Plymouth works in an unexpected way
System info: Intel i5-6300U, Intel HD Graphics 520, Manjaro KDE (X11), LightDM
I’ve followed the Arch Wiki guide to installing Plymouth as well as this video, and it works well with the plymouth --show-splash command, but for some reason the splash is shown during shutdown instead of after booting. In the latter case, an ugly grey screen with three off-center white dots is shown. I can’t for the life of me figure out why.
Here’s the relevant part of /etc/mkinitcpio.conf:
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev plymouth autodetect modconf block keyboard keymap consolefont filesystems fsck"
Here’s the relevant part of /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor splash rd.udev.log_priority=3 vt.global_cursor_default=0"
Here’s my full /etc/plymouth/plymouthd.conf file:
# Set your plymouth configuration here.
[Daemon]
Theme=angular
ShowDelay=0
DeviceTimeout=8
I have enabled the plymouth version of LightDM using systemctl.
I am also not dual booting with any other OS.
Anything I missed? Thanks in advance
You are using Intel GPU.
Edit /etc/mkinitcpio.conf to add i915 in MODULES
Then sudo mkinitcpio -P
Reboot
Thank you so much! That worked.
