Yeah, that’s not really an option if you need fractional scaling for real HiDPI support.
Especially if you consider how few applications have not even upgraded to Qt 6 at all, not to mention Qt 6.4.
I am using an 4K display and a Full HD one which should be aligned a bit more below the 4K screen, but I will just live with the incorrect positioning for now.
I can reproduce this issue when I changed position of one of two display, but it affects Dolphin and some KDE applications, it does not affect other applications.
I’ve been suffering with the horrible menu placement for months. Aligning the tops is just about as bad. Do you guys think if we all post on that ticket that a backport to Qt 5.x is badly needed we can sway anything? Or lost cause?
KDE/plasma is really poor for multi-monitor set-ups on so many fronts, at least coming from cinnamon.
