0.452699] pci 0000:00:07.0: Overriding RP PIO Log Size to 4
[    0.452731] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[    0.452752] pci 0000:00:07.0: PTM enabled (root), 4ns granularity
[    0.454546] pci 0000:00:08.0: [8086:464f] type 00 class 0x088000
[    0.454553] pci 0000:00:08.0: reg 0x10: [mem 0x622f29a000-0x622f29afff 64bit]
[    0.454631] pci 0000:00:0a.0: [8086:467d] type 00 class 0x118000
[    0.454637] pci 0000:00:0a.0: reg 0x10: [mem 0x622f280000-0x622f287fff 64bit]
[    0.454654] pci 0000:00:0a.0: enabling Extended Tags
[    0.454748] pci 0000:00:0d.0: [8086:461e] type 00 class 0x0c0330
[    0.454757] pci 0000:00:0d.0: reg 0x10: [mem 0x622f270000-0x622f27ffff 64bit]
[    0.454795] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[    0.456354] pci 0000:00:0d.2: [8086:463e] type 00 class 0x0c0340
[    0.456363] pci 0000:00:0d.2: reg 0x10: [mem 0x622f200000-0x622f23ffff 64bit]
[    0.456369] pci 0000:00:0d.2: reg 0x18: [mem 0x622f299000-0x622f299fff 64bit]
[    0.456397] pci 0000:00:0d.2: supports D1 D2
[    0.456398] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[    0.456577] pci 0000:00:0e.0: [8086:467f] type 00 class 0x010400
[    0.456589] pci 0000:00:0e.0: reg 0x10: [mem 0x622c000000-0x622dffffff 64bit]
[    0.456595] pci 0000:00:0e.0: reg 0x18: [mem 0x50000000-0x51ffffff]
[    0.456608] pci 0000:00:0e.0: reg 0x20: [mem 0x622f100000-0x622f1fffff 64bit]
[    0.456940] pci 0000:00:14.0: [8086:51ed] type 00 class 0x0c0330
[    0.456961] pci 0000:00:14.0: reg 0x10: [mem 0x622f260000-0x622f26ffff 64bit]
[    0.457048] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.458633] pci 0000:00:14.2: [8086:51ef] type 00 class 0x050000
[    0.458653] pci 0000:00:14.2: reg 0x10: [mem 0x622f290000-0x622f293fff 64bit]
[    0.458666] pci 0000:00:14.2: reg 0x18: [mem 0x622f298000-0x622f298fff 64bit]
[    0.458869] pci 0000:00:14.3: [8086:51f0] type 00 class 0x028000
[    0.458892] pci 0000:00:14.3: reg 0x10: [mem 0x622f28c000-0x622f28ffff 64bit]
[    0.459038] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.459818] pci 0000:00:15.0: [8086:51e8] type 00 class 0x0c8000
[    0.460561] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.464197] pci 0000:00:15.2: [8086:51ea] type 00 class 0x0c8000
[    0.464976] pci 0000:00:15.2: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    0.468133] pci 0000:00:16.0: [8086:51e0] type 00 class 0x078000
[    0.468158] pci 0000:00:16.0: reg 0x10: [mem 0x622f295000-0x622f295fff 64bit]
[    0.468247] pci 0000:00:16.0: PME# supported from D3hot
[    0.468851] pci 0000:00:1f.0: [8086:5182] type 00 class 0x060100
[    0.469184] pci 0000:00:1f.3: [8086:51c8] type 00 class 0x040300
[    0.469247] pci 0000:00:1f.3: reg 0x10: [mem 0x622f288000-0x622f28bfff 64bit]
[    0.469322] pci 0000:00:1f.3: reg 0x20: [mem 0x622f000000-0x622f0fffff 64bit]
[    0.469472] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.469933] pci 0000:00:1f.4: [8086:51a3] type 00 class 0x0c0500
[    0.469962] pci 0000:00:1f.4: reg 0x10: [mem 0x622f294000-0x622f2940ff 64bit]
[    0.469996] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    0.470211] pci 0000:00:1f.5: [8086:51a4] type 00 class 0x0c8000
[    0.470231] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.470389] pci 0000:00:1f.6: [8086:1a1e] type 00 class 0x020000
[    0.470433] pci 0000:00:1f.6: reg 0x10: [mem 0x60100000-0x6011ffff]
[    0.470646] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.470861] acpiphp: Slot [1] registered
[    0.470873] pci 0000:01:00.0: [10de:249d] type 00 class 0x030000
[    0.470881] pci 0000:01:00.0: reg 0x10: [mem 0x5f000000-0x5fffffff]
[    0.470887] pci 0000:01:00.0: reg 0x14: [mem 0x6000000000-0x61ffffffff 64bit pref]
[    0.470893] pci 0000:01:00.0: reg 0x1c: [mem 0x6200000000-0x6201ffffff 64bit pref]
[    0.470896] pci 0000:01:00.0: reg 0x24: [io  0x3000-0x307f]
[    0.470900] pci 0000:01:00.0: reg 0x30: [mem 0x60000000-0x6007ffff pref]
[    0.470944] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.470994] pci 0000:01:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.471161] pci 0000:01:00.1: [10de:228b] type 00 class 0x040300
[    0.471169] pci 0000:01:00.1: reg 0x10: [mem 0x60080000-0x60083fff]
[    0.471263] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.471264] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    0.471266] pci 0000:00:01.0:   bridge window [mem 0x5f000000-0x600fffff]
[    0.471268] pci 0000:00:01.0:   bridge window [mem 0x6000000000-0x6201ffffff 64bit pref]
[    0.471291] pci 0000:00:07.0: PCI bridge to [bus 02-2b]
[    0.471294] pci 0000:00:07.0:   bridge window [mem 0x52000000-0x5e1fffff]
[    0.471297] pci 0000:00:07.0:   bridge window [mem 0x6210000000-0x622bffffff 64bit pref]
[    0.476020] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.476098] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[    0.476175] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.476251] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.476327] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.476403] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.476479] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.476555] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.753067] Low-power S0 idle used by default for system suspend
[    0.765306] ACPI: EC: interrupt unblocked
[    0.765306] ACPI: EC: event unblocked
[    0.765337] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.765338] ACPI: EC: GPE=0x6e
[    0.765339] ACPI: \_SB_.PC00.LPCB.EC0_: Boot DSDT EC initialization complete
[    0.765340] ACPI: \_SB_.PC00.LPCB.EC0_: EC: Used to handle transactions and events
[    0.767164] iommu: Default domain type: Translated
[    0.767164] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.767210] SCSI subsystem initialized
[    0.767213] libata version 3.00 loaded.
