I installed manjaro-log-helper…you want them all…
but… either it doesn’t recognize my manjaro partition &/or there is no “OK” to click after choosing the logs to save.
I launched pamac from the terminal & no errors were displayed…I got this …
[manjaro@manjaro-pc ~]$ cat gdm.err.log
Apr 15 09:49:23 manjaro-pc gdm-autologin][726]: gkr-pam: couldn't unlock the login keyring.
Apr 15 10:05:46 manjaro-pc gdm-autologin][724]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:11:05 manjaro-pc gdm-autologin][729]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:18:12 manjaro-pc gdm-autologin][835]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:31:15 manjaro-pc gdm-autologin][727]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:34:31 manjaro-pc gdm-autologin][728]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:42:51 manjaro-pc gdm-autologin][759]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:45:28 manjaro-pc gdm-autologin][824]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:49:21 manjaro-pc gdm-autologin][740]: gkr-pam: couldn't unlock the login keyring.
Apr 15 15:55:08 manjaro-pc gdm-autologin][730]: gkr-pam: couldn't unlock the login keyring.
Apr 15 16:09:10 manjaro-pc gdm-autologin][737]: gkr-pam: couldn't unlock the login keyring.
Apr 15 16:13:05 manjaro-pc gdm-autologin][860]: gkr-pam: couldn't unlock the login keyring.
Apr 15 20:25:40 manjaro-pc gdm-autologin][848]: gkr-pam: couldn't unlock the login keyring.
Apr 17 13:15:38 manjaro-pc gdm-autologin][825]: gkr-pam: couldn't unlock the login keyring.
Apr 17 13:44:54 manjaro-pc gdm-autologin][869]: gkr-pam: couldn't unlock the login keyring.
Apr 17 14:20:48 manjaro-pc gdm-autologin][763]: gkr-pam: couldn't unlock the login keyring.
Apr 17 14:43:20 manjaro-pc gdm-autologin][739]: gkr-pam: couldn't unlock the login keyring.
Apr 18 05:53:15 manjaro-pc gdm-autologin][704]: gkr-pam: couldn't unlock the login keyring.
Apr 19 13:34:06 manjaro-pc gdm-autologin][735]: gkr-pam: couldn't unlock the login keyring.
Apr 23 16:25:35 manjaro-pc gdm-autologin][752]: gkr-pam: couldn't unlock the login keyring.
Apr 23 17:40:09 manjaro-pc gdm-autologin][808]: gkr-pam: couldn't unlock the login keyring.
Apr 23 17:55:57 manjaro-pc gdm-autologin][687]: gkr-pam: couldn't unlock the login keyring.
Apr 27 15:24:41 manjaro-pc gdm-autologin][760]: gkr-pam: couldn't unlock the login keyring.
Apr 27 16:06:40 manjaro-pc gdm-autologin][770]: gkr-pam: couldn't unlock the login keyring.
Apr 27 18:14:36 manjaro-pc gdm-autologin][746]: gkr-pam: couldn't unlock the login keyring.
Apr 27 18:16:45 manjaro-pc gdm-password][2335]: gkr-pam: unable to locate daemon control file
Apr 27 18:49:23 manjaro-pc gdm-autologin][733]: gkr-pam: couldn't unlock the login keyring.
Apr 29 12:54:14 manjaro-pc gdm-autologin][769]: gkr-pam: couldn't unlock the login keyring.
Apr 29 13:37:16 manjaro-pc gdm-autologin][761]: gkr-pam: couldn't unlock the login keyring.
Apr 29 13:46:11 manjaro-pc gdm-autologin][757]: gkr-pam: couldn't unlock the login keyring.
Apr 29 13:56:23 manjaro-pc gdm-autologin][759]: gkr-pam: couldn't unlock the login keyring.
Apr 29 18:53:03 manjaro-pc gdm-autologin][763]: gkr-pam: couldn't unlock the login keyring.
Apr 30 14:51:56 manjaro-pc gdm-autologin][772]: gkr-pam: couldn't unlock the login keyring.
Apr 30 16:22:41 manjaro-pc gdm[639]: GLib: Source ID 85 was not found when attempting to remove it
Apr 30 16:23:07 manjaro-pc gdm[639]: GLib: Source ID 102 was not found when attempting to remove it
Apr 30 16:24:26 manjaro-pc gdm[639]: GLib: Source ID 106 was not found when attempting to remove it
Apr 30 16:30:30 manjaro-pc gdm[639]: GLib: Source ID 110 was not found when attempting to remove it
Apr 30 16:39:04 manjaro-pc gdm[639]: GLib: Source ID 124 was not found when attempting to remove it
Apr 30 16:39:28 manjaro-pc gdm[639]: GLib: Source ID 134 was not found when attempting to remove it
Apr 30 16:39:47 manjaro-pc gdm[639]: GLib: Source ID 138 was not found when attempting to remove it
Apr 30 16:41:11 manjaro-pc gdm-autologin][771]: gkr-pam: couldn't unlock the login keyring.
