Plasma Wayland Menus wrong position
Hello,
I am using plasma under wayland.
I have in pamac, dolphin, kdenlive and various other applications the problem that the menus, dropdown, right click are not displayed in the correct position.
In Pamac the buttons (Apply) are at the top instead of at the bottom.
I have attached some screenshots to illustrate the problem.
I don’t know if it’s relevant to the problem, but I’m using a two monitor setup.
Greetings Michael
Hm. I also use Plasma wayland session and while I did have that issue at some point, but I haven’t seen it in some months.
Your profile says you use kernel 5.8, so maybe update that (either kernel or profile). :wink:
My profile is outdated, I will update it. I use kernel 5.19.1-3-MANJARO.
After I did today’s update and KDE Plasma is now in version 5.25.5, the problems are unfortunately still there.
I have now found out, if I align my two monitors at the top edge(see screenshot) it fits with the menu and the right click in Dolphin. As soon as I put them back the way they are, the problem is there again. This is a temporary solution but it doesn’t match my actual arrangement of the monitors, so it’s really unattractive.
Can anyone here give me a solution to this problem?
The problem in Pamac with the dropdown list still exists.
Oh, you have multiple monitors!
Seems the issue could be connected to multiple monitor setups with different resolutions maybe. :slight_smile:
yes, it seems so. But under x11 the problem does not exist, so it seems to be Wayland.
Try to disconnect one of both monitors, if the issue persists?
yes, the problem persists. Now it has even occurred again although I have aligned the monitors as described above in the settings, so this does not seem to help after all.
It seems that something is wrong in your KDE environment.
I can not reproduce this issue when using my two same monitors and KDE Plasma Wayland.
  1. Try to create a new profile user
  2. Reboot
  3. Login the new user.
  4. Check if this user has the same issue?
This is a bug in Qt 5 - Qt 6.3 : [QTBUG-85297] Menu location is offset depending on xdg_output.logical_layout in sway - Qt Bug Tracker
In Qt. 6.4 this is finally fixed, but unfortunately it will take ages until all application use this Qt version.
And the devs decided that this is a behaviour change and will most likely not be backported to Qt 6.3 and absolutely not to Qt 5…
The workaround with aligning the two displays on the top edge is the only one that i know and the one that i am also using.
It’s really not a great UX, but you will get used to it quickly.
Why can’t I reproduce this problem?
Can you compare with my versions here:
KDE Plasma Version: 5.25.5
KDE Frameworks Version: 5.97.0
Qt Version: 5.15.5
Kernel Version: 5.19.7-1-MANJARO (64-bit)
Graphics Platform: Wayland
Maybe it is due to the different resolutions. In my case, there are not two identical monitors. One has Full HD and the other WQHD.
Thank you for the answer. I will leave it then also that I align the monitors at the top edge and hope that the developers then update as soon as possible to Qt 6.3. I had said earlier that it didn’t work for me with it either, that was wrong, KDE just hadn’t saved my settings and had reset it back to the original settings.
Check if you installed some dependencies:
pacman -Q xorg-xwayland qt5-wayland plasma-wayland-session kwayland qt5-base qt6-base
$ pacman -Q xorg-xwayland qt5-wayland plasma-wayland-session kwayland qt5-base qt6-base
xorg-xwayland 22.1.3-1
qt5-wayland 5.15.5+kde+r38-3
plasma-wayland-session 5.25.5-1
kwayland 5.97.0-1
qt5-base 5.15.5+kde+r182-1
qt6-base 6.3.1-1
My System:
$ inxi -Fazy
  Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
    root=UUID=d0500f07-9490-44a3-9e12-b5ff7085726f rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: A.H0
    date: 05/19/2022
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3635 high: 3810 min/max: 2200/4426 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3793
    3: 3600 4: 3596 5: 3600 6: 3599 7: 3605 8: 3600 9: 3600 10: 3810 11: 3704
    12: 3660 13: 3600 14: 3600 15: 3600 16: 3599 bogomips: 115245
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1 code: Navi
    process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2f:00.0
    chip-ID: 1002:731f class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 5-1.2.4:8 chip-ID: 046d:082d
    class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
    d-rect: 4480x1440 display-ID: 0
  Monitor-1: DP-1 pos: right res: 2560x1440 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.47
    5.19.7-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
  Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
    driver: snd_hda_intel v: kernel bus-ID: 1-2.3:7 pcie: chip-ID: 0951:16a4
    gen: 1 class-ID: 0300 speed: 2.5 GT/s lanes: 1 serial: <filter>
    bus-ID: 29:00.0 chip-ID: 1102:0012 class-ID: 0403
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38
    class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: Kingston HyperX 7.1 Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-5: DCMT USB Condenser Microphone type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.2.3:7
    chip-ID: 31b2:0011 class-ID: 0300 serial: <filter>
  Device-6: Logitech HD Pro Webcam C920 type: USB
  Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.21 running: no
  Sound Server-4: PulseAudio v: 16.1 running: yes
  Sound Server-5: PipeWire v: 0.3.57 running: yes
    vendor: Micro-Star MSI X570-A PRO driver: r8168 v: 8.050.03-NAPI
    modules: r8169 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    driver: btusb v: 0.8 bus-ID: 3-6.2:4 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 7.5 TiB used: 2.5 TiB (33.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: DB6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
    type: SSD serial: <filter> rev: 4B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000LX001-1RG174
    type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD40EZRZ-00GXCB0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A80 scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: HD103UJ
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: N/A serial: <filter> rev: 1113 scheme: MBR
  ID-1: / raw-size: 500 GiB size: 491.08 GiB (98.22%) used: 132.52 GiB (27.0%)
    fs: ext4 dev: /dev/sdb1 maj-min: 8:17
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.9 MiB
    (27.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 1.95 TiB size: 1.92 TiB (98.38%) used: 1.67 TiB
    (86.7%) fs: ext4 dev: /dev/sdd3 maj-min: 8:51
  System Temperatures: cpu: 39.0 C mobo: 30.0 C gpu: amdgpu temp: 51.0 C
    mem: 56.0 C
  Fan Speeds (RPM): fan-1: 739 fan-2: 1829 fan-3: 668 fan-4: 0 fan-5: 445
    fan-6: 461 fan-7: 0 gpu: amdgpu fan: 0
  Processes: 429 Uptime: 4h 16m wakeups: 0 Memory: 31.27 GiB used: 8.89 GiB
  (28.4%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.2.0 clang: 14.0.6 Packages: 2615 pm: pacman pkgs: 2596 libs: 556
  tools: pamac,yay pm: flatpak pkgs: 19 Shell: fish v: 3.5.1
  running-in: konsole inxi: 3.3.21
Okay, we have the same versions and use AMD devices.
Maybe some desktop effects cause the issue:
KDE menu → Search: Desktop Effects → Try to disable features if it works.
I just tried it and with the new user it is exactly the same. When I align both monitors on the top edge everything is ok, when I align them on the bottom edge(or even centered) the menus are shifted.
You can switch back to Xorg and wait so long for Qt 6.4+ for many KDE applications.
Yes, I could do that, but unfortunately freesync doesn’t work reasonably under x.org, so I’d like to stick with wayland. I will have to live with the workaround then… Thanks a lot!
Does the shifted dropdown list have something to do with the same bug, because it is still shifted, no matter how I arrange the monitors.
I have disabled all effects, but it is exactly the same behavior. I have made a video of it for better understanding.
Video Qt Bug