[    0.767213] ACPI: bus type USB registered
[    0.767213] usbcore: registered new interface driver usbfs
[    0.767213] usbcore: registered new interface driver hub
[    0.767213] usbcore: registered new device driver usb
[    0.767213] pps_core: LinuxPPS API ver. 1 registered
[    0.767213] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.767213] PTP clock support registered
[    0.767213] EDAC MC: Ver: 3.0.0
[    0.767500] Registered efivars operations
[    0.767500] NetLabel: Initializing
[    0.767500] NetLabel:  domain hash size = 128
[    0.767500] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.767500] NetLabel:  unlabeled traffic allowed by default
[    0.767500] mctp: management component transport protocol core
[    0.767500] NET: Registered PF_MCTP protocol family
[    0.767500] PCI: Using ACPI for IRQ routing
[    0.845097] PCI: pci_cache_line_size set to 64 bytes
[    0.845302] pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
[    0.845488] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.845490] e820: reserve RAM buffer [mem 0x2069b000-0x23ffffff]
[    0.845490] e820: reserve RAM buffer [mem 0x33608000-0x33ffffff]
[    0.845491] e820: reserve RAM buffer [mem 0x37d58000-0x37ffffff]
[    0.845491] e820: reserve RAM buffer [mem 0x41800000-0x43ffffff]
[    0.845491] e820: reserve RAM buffer [mem 0x4b0800000-0x4b3ffffff]
[    0.847182] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.847182] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.847182] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.847182] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.847182] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.847182] vgaarb: loaded
[    0.847721] clocksource: Switched to clocksource tsc-early
[    0.847781] VFS: Disk quotas dquot_6.6.0
[    0.847788] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.847823] pnp: PnP ACPI init
[    0.848002] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.848004] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.848098] system 00:02: [io  0x1854-0x1857] has been reserved
[    0.848911] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[    0.848924] system 00:04: [mem 0xfedc0000-0xfedc7fff] has been reserved
[    0.848925] system 00:04: [mem 0xfeda0000-0xfeda0fff] has been reserved
[    0.848926] system 00:04: [mem 0xfeda1000-0xfeda1fff] has been reserved
[    0.848927] system 00:04: [mem 0xfed20000-0xfed7ffff] could not be reserved
[    0.848928] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.848928] system 00:04: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.848929] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.851270] system 00:05: [io  0x2000-0x20fe] has been reserved
[    0.851912] pnp: PnP ACPI: found 7 devices
[    0.856920] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.856955] NET: Registered PF_INET protocol family
[    0.857117] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.858742] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.858766] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.858863] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.859069] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.859158] TCP: Hash tables configured (established 131072 bind 65536)
[    0.859227] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.859263] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.859291] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.859328] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.859332] NET: Registered PF_XDP protocol family
[    0.859335] pci 0000:00:07.0: bridge window [io  0x1000-0x0fff] to [bus 02-2b] add_size 1000
[    0.859341] clipped [mem size 0x00000000 64bit pref] to [mem size 0xfffffffffffe0000 64bit pref] for e820 entry [mem 0x000a0000-0x000fffff]
[    0.859343] pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
[    0.859345] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffe0000 64bit] for e820 entry [mem 0x000a0000-0x000fffff]
[    0.859346] pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
[    0.859348] pci 0000:00:07.0: BAR 13: assigned [io  0x5000-0x5fff]
[    0.859349] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffe0000 64bit] for e820 entry [mem 0x000a0000-0x000fffff]
[    0.859350] pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
[    0.859696] clipped [mem size 0x00000000 64bit] to [mem size 0xfffffffffffe0000 64bit] for e820 entry [mem 0x000a0000-0x000fffff]
[    0.859697] pci 0000:00:15.2: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
[    0.860036] clipped [mem size 0x00020000] to [mem size 0xfffffffffffc0000] for e820 entry [mem 0x000a0000-0x000fffff]
[    0.860037] clipped [mem size 0x00010000] to [mem size 0xffffffffffff0000] for e820 entry [mem 0x000a0000-0x000fffff]
[    0.860038] pci 0000:00:1f.5: BAR 0: assigned [mem 0x4f800000-0x4f800fff]
[    0.860053] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.860054] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    0.860057] pci 0000:00:01.0:   bridge window [mem 0x5f000000-0x600fffff]
[    0.860058] pci 0000:00:01.0:   bridge window [mem 0x6000000000-0x6201ffffff 64bit pref]
[    0.860061] pci 0000:00:07.0: PCI bridge to [bus 02-2b]
[    0.860062] pci 0000:00:07.0:   bridge window [io  0x5000-0x5fff]
[    0.860064] pci 0000:00:07.0:   bridge window [mem 0x52000000-0x5e1fffff]
[    0.860066] pci 0000:00:07.0:   bridge window [mem 0x6210000000-0x622bffffff 64bit pref]
[    0.860069] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.860070] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.860071] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.860072] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000fffff window]
[    0.860072] pci_bus 0000:00: resource 8 [mem 0x4f800000-0xbfffffff window]
[    0.860073] pci_bus 0000:00: resource 9 [mem 0x4000000000-0x7fffffffff window]
[    0.860074] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.860074] pci_bus 0000:01: resource 1 [mem 0x5f000000-0x600fffff]
[    0.860075] pci_bus 0000:01: resource 2 [mem 0x6000000000-0x6201ffffff 64bit pref]
[    0.860075] pci_bus 0000:02: resource 0 [io  0x5000-0x5fff]
[    0.860076] pci_bus 0000:02: resource 1 [mem 0x52000000-0x5e1fffff]
[    0.860077] pci_bus 0000:02: resource 2 [mem 0x6210000000-0x622bffffff 64bit pref]
[    0.860623] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.860649] PCI: CLS 64 bytes, default 64
[    0.860652] DMAR: Intel-IOMMU force enabled due to platform opt in
[    0.860656] DMAR: No ATSR found
[    0.860657] DMAR: No SATC found
[    0.860657] DMAR: IOMMU feature fl1gp_support inconsistent
[    0.860658] DMAR: IOMMU feature pgsel_inv inconsistent
[    0.860658] DMAR: IOMMU feature nwfs inconsistent
[    0.860659] DMAR: IOMMU feature dit inconsistent
[    0.860659] DMAR: IOMMU feature sc_support inconsistent
[    0.860660] DMAR: IOMMU feature dev_iotlb_support inconsistent
[    0.860660] DMAR: dmar0: Using Queued invalidation
[    0.860662] DMAR: dmar1: Using Queued invalidation
[    0.860681] Trying to unpack rootfs image as initramfs...
[    0.860872] pci 0000:00:02.0: Adding to iommu group 0
[    0.860887] pci 0000:00:00.0: Adding to iommu group 1
[    0.860892] pci 0000:00:01.0: Adding to iommu group 2
[    0.860896] pci 0000:00:04.0: Adding to iommu group 3
[    0.860902] pci 0000:00:06.0: Adding to iommu group 4
[    0.860907] pci 0000:00:07.0: Adding to iommu group 5
[    0.860910] pci 0000:00:08.0: Adding to iommu group 6
[    0.860914] pci 0000:00:0a.0: Adding to iommu group 7
[    0.860921] pci 0000:00:0d.0: Adding to iommu group 8
[    0.860925] pci 0000:00:0d.2: Adding to iommu group 8
[    0.860929] pci 0000:00:0e.0: Adding to iommu group 9
[    0.860936] pci 0000:00:14.0: Adding to iommu group 10
[    0.860941] pci 0000:00:14.2: Adding to iommu group 10
[    0.860945] pci 0000:00:14.3: Adding to iommu group 11
[    0.860951] pci 0000:00:15.0: Adding to iommu group 12
[    0.860956] pci 0000:00:15.2: Adding to iommu group 12
[    0.860961] pci 0000:00:16.0: Adding to iommu group 13
[    0.860973] pci 0000:00:1f.0: Adding to iommu group 14
[    0.860977] pci 0000:00:1f.3: Adding to iommu group 14
[    0.860982] pci 0000:00:1f.4: Adding to iommu group 14
[    0.860986] pci 0000:00:1f.5: Adding to iommu group 14
[    0.860990] pci 0000:00:1f.6: Adding to iommu group 14
[    0.860999] pci 0000:01:00.0: Adding to iommu group 15
[    0.861004] pci 0000:01:00.1: Adding to iommu group 15
[    0.861134] DMAR: Intel(R) Virtualization Technology for Directed I/O
[    0.861135] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.861135] software IO TLB: mapped [mem 0x0000000016de9000-0x000000001ade9000] (64MB)
