suddenly I can’t start systemmonitor from the menu. I hear HDD that a process try to start but it does nothing.
I tried to do it via konsole but it does do nothing either.
Just
$ plasma-systemmonitor
no messages, no errors
What happend?
Just
What happend?
Hi,
It works on my side after this update, did you try to reinstall the software ?
[nicolas@nls-pc ~]$ plasma-systemmonitor
QML debugging is enabled. Only use this in a safe environment.
file:///usr/lib/qt/qml/org/kde/ksysguard/page/EditablePage.qml?page=overview.page:15:1: QML EditablePage: Binding loop detected for property "heightForContent"
file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/PageRowGlobalToolBarUI.qml:65:9: QML RowLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "maximumWidth"
org.kde.ksysguard.plugin.network: Helper process terminated abnormally!
org.kde.ksysguard.plugin.network: "The process doesn't have permission to open the capture source\n"
file:///usr/lib/qt/qml/QtQuick/Controls.2/org.kde.desktop/ScrollView.qml:99:27: QML ScrollBar: Binding loop detected for property "visible"
^C
[nicolas@nls-pc ~]$
Probably the program segfaulted. Did you check it’s exit code when starting from command line ?
$ echo $?
To view a list of core dumps use
$ coredumpctl
yes, I reinstalled it but it is still the same (nothing)
I’m not sure what to expect but I can’t find any info.
I do something in wrong way probably.
$ echo $?
0
$ coredumpctl
TIME PID UID GID SIG COREFILE EXE
Mon 2021-04-12 22:48:58 CEST 24504 1000 1001 11 missing /usr/bin/systemsettings5
Mon 2021-04-12 23:08:11 CEST 1678 1000 1001 6 missing /usr/bin/kglobalaccel5
Mon 2021-04-12 23:08:12 CEST 1723 1000 1001 6 missing /usr/bin/kglobalaccel5
Mon 2021-04-12 23:08:15 CEST 1729 1000 1001 6 missing /usr/bin/kglobalaccel5
Mon 2021-04-12 23:08:16 CEST 1735 1000 1001 6 missing /usr/bin/kglobalaccel5
Mon 2021-04-12 23:08:17 CEST 1743 1000 1001 6 missing /usr/bin/kglobalaccel5
Tue 2021-04-13 13:48:47 CEST 113302 1000 1001 11 missing /usr/bin/kdeinit5
Tue 2021-04-13 13:49:38 CEST 113335 1000 1001 11 missing /usr/bin/kdeinit5
Tue 2021-04-13 13:50:41 CEST 113695 1000 1001 11 missing /usr/bin/kdeinit5
Thu 2021-04-15 15:37:00 CEST 5082 1000 1001 11 missing /usr/bin/systemsettings5
Fri 2021-04-16 12:47:01 CEST 9912 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:47:15 CEST 9987 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:47:32 CEST 10076 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:47:44 CEST 10137 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:50:32 CEST 10848 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:51:15 CEST 11028 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:52:09 CEST 11241 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 12:52:45 CEST 8044 1000 1001 5 present /usr/bin/gjs-console
Fri 2021-04-16 12:52:55 CEST 8407 1000 1001 6 present /usr/bin/systemsettings5
Fri 2021-04-16 12:53:17 CEST 11632 1000 1001 6 present /usr/bin/kglobalaccel5
Fri 2021-04-16 12:53:18 CEST 11661 1000 1001 6 present /usr/bin/kglobalaccel5
Fri 2021-04-16 12:53:19 CEST 11678 1000 1001 6 present /usr/bin/kglobalaccel5
Fri 2021-04-16 12:53:20 CEST 11686 1000 1001 6 present /usr/bin/kglobalaccel5
Fri 2021-04-16 12:53:21 CEST 11696 1000 1001 6 present /usr/bin/kglobalaccel5
Fri 2021-04-16 12:59:03 CEST 13035 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 13:01:20 CEST 13242 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 13:01:45 CEST 13261 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 13:31:24 CEST 18737 1000 1001 11 present /usr/bin/luppp
Fri 2021-04-16 14:49:47 CEST 13892 1000 1001 5 present /usr/bin/gjs-console
Fri 2021-04-16 16:04:07 CEST 13221 1000 1001 6 present /usr/bin/systemsettings5
Fri 2021-04-16 16:08:04 CEST 52080 1000 1001 6 present /usr/bin/systemsettings5
Fri 2021-04-16 16:11:57 CEST 52336 1000 1001 6 present /usr/bin/systemsettings5
Fri 2021-04-16 18:03:16 CEST 52549 1000 1001 6 present /usr/bin/systemsettings5
Sun 2021-04-18 18:30:16 CEST 11618 1000 1001 6 present /usr/bin/systemsettings5
That output says plasma-systemmonitor executes and exits normally without any problems.
As there were some people who installed -git versions of kde/plasma packages, please check yours:
$ pacman -Qs '\-git$'
the result is:
local/kconfig-git .r773.gb57c7ad-1 (kf5-git)
Configuration system
local/ki18n-git .r436.gf88e694-1 (kf5-git)
Advanced internationalization framework
local/kirigami2-git .r2625.gd246695d-1 (kf5-git)
A QtQuick based components set
local/krecorder-git r75.gc156ea7-1
Audio recorder for Plasma Mobile and other platforms
I installed kde-manjaro from iso and then updated it us pamac sugested.
What did I wrong and how to correct problems?
Don’t know what went wrong but those few *-git packages don’t match your system and have to be replaced. Try explicitly installing their counterparts and answer “yes” when asked to replace:
$ sudo pacman -S kconfig ki18n kirigami2 krecorder
warning: krecorder-git-r75.gc156ea7-1 is up to date – reinstalling
resolving dependencies…
:: kconfig and kconfig-git are in conflict. Remove kconfig-git? [y/N] y
:: ki18n and ki18n-git are in conflict. Remove ki18n-git? [y/N] y
:: kirigami2 and kirigami2-git are in conflict. Remove kirigami2-git? [y/N] y
:: unable to satisfy dependency ‘ki18n-git’ required by krecorder-git
:: unable to satisfy dependency ‘kconfig-git’ required by krecorder-git
:: unable to satisfy dependency ‘kirigami2-git’ required by krecorder-git
I installed ki18n kconfig and kirigami2 using pamac. This action removed ki18n-git kconfig-git , kirigami2-git and krecorder-git.
pacman -Qs '-git
returns nothing (empty string).
It works after restart. Thank you.
additionally ![]()
You help me to solve my other problem
For some reason, krecorder 0.1 is not in the X64 repos yet. So it only has krecorder-git.
yes, I noticed that it was something wrong. Thank you for note.
I started to use Audio Recorder in Launchpad
I used it when I used Mint.
With this app I can choose source and quality of mp3.
