Good day,
Noticed ryzen-smu
has been added to the Extra Repo recently, previously it was only available from the AUR.
Though I could never get the module to load when building it from the AUR.
Tested the package again now it’s in Extra and running into the same issue:
modprobe: FATAL: Module ryzen_smu not found in directory /lib/modules/6.9.5-1-MANJARO
A quick find -name ryzen_smu
did not result into any hits.
Adding ‘Kernel-modules’ and debugging them is not something I have lots experience with if any.
Any help is appreciated
inxi -v7azy
Kernel: 6.9.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f rw plymouth.enable=0
disablehooks=plymouth quiet splash udev.log_priority=3 amd_pstate=passive
amd_pstate.shared_mem=1 amd_prefcore=enable
amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 3.D0 date: 04/01/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 6.69 GiB (21.4%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3600C16-16GVKC serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 553 high: 571 min/max: 550/4822 boost: enabled scaling:
driver: amd-pstate governor: conservative cores: 1: 550 2: 550 3: 550 4: 550
5: 550 6: 550 7: 550 8: 550 9: 550 10: 568 11: 550 12: 568 13: 550 14: 550
15: 550 16: 571 bogomips: 108836
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1, Writeback-1
bus-ID: 28:00.0 chip-ID: 1002:73df class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (radeonsi
navi22 LLVM 17.0.6 DRM 3.57 6.9.5-1-MANJARO) device-ID: 1002:73df
memory: 11.72 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.1.1-manjaro1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.9.5-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager,smbd
Local Storage: total: 5.05 TiB used: 1.4 TiB (27.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Reletech model: M.2 SSD 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM32.1 temp: 25.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Lexar model: SSD NM620 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.23 temp: 36.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 022 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0104 scheme: MBR
ID-1: / raw-size: 857.7 GiB size: 843.16 GiB (98.31%)
used: 406.85 GiB (48.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4A19-EA19
ID-3: /mnt/data raw-size: 858.48 GiB size: 843.93 GiB (98.31%)
used: 222.96 GiB (26.4%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:4
label: DATA uuid: 74423f52-a944-4f61-9500-f4bc683c2cef
ID-4: /mnt/data2 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 309.13 GiB (18.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: DATA2
uuid: 4de3dfe5-98c9-438d-9fef-7bd41d5bf67f
ID-5: /mnt/storage raw-size: 755.73 GiB size: 755.73 GiB (100.00%)
used: 491.17 GiB (65.0%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: STORAGE
uuid: B0A0696BA069394C
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 529 MiB fs: ntfs label: Recovery
uuid: AC98EB3A98EB01A6
ID-2: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: A8EF-469B
ID-3: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb4 maj-min: 8:20 size: 79.88 GiB fs: ntfs label: MAIN_SSD
uuid: 5C828893828872F6
ID-5: /dev/sdb5 maj-min: 8:21 size: 331.05 GiB fs: ntfs label: DATA_GAMES
uuid: FC8038908038537E
ID-6: /dev/sdc2 maj-min: 8:34 size: 175.78 GiB fs: ext4 label: BACKUP
uuid: b2548556-eb55-44c4-bc73-91b7499dee60
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-8:3 info: SONiX USB DEVICE type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 320f:500c class-ID: 0301
Device-2: 1-9:4 info: A4Tech XL-730K / XL-747H XL-750BK XL-755BK Mice
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 09da:9090 class-ID: 0301
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 2-1:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Texas Instruments PCM2902 Audio Codec type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-1:2 info: JMS578 based SATA bridge type: mass storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 8mA chip-ID: 0080:a001 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 28.0 C mobo: 27.0 C gpu: amdgpu temp: 30.0 C
mem: 38.0 C
Fan Speeds (rpm): fan-1: 617 fan-2: 498 fan-3: 0 fan-4: 820 fan-5: 0
fan-6: 0 gpu: amdgpu fan: 0
Processes: 470 Power: uptime: 8h 14m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1667 libs: 485 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.35