[    0.861163] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26bef67878b, max_idle_ns: 440795293631 ns
[    0.861213] clocksource: Switched to clocksource tsc
[    0.862643] Initialise system trusted keyrings
[    0.862648] Key type blacklist registered
[    0.862674] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.863133] zbud: loaded
[    0.863243] integrity: Platform Keyring initialized
[    0.863244] integrity: Machine keyring initialized
[    0.868570] Key type asymmetric registered
[    0.868570] Asymmetric key parser 'x509' registered
[    3.658262] Freeing initrd memory: 51328K
[    3.660160] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    3.660176] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    3.660197] io scheduler mq-deadline registered
[    3.660199] io scheduler kyber registered
[    3.660223] io scheduler bfq registered
[    3.667441] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[    3.667581] pcieport 0000:00:07.0: PME: Signaling with IRQ 123
[    3.667591] pcieport 0000:00:07.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    3.667718] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.668568] ACPI: AC: AC Adapter [ACAD] (on-line)
[    3.668604] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    3.668614] ACPI: button: Sleep Button [SLPB]
[    3.668629] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    3.668636] ACPI: button: Power Button [PWRB]
[    3.668648] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
[    3.668670] ACPI: button: Lid Switch [LID0]
[    3.672077] thermal LNXTHERM:00: registered as thermal_zone0
[    3.672078] ACPI: thermal: Thermal Zone [THRM] (62 C)
[    3.672621] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    3.672710] ACPI: battery: Slot [BAT1] (battery present)
[    3.673700] hpet_acpi_add: no address or irqs in _CRS
[    3.673722] Non-volatile memory driver v1.3
[    3.673722] Linux agpgart interface v0.103
[    3.694922] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    3.695212] ACPI: bus type drm_connector registered
[    3.696892] usbcore: registered new interface driver usbserial_generic
[    3.696894] usbserial: USB Serial support registered for generic
[    3.696921] rtc_cmos 00:01: RTC can wake from S4
[    3.698807] rtc_cmos 00:01: registered as rtc0
[    3.699182] rtc_cmos 00:01: setting system clock to 2023-01-14T02:39:41 UTC (1673663981)
[    3.699189] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
[    3.700723] intel_pstate: Intel P-state driver initializing
[    3.703165] intel_pstate: HWP enabled
[    3.703697] ledtrig-cpu: registered to indicate activity on CPUs
[    3.703872] efifb: probing for efifb
[    3.704025] efifb: Ignoring BGRT: unexpected or invalid BMP data
[    3.704026] efifb: framebuffer at 0x4000000000, using 3072k, total 3072k
[    3.704027] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    3.704027] efifb: scrolling: redraw
[    3.704028] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.704047] fbcon: Deferring console take-over
[    3.704048] fb0: EFI VGA frame buffer device
[    3.704067] hid: raw HID events driver (C) Jiri Kosina
[    3.704151] intel_pmc_core INT33A1:00:  initialized
[    3.704223] drop_monitor: Initializing network drop monitor service
[    3.710629] Initializing XFRM netlink socket
[    3.710681] NET: Registered PF_INET6 protocol family
[    3.713402] Segment Routing with IPv6
[    3.713402] RPL Segment Routing with IPv6
[    3.713404] In-situ OAM (IOAM) with IPv6
[    3.713414] NET: Registered PF_PACKET protocol family
[    3.715222] microcode: sig=0x906a3, pf=0x80, revision=0x424
[    3.716030] microcode: Microcode Update Driver: v2.2.
[    3.716032] IPI shorthand broadcast: enabled
[    3.716043] sched_clock: Marking stable (3699300259, 15755633)->(3734487993, -19432101)
[    3.716490] registered taskstats version 1
[    3.718203] Loading compiled-in X.509 certificates
[    3.719949] Loaded X.509 cert 'Build time autogenerated kernel key: 5c5acb36a23c86b35d7c1f3b43fac8d124b46bd9'
[    3.722931] zswap: loaded using pool zstd/z3fold
[    3.723514] Key type .fscrypt registered
[    3.723515] Key type fscrypt-provisioning registered
[    3.723950] integrity: Loading X.509 certificate: UEFI:db
[    3.724538] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[    3.724539] integrity: Loading X.509 certificate: UEFI:db
[    3.724618] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[    3.724619] integrity: Loading X.509 certificate: UEFI:db
[    3.724629] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    3.724629] integrity: Loading X.509 certificate: UEFI:db
[    3.724636] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    3.724636] integrity: Loading X.509 certificate: UEFI:db
[    3.724712] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[    3.726345] PM:   Magic number: 7:362:662
[    3.726496] RAS: Correctable Errors collector initialized.
[    3.729423] Freeing unused decrypted memory: 2036K
[    3.729830] Freeing unused kernel image (initmem) memory: 2148K
[    3.750751] Write protecting the kernel read-only data: 30720k
[    3.751953] Freeing unused kernel image (text/rodata gap) memory: 2040K
[    3.752450] Freeing unused kernel image (rodata/data gap) memory: 1216K
[    3.762346] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    3.762348] rodata_test: all tests were successful
[    3.762351] Run /init as init process
[    3.762352]   with arguments:
[    3.762353]     /init
[    3.762354]     splash
[    3.762354]   with environment:
[    3.762355]     HOME=/
[    3.762355]     TERM=linux
[    3.762355]     BOOT_IMAGE=/boot/vmlinuz-x86_64
[    3.762356]     lang=en_US
[    3.762356]     keytable=us
[    3.762357]     tz=UTC
[    3.762357]     misobasedir=manjaro
[    3.762357]     misolabel=MANJARO_GNOME_220
[    3.762358]     driver=free
[    3.794128] fbcon: Taking over console
[    3.794200] Console: switching to colour frame buffer device 128x48
[    3.798652] loop: module loaded
[    3.803076] device-mapper: uevent: version 1.0.3
[    3.803100] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[    3.857331] vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
[    3.857334] pci_bus 10000:e0: root bus resource [bus e0-ff]
[    3.857335] pci_bus 10000:e0: root bus resource [mem 0x50000000-0x51ffffff]
[    3.857336] pci_bus 10000:e0: root bus resource [mem 0x622f102000-0x622f1fffff 64bit]
[    3.857352] pci 10000:e0:06.0: [8086:464d] type 01 class 0x060400
[    3.857395] pci 10000:e0:06.0: PME# supported from D0 D3hot D3cold
[    3.857416] pci 10000:e0:06.0: PTM enabled (root), 4ns granularity
[    3.857497] pci 10000:e0:06.0: Adding to iommu group 9
[    3.857516] pci 10000:e0:06.2: [8086:463d] type 01 class 0x060400
[    3.857565] pci 10000:e0:06.2: PME# supported from D0 D3hot D3cold
[    3.857584] pci 10000:e0:06.2: PTM enabled (root), 4ns granularity
[    3.857629] pci 10000:e0:06.2: Adding to iommu group 9
[    3.857640] pci 10000:e0:06.0: Primary bus is hard wired to 0
[    3.857665] pci 10000:e1:00.0: [144d:a80a] type 00 class 0x010802
[    3.857683] pci 10000:e1:00.0: reg 0x10: [mem 0x50000000-0x50003fff 64bit]
[    3.857699] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[    3.857702] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    3.857876] pci 10000:e1:00.0: Adding to iommu group 9
[    3.857900] pci 10000:e0:06.0: PCI bridge to [bus e1]
[    3.857902] pci 10000:e0:06.0:   bridge window [io  0x0000-0x0fff]
[    3.857904] pci 10000:e0:06.0:   bridge window [mem 0x50000000-0x500fffff]
[    3.857907] pci 10000:e0:06.2: Primary bus is hard wired to 0
[    3.857932] pci 10000:e2:00.0: [1e49:0041] type 00 class 0x010802
[    3.857945] pci 10000:e2:00.0: reg 0x10: [mem 0x50100000-0x50103fff 64bit]
[    3.857963] pci 10000:e2:00.0: reg 0x20: [mem 0x00000000-0x0000ffff 64bit]
[    3.857969] pci 10000:e2:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref]
[    3.858045] pci 10000:e2:00.0: reg 0x1d8: [mem 0x00000000-0x00003fff 64bit]
[    3.858046] pci 10000:e2:00.0: VF(n) BAR0 space: [mem 0x00000000-0x0007ffff 64bit] (contains BAR0 for 32 VFs)
[    3.858219] pci 10000:e2:00.0: Adding to iommu group 9
[    3.858242] pci 10000:e0:06.2: PCI bridge to [bus e2]
[    3.858243] pci 10000:e0:06.2:   bridge window [io  0x0000-0x0fff]
[    3.858245] pci 10000:e0:06.2:   bridge window [mem 0x50100000-0x501fffff]
[    3.858248] pci 10000:e0:06.0: Primary bus is hard wired to 0
[    3.858251] pci 10000:e0:06.2: Primary bus is hard wired to 0
[    3.859020] serio: i8042 KBD port at 0x60,0x64 irq 1
