After recent update providing Plasma-6 different apps fail or stop working.
Crashes that been noted and constantly appear so far:
System monitor shuts down when clicking on any item in Application section.
plasmashell shows crash window (Crash handler window with prompt to report) when resuming from suspend
Screen-locking : after a minute or so on screen-locking the display image gets frozen and fan gets constantly noisy (intensive work) until I switch to TTY-1, then get back to TTY-2 and unlock the screen. In htop
I could notice for a moment that most CPU consumption jumped between plasmashell
or kwin_x11
. That happens every time (since that recent update).
Spectacle does not work:
17.05.24 16:31 spectacle Screenshot request failed: “The process is not authorized to take a screenshot”
17.05.24 16:31 plasmashell kpipewire_logging: error: “Failed to connect to PipeWire” 0
17.05.24 16:31 plasmashell received error while creating the stream “Failed to connect to PipeWire” Media monitor will not work.
$ inxi -b
Host: roman-pc Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.4 Distro: Manjaro Linux
Type: Laptop System: Dell product: G3 3779 v: N/A
serial:
Mobo: Dell model: 04R93M v: A00 serial: UEFI: Dell
v: 1.2.1 date: 07/18/2018
ID-1: BAT0 charge: 3.8 Wh (100.0%) condition: 3.8/56.0 Wh (6.9%)
Info: 6-core Intel Core i7-8750H [MT MCP] speed (MHz): avg: 800
min/max: 800/4100
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: nvidia v: 550.78
Device-3: Realtek Integrated Webcam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting dri: iris gpu: i915 resolution: 1920x1080~60Hz
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi
driver: r8169
Local Storage: total: 2.05 TiB used: 490.52 GiB (23.3%)
Memory: total: 16 GiB available: 15.48 GiB used: 4.3 GiB (27.8%)
Processes: 322 Uptime: 16m Shell: Bash inxi: 3.3.34
I had the same problem with system monitor and I fixed it by deleting the “~/.config/systemmonitorrc” file.
Maybe the rest of your problems will be solved if you delete the appropriate configuration files.
can you boot with another kernel ?
version 6.8 or 6.6 LTS or 6.1 LTS , maybe 5.15 LTS
I’ve been on 6.6 LTS and had the same.
That one I have experienced my self.
I think I removed spectaclerc from .config
As general rule for this major change - we all had to do so - remove all plasma related configuration from - best done when looged out and switching to a TTY
finally remove .cache
Unfortunately didn’t solve it for me. After update to Plasma 6 I have the same issue as @RomanPerekhrest
Try removing the .page
files from ~/.local/share/plasma-systemmonitor/
This worked for me. I kept only the files for the custom pages that I’ve created.
Seeing something similar in another thread was related to the use of the deprecated pipewire-media-session
Which we might have seen also if a decent inxi was used;
inxi -Farz
$ inxi -Farz
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=a3d17ce4-9aaf-437d-a73a-439edc842272 rw acpi_rev_override=1
pcie_port_pm=off resume=UUID=1a692f9b-337c-4cfa-81e9-a514be6aa511
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Mobo: Dell model: 04R93M v: A00 serial: <superuser required> part-nu: 0886
uuid: <superuser required> UEFI: Dell v: 1.2.1 date: 07/18/2018
ID-1: BAT0 charge: 3.8 Wh (100.0%) condition: 3.8/56.0 Wh (6.9%) volts: 17.5
min: 15.2 model: Samsung SDI DELL W7NKD87 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1808 high: 1901 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1901 2: 1900 3: 1901
4: 1900 5: 800 6: 1901 7: 1900 8: 1900 9: 1900 10: 1901 11: 1900 12: 1899
bogomips: 52815
vulnerable
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Dell
driver: nvidia v: 550.78 non-free: 545.xx+ status: current (as of 2024-04;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c20 class-ID: 0302
Device-3: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:568a
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting dri: iris gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x046e built: 2014 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.8-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e9b memory: 15.12 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 with Max-Q Design driver: nvidia v: 550.78
device-ID: 10de:1c20 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
v: 24.0.8-manjaro1.1 device-ID: 8086:3e9b surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: off with: 1: wireplumber status: off
2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active tools: pacat,pactl,pavucontrol
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlan0 state: down mac: <filter>
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 3b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd
Local Storage: total: 2.05 TiB used: 464.29 GiB (22.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM2 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
ID-1: / raw-size: 44.94 GiB size: 44.06 GiB (98.04%) used: 33.21 GiB (75.4%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 292 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 176.16 GiB size: 172.33 GiB (97.83%)
used: 30.7 GiB (17.8%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19
ID-4: /var raw-size: 93.14 GiB size: 91.11 GiB (97.83%)
used: 19.31 GiB (21.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: partition size: 17.08 GiB used: 768 KiB (0.0%)
priority: -2 dev: /dev/sdb4 maj-min: 8:20
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Packages: 2180 pm: pacman pkgs: 2173 libs: 493
tools: octopi,pamac,yaourt,yay pm: flatpak pkgs: 7
1: https://mirrors2.manjaro.org/stable/$repo/$arch
Memory: total: 16 GiB available: 15.48 GiB used: 4.7 GiB (30.3%)
Processes: 328 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
RomanPerekhrest:
This seems to show you have pipewire but its disabled?
Is this intentional?
To install the metapackage you could do
sudo pacman -Syu manjaro-pipewire
Which should install and enable pipewire services etc.
I’m on pulseaudio
. Don’t pulseaudio
and pipewire
exclude each other?
Yous should consider updating system BIOS
https://www.dell.com/support/home/en-uk/product-support/product/g-series-15-3579-laptop/drivers
System data is showing 2 incompatible sound servers running
Sound Server-4: PipeWire v: 0.3.40 running: yes
PipeWire cannot support audio unless PulseAudio is removed and replaced, but it can impede PulseAudio functions.
Install metapackage manjaro-pipewire to remove and replace PulseAudio packages
To …
rm -rf ~/.local/share/plasma* && rm -rf ~/.config/plasma*
pipewire
does not conflict with any PulseAudio packages
pipewire-pulse
conflicts with pulseaudio
and pulseaudio-bluetooth
pipewire-alsa
conflicts with pulseaudio-alsa
I suggest check pipewire.socket and pipewire.service
systemctl --user -l status pipewire.socket pipewire.service
kpipewire
might be failing to connect to PipeWire If the service is not running
but I don’t use KDE or PipeWire
That was one the worst resets: I’ve lost all my settings and sessions in different apps … and spectacle still does not work.
cscs
3 June 2024 11:19
15
Can you remove the spectacle cache?
rm -r ~/.cache/spectacle
And maybe also the spectaclerc file?
rm ~/.config/spectaclerc
(neither of these would have been included in the above script)
@cscs –
Tried just now. Same window with error.
cscs
3 June 2024 11:28
18
Do you happen to have a spectacle launcher in ~/.local/share/applications
I got ~/.local/share/applications/org.kde.spectacle.desktop
there.
cscs
3 June 2024 11:33
20
I dont know why.
We could investigate blah blah … but I say remove it or back it up by moving it somewhere else.
(the current/correct file should be provided at /usr/share/applications/org.kde.spectacle.desktop
How does spectacle run then?
Yes, it’s working now. Why it happened to be placed in ~/.local/share/applications/