Apr 30 16:56:09 manjaro-pc gdm[631]: GLib: Source ID 59 was not found when attempting to remove it
May 01 19:13:05 manjaro-pc gdm[631]: GLib: Source ID 62 was not found when attempting to remove it
May 01 19:14:35 manjaro-pc gdm-autologin][774]: gkr-pam: couldn't unlock the login keyring.
May 01 19:32:16 manjaro-pc gdm-password][2738]: gkr-pam: unable to locate daemon control file
May 01 19:43:43 manjaro-pc gdm-autologin][761]: gkr-pam: couldn't unlock the login keyring.
May 01 19:46:48 manjaro-pc gdm-password][2512]: gkr-pam: unable to locate daemon control file
May 02 13:29:15 manjaro-pc gdm-autologin][22955]: gkr-pam: couldn't unlock the login keyring.
May 01 19:42:27 manjaro-pc polkit-agent-helper-1[3864]: pam_unix(polkit-1:auth): conversation failed
May 01 19:42:27 manjaro-pc polkit-agent-helper-1[3864]: pam_unix(polkit-1:auth): auth could not identify password for [manjaro]
That’s because it’s not an issue with Pamac as we already went over.
Nothing related there.
How about:
journalctl -b | grep polkit
[manjaro@manjaro-pc ~]$ journalctl -b | grep polkit
May 01 19:43:27 manjaro-pc polkitd[552]: Started polkitd version 124
May 01 19:43:27 manjaro-pc polkitd[552]: Loading rules from directory /etc/polkit-1/rules.d
May 01 19:43:27 manjaro-pc polkitd[552]: Loading rules from directory /usr/share/polkit-1/rules.d
May 01 19:43:28 manjaro-pc polkitd[552]: Finished loading, compiling and executing 9 rules
May 01 19:43:28 manjaro-pc polkitd[552]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
May 01 19:44:32 manjaro-pc polkitd[552]: Registered Authentication Agent for unix-session:1 (system bus name :1.25 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 01 19:46:24 manjaro-pc polkitd[552]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.25, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 01 19:46:30 manjaro-pc polkitd[552]: Registered Authentication Agent for unix-session:3 (system bus name :1.110 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 01 19:46:58 manjaro-pc polkitd[552]: Registered Authentication Agent for unix-session:5 (system bus name :1.153 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 01 19:47:00 manjaro-pc polkitd[552]: Unregistered Authentication Agent for unix-session:3 (system bus name :1.110, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 01 20:41:19 manjaro-pc polkitd[552]: Operator of unix-session:5 successfully authenticated as unix-user:manjaro to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.226 [/usr/bin/pamac-manager --gapplication-service] (owned by unix-user:manjaro)
May 02 13:06:04 manjaro-pc polkitd[552]: Operator of unix-session:5 successfully authenticated as unix-user:manjaro to gain TEMPORARY authorization for action org.manjaro.pamac.commit for system-bus-name::1.358 [pamac-manager] (owned by unix-user:manjaro)
May 02 13:21:04 manjaro-pc polkitd[552]: Operator of unix-session:5 FAILED to authenticate to gain authorization for action org.manjaro.pamac.commit for system-bus-name::1.370 [pamac-manager] (owned by unix-user:manjaro)
May 02 13:21:45 manjaro-pc polkitd[552]: Operator of unix-session:5 FAILED to authenticate to gain authorization for action org.manjaro.pamac.commit for system-bus-name::1.370 [pamac-manager] (owned by unix-user:manjaro)
May 02 13:29:10 manjaro-pc polkitd[552]: Registered Authentication Agent for unix-process:22831:6398095 (system bus name :1.381 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
May 02 13:29:13 manjaro-pc polkitd[552]: Operator of unix-process:22831:6398095 successfully authenticated as unix-user:manjaro to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.380 [systemctl restart display-manager.service] (owned by unix-user:manjaro)
May 02 13:29:14 manjaro-pc polkitd[552]: Unregistered Authentication Agent for unix-session:5 (system bus name :1.153, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 02 13:29:14 manjaro-pc polkitd[552]: Operator of unix-session:5 FAILED to authenticate to gain authorization for action org.manjaro.pamac.commit for system-bus-name::1.370 [] (owned by unix-user:manjaro)
May 02 13:29:15 manjaro-pc polkitd[552]: Unregistered Authentication Agent for unix-process:22831:6398095 (system bus name :1.381, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 02 13:29:36 manjaro-pc polkitd[552]: Registered Authentication Agent for unix-session:8 (system bus name :1.395 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Enclose all that in a text box, as you did before, so that the output is more readable. I’m sure it will be appreciated.
Out of interest, do you notice any difference if you don’t use autologin? I don’t mean just turn it off and back on; set a normal password login for a day, reboot a few times, and see what difference (if any) that reveals.
And again.
I’ll try it…
We already did…
…and…
Need to use journalctl -p debug for it to be formatted
…and…
- This post from some random Manjaro Team Member.
- One of the links given
- Which would have led you to this.
No charge.
Oh well…
for what it’s worth (I think the more cool acronym is: FWIW).
The issue is NOT dependent on auto-login.
I see the exact same behavior with normal login (no auto login).
It was worth checking.
indeed it was
Well, if you don’t care, then neither do we.
EDIT: Waiting for a properly formatted log.