[    3.860394] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[    3.860398] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[    3.861445] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[    3.861596] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[    3.861598] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[    3.861599] xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
[    3.861624] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.861625] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.861626] usb usb1: Product: xHCI Host Controller
[    3.861627] usb usb1: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[    3.861628] usb usb1: SerialNumber: 0000:00:0d.0
[    3.861687] hub 1-0:1.0: USB hub found
[    3.861693] hub 1-0:1.0: 1 port detected
[    3.861884] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.861885] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.861886] usb usb2: Product: xHCI Host Controller
[    3.861886] usb usb2: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[    3.861887] usb usb2: SerialNumber: 0000:00:0d.0
[    3.861929] hub 2-0:1.0: USB hub found
[    3.861935] hub 2-0:1.0: 1 port detected
[    3.862211] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    3.862213] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    3.863288] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000100200009810
[    3.863459] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    3.863460] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[    3.863461] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    3.863479] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.863480] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.863481] usb usb3: Product: xHCI Host Controller
[    3.863482] usb usb3: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[    3.863482] usb usb3: SerialNumber: 0000:00:14.0
[    3.863545] hub 3-0:1.0: USB hub found
[    3.863558] hub 3-0:1.0: 12 ports detected
[    3.864070] ACPI: bus type thunderbolt registered
[    3.864100] cryptd: max_cpu_qlen set to 1000
[    3.865129] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[    3.865131] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.865132] usb usb4: Product: xHCI Host Controller
[    3.865132] usb usb4: Manufacturer: Linux 6.1.1-1-MANJARO xhci-hcd
[    3.865133] usb usb4: SerialNumber: 0000:00:14.0
[    3.865239] hub 4-0:1.0: USB hub found
[    3.865246] hub 4-0:1.0: 4 ports detected
[    3.865721] pci 10000:e0:06.2: bridge window [mem 0x00100000-0x001fffff] to [bus e2] add_size 100000 add_align 100000
[    3.865725] pci 10000:e0:06.0: BAR 14: assigned [mem 0x50000000-0x500fffff]
[    3.865727] pci 10000:e0:06.2: BAR 14: assigned [mem 0x50100000-0x502fffff]
[    3.865727] pci 10000:e0:06.0: BAR 13: no space for [io  size 0x1000]
[    3.865728] pci 10000:e0:06.0: BAR 13: failed to assign [io  size 0x1000]
[    3.865729] pci 10000:e0:06.2: BAR 13: no space for [io  size 0x1000]
[    3.865730] pci 10000:e0:06.2: BAR 13: failed to assign [io  size 0x1000]
[    3.865731] pci 10000:e0:06.0: BAR 13: no space for [io  size 0x1000]
[    3.865731] pci 10000:e0:06.0: BAR 13: failed to assign [io  size 0x1000]
[    3.865732] pci 10000:e0:06.2: BAR 13: no space for [io  size 0x1000]
[    3.865732] pci 10000:e0:06.2: BAR 13: failed to assign [io  size 0x1000]
[    3.865734] pci 10000:e1:00.0: BAR 0: assigned [mem 0x50000000-0x50003fff 64bit]
[    3.865741] pci 10000:e0:06.0: PCI bridge to [bus e1]
[    3.865744] pci 10000:e0:06.0:   bridge window [mem 0x50000000-0x500fffff]
[    3.865748] pci 10000:e2:00.0: BAR 6: assigned [mem 0x50100000-0x5011ffff pref]
[    3.865749] pci 10000:e2:00.0: BAR 4: assigned [mem 0x50120000-0x5012ffff 64bit]
[    3.865755] pci 10000:e2:00.0: BAR 0: assigned [mem 0x50130000-0x50133fff 64bit]
[    3.865760] pci 10000:e2:00.0: BAR 7: assigned [mem 0x50134000-0x501b3fff 64bit]
[    3.865763] pci 10000:e0:06.2: PCI bridge to [bus e2]
[    3.865765] pci 10000:e0:06.2:   bridge window [mem 0x50100000-0x502fffff]
[    3.865777] pcieport 10000:e0:06.0: can't derive routing for PCI INT D
[    3.865777] pcieport 10000:e0:06.0: PCI INT D: no GSI
[    3.865808] pcieport 10000:e0:06.0: PME: Signaling with IRQ 161
[    3.865849] pcieport 10000:e0:06.2: can't derive routing for PCI INT B
[    3.865849] pcieport 10000:e0:06.2: PCI INT B: no GSI
[    3.865868] pcieport 10000:e0:06.2: PME: Signaling with IRQ 162
[    3.865923] vmd 0000:00:0e.0: Bound to PCI domain 10000
[    3.866490] e1000e: Intel(R) PRO/1000 Network Driver
[    3.866492] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.866526] e1000e 0000:00:1f.6: enabling device (0000 -> 0002)
[    3.866819] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    3.872926] AVX2 version of gcm_enc/dec engaged.
[    3.872967] AES CTR mode by8 optimization enabled
[    3.886896] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    3.925405] nvme nvme0: pci function 10000:e1:00.0
[    3.925425] pcieport 10000:e0:06.0: can't derive routing for PCI INT A
[    3.925428] nvme 10000:e1:00.0: PCI INT A: not connected
[    3.925526] nvme nvme1: pci function 10000:e2:00.0
[    3.925539] pcieport 10000:e0:06.2: can't derive routing for PCI INT A
[    3.925541] nvme 10000:e2:00.0: PCI INT A: not connected
[    3.930755] nvme nvme1: 18/0/0 default/read/poll queues
[    3.932493]  nvme1n1: p1 p2 p3
[    3.937570] nvme nvme0: Shutdown timeout set to 10 seconds
[    3.941430] nvme nvme0: 18/0/0 default/read/poll queues
[    3.943687]  nvme0n1: p1 p2 p3 p4 p5 p6
[    4.024073] ACPI Warning: \_SB.PC00.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
[    4.024116] ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
[    4.024245] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[    4.024249] VGA switcheroo: detected Optimus DSM method \_SB_.PC00.PEG1.PEGP handle
[    4.024249] nouveau: detected PR support, will not use DSM
[    4.024269] nouveau 0000:01:00.0: enabling device (0000 -> 0003)
[    4.024533] Console: switching to colour dummy device 80x25
[    4.024604] nouveau 0000:01:00.0: NVIDIA GA104 (b74000a1)
[    4.117141] usb 3-7: new high-speed USB device number 2 using xhci_hcd
[    4.122219] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    4.125906] i915 0000:00:02.0: [drm] VT-d active for gfx access
[    4.125908] i915 0000:00:02.0: vgaarb: deactivate vga console
[    4.125938] i915 0000:00:02.0: [drm] Using Transparent Hugepages
[    4.126270] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    4.127744] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/adlp_dmc_ver2_16.bin (v2.16)
[    4.138681] nouveau 0000:01:00.0: bios: version 94.04.7e.00.6e
[    4.139139] nouveau 0000:01:00.0: fb: 8192 MiB GDDR6
[    4.144582] nouveau 0000:01:00.0: DRM: VRAM: 8192 MiB
[    4.144583] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[    4.144584] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[    4.144585] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[    4.144585] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[    4.144586] nouveau 0000:01:00.0: DRM: DCB version 4.1
[    4.144587] nouveau 0000:01:00.0: DRM: DCB outp 00: 02813f66 04600020
[    4.144588] nouveau 0000:01:00.0: DRM: DCB outp 01: 04824f72 00020010
[    4.144588] nouveau 0000:01:00.0: DRM: DCB outp 02: 02802f56 04600010
[    4.144589] nouveau 0000:01:00.0: DRM: DCB outp 03: 02802f52 00020010
[    4.144589] nouveau 0000:01:00.0: DRM: DCB conn 02: 00010246
[    4.144590] nouveau 0000:01:00.0: DRM: DCB conn 03: 00020347
[    4.144590] nouveau 0000:01:00.0: DRM: DCB conn 04: 01000461
[    4.144854] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[    4.190735] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) a0:36:bc:2e:3b:56
[    4.190741] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    4.190868] e1000e 0000:00:1f.6 eth0: MAC: 15, PHY: 12, PBA No: FFFFFF-0FF
[    4.229008] i915 0000:00:02.0: [drm] GuC error state capture buffer maybe too small: 2097152 < 2360316 (min = 786772)
[    4.230693] i915 0000:00:02.0: [drm] GuC firmware i915/adlp_guc_70.bin version 70.5.1
[    4.230694] i915 0000:00:02.0: [drm] HuC firmware i915/tgl_huc.bin version 7.9.3
[    4.244834] i915 0000:00:02.0: [drm] HuC authenticated
[    4.245777] i915 0000:00:02.0: [drm] GuC submission enabled
[    4.245777] i915 0000:00:02.0: [drm] GuC SLPC enabled
[    4.246248] i915 0000:00:02.0: [drm] GuC RC: enabled
[    4.247041] i915 0000:00:02.0: [drm] Protected Xe Path (PXP) protected content support initialized
[    4.280184] usb 3-7: New USB device found, idVendor=322e, idProduct=202c, bcdDevice= 1.03
[    4.280198] usb 3-7: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    4.280202] usb 3-7: Product: USB2.0 HD UVC WebCam
[    4.280206] usb 3-7: Manufacturer: Sonix Technology Co., Ltd.
