After reboot, logout, or plugging headphones in and out, the system does not remember the sound that was previously set on any device, including the microphone.
If i set volume to 50%, plug headphones in and out, the sound will reset to 100%. If i set to 50% on headphones, replug them again, it will set to 0%.
What can i do to fix this?
Welcome to Manjaro!
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. - The output of
pacmd listwould be helpful as well.
output of inxi:
Kernel: 5.13.0-pf3 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-pf
root=UUID=c22b350a-7729-4ce0-bf44-50da1637883c rw quiet udev.log_priority=3
mitigations=off
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 7459EH9 v: ThinkPad X200
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 7459EH9 serial: <filter> BIOS: LENOVO
v: 6DET44WW (2.08 ) date: 04/22/2009
ID-1: BAT0 charge: 28.1 Wh (100.0%) condition: 28.1/47.5 Wh (59.1%)
volts: 12.5 min: 10.8 model: SANYO 42T4647 type: Li-ion serial: <filter>
status: Unknown
RAM: total: 7.67 GiB used: 3.34 GiB (43.5%)
Info: Dual Core model: Intel Core2 Duo P8600 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B cache: L2: 3 MiB
bogomips: 9581
Speed: 1049 MHz min/max: 800/2401 MHz boost: enabled Core speeds (MHz):
1: 1049 2: 1502
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht ida
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 sep smx sse sse2 sse4_1 ssse3 syscall tm tm2 tpr_shadow tsc
vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable; SMT disabled
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, STIBP: disabled
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
s-diag: 398mm (15.7")
Monitor-1: LVDS1 res: 1280x800 hz: 60 dpi: 125 size: 260x160mm (10.2x6.3")
diag: 305mm (12")
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG)
v: 2.1 Mesa 21.1.5 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Lenovo ThinkPad T400
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
class-ID: 0403
Sound Server-1: ALSA v: k5.13.0-pf3 running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Device-1: Intel 82567LM Gigabit Network vendor: Lenovo ThinkPad T400
driver: e1000e v: kernel port: 1840 bus-ID: 00:19.0 chip-ID: 8086:10f5
class-ID: 0200
IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel PRO/Wireless 5100 AGN [Shiloh] Network driver: iwlwifi
v: kernel port: 1c60 bus-ID: 03:00.0 chip-ID: 8086:4237 class-ID: 0280
IF: wls1 state: down mac: <filter>
Local Storage: total: 111.79 GiB used: 32.49 GiB (29.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: L5Lite3D120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 6A scheme: MBR
ID-1: / raw-size: 111.79 GiB size: 109.47 GiB (97.93%)
used: 32.49 GiB (29.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: c22b350a-7729-4ce0-bf44-50da1637883c
ID-1: swap-1 type: zram size: 3.83 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 6-2:2 info: KYE Systems (Mouse Systems) NetScroll+ Mini Traveler /
Genius NetScroll 120
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 100mA chip-ID: 0458:003a class-ID: 0301
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 56.0 C mobo: 56.0 C
Fan Speeds (RPM): cpu: 3367
Processes: 200 Uptime: 7h 34m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1213
lib: 375 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
output of pacmd:
Memory blocks currently allocated: 2, size: 75,4 KiB.
Memory blocks allocated during the whole lifetime: 5107033, size: 4,0 GiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 11,5 KiB.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.pci-0000_00_1b.0.analog-stereo
Default source name: alsa_input.pci-0000_00_1b.0.analog-stereo
Memory blocks of type POOL: 2 allocated/2549623 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/628 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/1779335 accumulated.
Memory blocks of type IMPORTED: 0 allocated/778075 accumulated.
24 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "14.2"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="0" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 7
argument: <channels=2>
used: -1
load once: yes
properties:
module.description = "Adds JACK sink/source ports when JACK is started"
index: 8
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 9
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 12
argument: <>
used: -1
load once: yes
properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 14
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 15
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 21
argument: <display=:0 xauthority=/home/wtl/.Xauthority>
used: -1
load once: no
properties:
module.description = "X11 credential publisher"
index: 22
argument: <display=:0 xauthority=/home/wtl/.Xauthority session_manager=local/x200:@/tmp/.ICE-unix/844,unix/x200:/tmp/.ICE-unix/844>
used: -1
load once: no
properties:
module.description = "X11 session management"
index: 23
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 49152 / 75% / -7,50 dB, front-right: 49152 / 75% / -7,50 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
card: 0 <alsa_card.pci-0000_00_1b.0>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "CX20561 Analog"
alsa.id = "CX20561 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA Intel"
alsa.long_card_name = "HDA Intel at 0xf2620000 irq 31"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "293e"
device.product.name = "82801I (ICH9 Family) HD Audio Controller (ThinkPad T400)"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
active port: <analog-output-headphones>
2 source(s) available.
