(Plasma 5.25.5)when i click add widgets on desktop everything freezing
I just installed Nobara with is a Fedora based Distro, updated to Plasma 5.25.5, rebooted, rightclicked the desktop and added my widgets without any issue.
I am having the same problem, I hope someone finds a fix soon.
when running plasma shell from konsole after running killall plasmashell i get the following error:
" Could not find the Plasmoid for Plasma::FrameSvgItem(0x556238cd9
340) QQmlContext(0x5562373ef8e0) QUrl(“file:///usr/share/plasma/plasmoids/org.
kde.plasma.private.systemtray/contents/ui/main.qml”)
Could not find the Plasmoid for Plasma::FrameSvgItem(0x556238cd9340) QQmlConte
xt(0x5562373ef8e0) QUrl(“file:///usr/share/plasma/plasmoids/org.kde.plasma.pri
file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML
Heading: Binding loop detected for property “verticalAlignment”"
this widget issue happens only when you are using global menu, disable it and it should work normally - check the link in the link above …
And yet another reason to never use Global Menu.