[    4.387762] usb 4-2: new SuperSpeed USB device number 2 using xhci_hcd
[    4.418243] usb 4-2: New USB device found, idVendor=0dd8, idProduct=3b00, bcdDevice= 0.02
[    4.418260] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.418266] usb 4-2: Product: OnlyDisk
[    4.418270] usb 4-2: Manufacturer: Netac
[    4.418274] usb 4-2: SerialNumber: 72F7381EF24B11D6
[    4.435978] usb-storage 4-2:1.0: USB Mass Storage device detected
[    4.436194] scsi host0: usb-storage 4-2:1.0
[    4.436248] usbcore: registered new interface driver usb-storage
[    4.438393] usbcore: registered new interface driver uas
[    4.513818] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[    4.514568] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[    4.533867] usb 3-9: new full-speed USB device number 3 using xhci_hcd
[    4.567150] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[    4.620482] nouveau 0000:01:00.0: [drm] Cannot find any crtc or sizes
[    5.549395] scsi 0:0:0:0: Direct-Access     Netac    OnlyDisk         8.01 PQ: 0 ANSI: 6
[    5.553034] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    5.553568] ACPI: video: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[    5.553632] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input4
[    5.553886] sd 0:0:0:0: [sda] 121610240 512-byte logical blocks: (62.3 GB/58.0 GiB)
[    5.554505] sd 0:0:0:0: [sda] Write Protect is off
[    5.554514] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[    5.554752] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    5.556440] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    5.557095] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input5
[    5.557639] vga_switcheroo: enabled
[    5.558046]  sda: sda1 sda2
[    5.558335] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    5.566962] fbcon: i915drmfb (fb0) is primary device
[    5.570869] Console: switching to colour frame buffer device 160x45
[    5.582481] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    5.672032] usb 3-9: New USB device found, idVendor=0b05, idProduct=6203, bcdDevice= 1.08
[    5.672042] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.672046] usb 3-9: Product: C-Media(R) Audio
[    5.672048] usb 3-9: Manufacturer: ASUSTeK COMPUTER INC.
[    5.686321] input: ASUSTeK COMPUTER INC. C-Media(R) Audio as /devices/pci0000:00/0000:00:14.0/usb3/3-9/3-9:1.3/0003:0B05:6203.0001/input/input6
[    5.741261] hid-generic 0003:0B05:6203.0001: input,hidraw0: USB HID v1.11 Device [ASUSTeK COMPUTER INC. C-Media(R) Audio] on usb-0000:00:14.0-9/input3
[    5.741357] usbcore: registered new interface driver usbhid
[    5.741361] usbhid: USB HID core driver
[    5.797195] usb 3-10: new full-speed USB device number 4 using xhci_hcd
[    5.819082] EXT4-fs (nvme1n1p2): mounted filesystem with ordered data mode. Quota mode: none.
[    5.819813] EXT4-fs (nvme1n1p2): unmounting filesystem.
[    5.939242] usb 3-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[    5.939249] usb 3-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.949648] ISO 9660 Extensions: Microsoft Joliet Level 3
[    5.951085] ISO 9660 Extensions: RRIP_1991A
[    6.022166] ISO 9660 Extensions: Microsoft Joliet Level 3
[    6.023624] ISO 9660 Extensions: RRIP_1991A
[    6.035121] loop0: detected capacity change from 0 to 274144
[    6.103826] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    6.108092] loop1: detected capacity change from 0 to 2051712
[    6.173005] loop2: detected capacity change from 0 to 3426440
[    6.237260] loop3: detected capacity change from 0 to 1514184
[    6.311352] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[    6.636558] systemd[1]: systemd 252.4-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    6.636563] systemd[1]: Detected architecture x86-64.
[    6.641565] systemd[1]: Hostname set to <manjaro-gnome>.
[    7.137524] systemd[1]: bpf-lsm: LSM BPF program attached
[    7.473524] systemd[1]: Queued start job for default target Graphical Interface.
[    7.501051] systemd[1]: Created slice Slice /system/getty.
[    7.501366] systemd[1]: Created slice Slice /system/modprobe.
[    7.501507] systemd[1]: Created slice User and Session Slice.
[    7.501585] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.501732] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.501798] systemd[1]: Reached target Login Prompts.
[    7.501844] systemd[1]: Reached target Local Integrity Protected Volumes.
[    7.501899] systemd[1]: Reached target Remote File Systems.
[    7.501943] systemd[1]: Reached target Slice Units.
[    7.501989] systemd[1]: Reached target Swaps.
[    7.502032] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.502104] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    7.502836] systemd[1]: Listening on LVM2 poll daemon socket.
[    7.503551] systemd[1]: Listening on Process Core Dump Socket.
[    7.503686] systemd[1]: Listening on Journal Audit Socket.
[    7.503765] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.503837] systemd[1]: Listening on Journal Socket.
[    7.504186] systemd[1]: Listening on udev Control Socket.
[    7.504254] systemd[1]: Listening on udev Kernel Socket.
[    7.504735] systemd[1]: Mounting Huge Pages File System...
[    7.505152] systemd[1]: Mounting POSIX Message Queue File System...
[    7.505581] systemd[1]: Mounting Kernel Debug File System...
[    7.505984] systemd[1]: Mounting Kernel Trace File System...
[    7.508702] systemd[1]: Mounting Temporary Directory /tmp...
[    7.509523] systemd[1]: Starting Create List of Static Device Nodes...
[    7.509930] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    7.510365] systemd[1]: Starting Load Kernel Module configfs...
[    7.510769] systemd[1]: Starting Load Kernel Module drm...
[    7.511135] systemd[1]: Starting Load Kernel Module fuse...
[    7.530070] systemd[1]: Starting Load Kernel Modules...
[    7.530672] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.534478] fuse: init (API version 7.37)
[    7.537456] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    7.537836] systemd[1]: Starting Coldplug All udev Devices...
[    7.538632] systemd[1]: Mounted Huge Pages File System.
[    7.538711] systemd[1]: Mounted POSIX Message Queue File System.
[    7.538769] systemd[1]: Mounted Kernel Debug File System.
[    7.538822] systemd[1]: Mounted Kernel Trace File System.
[    7.538876] systemd[1]: Mounted Temporary Directory /tmp.
[    7.560985] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.580700] systemd[1]: Finished Create List of Static Device Nodes.
[    7.581265] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.614230] systemd[1]: Finished Load Kernel Module configfs.
[    7.614447] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.651025] systemd[1]: Finished Load Kernel Module drm.
[    7.651518] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.681371] systemd[1]: Finished Load Kernel Module fuse.
[    7.701385] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[    7.724490] systemd[1]: Finished Load Kernel Modules.
[    7.747791] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.771175] systemd[1]: Finished Coldplug All udev Devices.
[    7.804277] systemd[1]: Mounting FUSE Control File System...
[    7.807260] systemd[1]: Mounting Kernel Configuration File System...
