Has anyone noticed when the applications launcher broke? Perhaps with the last array of qt6 updates?
On mine the launcher is working with no issues.Before upgrading to plasma 6 I did reset themes and icons back to the defaults which was breeze.You might try and check to make sure everything upgraded and works on plasma 6.
Also cannot reproduce with either the ‘simple application launcher’ or the default.
(moving to own thread)
A reboot…
Ah, well, I have nothing to add…
Cheers.
Yeah, better to reboot first and if not fixed yet, then to try Arch wiki: Clean cache to resolve KDE upgrade problems and to reboot once more.
