Plymouth problems
sudo pacman -U https://mirror.easyname.at/manjaro/pool/overlay/plymouth-24.004.60-12-x86_64.pkg.tar.zst
solves the issue after update and stuck on plymouth with Nvidia 570 drivers.
Replicate:
  • press Alt+F2
  • login as root
  • add command above
  • reboot
Thank you for your post.
inxi -Fza
Summary
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=42079654-61e1-4f8c-b7ab-a9ae07117ff5 rw nvidia_drm.modeset=1
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
  Type: Desktop System: Micro-Star product: MS-7A34 v: 4.0
    serial: <superuser required>
  Mobo: Micro-Star model: B350 GAMING PLUS (MS-7A34) v: 4.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: M.J6 date: 05/17/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K540/K545
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
    level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
    model-id: 8 stepping: 2 microcode: 0x800820D
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1550 min/max: 1550/3400 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550 3: 1550
    4: 1550 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
    bogomips: 81631
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: Gigabyte driver: nvidia
    v: 570.133.07 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
    off: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 26:00.0 chip-ID: 10de:2184
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1108 s-dpi: 80 s-size: 1219x351mm (47.99x13.82")
    s-diag: 1269mm (49.94")
  Monitor-1: DP-3 mapped: DP-5 note: disabled pos: primary,bottom-l
    model: Philips PHL 273V7 serial: <filter> built: 2023 res: mode: 1920x1080
    hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: top-right
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1660 driver: N/A device-ID: 10de:2184
    surfaces: xcb,xlib
  Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
    bus-ID: 26:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 23:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp35s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Realtek Bluetooth 5.3 Radio driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 0bda:a729
  Local Storage: total: 1.01 TiB used: 322.86 GiB (31.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0000
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: K1B3 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: GOODRAM model: SSDPR-CX400-512-G2
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 61.5 scheme: MBR
  ID-1: / raw-size: 446.83 GiB size: 438.75 GiB (98.19%)
    used: 322.86 GiB (73.6%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
    used: 300 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  System Temperatures: cpu: 30.0 C mobo: 35.0 C gpu: nvidia temp: 45 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 474 fan-3: 0 fan-4: 742 fan-5: 0
    fan-6: 763 gpu: nvidia fan: 0%
  Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.30
  Memory: total: 8 GiB available: 7.68 GiB used: 2.33 GiB (30.3%)
  Processes: 312 Power: uptime: 25m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.99 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1952 pm: pacman pkgs: 1943 libs: 486 tools: pamac,yay
    pm: flatpak pkgs: 9 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Your post has been moved to a dedicated topic
Please note that the alternative workaround posted in Known Issues and Solutions doesn’t seem to apply any longer.
See Notable Update Packages in the Stable Update 2025-03-30 announcment:
Plymouth 24.004.60 is a part of this update.
I dare say, the workaround to disable Plymouth might still apply if any users have difficulty with this new version.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
