My laptop takes 2 minutes to shutdown completely. I’d say it powers off right away, but then the monitor backlight stays on for a little less than 2 minutes.
Kernel: 5.9.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0XPYYD v: A00 serial: <filter> UEFI: Dell v: 2.13.0
date: 08/13/2020
RAM: total: 7.64 GiB used: 2.26 GiB (29.6%)
RAM Report:
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake rev: 9 L2 cache: 3072 KiB bogomips: 21607
Speed: 3100 MHz min/max: 400/2601 MHz boost: enabled Core speeds (MHz):
1: 3100 2: 3100 3: 3100 4: 3100
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus ID: 1-5:3 chip ID: 1bcf:28c0
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: i915 note: display driver n/a - try sudo/root
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.0
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.12-1-MANJARO
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040
bus ID: 01:00.0 chip ID: 8086:3165
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8136
Local Storage: total: 931.51 GiB used: 59.90 GiB (6.4%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0A-00SM50
size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> rev: 40WD scheme: GPT
ID-1: / size: 449.95 GiB used: 59.87 GiB (13.3%) fs: ext4 dev: /dev/sda5
label: N/A uuid: 14730961-78c6-b863-a49f-08ca1a93b337
ID-2: /boot/efi size: 99.2 MiB used: 35.1 MiB (35.3%) fs: vfat
dev: /dev/sda3 label: N/A uuid: BBFA-B57B
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda6 label: N/A
uuid: bc8acd18-170e-3e2b-e5db-ea38074cef3e
ID-1: /dev/sda1 size: 128.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-2: /dev/sda2 size: 499.0 MiB fs: ntfs label: Recovery
uuid: E38AFBB3DDC4CE48
ID-3: /dev/sda4 size: 465.12 GiB fs: ntfs label: N/A
uuid: EA92414EAD295C01
ID-4: /dev/sda7 size: 580.0 MiB fs: ntfs label: N/A uuid: 677A6DF7D6B9EE21
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 1bcf:0005
Device-2: 1-5:3 info: Sunplus Innovation Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1bcf:28c0
Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-4: 1-8:5 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2a
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 42.0 C mobo: 40.0 C
Fan Speeds (RPM): cpu: 0
Processes: 215 Uptime: 21m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1229 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.09
I managed to query journalctl to get some info about the last shutdown, but the log is too long. I uploaded it on MEGA:
mega [dot] nz/file/Yp9zVChL#wLIl9krZ5uG4ip981w6jRVICBiJFnauVxA6mG5fDKxg
virustotal [dot] com/gui/url/5c781fcf929dedca62f41fe3a0ff21f9d43c7aeafc6ff15d0007ce51ddaec2c7/detection