index: 0
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 0
module: 6
properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
* index: 1
flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 19661 / 30% / -31,37 dB, front-right: 19661 / 30% / -31,37 dB
balance 0,00
base volume: 8250 / 13% / -54,00 dB
volume steps: 65537
muted: no
max rewind: 0 KiB
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 1837,50 ms
module: 6
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-dock-mic: Dock Microphone (priority 7800, latency offset 0 usec, available: no)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
active port: <analog-input-internal-mic>
7 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 16
properties:
application.name = "Login Session 2"
systemd-login.session = "2"
index: 3
driver: <module-x11-xsmp.c>
owner module: 22
properties:
application.name = "XSMP Session on KDE as 1078323030000162826163400000008440008"
xsmp.vendor = "KDE"
xsmp.client.id = "1078323030000162826163400000008440008"
index: 4
driver: <protocol-native.c>
owner module: 9
properties:
application.name = "Plasma PA"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "34"
application.id = "org.kde.plasma-pa"
application.icon_name = "audio-card"
application.process.id = "878"
application.process.user = "wtl"
application.process.host = "x200"
application.process.binary = "plasmashell"
application.language = "en_US.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "a8a051a34bcc42a8b36421532aadc25d"
application.process.session_id = "2"
index: 8
owner module: 9
properties:
application.name = "libcanberra"
application.version = "0.30"
application.id = "org.freedesktop.libcanberra"
index: 9
owner module: 9
properties:
application.name = "Chromium input"
application.process.id = "1854"
application.process.binary = "chromium"
application.icon_name = "chromium"
index: 12
owner module: 9
properties:
application.name = "KDE Power Management System"
application.icon_name = ""
application.id = "org.kde.org_kde_powerdevil"
application.process.id = "880"
application.process.binary = "org_kde_powerdevil"
index: 196
driver: <cli.c>
owner module: 23
properties:
application.name = "UNIX socket client"
1 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: no)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Built-in Audio Analog Stereo
ports:
properties:
properties:
properties:
properties:
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
0 sink input(s) available.
0 source output(s) available.
1 cache entrie(s) available.
index: 0
Stereo
length: 11776
duration: 0,1 s
volume: n/a
balance 0,00
lazy: no
filename: <n/a>
properties:
media.role = "event"
event.id = "audio-volume-change"
event.description = "Volume Control Feedback Sound"
media.name = "audio-volume-change"
media.filename = "/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga"
It seems that i have pipewire installed in addition to pulseaudio, but i don’t remember installing it, perhaps it comes from a new update? maybe pipewire broke everything?
You have the same kind of config as me and on my system this work, except for:
so please install both 5.4 and 5.10 LTS (Long Time Support) and see which one of the two troubles you least?
No, the same problem persists, i don’t think it’s a problem with kernel to begin with, probably something with pipewire.
Please execute:
alsa-info.sh
answer Y to upload to the ALSA project web page and provide the link they’re giving you back here…
alsa-project dot org/db/?f=4fbebbeca661f1217866457c3f11ced13daa49e0
@nikgnomic Can you have a look here, please? (I’m out of my leageue again)
ALSA audio settings show the Headphone output set to 100% and unmuted, but Speakers set to 0% and muted
Simple mixer control 'Headphone',0 Front Left: Playback 74 [100%] [0.00dB] [on] Front Right: Playback 74 [100%] [0.00dB] [on] Simple mixer control 'Speaker',0 Front Left: Playback 0 [0%] [-99999.99dB] [off] Front Right: Playback 0 [0%] [-99999.99dB] [off]
It would be typical to see the Speaker muted when Headphones are plugged in, and speakers should unmute and change volume if headphone jack is unplugged
But not when ALSA Auto-Mute function to control this has been disabled
Simple mixer control 'Auto-Mute Mode',0 Item0: 'Disabled'
I suggest you use this command to unmute the Speakers and set level to 75%
amixer -c0 sset Speaker 75% unmute
and this to turn on the auto-mute
amixer -c0 sset 'Auto-Mute Mode' Enabled
and finally this to save the correct settings for ALSA
sudo alsactl store
You can check ALSA settings are still correct when system is rebooted with the terminal mixer
alsamixer -c0
but if you need to post text-data here use this command
amixer -c0
