System becomes unresponsive (hard restart required) after disconnecting the third display via hdmi switch - which I do quite often as the third display doubles as a TV.
Coredump created on this occasion.
Remaining two displays (connected via DVI) normally should refresh and show the reconfigured desktop - but they remain black - and no keyboard input can bring the system back.
Linux/KDE Plasma: Manjaro 21.1.0
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.85.0
Qt Version: 5.12.2
Especially the Whatâs this upstream/downstream business as the answer is: it needs to be fixed in KDE and if it was fixed recently, the next update will incorporate the change.
In that case, read the rest of the N00b guide too! (at least the sections youâre not aware of)
Iâve marked this answer as the solution to your question as it is by far the best answer youâll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldnât have done this or or if you agree)
P.S. In the future, please donât forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
so that the next person that has the exact same problem you just had will benefit from your post as well as your question will now be in the âsolvedâ status.
The best 'Thank you" you can give someone in a thread you started, is to press the Solution button. (Only if that answer actually solved your problem!!!)
The 2nd best 'Thank you" is by pressing the emoji below their post.
The 3rd Best 'Thank you" is by pressing the black emoji and giving them
And last, but not least, itâs writing 'Thank you".
Why???Oh, why, you ask?
Thatâs because the forum software tallies the solutions and and gives these people bragging rights to the other geeks and nerds here on the forum, and eventually unlocks more privileges for themâŚ