[    7.808556] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[    7.810807] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    7.811757] systemd[1]: Starting Load/Save Random Seed...
[    7.814226] systemd[1]: Starting Apply Kernel Variables...
[    7.815601] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[    7.816396] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.818027] systemd[1]: Starting Setup Virtual Console...
[    7.820058] systemd[1]: Mounted FUSE Control File System.
[    7.820898] systemd[1]: Mounted Kernel Configuration File System.
[    7.847335] systemd[1]: Finished Load/Save Random Seed.
[    7.870821] systemd[1]: Finished Apply Kernel Variables.
[    7.897806] systemd[1]: Finished Setup Virtual Console.
[    7.899424] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[    7.934365] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.936377] systemd[1]: Reached target Preparation for Local File Systems.
[    7.964423] systemd[1]: Mounting Temporary /etc/pacman.d/gnupg directory...
[    7.966725] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[    7.966774] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[    7.969581] systemd[1]: Starting Journal Service...
[    7.971720] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    7.973874] systemd[1]: Mounted Temporary /etc/pacman.d/gnupg directory.
[    7.975112] systemd[1]: Reached target Local File Systems.
[    7.975980] systemd[1]: Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[    7.976386] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    7.986182] systemd[1]: Set Up Additional Binary Formats was skipped because no trigger condition checks were met.
[    7.986206] systemd[1]: Store a System Token in an EFI Variable was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[    7.986224] systemd[1]: Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[    8.024143] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    8.025145] audit: type=1130 audit(1673663985.823:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.025218] systemd[1]: Started Journal Service.
[    8.026172] audit: type=1130 audit(1673663985.823:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.061757] systemd-journald[527]: Received client request to flush runtime journal.
[    8.110698] audit: type=1130 audit(1673663985.910:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.128925] audit: type=1130 audit(1673663985.926:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.173816] audit: type=1130 audit(1673663985.973:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.209502] resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:04 [mem 0xfedc0000-0xfedc7fff]
[    8.209506] caller igen6_probe+0x19d/0x7e0 [igen6_edac] mapping multiple BARs
[    8.209533] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[    8.209553] EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
[    8.209563] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[    8.209563] EDAC igen6 MC0: ADDR 0x7fffffffe0
[    8.209569] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[    8.209569] EDAC igen6 MC1: ADDR 0x7fffffffe0
[    8.209594] EDAC igen6: v2.5
[    8.222049] e1000e 0000:00:1f.6 eno2: renamed from eth0
[    8.227376] audit: type=1130 audit(1673663986.026:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.234145] audit: type=1334 audit(1673663986.033:8): prog-id=29 op=LOAD
[    8.263197] proc_thermal_pci 0000:00:04.0: enabling device (0000 -> 0002)
[    8.263720] Consider using thermal netlink events interface
[    8.263957] intel_rapl_common: Found RAPL domain package
[    8.267322] audit: type=1127 audit(1673663986.066:9): pid=605 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[    8.297378] audit: type=1130 audit(1673663986.096:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.297527] audit: type=1130 audit(1673663986.096:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    9.230521] NET: Registered PF_QIPCRTR protocol family
[    9.358524] input: Intel HID events as /devices/platform/INTC1070:00/input/input7
[    9.358645] intel-hid INTC1070:00: platform supports 5 button array
[    9.358658] input: Intel HID 5 button array as /devices/platform/INTC1070:00/input/input8
[    9.562490] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[    9.806015] mc: Linux media interface: v0.10
[    9.867301] Bluetooth: Core ver 2.22
[    9.867325] NET: Registered PF_BLUETOOTH protocol family
[    9.867326] Bluetooth: HCI device and connection manager initialized
[    9.867329] Bluetooth: HCI socket layer initialized
[    9.867331] Bluetooth: L2CAP socket layer initialized
[    9.867335] Bluetooth: SCO socket layer initialized
[    9.882491] videodev: Linux video capture interface: v2.00
[    9.907028] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    9.907254] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    9.907467] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    9.907545] snd_hda_intel 0000:01:00.1: Disabling MSI
[    9.907550] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[   10.004098] usb 3-7: Found UVC 1.00 device USB2.0 HD UVC WebCam (322e:202c)
[   10.006926] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[   10.011916] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:14.0/usb3/3-7/3-7:1.0/input/input13
[   10.011970] usbcore: registered new interface driver uvcvideo
[   10.013099] usbcore: registered new interface driver snd-usb-audio
[   10.020328] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   10.020422] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   10.033810] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[   10.034113] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   10.053849] intel-lpss 0000:00:15.2: enabling device (0004 -> 0006)
[   10.054086] idma64 idma64.1: Found Intel integrated DMA 64-bit
[   10.061211] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[   10.061232] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[   10.061249] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[   10.061265] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[   10.110942] usbcore: registered new interface driver btusb
[   10.113088] Bluetooth: hci0: Device revision is 2
[   10.113104] Bluetooth: hci0: Secure boot is enabled
[   10.113110] Bluetooth: hci0: OTP lock is enabled
[   10.113114] Bluetooth: hci0: API lock is enabled
[   10.113118] Bluetooth: hci0: Debug lock is disabled
[   10.113118] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[   10.113119] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[   10.138670] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[   10.138689] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   10.138703] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[   10.138715] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[   10.141481] Bluetooth: hci0: Found device firmware: intel/ibt-0040-4150.sfi
[   10.141503] Bluetooth: hci0: Boot Address: 0x100800
[   10.141504] Bluetooth: hci0: Firmware Version: 191-39.22
[   10.142934] Intel(R) Wireless WiFi driver for Linux
[   10.143039] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   10.144675] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   10.166358] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[   10.166369] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[   10.166847] iwlwifi 0000:00:14.3: loaded firmware version 72.daa05125.0 so-a0-hr-b0-72.ucode op_mode iwlmvm
[   10.189367] input: ASUF1204:00 2808:0104 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-31/i2c-ASUF1204:00/0018:2808:0104.0002/input/input18
[   10.189458] input: ASUF1204:00 2808:0104 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-31/i2c-ASUF1204:00/0018:2808:0104.0002/input/input19
[   10.189484] hid-generic 0018:2808:0104.0002: input,hidraw1: I2C HID v1.00 Mouse [ASUF1204:00 2808:0104] on i2c-ASUF1204:00
[   10.208501] input: ITE5570:00 048D:8051 as /devices/pci0000:00/0000:00:15.2/i2c_designware.1/i2c-32/i2c-ITE5570:00/0018:048D:8051.0003/input/input22
[   10.208625] hid-generic 0018:048D:8051.0003: input,hidraw2: I2C HID v1.00 Device [ITE5570:00 048D:8051] on i2c-ITE5570:00
[   10.311468] i801_smbus 0000:00:1f.4: enabling device (0001 -> 0003)
[   10.311680] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[   10.311801] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[   10.311828] spi-nor spi0.0: w25q256 (32768 Kbytes)
[   10.313693] Creating 1 MTD partitions on "0000:00:1f.5":
[   10.313703] 0x000000000000-0x000002000000 : "BIOS"
[   10.315320] i2c i2c-33: 2/2 memory slots populated (from DMI)
[   10.315322] i2c i2c-33: Memory type 0x22 not supported yet, not instantiating SPD
[   10.409149] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x370
[   10.409185] thermal thermal_zone6: failed to read out thermal zone (-61)
[   10.523889] iwlwifi 0000:00:14.3: Detected RF HR B3, rfid=0x10a100
[   10.591028] iwlwifi 0000:00:14.3: base HW address: bc:09:1b:ac:c0:c9
[   10.777258] ucsi_acpi USBC000:00: PPM init failed (-110)
[   11.646652] Bluetooth: hci0: Waiting for firmware download to complete
[   11.647095] Bluetooth: hci0: Firmware loaded in 1470323 usecs
[   11.647170] Bluetooth: hci0: Waiting for device to boot
[   11.663210] Bluetooth: hci0: Device booted in 15682 usecs
[   11.663213] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[   11.682014] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0040-4150.ddc
[   11.684131] Bluetooth: hci0: Applying Intel DDC parameters completed
[   11.687255] Bluetooth: hci0: Firmware timestamp 2022.39 buildtype 1 build 52159
[   12.857973] asus_wmi: ASUS WMI generic driver loaded
[   12.860299] asus_wmi: Initialization: 0x1
[   12.860634] asus_wmi: SFUN value: 0x21
[   12.860636] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[   12.860637] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[   12.868695] asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
[   12.871979] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input23
[   12.889485] ACPI: battery: new extension: ASUS Battery Extension
[   12.918468] input: PC Speaker as /devices/platform/pcspkr/input/input24
[   12.935466] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[   12.935469] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   12.935469] RAPL PMU: hw unit of domain package 2^-14 Joules
[   12.935470] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   13.108084] intel_tcc_cooling: Programmable TCC Offset detected
[   14.233781] intel_rapl_msr: PL4 support detected.
