We have been running the current supported editions for a while, so we wanted input from the community to see if we should change it up a bit.
KDE Plasma and XFCE are going to stay.
We have the option to change a couple of editions, so please vote for ones you would like to see as pre-made images. The others will still be available in the Manjaro ARM Installer.
Only Editions deemed stable are mentioned.
On the first point I am interested too …
If minimal is suitable to build into server … then I dont see a need for the redundancy.
In fact … minimal would be my personal desire of base in the groupings … it should ensure all other things are technically possible.
As to the second point (regardless of suggestion) … it would be a bit late for that to not create inaccurate results.
With this in mind I have changed my vote … Minimal and LXQT it is then.
(anyone desiring to operate a server should be able to install minimal and add LAMP)