[   14.233863] intel_rapl_common: Found RAPL domain package
[   14.233865] intel_rapl_common: Found RAPL domain core
[   14.233867] intel_rapl_common: Found RAPL domain uncore
[   14.400659] kauditd_printk_skb: 41 callbacks suppressed
[   14.400661] audit: type=1130 audit(1673663992.200:53): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.451335] audit: type=1130 audit(1673663992.250:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.471874] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.471876] Bluetooth: BNEP filters: protocol multicast
[   14.471880] Bluetooth: BNEP socket layer initialized
[   14.472601] Bluetooth: MGMT ver 1.22
[   14.477349] NET: Registered PF_ALG protocol family
[   14.489104] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[   14.490422] mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
[   14.510975] audit: type=1130 audit(1673663992.310:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.511547] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[   14.540953] iTCO_vendor_support: vendor-support=0
[   14.584482] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[   14.584548] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   14.603074] input: ASUF1204:00 2808:0104 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-31/i2c-ASUF1204:00/0018:2808:0104.0002/input/input25
[   14.603105] input: ASUF1204:00 2808:0104 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-31/i2c-ASUF1204:00/0018:2808:0104.0002/input/input26
[   14.603132] hid-multitouch 0018:2808:0104.0002: input,hidraw1: I2C HID v1.00 Mouse [ASUF1204:00 2808:0104] on i2c-ASUF1204:00
[   14.604154] audit: type=1130 audit(1673663992.403:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:asus::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.616943] e1000e 0000:00:1f.6 eno2: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
[   14.658392] mousedev: PS/2 mouse device common for all mice
[   14.748935] IPv6: ADDRCONF(NETDEV_CHANGE): eno2: link becomes ready
[   14.940779] audit: type=1130 audit(1673663992.740:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.940782] audit: type=1131 audit(1673663992.740:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.007516] audit: type=1130 audit(1673663992.806:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.043727] audit: type=1130 audit(1673663992.840:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.050163] audit: type=1130 audit(1673663992.846:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.658582] audit: type=1334 audit(1673663995.456:62): prog-id=36 op=LOAD
[   18.657543] nouveau 0000:01:00.0: mc: intr 00000040
[   18.657553] nouveau 0000:01:00.0: mc: intr 00000040
[   18.657557] nouveau 0000:01:00.0: mc: intr 00000040
[   18.657562] nouveau 0000:01:00.0: mc: intr 00000040
[   18.657569] nouveau 0000:01:00.0: mc: intr 00000040
[   18.657580] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662659] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662663] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662666] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662669] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662672] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662675] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662678] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662682] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662685] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662688] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662691] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662694] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662698] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662701] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662704] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662707] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662710] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662713] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662717] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662720] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662723] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662726] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662730] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662733] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662736] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662739] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662743] nouveau 0000:01:00.0: mc: intr 00000040
[   18.662753] nouveau 0000:01:00.0: mc: intr 00000040
[   18.994466] nouveau 0000:01:00.0: mc: intr 00000040
[   19.009408] nouveau 0000:01:00.0: disp: chid 0 stat 00007082 reason 7 [UNRESOLVABLE_HANDLE] mthd 0208 data f0000000 code 00000000
[   19.544029] kauditd_printk_skb: 16 callbacks suppressed
[   19.544031] audit: type=1131 audit(1673663997.343:75): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.587565] audit: type=1131 audit(1673663997.386:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.650780] audit: type=1334 audit(1673663998.450:77): prog-id=37 op=LOAD
[   20.650790] audit: type=1334 audit(1673663998.450:78): prog-id=38 op=LOAD
[   20.680528] audit: type=1130 audit(1673663998.480:79): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=power-profiles-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.683218] audit: type=1130 audit(1673663998.480:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.683708] audit: type=1130 audit(1673663998.480:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.686924] audit: type=1130 audit(1673663998.483:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.758157] audit: type=1130 audit(1673663998.556:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.226581] audit: type=1130 audit(1673663999.023:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.228093] rfkill: input handler disabled
[   21.963911] Bluetooth: RFCOMM TTY layer initialized
[   21.963916] Bluetooth: RFCOMM socket layer initialized
[   21.963918] Bluetooth: RFCOMM ver 1.11
[   27.860978] kauditd_printk_skb: 14 callbacks suppressed
[   27.860981] audit: type=1130 audit(1673664005.660:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.912143] audit: type=1101 audit(1673664013.710:100): pid=2489 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   35.912384] audit: type=1110 audit(1673664013.710:101): pid=2489 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   35.912388] audit: type=1105 audit(1673664013.710:102): pid=2489 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[   36.049368] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[   36.061249] JFS: nTxBlock = 8192, nTxLock = 65536
[   36.094094] raid6: skipped pq benchmark and selected avx2x4
[   36.094096] raid6: using avx2x2 recovery algorithm
[   36.097474] xor: automatically using best checksumming function   avx
[   36.156365] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[   38.291412] EXT4-fs (nvme1n1p2): mounted filesystem with ordered data mode. Quota mode: none.
[   38.657632] audit: type=1130 audit(1673664016.456:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-quit-wait comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   44.160049] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[   52.034511] audit: type=1131 audit(1673664029.813:104): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.074509] audit: type=1131 audit(1673664029.853:105): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   52.134158] audit: type=1334 audit(1673664029.913:106): prog-id=0 op=UNLOAD
[   52.134198] audit: type=1334 audit(1673664029.913:107): prog-id=0 op=UNLOAD
[   52.134205] audit: type=1334 audit(1673664029.913:108): prog-id=0 op=UNLOAD
[   52.224058] audit: type=1334 audit(1673664030.003:109): prog-id=0 op=UNLOAD
[   52.224073] audit: type=1334 audit(1673664030.003:110): prog-id=0 op=UNLOAD
[   52.224079] audit: type=1334 audit(1673664030.003:111): prog-id=0 op=UNLOAD
[   81.090156] audit: type=1131 audit(1673664058.857:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   85.938665] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  114.721409] perf: interrupt took too long (6392 > 2500), lowering kernel.perf_event_max_sample_rate to 31200
[  129.306092] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  129.358425] ------------[ cut here ]------------
[  129.358425] nouveau 0000:01:00.0: disabling already-disabled device
[  129.358430] WARNING: CPU: 1 PID: 142 at drivers/pci/pci.c:2246 pci_disable_device+0xa4/0xd0
[  129.358434] Modules linked in: btrfs blake2b_generic xor raid6_pq ufs hfsplus hfs minix msdos jfs xfs libcrc32c rfcomm mousedev cmac iTCO_wdt intel_pmc_bxt algif_hash iTCO_vendor_support algif_skcipher hid_multitouch af_alg mei_pxp mei_hdcp bnep pmt_telemetry pmt_class intel_rapl_msr intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul polyval_clmulni polyval_generic gf128mul ghash_clmulni_intel rapl intel_cstate intel_uncore pcspkr asus_nb_wmi asus_wmi ledtrig_audio platform_profile wmi_bmof snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match iwlmvm snd_soc_acpi soundwire_bus mac80211 spi_nor i2c_i801 snd_soc_core snd_compress ac97_bus libarc4 mtd iwlwifi snd_pcm_dmaengine i2c_smbus mei_me intel_lpss_pci mei intel_lpss snd_hda_codec_hdmi idma64
[  129.358490]  uvcvideo btusb cfg80211 snd_usb_audio snd_hda_intel btrtl btbcm videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 btintel snd_usbmidi_lib snd_intel_dspcfg videobuf2_common snd_rawmidi snd_intel_sdw_acpi snd_seq_device btmtk snd_hda_codec videodev snd_hda_core mc bluetooth snd_hwdep snd_pcm snd_timer ecdh_generic snd intel_vsec soundcore ucsi_acpi typec_ucsi typec roles st sr_mod int3403_thermal intel_hid i2c_hid_acpi i2c_hid rfkill sparse_keymap int3400_thermal qrtr acpi_thermal_rel acpi_pad joydev processor_thermal_device_pci processor_thermal_device processor_thermal_rfim processor_thermal_mbox processor_thermal_rapl intel_rapl_common int340x_thermal_zone igen6_edac mac_hid dm_multipath sg crypto_user fuse bpf_preload ip_tables x_tables overlay squashfs isofs cdrom ext4 crc32c_generic crc16 mbcache jbd2 vfat fat usbhid uas usb_storage i915 nouveau serio_raw crc32_pclmul nvme atkbd crc32c_intel nvme_core mxm_wmi libps2 sha512_ssse3 drm_ttm_helper vivaldi_fmap aesni_intel
[  129.358519]  drm_buddy nvme_common ttm crypto_simd drm_display_helper cryptd e1000e spi_intel_pci xhci_pci thunderbolt cec i8042 spi_intel intel_gtt xhci_pci_renesas vmd video serio wmi dm_snapshot dm_bufio dm_mod loop
[  129.358527] CPU: 1 PID: 142 Comm: kworker/1:2 Not tainted 6.1.1-1-MANJARO #1 58eeef856bad441bca33a8abb39f91301fd24d8d
[  129.358529] Hardware name: ASUSTeK COMPUTER INC. ASUS TUF Gaming F15 FX507ZR_FX507ZR/FX507ZR, BIOS FX507ZR.315 06/17/2022
[  129.358530] Workqueue: pm pm_runtime_work
[  129.358533] RIP: 0010:pci_disable_device+0xa4/0xd0
[  129.358535] Code: 48 85 ed 75 07 48 8b ab d0 00 00 00 48 8d bb d0 00 00 00 e8 ee 2c 1b 00 48 89 ea 48 c7 c7 a8 97 8f 91 48 89 c6 e8 47 88 5a 00 <0f> 0b e9 76 ff ff ff 48 89 df e8 cd fe ff ff 80 a3 09 08 00 00 df
[  129.358535] RSP: 0018:ffffa2a14063fd40 EFLAGS: 00010282
[  129.358537] RAX: 0000000000000000 RBX: ffff93f4c30c6000 RCX: 0000000000000027
[  129.358537] RDX: ffff93f860261668 RSI: 0000000000000001 RDI: ffff93f860261660
[  129.358538] RBP: ffff93f4c30f5010 R08: 0000000000000000 R09: ffffa2a14063fbc8
[  129.358538] R10: 0000000000000003 R11: ffff93f8707a9c28 R12: ffff93f4dc0d3800
[  129.358539] R13: 0000000000000003 R14: 0000000000000000 R15: ffff93f4c30c6248
[  129.358539] FS:  0000000000000000(0000) GS:ffff93f860240000(0000) knlGS:0000000000000000
[  129.358540] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  129.358541] CR2: 00005615140f7a08 CR3: 000000014ce10002 CR4: 0000000000f70ee0
[  129.358541] PKRU: 55555554
[  129.358542] Call Trace:
[  129.358543]  <TASK>
[  129.358545]  nouveau_pmops_runtime_suspend+0x50/0xb0 [nouveau b94536815bcbee6c07bf0305391ef14c5a1db60e]
[  129.358605]  pci_pm_runtime_suspend+0x67/0x1b0
[  129.358606]  ? pci_dev_put+0x20/0x20
[  129.358607]  __rpm_callback+0x41/0x170
[  129.358609]  ? pci_dev_put+0x20/0x20
[  129.358610]  rpm_callback+0x5d/0x70
[  129.358611]  ? pci_dev_put+0x20/0x20
[  129.358612]  rpm_suspend+0x11a/0x720
[  129.358614]  ? __schedule+0x378/0x12a0
[  129.358616]  pm_runtime_work+0x98/0xb0
[  129.358617]  process_one_work+0x1c4/0x380
[  129.358620]  worker_thread+0x51/0x390
[  129.358621]  ? rescuer_thread+0x3b0/0x3b0
[  129.358622]  kthread+0xdb/0x110
[  129.358624]  ? kthread_complete_and_exit+0x20/0x20
[  129.358625]  ret_from_fork+0x1f/0x30
[  129.358628]  </TASK>
[  129.358628] ---[ end trace 0000000000000000 ]---
[  152.003418] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  173.260164] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  193.566721] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  202.999192] perf: interrupt took too long (12618 > 7990), lowering kernel.perf_event_max_sample_rate to 15600
[  217.200153] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  250.879405] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  304.123460] nouveau 0000:01:00.0: DRM: failed to idle channel 0 [DRM]
[  900.259425] audit: type=1130 audit(1673664878.021:113): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  900.259433] audit: type=1131 audit(1673664878.021:114): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
i’t seems that the free driver nouveau doesn’t work.
please forgive me for being a novice, and what i’m supposed to do that can fix this problem and is there are and way to make my nvidia gpu with no-free driver(nvidia official driver) work well with intel intergrade gpu. i would be appreciate if u could offer me help.
Check this ASUS TUF DASH F15 (2022) - ArchWiki
thank u for reply and i see that it control gpu switching via optimus manager.
what confused me is that what’s the difference between the optimus manager and prime driver(mhwd offered).
do i need to remove the prime driver before/after i installed optimus manager successfully?
probably adding the ibt parameter would help to boot with the nvidia proprietary drivers…
open this file:
sudo nano /etc/default/grub
and inside this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
ibt=off
dont remove anything, just add it to existing parameters, save the file with ctrl+x, press Y, update grub:
sudo update-grub
reboot and see if it helped
thank u very much, i works for me.
and furthermore, is there any method or command which can testify my 3070 are cooperate well with integrated gpu.
for more specific, i wish that i can use the 3070 accelerate the my deep learning training, but for video and movie, i wish use the integrated gpu to save power.
the default mode is hybrid, which means you are running on intel …
you can run specific programs on nvidia with the prime-run command - you can append it directly to the specific program, so that you dont have to type it every time, and you run those programs automatically on nvidia…
sorry, i don’t get it, how to append the prime-run to a specific program?
is the way like
alias python = 'prime-run python'
or some other ways?
besides, after i successfully installed the nvidia proprietary driver, i found that the grub screen cannot be displayed. is there any guide that i can follow to fix it.
you use it for example:
prime-run program_name
if you want to make it permanent, as is mentioned above, right click on the icon application/edit application/application and under program there will be the name of the app or path, so you put the prime-run in front of that - these are instruction for kde, i dont use gnome, so dont know exactly how it works there, but it should be the same…
Grub can’t be displayed or just isn’t displayed by default? Grub is hidden by default on most DE on manjaro and updating your drivers has probably updated grub and it may just be hidden. On cinnamon I press shift while booting to show grub. You can edit grub manually so it isn’t hidden
but before i install the prime driver, ever times that i power my laptop would displayed the grub screen fist,which i can choose to boot the windows or manjaro.
after i install the prime driver, the screen cannot be displayed any more. also i tried to use F2 to get into bios and boot the uefi os(grub), and it also cannot be displayed…
is that my gpu driver cause this reason? and is there are any way to fix it.
oh thank u very much, i checked config file of grub and found that GRUB_TIMEOUT_STYLE=hidden is seted.
No expert but I know if you have installed a kernel or nvidia drivers (which will update the kernel) then grub will be updated. By default in grub os prober is disabled meaning your Windows install isn’t showing. If that’s your issue then you just need to enable is prober again.
Like I said I’m no expert but it sounds like that’s what happened
yes, what u said is make sence for me.
